error while fastboot for android OS in imx8m mini
1,725件の閲覧回数
Ruban1
Error not able to run the command
sudo ./fastboot_imx_flashall.sh -f imx8mm -a -e -u trusty -D /imx_android-11.0/evk_8mm/~/Desktop/after_building_imx8m_mini/android_build/out/target/product/evk_8mm/
flash the file of partition-table.img to the partition of gpt
./fastboot_imx_flashall.sh: line 140: fastboot: command not found
i have attached the shell file and i have build successfully and have all .img file in tat path
1,721件の閲覧回数
Zhiming_Liu
Try uuu_imx_flashall.sh,if you still want to use fastboot, you need make fastboot in aosp first.
