cracklib issues during the bitbake <target>
12,457 次查看
Embedded-world
Dear Experts,
I am trying to build an image with the meta-qt6 feature, but during the Bitbake execution, I encountered the following error. Despite multiple attempts, the issue persists. Could you please help me resolve the error mentioned below?
calixto-systems@calixtosystems-HP-Notebook:/media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/build-xwayland$ bitbake imx-image-full
WARNING: You have included the meta-virtualization layer, but 'virtualization' has not been enabled in your DISTRO_FEATURES. Some bbappend files may not take effect. See the meta-virtualization README for details on enabling virtualization support.
Loading cache: 100% |##########################################################################################################| Time: 0:00:01
Loaded 4742 entries from dependency cache.
Parsing recipes: 100% |########################################################################################################| Time: 0:00:01
Parsing of 3195 .bb files complete (3194 cached, 1 parsed). 4743 targets, 371 skipped, 3 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION           = "2.0.0"
BUILD_SYS            = "x86_64-linux"
NATIVELSBSTRING      = "universal"
TARGET_SYS           = "arm-poky-linux-gnueabi"
MACHINE              = "imx6ull-versa256"
DISTRO               = "fsl-imx-xwayland"
DISTRO_VERSION       = "5.15-kirkstone"
TUNE_FEATURES        = "arm vfp cortexa7 neon thumb callconvention-hard"
TARGET_FPU           = "hard"
meta
meta-poky            = "HEAD:24a3f7b3648185e33133f5d96b184a6cb6524f3d"
meta-oe
meta-multimedia
meta-python          = "HEAD:744a4b6eda88b9a9ca1cf0df6e18be384d9054e3"
meta-freescale       = "HEAD:c82d4634e7aba8bc0de73ce1dfc997b630051571"
meta-freescale-3rdparty = "HEAD:5977197340c7a7db17fe3e02a4e014ad997565ae"
meta-freescale-distro = "HEAD:d5bbb487b2816dfc74984a78b67f7361ce404253"
meta-calixto-nxp     = "HEAD:c547c4347d887a7212bd3d306f0601c21ff36d65"
meta-bsp
meta-sdk
meta-ml
meta-v2x             = "HEAD:ca68ab5d25322b51f54564275c84ab8de3c74ea6"
meta-nxp-demo-experience = "HEAD:52eaf8bf42f8eda2917a1c8c046003c8c2c8f629"
meta-chromium        = "HEAD:e232c2e21b96dc092d9af8bea4b3a528e7a46dd6"
meta-clang           = "HEAD:c728c3f9168c8a4ed05163a51dd48ca1ad8ac21d"
meta-gnome
meta-networking
meta-filesystems     = "HEAD:744a4b6eda88b9a9ca1cf0df6e18be384d9054e3"
meta-qt6             = "HEAD:ed785a25d12e365d1054700d4fc94a053176eb14"
meta-virtualization  = "HEAD:9482648daf0bb42ff3475e7892542cf99f3b8d48"
Initialising tasks: 100% |#####################################################################################################| Time: 0:00:13
Sstate summary: Wanted 3349 Local 0 Mirrors 0 Missed 3349 Current 101 (0% match, 2% complete)
NOTE: Executing Tasks
WARNING: cracklib-2.9.8-r0 do_fetch: Failed to fetch URL git://github.com/cracklib/cracklib;protocol=https;branch=master, attempting MIRRORS if available
ERROR: cracklib-2.9.8-r0 do_fetch: Fetcher failure: Unable to find revision d9e8f9f47718539aeba80f90f4e072549926dc9c in branch master even from upstream
ERROR: cracklib-2.9.8-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/cracklib/cracklib;protocol=https;branch=master')
ERROR: Logfile of failure stored in: /media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/build-xwayland/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/cracklib/2.9.8-r0/temp/log.do_fetch.919291
ERROR: Task (/media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/sources/poky/meta/recipes-extended/cracklib/cracklib_2.9.8.bb:do_fetch) failed with exit code '1'
WARNING: cracklib-native-2.9.8-r0 do_fetch: Failed to fetch URL git://github.com/cracklib/cracklib;protocol=https;branch=master, attempting MIRRORS if available
ERROR: cracklib-native-2.9.8-r0 do_fetch: Fetcher failure: Unable to find revision d9e8f9f47718539aeba80f90f4e072549926dc9c in branch master even from upstream
ERROR: cracklib-native-2.9.8-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/cracklib/cracklib;protocol=https;branch=master')
ERROR: Logfile of failure stored in: /media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/build-xwayland/tmp/work/x86_64-linux/cracklib-native/2.9.8-r0/temp/log.do_fetch.930524
ERROR: Task (virtual:native:/media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/sources/poky/meta/recipes-extended/cracklib/cracklib_2.9.8.bb:do_fetch) failed with exit code '1'
also Please share proper link to fetch the above respective repo.
