custom imx8mp fastboot flash uboot error
2,122件の閲覧回数
hjk003
Hi, nxp team. We are using our own customized version based on imx8mp-evk, with the boot mode set to SDPS. An error occurred when flashing uboot; we wanted it to be flashed to eMMC, but it didn't. Below is the error message:
Unknown image format!
Run fastboot
(NULL udevice *): request 00000000fcf12640 was not queued to ep1in-bulk
Starting download of 1701840 bytes
downloading of 1701840 bytes finished
Not support flash command for current device 255
He suggested `Not support flash command for current device 255`
ラベル(2)
3 返答(返信)
1,963件の閲覧回数
pengyong_zhang
Hi @hjk003
Please create another ticket talk about this new question.
B.R
2,079件の閲覧回数
pengyong_zhang
Hi @hjk003
What is your flash tool? we suggest you use our UUU tool flash the Image to your EMMC.
B.R
2,074件の閲覧回数
hjk003
@pengyong_zhang , Hi, We've solved that problem, but we have another question about the SJA1105P. Our board's general structure and device tree are as follows. We use ethernet0 for external communication, ethernet1's MAC address is directly connected to port 2 of the SJA1105P, and the other four ports are also in use. What modifications are needed to the device tree based on the imx8mp-evk? Thank you for your reply.
        │                  │         SPI               │
  │   SPI         │        │                           │
  │ port0         │        │M                          │
  │ port1    port2◄────────┤A                          │
  │    SJA1105    │        │C                          │
  │               │        │1       CPU                │
  │ port3         │        │   MIMX8ML8DVNLZAB         │
  │ port4         │        │                           │
                           │        MAC2               │
│       RGMII      │                  │
│   PHY            │                  │
│   88E1512       M│                  │
│                 D◄──────────────────┘
│                 I│
│                 O│
        └► OUT
			eqos: ethernet@30bf0000 {
				compatible = "nxp,imx8mp-dwmac-eqos", "snps,dwmac-5.10a";
				reg = <0x30bf0000 0x10000>;
				interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>,
					     <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>;
				interrupt-names = "macirq", "eth_wake_irq";
				clocks = <&clk IMX8MP_CLK_ENET_QOS_ROOT>,
					 <&clk IMX8MP_CLK_QOS_ENET_ROOT>,
					 <&clk IMX8MP_CLK_ENET_QOS_TIMER>,
					 <&clk IMX8MP_CLK_ENET_QOS>;
				clock-names = "stmmaceth", "pclk", "ptp_ref", "tx";
				assigned-clocks = <&clk IMX8MP_CLK_ENET_AXI>,
				assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_266M>,
							 <&clk IMX8MP_SYS_PLL2_100M>,
							 <&clk IMX8MP_SYS_PLL2_125M>;
				assigned-clock-rates = <0>, <100000000>, <125000000>;
				nvmem-cells = <&eth_mac2>;
				nvmem-cell-names = "mac-address";
				intf_mode = <&gpr 0x4>;
				status = "disabled";
&iomuxc {
pinctrl_eqos: eqosgrp {
		fsl,pins = <
			MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC				0x2
			MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO				0x2
			MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0			0x90
			MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1			0x90
			MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2			0x90
			MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3			0x90
			MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK	0x90
			MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL			0x90
			MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0			0x16
			MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1			0x16
			MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2			0x16
			MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3			0x16
			MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL			0x16
			MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK	0x16
			MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22				0x10
&eqos {
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_eqos>;
  status = "okay";
&ecspi1 {  // switch & imu
	fsl,spi-num-chipselects = <3>;
	pinctrl-0 = <&pinctrl_ecspi1>;
	cs-gpios = <&gpio1 15 GPIO_ACTIVE_LOW>,		// CS 0 switch
							<&gpio1 14 GPIO_ACTIVE_LOW>,
							<&gpio1 10 GPIO_ACTIVE_LOW>;
	status = "okay";
