Dear team,
I am writing Device tree source (dts) file for jadard jd9365d (TFT LCD single chip ) display panel that is connected to freescale imx8mm core board
kernel driver for jd9365d panel is included by referring below link. https://github.com/edgeble/kernel/blob/linux-5.10-gen-rkr3.4/drivers/gpu/drm/panel/panel-jadard-jd93...
But dts file code reference for jd9365d panel is added for rockchip core and it can not be referred for writing dts code for imx8mm core board. respective rockchip dts file is given below.
https://github.com/edgeble/kernel/blob/linux-5.10-gen-rkr3.4/arch/arm64/boot/dts/rockchip/rk3588-edg...
hence requesting to provide some insights / reference dts file of TFT lcd panel compatible for imx8mm core board as it can be used to write jd9365da panel dts code.
Attached jd9365d panel document for reference.
kote
