error when porting android on imx6 sabrelite reg.
pratikpawar
HI,
          I am trying to port android on imx6 sabrelite by following Android_user_Guide.pdf  i followed the steps mentioned in the document and facing with errors
$ cd ~/myandroid
$ source build/envsetup.sh
$ lunch sabresd_6dq-user
$ make
errors :
  OBJCOPY arch/arm/boot/zImage
  Kernel: arch/arm/boot/zImage is ready
  UIMAGE  arch/arm/boot/uImage
Image Name:   Linux-3.0.35-06114-g3b96084
Created:      Sat Dec 14 11:42:14 2013
Image Type:   ARM Linux Kernel Image (uncompressed)
Data Size:    4709256 Bytes = 4598.88 kB = 4.49 MB
Load Address: 10008000
Entry Point:  10008000
  Image arch/arm/boot/uImage is ready
make[1]: Leaving directory `/home/sasidhar/competency_imx/android/myandroid/kernel_imx'
install -D kernel_imx/arch/arm/boot/uImage  out/target/product/sabresd_6dq/uImage
install -D kernel_imx/arch/arm/boot/zImage  out/target/product/sabresd_6dq/kernel
host Executable: mkfs.ubifs (out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/mkfs.ubifs)
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libz.so when searching for -lz
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libz.a when searching for -lz
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/liblzo2.so when searching for -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/liblzo2.a when searching for -llzo2
/usr/bin/ld: cannot find -llzo2
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libuuid.so when searching for -luuid
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libuuid.a when searching for -luuid
/usr/bin/ld: cannot find -luuid
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libm.so when searching for -lm
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libm.a when searching for -lm
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libc.so when searching for -lc
/usr/bin/ld: skipping incompatible /usr/lib/x86_64-linux-gnu/libc.a when searching for -lc
collect2: error: ld returned 1 exit status
make: *** [out/host/linux-x86/obj/EXECUTABLES/mkfs.ubifs_intermediates/mkfs.ubifs] Error 1
Please help me to fix these errors.
Thanks & Regards,
Pratik
Labels (2)
Rita_Wang
Hi Pratik,
You need to install these packages needed for building android as follows:
$sudo apt-get install uuid uuid-dev
$sudo apt-get install zlib1g-dev liblz-dev
$sudo apt-get install liblzo2-2 liblzo2-dev
You can have a try. Hope this can help you~~
Best Regards
Dan
Rita_Wang
Hi Pratik,
Best Regards
Dan
pratikpawar
Hi Dan,
                 Thanks for your suggestions, now its working fine.
Thanks & Regards,
RBT
dreamfly999
Hi Pratik,
I meet the same problem with you. Have you solved by run these commends as Dan post ?
I have tried ,but .......
Could you please share your methods? Thanks a lot.
pratikpawar
Hi Dream,
You can follow the thread https://community.freescale.com/thread/303536
To fix the error, you should install 32 bits lzo2 and luuid to your 64 bits ubuntu.
I installed liblzo2-2_2.05-1_i386.deb ,liblzo2-dev_2.05-1_i386.deb and uuid-dev_2.20.1-1ubuntu3_i386.deb
To install liblzo2
    $ sudo mkdir /usr/lib/liblzo2_i386
    $ sudo dpkg -x liblzo2-dev_2.05-1_i386.deb /usr/lib/liblzo2_i386/
    $ sudo dpkg -x liblzo2-2_2.05-1_i386.deb /usr/lib/liblzo2_i386/
    $ cd /usr/lib/
    $ sudo rm liblzo2.a
    $ sudo rm liblzo2.so
    $ sudo rm liblzo2.so.2
    $ sudo ln -s liblzo2_i386/usr/lib/liblzo2.a liblzo2.a
    $ sudo ln -s liblzo2_i386/usr/lib/liblzo2.so.2.0.0 liblzo2.so
    $ sudo ln -s liblzo2_i386/usr/lib/liblzo2.so.2.0.0 liblzo2.so.2
To install uuid-dev
$ sudo mkdir /usr/lib/uuid-dev
$ sudo dpkg -x uuid-dev_2.20.1-1ubuntu3_i386.deb  /usr/lib/uuid-dev/
$ cd /usr/lib/
$ sudo ln -s uuid-dev/usr/lib/i386-linux-gnu/libuuid.a  libuuid.a
$ sudo ln -s uuid-dev/usr/lib/i386-linux-gnu/libuuid.so  libuuid.so
modify the  external/mtd-utils/mkfs.ubifs/Android.mk.This fixed the "-llzo2 not found; uuid/uuid.h not found;".
$ vi external/mtd-utils/mkfs.ubifs/Android.mk
Remove this flag
LOCAL_LDFLAGS +=-L /usr/lib/x86_64-linux-gnu/
Add the following Flags
LOCAL_C_INCLUDES +=/usr/lib/uuid-dev/usr/include/
LOCAL_C_INCLUDES +=/usr/lib/liblzo2_i386/usr/include
Thanks & Regards,
Pratik.
dreamfly999
Hi Pratik,
I have build success according to your method. Thanks for sharing :smileyhappy:.
Best Regards
Rita_Wang
Hi Dream,
You can also  install 32 bits lzo2 and luuid to your 64 bits ubuntu by commends as follows:
sudo apt-get install liblzo2-dev:i386
sudo apt-get install uuid-dev:i386
Dan
dreamfly999
Hi Pratik,
Thanks a lot~~
I will try~~
Best Regards & Merry Christmas
Rita_Wang
Hi Pratik,
It's my plessure~~
Since you have solved the problem, I close this DI. If any questions contact  us~~
Best Regards
Dan
Rita_Wang
Hi Pratik,
What version of Ubuntu and Android are you using?
Best Regards
Dan
Raybiztech
Contributor V
Can you mention which Version on Android source you are using and what is your source..