	sja1105p@0 {
    #address-cells = <1>;
    #size-cells = <0>;
		compatible = "nxp,sja1105p";
		firmware_name = "sja1105p_cfg.bin"; /// optional
		spi-max-frequency = <0x17d7840>;  // 25 000 000
		spi-cpha;
		reg = <0x0>;
		port-0 {
			is-host = <0x0>;
			null-phy = <0x1>;
			phy-ref = < 0 >;
			logical-port-num = < 0 >;
		port-1 {
			is-host = <0x0>;
			null-phy = <0x1>;
			phy-ref = < 0 >;
			logical-port-num = < 0xff >;
		port-2 {
      label = "cpuMAC";
      phy-mode = "rgmii-id";
			is-host = <0x1>;
			null-phy = <0x0>;
			phy-ref = <0>;
			logical-port-num = < 1 >;
      ethernet = <&eqos>;
      fixed-link {
        speed = <1000>;
        full-duplex;
		port-3 {
			is-host = <0x0>;
			null-phy = <0x0>;
			phy-ref = <0>;
			logical-port-num = < 2 >;
		port-4 {
			is-host = <0x0>;
			null-phy = <0x0>;
			phy-ref = <0>;
			logical-port-num = < 3 >;
	imu_accel@1 {
		reg = <1>;
		compatible = "SMI230ACC";
		cs-gpios = <&gpio1 14 GPIO_ACTIVE_LOW>;
	imu_gyro@2 {
		reg = <2>;
		compatible = "SMI230GYRO";
		cs-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
%3CLINGO-SUB%20id%3D%22lingo-sub-2267707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20imx8mp%20fastboot%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20uboot%20%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81nxp%20%E3%83%81%E3%83%BC%E3%83%A0%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%20SDPS%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%81imx8mp-evk%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E7%8B%AC%E8%87%AA%E3%81%AB%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82uboot%20%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82eMMC%20%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%A4%E3%82%82%E3%82%8A%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EUnknown%20image%20format!%0ARun%20fastboot%0A(NULL%20udevice%20*)%3A%20request%2000000000fcf12640%20was%20not%20queued%20to%20ep1in-bulk%0AStarting%20download%20of%201701840%20bytes%0A(NULL%20udevice%20*)%3A%20request%2000000000fcf12640%20was%20not%20queued%20to%20ep1in-bulk%0A............%0Adownloading%20of%201701840%20bytes%20finished%0A(NULL%20udevice%20*)%3A%20request%2000000000fcf12640%20was%20not%20queued%20to%20ep1in-bulk%0ANot%20support%20flash%20command%20for%20current%20device%20255%0A(NULL%20udevice%20*)%3A%20request%2000000000fcf12640%20was%20not%20queued%20to%20ep1in-bulk%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%BC%E3%81%AF%E3%80%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9255%E3%81%A7%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%80%8D%E3%81%A8%E6%8F%90%E6%A1%88%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2267707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20custom%20imx8mp%20fastboot%20flash%20uboot%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257340%22%20target%3D%22_blank%22%3E%40hjk003%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%E5%BC%8A%E7%A4%BE%E3%81%AE%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fmfgtools%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUUU%3C%2FA%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%20EMMC%20%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20custom%20imx8mp%20fastboot%20flash%20uboot%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%20%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E3%81%9D%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81SJA1105P%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%88%A5%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E6%A7%8B%E9%80%A0%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E5%A4%96%E9%83%A8%E9%80%9A%E4%BF%A1%E3%81%AB%E3%81%AF%20ethernet0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81ethernet1%20%E3%81%AE%20MAC%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%20SJA1105P%20%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%202%20%E3%81%AB%E7%9B%B4%E6%8E%A5%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E4%BB%96%E3%81%AE%204%20%E3%81%A4%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82imx8mp-evk%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20%20%20%20%20%E2%94%8C%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%90%0A%