create own machine
create own machine
1,453件の閲覧回数
niklasmolin
Senior Contributor I
Hi.
I trying to create my own machine in Yocto, using SabreSD as reference.
Is there any good documentation I can follow?
I assume there needs to be an addition to the u-boot for my machine name (since I also want to modify the board file to fit my custom board etc.) plus also for the linux build?
Niklas
ラベル(2)
1,334件の閲覧回数
LeonardoSandova
Specialist I
Just the BSP layer standard tutorial by the Yocto Project. It covers machines an other BSP metadata.
I think your approach is fine: create a layer, copy a machine there, then start changing certain variables.
