does IMX8MP evaluation board have a RTC ?
francesco_giust
Hi all,
I have an NXP evaluation board for i.MX8M plus processor, and at every reboot I have to set again time and date.
There is a way to keep date and time with RTC or maybe there is other solution... it is quite annoying.
Francesco Giusti
Rita_Wang
Are you using NXP evk board? Which version BSP are you running on your board?
francesco_giust
yes, I am using your NXP evaluation board.
I did some other tests with LF_v6.6.3-1.0.0_images_IMX8MPEVK, and I see that hwclock mantains time & date only if I don't turn off PWR switch.
I suppose that there is a built-in RTC, but it is without battery. Is it right?
If it is, there is a way to connect a battery ?
Francesco
