/dev/mxc_vpu can not be generated
1,151 次查看
824497590
I'm currently using the 4.9.11 kernel,i found that it  can not generated /dev/mxc_vpu,When my kernel version is higher than 4.9.11, both can not generated mxc_vpu device node, where do I need special configuration.
1,141 次查看
joanxie
what board are you using? and what is your request? do you need test vpu?
1,135 次查看
824497590
是pmic影响到vpu节点的生成了 ,不过为什么影响我没有搞清楚,现在已经正常了
