different loading speed of same apk on imx6dl and imx6q
2,353 次查看
conteczxy
I am working on
imx6dl with android 4.2.2 (I applied patch JB4.2.2_1.1-upgrade-gpu-p12), and
imx6q with android 4.4.2(apply no patch, because in i.MX_6Dual6Quad_SABRE-SD_Linux_Release_Notes.pdf, it is said, Upgrade GPU to 4.6.9 p12 version)
Now, I install the same apk, which is used for drawing lines with egl and opengl,
on imx6dl, it starts very  quickly, about 2 seconds at most, but
on imx6q, it starts very slowly, about 7 seconds.
and I looked into the logs, they are different in loading libEGL_VIVANTE.so, libGLESv1_CM_VIVANTE.so, libGLESv2_VIVANTE.so.
The logs are as below,
On imx6dl with android 4.2.2
08-01 14:30:49.200: I/ActivityManager(2637): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.contec.healthexamination/com.qihoo.util.StartActivity} from pid 2831
08-01 14:30:49.210: W/audio_hw_primary(2318): card 1, port 0 device 0x400
08-01 14:30:49.210: W/audio_hw_primary(2318): rate 44100, channel 2 period_size 0x300
08-01 14:30:49.290: D/dalvikvm(2637): GC_FOR_ALLOC freed 187K, 19% free 4693K/5780K, paused 36ms, total 36ms
08-01 14:30:49.330: I/ActivityManager(2637): Start proc com.contec.healthexamination for activity com.contec.healthexamination/com.qihoo.util.StartActivity: pid=3159 uid=10023 gids={50023, 3002, 3001, 3003, 1015, 1028}
08-01 14:30:49.350: D/dalvikvm(3159): Debugger has detached; object registry had 1 entries
08-01 14:30:49.380: D/dalvikvm(3159): DexOpt: couldn't find static field Landroid/os/Build;.SUPPORTED_32_BIT_ABIS
08-01 14:30:49.380: W/dalvikvm(3159): VFY: unable to resolve static field 3 (SUPPORTED_32_BIT_ABIS) in Landroid/os/Build;
08-01 14:30:49.380: D/dalvikvm(3159): VFY: replacing opcode 0x62 at 0x0002
08-01 14:30:49.440: D/dalvikvm(3159): Trying to load lib /data/data/com.contec.healthexamination/files/libjiagu.so 0x40e51aa0
08-01 14:30:49.450: D/dalvikvm(3159): Added shared lib /data/data/com.contec.healthexamination/files/libjiagu.so 0x40e51aa0
08-01 14:30:49.910: E/dalvikvm(3159): ERROR: couldn't find native method
08-01 14:30:49.910: E/dalvikvm(3159): Requested: Lcom/qihoo/util/StubApp4041099101;.interface7:(Landroid/app/Application;Landroid/content/Context;)Z
08-01 14:30:49.910: W/asset(3159): Asset path /data/data/com.contec.healthexamination/files/libjiagu_x64.a is neither a directory nor file (type=1).
08-01 14:30:49.920: I/ActivityManager(2637): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 cmp=com.contec.healthexamination/.activity.LoginActivity bnds=[228,118][324,214]} from pid 3159
08-01 14:30:50.030: D/dalvikvm(3159): GC_FOR_ALLOC freed 153K, 11% free 2510K/2792K, paused 17ms, total 17ms
08-01 14:30:50.040: I/dalvikvm-heap(3159): Grow heap (frag case) to 10.485MB for 8294416-byte allocation
08-01 14:30:50.060: D/dalvikvm(3159): GC_FOR_ALLOC freed <1K, 3% free 10610K/10896K, paused 15ms, total 15ms
08-01 14:30:50.080: D/dalvikvm(3159): GC_CONCURRENT freed 1K, 3% free 10609K/10896K, paused 3ms+3ms, total 20ms
08-01 14:30:50.570: D/dalvikvm(3159): GC_FOR_ALLOC freed 8344K, 64% free 4867K/13428K, paused 15ms, total 15ms
08-01 14:30:50.580: E/LoginActivity(3159): onCreateView
08-01 14:30:50.590: W/System.err(3159): java.io.FileNotFoundException: /storage/emulated/0/PHMS/PhmsConfig.ini: open failed: ENOENT (No such file or directory)
08-01 14:30:50.590: W/System.err(3159): at libcore.io.IoBridge.open(IoBridge.java:416)
08-01 14:30:50.590: W/System.err(3159): at java.io.FileOutputStream.<init>(FileOutputStream.java:88)
08-01 14:30:50.590: W/System.err(3159): at java.io.FileOutputStream.<init>(FileOutputStream.java:73)
08-01 14:30:50.590: W/System.err(3159): at com.contec.healthexamination.util.FileHelper.copyAssetFileToPath(FileHelper.java:227)
08-01 14:30:50.590: W/System.err(3159): at com.contec.healthexamination.activity.LoginActivity.onCreateView(LoginActivity.java:107)
08-01 14:30:50.590: W/System.err(3159): at com.contec.healthexamination.activity.BaseActivity.onCreate(BaseActivity.java:51)
