eMMC DDR mode
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Dear all,
i am actually using a eMMC powered 3.3V as normal MMC 8 bit mode.
I have seen imx6q supports eMMC DDR mode. So i enabled (set resitors approriate),
but have no more working boot (u-boot and Linux not executed, empty tty output).
Is it enough to set the jumper on board for DDR (changed EIM_DA15 to 1),
or there is something else to setup ?
angelo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi angelo
for emmc DDR boot one also needs to set BOOT_CFG2[2](DLL override),
with MMC_DLL_DLY[6:0] values found experimentally.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Igor,
ok, DDR mode works. I finally see it active at u-boot loading and linux image loading.
I confirm your suggested settings:
BOOT_CFG2[5:7]
BOOT_CFG2[2](DLL override), with MMC_DLL_DLY[6:0] to be set experimentally.
Thanks for the great support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Igor,
many thanks, trying, then will report here.
How should i set MMC_DLL_DLY[6:0] since they should be read from the ROM bootloader prior to load u-boot from eMMC ?
Do you know if there can be any limitation using 3.3 voltage for the eMMC with DDR mode ?
Best Regards
Angelo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Angelo
MMC_DLL_DLY[6:0] values are found experimentally,
no imitation for using 3.3 voltage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Igor,
still thanks for support.
I have DDR mode enabled, (DDR and DLL override boot_cfg bits set, so i suppose to be into DDR mode). I can boot now, MMC_DLL_DLY[6:0] are now left uset, emmc is very near to cpu and tracks quite similar, so i am expecting no delay are needed.
BTW, at 50 Mhz data transfert i don't see any evidence of DDR bit shapes. Seems i am still in SDR.
Every hint is appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Angelo
yes, waveforms are the same, check
sect.4.11.4.2 eMMC4.4/4.41 (Dual Data Rate) eSDHCv3 AC Timing IMX6DQCEC
~igor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Igor,
thanks,
what i mean is that i was expecting to see 2 data bits for a single clock cycle, as per DDR. Of course depend from the data pattern i look, anyway, i check better, but don't seems to see the data bits changing on each clock edge, as i am expecting.
I am using u-boot, is it possible i have to reconfigure usdhc4 controller for DDR mode from u-boot (i am assuming HW boot_cfg settings are enough) ?
