drive strength
drive strength
3,071 次查看
geethar
How to change the drive strength of mobile DDR?
5 回复数
2,803 次查看
geethar
How can i access the mobile DDR mode register and extended mode register address?
How to set mode register in DDR?
2,803 次查看
geethar
part number for my micron mobile ddr is MT46H32M16LFBF-6 IT:C
2,803 次查看
Yuri
  According to the MT46H32M16LFBF  Datasheet, Extended Mode Register (EMR)
controls in particular drive strength. The EMR is programmed via the LOAD MODE REGISTER
command with BA0 = 0 and BA1 = 1. EMR bits 5,6,7 define memory drive strength.
< http://www.micron.com/~/media/Documents/Products/Data%20Sheet/DRAM/Mobile%20DRAM/Low-Power%20DRAM/LP... >
IMX23 provides EMR writing via setting bit field HW_DRAM_CTL38 [EMRS1_DATA] and
setting HW_DRAM_CTL09 [ WRITE_MODEREG ].
Yuri
2,803 次查看
Yuri
What is modile DDR (part number, Datasheet) ?
2,803 次查看
Yuri
   Please use DDR Mode registers (Extended Mode Register) to configure DDR
Output Drive Strength during DDR initialization.
Yuri