08-01 14:30:50.590: W/System.err(3159): at android.app.Activity.performCreate(Activity.java:5104)
08-01 14:30:50.590: W/System.err(3159): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1080)
08-01 14:30:50.590: W/System.err(3159): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2144)
08-01 14:30:50.590: W/System.err(3159): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2230)
08-01 14:30:50.590: W/System.err(3159): at android.app.ActivityThread.access$600(ActivityThread.java:141)
08-01 14:30:50.590: W/System.err(3159): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1234)
08-01 14:30:50.590: W/System.err(3159): at android.os.Handler.dispatchMessage(Handler.java:99)
08-01 14:30:50.590: W/System.err(3159): at android.os.Looper.loop(Looper.java:137)
08-01 14:30:50.590: W/System.err(3159): at android.app.ActivityThread.main(ActivityThread.java:5042)
08-01 14:30:50.590: W/System.err(3159): at java.lang.reflect.Method.invokeNative(Native Method)
08-01 14:30:50.590: W/System.err(3159): at java.lang.reflect.Method.invoke(Method.java:511)
08-01 14:30:50.590: W/System.err(3159): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:793)
08-01 14:30:50.590: W/System.err(3159): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:560)
08-01 14:30:50.590: W/System.err(3159): at dalvik.system.NativeStart.main(Native Method)
08-01 14:30:50.590: W/System.err(3159): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory)
08-01 14:30:50.590: W/System.err(3159): at libcore.io.Posix.open(Native Method)
08-01 14:30:50.590: W/System.err(3159): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110)
08-01 14:30:50.600: W/System.err(3159): at libcore.io.IoBridge.open(IoBridge.java:400)
08-01 14:30:50.600: W/System.err(3159): ... 19 more
08-01 14:30:50.600: D/dalvikvm(3159): Trying to load lib /data/app-lib/com.contec.healthexamination-1/libHealth.so 0x40e51aa0
08-01 14:30:50.610: D/dalvikvm(3159): Added shared lib /data/app-lib/com.contec.healthexamination-1/libHealth.so 0x40e51aa0
08-01 14:30:50.610: D/dalvikvm(3159): No JNI_OnLoad found in /data/app-lib/com.contec.healthexamination-1/libHealth.so 0x40e51aa0, skipping init
08-01 14:30:50.620: W/System.err(3159): java.io.IOException: Error running exec(). Command: [su] Working Directory: null Environment: null
08-01 14:30:50.620: W/System.err(3159): at java.lang.ProcessManager.exec(ProcessManager.java:211)
08-01 14:30:50.620: W/System.err(3159): at java.lang.Runtime.exec(Runtime.java:168)
08-01 14:30:50.620: W/System.err(3159): at java.lang.Runtime.exec(Runtime.java:241)
08-01 14:30:50.620: W/System.err(3159): at java.lang.Runtime.exec(Runtime.java:184)
08-01 14:30:50.620: W/System.err(3159): at com.contec.jni.SerialPort.<init>(SerialPort.java:9)
08-01 14:30:50.620: W/System.err(3159): at com.contec.healthexamination.activity.MyApplication.<init>(MyApplication.java:100)
08-01 14:30:50.620: W/System.err(3159): at com.contec.healthexamination.activity.MyApplication.getInstance(MyApplication.java:86)
08-01 14:30:50.620: W/System.err(3159): at com.contec.healthexamination.activity.LoginActivity.onCreateView(LoginActivity.java:117)
08-01 14:30:50.620: W/System.err(3159): at com.contec.healthexamination.activity.BaseActivity.onCreate(BaseActivity.java:51)
08-01 14:30:50.620: W/System.err(3159): at android.app.Activity.performCreate(Activity.java:5104)
08-01 14:30:50.620: W/System.err(3159): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1080)
08-01 14:30:50.620: W/System.err(3159): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2144)
08-01 14:30:50.620: W/System.err(3159): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2230)
08-01 14:30:50.620: W/System.err(3159): at android.app.ActivityThread.access$600(ActivityThread.java:141)
08-01 14:30:50.620: W/System.err(3159): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1234)
08-01 14:30:50.620: W/System.err(3159): at android.os.Handler.dispatchMessage(Handler.java:99)
08-01 14:30:50.620: W/System.err(3159): at android.os.Looper.loop(Looper.java:137)
