does any tool like mfgtools can run on linux host
已解决
跳至解决方案
4,070 次查看
caibai
hi,i just install linux OS on my computer and lazy to install windows,does any tool can down load image to my i.MX6UL board on linux?
1 解答
3,809 次查看
Rita_Wang
In our website only the mfgtool supplied for downlaodiing the images to the board. So sorry. So you need to copy your images to windows then download images to your board and then boot. Or you can only download the uboot image to your board and then boot up kernel and rootfs from NFS, hope this can help you.
Rita
在原帖中查看解决方案
5 回复数
3,809 次查看
andrewdyer
https://community.nxp.com/docs/DOC-94117
might help you.  It doesn't have all the stuff that mfgtool does.  It pretty much executes DCD files to set up registers and loads binaries, no gui, no xml config files (yay!).
3,809 次查看
caibai
that is what i want,thank you very much.
3,810 次查看
Rita_Wang
Rita
3,809 次查看
caibai
OK,thank you for reply。
3,809 次查看
Rita_Wang
It's my pleasure. If you have new questions you can create new threads in our community.
Have a nice day
Rita