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%8C%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%B4%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%90%0A%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20SPI%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%E2%94%8C%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%96%BC%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%90%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%E2%94%82%20%20%20SPI%20%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%E2%94%82%20port0%20%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%E2%94%82M%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%E2%94%82%20port1%20%20%20%20port2%E2%97%84%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%80%E2%94%A4A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%E2%94%82%20%20%20%20SJA1105%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%E2%94%82C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%E2%94%82%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%E2%94%821%20%20%20%20%20%20%20CPU%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%E2%94%82%20port3%20%20%20%20%20%20%20%20%20%E2%94%82%20%20%20%20%20%20%20%20%E2%94%82%20%20%20MIMX8ML8DVNLZAB%20%20%20%20%20%20%20%20%20%E2%94%82%0A%20%20%E2%94%82%20port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class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%09%09%09eqos%3A%20ethernet%4030bf0000%20%7B%0A%09%09%09%09compatible%20%3D%20%22nxp%2Cimx8mp-dwmac-eqos%22%2C%20%22snps%2Cdwmac-5.10a%22%3B%0A%09%09%09%09reg%20%3D%20%26lt%3B0x30bf0000%200x10000%26gt%3B%3B%0A%09%09%09%09interrupts%20%3D%20%3CGIC_SPI%20135%3D%22%22%20irq_type_level_high%3D%22%22%3E%2C%0A%09%09%09%09%09%20%20%20%20%20%3CGIC_SPI%20134%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%0A%09%09%09%09interrupt-names%20%3D%20%22macirq%22%2C%20%22eth_wake_irq%22%3B%0A%09%09%09%09clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_ENET_QOS_ROOT%26gt%3B%2C%0A%09%09%09%09%09%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_QOS_ENET_ROOT%26gt%3B%2C%0A%09%09%09%09%09%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_ENET_QOS_TIMER%26gt%3B%2C%0A%09%09%09%09%09%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_ENET_QOS%26gt%3B%3B%0A%09%09%09%09clock-names%20%3D%20%22stmmaceth%22%2C%20%22pclk%22%2C%20%22ptp_ref%22%2C%20%22tx%22%3B%0A%09%09%09%09assigned-clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_ENET_AXI%26gt%3B%2C%0A%09%09%09%09%09%09%20%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_ENET_QOS_TIMER%26gt%3B%2C%0A%09%09%09%09%09%09%20%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_ENET_QOS%26gt%3B%3B%0A%09%09%09%09assigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_SYS_PLL1_266M%26gt%3B%2C%0A%09%09%09%09%09%09%09%20%26lt%3B%26amp%3Bclk%20IMX8MP_SYS_PLL2_100M%26gt%3B%2C%0A%09%09%09%09%09%09%09%20%26lt%3B%26amp%3Bclk%20IMX8MP_SYS_PLL2_125M%26gt%3B%3B%0A%09%09%09%09assigned-clock-rates%20%3D%20%26lt%3B0%26gt%3B%2C%20%26lt%3B100000000%26gt%3B%2C%20%26lt%3B125000000%26gt%3B%3B%0A%09%09%09%09nvmem-cells%20%3D%20%26lt%3B%26amp%3Beth_mac2%26gt%3B%3B%0A%09%09%09%09nvmem-cell-names%20%3D%20%22mac-address%22%3B%0A%09%09%09%09intf_mode%20%3D%20%26lt%3B%26amp%3Bgpr%200x4%26gt%3B%3B%0A%09%09%09%09status%20%3D%20%22disabled%22%3B%0A%09%09%09%7D%3B%0A%09%09%7D%3B%3C%2FGIC_SPI%3E%3C%2FGIC_SPI%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%26amp%3Biomuxc%20%7B%09%0Apinctrl_eqos%3A%20eqosgrp%20%7B%0A%09%09fsl%2Cpins%20%3D%20%26lt%3B%0A%09%09%09MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC%09%09%09%090x2%0A%09%09%09MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO%09%09%09%090x2%0A%09%09%09MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0%09%09%090x90%0A%09%09%09MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1%09%09%090x90%0A%09%09%09MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2%09%09%090x90%0A%09%09%09MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3%09%09%090x90%0A%09%09%09MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK%090x90%0A%09%09%09MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL%09%09%090x90%0A%09%09%09MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0%09%09%090x16%0A%09