08-01 14:30:50.620: W/System.err(3159): at android.app.ActivityThread.main(ActivityThread.java:5042)
08-01 14:30:50.620: W/System.err(3159): at java.lang.reflect.Method.invokeNative(Native Method)
08-01 14:30:50.620: W/System.err(3159): at java.lang.reflect.Method.invoke(Method.java:511)
08-01 14:30:50.620: W/System.err(3159): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:793)
08-01 14:30:50.620: W/System.err(3159): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:560)
08-01 14:30:50.620: W/System.err(3159): at dalvik.system.NativeStart.main(Native Method)
08-01 14:30:50.620: W/System.err(3159): Caused by: java.io.IOException: Permission denied
08-01 14:30:50.620: W/System.err(3159): at java.lang.ProcessManager.exec(Native Method)
08-01 14:30:50.620: W/System.err(3159): at java.lang.ProcessManager.exec(ProcessManager.java:209)
08-01 14:30:50.620: W/System.err(3159): ... 22 more
08-01 14:30:50.680: E/setExpandModule(3159): 1
08-01 14:30:50.680: E/initDevice(3159): open CM serial port! fd = 37
08-01 14:30:50.680: E/initDevice(3159): open TEMP serial port! fd = -1
08-01 14:30:50.680: E/initDevice(3159): can't open TEMP serial port!
08-01 14:30:50.680: E/initDevice(3159): open BG serial port! fd = -1
08-01 14:30:50.680: E/initDevice(3159): can't open BG serial port!
08-01 14:30:50.680: E/initDevice(3159): open BC serial port! fd = -1
08-01 14:30:50.680: E/initDevice(3159): can't open BC serial port!
08-01 14:30:50.680: E/initDevice(3159): open HW serial port! fd = 39
08-01 14:30:50.680: E/initDevice(3159): open HB serial port! fd = -1
08-01 14:30:50.680: E/initDevice(3159): can't open HB serial port!
08-01 14:30:50.680: E/initDevice(3159): initDevice
08-01 14:30:50.690: D/com.contec.healthexamination.receiver.ListenerNetworkConnState(3159): networkstat:UNKNOWN
08-01 14:30:50.690: D/ListenerNetworkConnState(3159): isWifiConnected() = false
08-01 14:30:50.700: D/BluetoothManagerService(2637): Message: 20
08-01 14:30:50.700: D/BluetoothManagerService(2637): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@40f05930:true
08-01 14:30:50.700: D/BluetoothAdapter(3159): 1089196880: getState() :  mService = null. Returning STATE_OFF
08-01 14:30:50.700: I/start:(3159): open IDCard EX port!
08-01 14:30:50.700: E/IDCARD(3159): fd = -1  idc_init
08-01 14:30:50.700: E/setCMType(3159): 0
08-01 14:30:50.700: E/LoginActivity(3159): 休眠时间-1
08-01 14:30:50.800: D/libEGL(3159): loaded /system/lib/egl/libEGL_VIVANTE.so
08-01 14:30:50.820: D/dalvikvm(3159): GC_CONCURRENT freed 686K, 64% free 4870K/13428K, paused 5ms+7ms, total 46ms
08-01 14:30:50.820: D/libEGL(3159): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
08-01 14:30:50.830: D/libEGL(3159): loaded /system/lib/egl/libGLESv2_VIVANTE.so
08-01 14:30:50.860: E/BufferQueue(2315): [com.contec.healthexamination/com.contec.healthexamination.activity.LoginActivity] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
08-01 14:30:50.870: D/OpenGLRenderer(3159): Enabling debug mode 0
08-01 14:30:51.030: I/ActivityManager(2637): Displayed com.contec.healthexamination/.activity.LoginActivity: +1s69ms (total +1m3s491ms)
On imx6q with android 4.4.2
08-01 14:11:13.210: I/ActivityManager(2714): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.contec.healthexamination/com.qihoo.util.StartActivity} from pid 2899
08-01 14:11:13.250: D/dalvikvm(2714): GC_FOR_ALLOC freed 146K, 27% free 6064K/8244K, paused 42ms, total 42ms
08-01 14:11:13.280: I/ActivityManager(2714): Start proc com.contec.healthexamination for activity com.contec.healthexamination/com.qihoo.util.StartActivity: pid=3471 uid=10035 gids={50035, 3002, 3001, 3003, 1028, 1015}
08-01 14:11:13.340: D/dalvikvm(3471): DexOpt: couldn't find static field Landroid/os/Build;.SUPPORTED_32_BIT_ABIS
08-01 14:11:13.340: W/dalvikvm(3471): VFY: unable to resolve static field 3 (SUPPORTED_32_BIT_ABIS) in Landroid/os/Build;
08-01 14:11:13.340: D/dalvikvm(3471): VFY: replacing opcode 0x62 at 0x0002
08-01 14:11:13.390: D/dalvikvm(3471): GC_FOR_ALLOC freed 45K, 5% free 3054K/3208K, paused 19ms, total 19ms