Ravikumar
12,374 次查看
x85446
Its a problem of the cracklib changing their github from master to main.
hack: after you get the error (or before on a clean machine), dive into the code, and change master to main
$editor ./layers/openembedded-core/meta/recipes-extended/cracklib/cracklib_2.9.8.bb
SRC_URI = "git://github.com/cracklib/cracklib;protocol=https;branch=master \
           file://0001-packlib.c-support-dictionary-byte-order-dependent.patch \
           file://0002-craklib-fix-testnum-and-teststr-failed.patch \
SRC_URI = "git://github.com/cracklib/cracklib;protocol=https;branch=main \
higher quality fix:  write a bbappend, that changes the SRC_URI... Like we did here back in the day when runc did the same master/main change...
Travis
Izuma Networks - lightest possible way to orchestrate kubernetes at the edge
8 回复数
12,434 次查看
Chavira
Hi  @Embedded-world!
Thank you for contacting NXP Support!
What BSP version are you using?
I will try to reproduce the error by my side.
Best Regards!
Chavira
12,392 次查看
Embedded-world
Hi Chavira
This is the BSP source i cloned for my build.
https://github.com/nxp-imx/meta-imx/tree/kirkstone-5.15.71-2.2.2
Thanks & Regards,
Ravikumar
12,417 次查看
TFSchuhmacher
Hello Chavira,
I have the same issue with cracklib-2.9.8
I am using a versalogic swordtail imx6 with kirkstone and manifest imx-5.15.71-2.2.2.xml
I tried also the "original" 5.15.32-2.0.0 with the same result:
NATIVELSBSTRING = "ubuntu-18.04"
MACHINE = "imx6swordtail"
TUNE_FEATURES = "arm vfp cortexa9 neon thumb callconvention-hard"
TARGET_FPU = "hard"
meta
meta-oe
meta-multimedia
meta-versalogic = "kirkstone:16df027b80ac33f80e9062bd8048e23d8e5dc2e1"
meta-bsp
meta-sdk
meta-ml
meta-gnome
meta-networking
NOTE: Fetching uninative binary shim http://downloads.yoctoproject.org/releases/uninative/3.7/x86_64-nativesdk-libc-3.7.tar.xz;sha256sum=... (will check PREMIRRORS first)
Initialising tasks: 100% |##############################################################################################################| Time: 0:00:03
Sstate summary: Wanted 1358 Local 0 Mirrors 0 Missed 1358 Current 0 (0% match, 0% complete)
ERROR: Logfile of failure stored in: /data/swordtail/v100/tmp/work/x86_64-linux/cracklib-native/2.9.8-r0/temp/log.do_fetch.14842
ERROR: Task (virtual:native:/data/swordtail/sources/poky/meta/recipes-extended/cracklib/cracklib_2.9.8.bb:do_fetch) failed with exit code '1'
ERROR: Logfile of failure stored in: /data/swordtail/v100/tmp/work/cortexa9t2hf-neon-poky-linux-gnueabi/cracklib/2.9.8-r0/temp/log.do_fetch.18742
ERROR: Task (/data/swordtail/sources/poky/meta/recipes-extended/cracklib/cracklib_2.9.8.bb:do_fetch) failed with exit code '1'
Thank you and best regards,
Thomas
12,375 次查看
x85446
Travis
12,326 次查看
Chavira
HI all!
As @x85446! mention, the problem is the name of the branch because cracklib doesn´t have master branch the library has instead main branch.
Changing the branch the line Yocto is able to fetch and compile the library without problem.
Best Regards!