%09%09MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1%09%09%090x16%0A%09%09%09MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2%09%09%090x16%0A%09%09%09MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3%09%09%090x16%0A%09%09%09MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL%09%09%090x16%0A%09%09%09MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK%090x16%0A%09%09%09MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22%09%09%09%090x10%0A%09%09%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%0A%0A%26amp%3Beqos%20%7B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_eqos%26gt%3B%3B%0A%20%20status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%0A%26amp%3Becspi1%20%7B%20%20%2F%2F%20switch%20%26amp%3B%20imu%0A%0A%09fsl%2Cspi-num-chipselects%20%3D%20%26lt%3B3%26gt%3B%3B%0A%09pinctrl-names%20%3D%20%22default%22%3B%0A%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_ecspi1%26gt%3B%3B%0A%09cs-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%2015%20GPIO_ACTIVE_LOW%26gt%3B%2C%09%09%2F%2F%20CS%200%20switch%20%0A%09%09%09%09%09%09%09%26lt%3B%26amp%3Bgpio1%2014%20GPIO_ACTIVE_LOW%26gt%3B%2C%09%20%0A%09%09%09%09%09%09%09%26lt%3B%26amp%3Bgpio1%2010%20GPIO_ACTIVE_LOW%26gt%3B%3B%09%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09sja1105p%400%20%7B%0A%20%20%20%20%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09compatible%20%3D%20%22nxp%2Csja1105p%22%3B%0A%09%09firmware_name%20%3D%20%22sja1105p_cfg.bin%22%3B%20%2F%2F%2F%20optional%20%0A%09%09spi-max-frequency%20%3D%20%26lt%3B0x17d7840%26gt%3B%3B%20%20%2F%2F%2025%20000%20000%20%0A%09%09spi-cpha%3B%0A%09%09reg%20%3D%20%26lt%3B0x0%26gt%3B%3B%0A%0A%09%09port-0%20%7B%0A%09%09%09is-host%20%3D%20%26lt%3B0x0%26gt%3B%3B%0A%09%09%09null-phy%20%3D%20%26lt%3B0x1%26gt%3B%3B%0A%09%09%09phy-ref%20%3D%20%26lt%3B%200%20%26gt%3B%3B%0A%09%09%09logical-port-num%20%3D%20%26lt%3B%200%20%26gt%3B%3B%0A%09%09%7D%3B%0A%0A%09%09port-1%20%7B%0A%09%09%09is-host%20%3D%20%26lt%3B0x0%26gt%3B%3B%0A%09%09%09null-phy%20%3D%20%26lt%3B0x1%26gt%3B%3B%0A%09%09%09phy-ref%20%3D%20%26lt%3B%200%20%26gt%3B%3B%0A%09%09%09logical-port-num%20%3D%20%26lt%3B%200xff%20%26gt%3B%3B%0A%09%09%7D%3B%0A%0A%09%09port-2%20%7B%0A%20%20%20%20%20%20label%20%3D%20%22cpuMAC%22%3B%0A%20%20%20%20%20%20phy-mode%20%3D%20%22rgmii-id%22%3B%0A%09%09%09is-host%20%3D%20%26lt%3B0x1%26gt%3B%3B%0A%09%09%09null-phy%20%3D%20%26lt%3B0x0%26gt%3B%3B%0A%09%09%09phy-ref%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09logical-port-num%20%3D%20%26lt%3B%201%20%26gt%3B%3B%0A%0A%20%20%20%20%20%20ethernet%20%3D%20%26lt%3B%26amp%3Beqos%26gt%3B%3B%0A%20%20%20%20%20%20fixed-link%20%7B%0A%20%20%20%20%20%20%20%20speed%20%3D%20%26lt%3B1000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20full-duplex%3B%0A%20%20%20%20%20%20%7D%3B%0A%09%09%7D%3B%0A%0A%09%09port-3%20%7B%0A%09%09%09is-host%20%3D%20%26lt%3B0x0%26gt%3B%3B%0A%09%09%09null-phy%20%3D%20%26lt%3B0x0%26gt%3B%3B%0A%09%09%09phy-ref%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09logical-port-num%20%3D%20%26lt%3B%202%20%26gt%3B%3B%0A%09%09%7D%3B%0A%0A%09%09port-4%20%7B%0A%09%09%09is-host%20%3D%20%26lt%3B0x0%26gt%3B%3B%0A%09%09%09null-phy%20%3D%20%26lt%3B0x0%26gt%3B%3B%0A%09%09%09phy-ref%20%3D%20%26lt%3B0%26gt%3B%3B%0A%09%09%09logical-port-num%20%3D%20%26lt%3B%203%20%26gt%3B%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%0A%09imu_accel%401%20%7B%0A%09%09reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%09compatible%20%3D%20%22SMI230ACC%22%3B%0A%09%09cs-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%2014%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%09%7D%3B%0A%09imu_gyro%402%20%7B%0A%09%09reg%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09compatible%20%3D%20%22SMI230GYRO%22%3B%0A%09%09cs-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%2010%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20custom%20imx8mp%20fastboot%20flash%20uboot%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257340%22%20target%3D%22_blank%22%3E%40hjk003%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%88%A5%E3%81%AE%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E8%A9%B1%E3%81%97%E5%90%88%E3%81%84%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E