08-01 14:11:13.430: D/dalvikvm(3471): Trying to load lib /data/data/com.contec.healthexamination/files/libjiagu.so 0x41fce290
08-01 14:11:13.430: D/dalvikvm(3471): Added shared lib /data/data/com.contec.healthexamination/files/libjiagu.so 0x41fce290
08-01 14:11:13.860: E/dalvikvm(3471): ERROR: couldn't find native method
08-01 14:11:13.860: E/dalvikvm(3471): Requested: Lcom/qihoo/util/StubApp4041099101;.interface7:(Landroid/app/Application;Landroid/content/Context;)Z
08-01 14:11:13.860: W/asset(3471): Asset path /data/data/com.contec.healthexamination/files/libjiagu_x64.a is neither a directory nor file (type=1).
08-01 14:11:13.880: I/ActivityManager(2714): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 cmp=com.contec.healthexamination/.activity.LoginActivity bnds=[228,118][324,214]} from pid 3471
08-01 14:11:13.900: W/Settings(3471): Setting android_id has moved from android.provider.Settings.System to android.provider.Settings.Secure, returning read-only value.
08-01 14:11:13.920: D/dalvikvm(3471): GC_CONCURRENT freed 649K, 21% free 2873K/3616K, paused 2ms+3ms, total 18ms
08-01 14:11:13.960: D/dalvikvm(3471): GC_CONCURRENT freed 473K, 20% free 2912K/3616K, paused 2ms+2ms, total 18ms
08-01 14:11:13.960: D/dalvikvm(3471): WAIT_FOR_CONCURRENT_GC blocked 9ms
08-01 14:11:14.420: D/dalvikvm(3471): GC_FOR_ALLOC freed 17K, 19% free 2930K/3616K, paused 13ms, total 13ms
08-01 14:11:14.420: I/dalvikvm-heap(3471): Grow heap (frag case) to 4.929MB for 2073616-byte allocation
08-01 14:11:14.440: D/dalvikvm(3471): GC_FOR_ALLOC freed 0K, 13% free 4955K/5644K, paused 14ms, total 14ms
08-01 14:11:14.450: D/dalvikvm(3471): GC_CONCURRENT freed <1K, 13% free 4955K/5644K, paused 2ms+1ms, total 16ms
08-01 14:11:14.520: E/LoginActivity(3471): onCreateView
08-01 14:11:14.520: W/System.err(3471): java.io.FileNotFoundException: /storage/emulated/0/PHMS/PhmsConfig.ini: open failed: ENOENT (No such file or directory)
08-01 14:11:14.520: W/System.err(3471): at libcore.io.IoBridge.open(IoBridge.java:409)
08-01 14:11:14.520: W/System.err(3471): at java.io.FileOutputStream.<init>(FileOutputStream.java:88)
08-01 14:11:14.520: W/System.err(3471): at java.io.FileOutputStream.<init>(FileOutputStream.java:73)
08-01 14:11:14.520: W/System.err(3471): at com.contec.healthexamination.util.FileHelper.copyAssetFileToPath(FileHelper.java:227)
08-01 14:11:14.520: W/System.err(3471): at com.contec.healthexamination.activity.LoginActivity.onCreateView(LoginActivity.java:107)
08-01 14:11:14.520: W/System.err(3471): at com.contec.healthexamination.activity.BaseActivity.onCreate(BaseActivity.java:51)
08-01 14:11:14.520: W/System.err(3471): at android.app.Activity.performCreate(Activity.java:5231)
08-01 14:11:14.520: W/System.err(3471): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1087)
08-01 14:11:14.520: W/System.err(3471): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2159)
08-01 14:11:14.520: W/System.err(3471): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2245)
08-01 14:11:14.520: W/System.err(3471): at android.app.ActivityThread.access$800(ActivityThread.java:135)
08-01 14:11:14.520: W/System.err(3471): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1196)
08-01 14:11:14.520: W/System.err(3471): at android.os.Handler.dispatchMessage(Handler.java:102)
08-01 14:11:14.520: W/System.err(3471): at android.os.Looper.loop(Looper.java:136)
08-01 14:11:14.520: W/System.err(3471): at android.app.ActivityThread.main(ActivityThread.java:5017)
08-01 14:11:14.520: W/System.err(3471): at java.lang.reflect.Method.invokeNative(Native Method)
08-01 14:11:14.520: W/System.err(3471): at java.lang.reflect.Method.invoke(Method.java:515)
08-01 14:11:14.520: W/System.err(3471): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:779)
08-01 14:11:14.520: W/System.err(3471): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:595)
08-01 14:11:14.520: W/System.err(3471): at dalvik.system.NativeStart.main(Native Method)
08-01 14:11:14.520: W/System.err(3471): Caused by: libcore.io.ErrnoException: open failed: ENOENT (No such file or directory)
08-01 14:11:14.520: W/System.err(3471): at libcore.io.Posix.open(Native Method)
08-01 14:11:14.520: W/System.err(3471): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110)
08-01 14:11:14.520: W/System.err(3471): at libcore.io.IoBridge.open(IoBridge.java:393)
08-01 14:11:14.530: W/System.err(3471): ... 19 more
08-01 14:11:14.530: D/dalvikvm(3471): Trying to load lib /data/app-lib/com.contec.healthexamination-1/libHealth.so 0x41fce290
08-01 14:11:14.530: D/dalvikvm(3471): Added shared lib /data/app-lib/com.contec.healthexamination-1/libHealth.so 0x41fce290
08-01 14:11:14.530: D/dalvikvm(3471): No JNI_OnLoad found in /data/app-lib/com.contec.healthexamination-1/libHealth.so 0x41fce290, skipping init
08-01 14:11:14.550: W/System.err(3471): java.io.IOException: Error running exec(). Command: [su] Working Directory: null Environment: null
08-01 14:11:14.550: W/System.err(3471): at java.lang.ProcessManager.exec(ProcessManager.java:211)
08-01 14:11:14.550: W/System.err(3471): at java.lang.Runtime.exec(Runtime.java:173)
08-01 14:11:14.550: W/System.err(3471): at java.lang.Runtime.exec(Runtime.java:246)
08-01 14:11:14.550: W/System.err(3471): at java.lang.Runtime.exec(Runtime.java:189)
08-01 14:11:14.550: W/System.err(3471): at com.contec.jni.SerialPort.<init>(SerialPort.java:9)
08-01 14:11:14.550: W/System.err(3471): at com.contec.healthexamination.activity.MyApplication.<init>(MyApplication.java:100)
08-01 14:11:14.550: W/System.err(3471): at com.contec.healthexamination.activity.MyApplication.getInstance(MyApplication.java:86)
08-01 14:11:14.550: W/System.err(3471): at com.contec.healthexamination.activity.LoginActivity.onCreateView(LoginActivity.java:117)
08-01 14:11:14.550: W/System.err(3471): at com.contec.healthexamination.activity.BaseActivity.onCreate(BaseActivity.java:51)
08-01 14:11:14.550: W/System.err(3471): at android.app.Activity.performCreate(Activity.java:5231)
08-01 14:11:14.550: W/System.err(3471): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1087)
08-01 14:11:14.550: W/System.err(3471): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2159)
08-01 14:11:14.550: W/System.err(3471): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2245)
08-01 14:11:14.550: W/System.err(3471): at android.app.ActivityThread.access$800(ActivityThread.java:135)
08-01 14:11:14.550: W/System.err(3471): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1196)
08-01 14:11:14.550: W/System.err(3471): at android.os.Handler.dispatchMessage(Handler.java:102)
08-01 14:11:14.550: W/System.err(3471): at android.os.Looper.loop(Looper.java:136)
08-01 14:11:14.550: W/System.err(3471): at android.app.ActivityThread.main(ActivityThread.java:5017)
08-01 14:11:14.550: W/System.err(3471): at java.lang.reflect.Method.invokeNative(Native Method)
08-01 14:11:14.550: W/System.err(3471): at java.lang.reflect.Method.invoke(Method.java:515)
08-01 14:11:14.550: W/System.err(3471): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:779)
08-01 14:11:14.550: W/System.err(3471): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:595)
08-01 14:11:14.550: W/System.err(3471): at dalvik.system.NativeStart.main(Native Method)
08-01 14:11:14.550: W/System.err(3471): Caused by: java.io.IOException: Permission denied
08-01 14:11:14.550: W/System.err(3471): at java.lang.ProcessManager.exec(Native Method)
08-01 14:11:14.550: W/System.err(3471): at java.lang.ProcessManager.exec(ProcessManager.java:209)
08-01 14:11:14.550: W/System.err(3471): ... 22 more
08-01 14:11:14.580: W/FileUtils(3471): Failed to chmod(/storage/emulated/0/lite/orm/health.db): libcore.io.ErrnoException: chmod failed: EPERM (Operation not permitted)
08-01 14:11:14.610: E/setExpandModule(3471): 1
08-01 14:11:14.610: E/initDevice(3471): open CM serial port! fd = 53
08-01 14:11:14.610: E/initDevice(3471): open TEMP serial port! fd = -1
08-01 14:11:14.610: E/initDevice(3471): can't open TEMP serial port!
08-01 14:11:14.610: E/initDevice(3471): open BG serial port! fd = -1
08-01 14:11:14.610: E/initDevice(3471): can't open BG serial port!
08-01 14:11:14.610: E/initDevice(3471): open BC serial port! fd = -1
08-01 14:11:14.610: E/initDevice(3471): can't open BC serial port!
08-01 14:11:14.610: E/initDevice(3471): open HW serial port! fd = 54
08-01 14:11:14.610: E/initDevice(3471): open HB serial port! fd = -1
08-01 14:11:14.610: E/initDevice(3471): can't open HB serial port!
08-01 14:11:14.610: E/initDevice(3471): initDevice
08-01 14:11:14.620: D/com.contec.healthexamination.receiver.ListenerNetworkConnState(3471): networkstat:CONNECTED
08-01 14:11:14.620: D/ListenerNetworkConnState(3471): isWifiConnected() = true
08-01 14:11:14.620: D/ListenerNetworkConnState(3471): isWifiConnected()-newSignalLevel = 2
08-01 14:11:14.620: D/BluetoothManagerService(2714): Message: 20
08-01 14:11:14.620: D/BluetoothManagerService(2714): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@421f87b0:true
08-01 14:11:14.620: D/BluetoothAdapter(3471): 1107371560: getState() :  mService = null. Returning STATE_OFF
08-01 14:11:14.620: I/start:(3471): open IDCard EX port!
08-01 14:11:14.620: E/IDCARD(3471): fd = -1  idc_init
08-01 14:11:14.630: E/setCMType(3471): 0
08-01 14:11:14.630: E/LoginActivity(3471): 休眠时间-1
08-01 14:11:14.630: D/com.contec.healthexamination.receiver.ListenerNetworkConnState(3471): updateConnectivity:TYPE_WIFI -mLastWifiSignalLevel = 2
08-01 14:11:14.630: D/com.contec.healthexamination.receiver.ListenerNetworkConnState(3471): WIFI_STATE_CHANGED_ACTION-visible : = 0
08-01 14:11:14.700: D/libEGL(3471): loaded /system/lib/egl/libEGL_VIVANTE.so
08-01 14:11:15.050: D/dalvikvm(3471): GC_CONCURRENT freed 296K, 7% free 5312K/5708K, paused 2ms+2ms, total 27ms
08-01 14:11:18.960: D/libEGL(3471): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
08-01 14:11:19.030: D/libEGL(3471): loaded /system/lib/egl/libGLESv2_VIVANTE.so
08-01 14:11:19.120: E/BufferQueue(2335): [com.contec.healthexamination/com.contec.healthexamination.activity.LoginActivity] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
08-01 14:11:19.130: D/OpenGLRenderer(3471): Enabling debug mode 0
08-01 14:11:19.270: I/ActivityManager(2714): Displayed com.contec.healthexamination/.activity.LoginActivity: +5s354ms (total +5s994ms)
Anyone knows what is the problem?
标签 (3)
标记 (1)
1,730 次查看
guoprothes
hi, I have same problem, and  shoud not i to check it
1,730 次查看
b36401
You can debug the kernel by enabling debug output or adding printk functions.
Also please turn on DEBUG flag in GPU driver kernel side.
Victor