Alejandro
12,293 次查看
Embedded-world
Hi @Chavira@x85446
Now i got the issues with bmap-tools_git.bb source fetching so is there any proper source/repo link to resolve this error.
Ref Build log:
$ bitbake -f imx-image-full
Loading cache: 100% |#########################################################################################################################################################| Time: 0:00:00
Parsing recipes: 100% |#######################################################################################################################################################| Time: 0:00:01
TARGET_FPU           = "hard"
meta
meta-oe
meta-multimedia
meta-bsp
meta-sdk
meta-ml
meta-gnome
meta-networking
NOTE: Tainting hash to force rebuild of task /home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/sources/meta-imx/meta-sdk/dynamic-layers/qt6-layer/recipes-fsl/images/imx-image-full.bb, do_build
WARNING: /home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/sources/meta-imx/meta-sdk/dynamic-layers/qt6-layer/recipes-fsl/images/imx-image-full.bb:do_build is tainted from a forced run
Initialising tasks: 100% |####################################################################################################################################################| Time: 0:00:06
Sstate summary: Wanted 2424 Local 0 Mirrors 0 Missed 2424 Current 1026 (0% match, 29% complete)
WARNING: bmap-tools-native-3.6+gitAUTOINC+c0673962a8-r0 do_fetch: Failed to fetch URL git://github.com/intel/bmap-tools;branch=master;protocol=https, attempting MIRRORS if available
ERROR: bmap-tools-native-3.6+gitAUTOINC+c0673962a8-r0 do_fetch: Fetcher failure: Unable to find revision c0673962a8ec1624b5189dc1d24f33fe4f06785a in branch master even from upstream
ERROR: bmap-tools-native-3.6+gitAUTOINC+c0673962a8-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/intel/bmap-tools;branch=master;protocol=https')
ERROR: Logfile of failure stored in: /home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/build-xwayland/tmp/work/x86_64-linux/bmap-tools-native/3.6+gitAUTOINC+c0673962a8-r0/temp/log.do_fetch.853925
ERROR: Task (virtual:native:/home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/sources/poky/meta/recipes-support/bmap-tools/bmap-tools_git.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3519 tasks of which 3348 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 3 WARNING messages.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
Thanks & Regards,
Ravikumar
5,572 次查看
swathi
I'm also facing same issue, please help me with proper git commit hash ID to resolve it.
12,271 次查看
Embedded-world
Hi @Chavira,
I got an issue with the bmap-tools_git.bb file:
Solved: I just changed the branch for this.
Now, I'm getting a compile error for the linux-imx_5.15.bb file.
Ref Log Error:
ERROR: Task (/home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/sources/meta-imx/meta-bsp/recipes-kernel/linux/linux-imx_5.15.bb:do_compile) failed with exit code '1'.
I've tried running bitbake imx-image-full multiple times, but the same error keeps appearing. Could you guide me on this issue or provide the appropriate upstream source to resolve it?
Thanks and regards,
Ravikumar
%3CLINGO-SUB%20id%3D%22lingo-sub-1978262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ebitbake%20%E6%9C%9F%E9%97%B4%E7%9A%84%20cracklib%20%E9%97%AE%E9%A2%98%20%3CTARGET%3E%3C%2FTARGET%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E5%B0%8A%E6%95%AC%E7%9A%84%E4%B8%93%E5%AE%B6%E4%BB%AC%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20meta-qt6%20%E5%8A%9F%E8%83%BD%E6%9E%84%E5%BB%BA%E5%9B%BE%E5%83%8F%EF%BC%8C%E4%BD%86%E5%9C%A8%20Bitbake%20%E6%89%A7%E8%A1%8C%E6%9C%9F%E9%97%B4%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E3%80%82%E5%B0%BD%E7%AE%A1%E5%A4%9A%E6%AC%A1%E5%B0%9D%E8%AF%95%EF%BC%8C%E9%97%AE%E9%A2%98%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E4%B8%8B%E9%9D%A2%E6%8F%90%E5%88%B0%E7%9A%84%E9%94%99%E8%AF%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ecalixto-systems%40calixtosystems-HP-Notebook%3A%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fbuild-xwayland%24%20bitbake%20imx-image-full%0AWARNING%3A%20You%20have%20included%20the%20meta-virtualization%20layer%2C%20but%20'virtualization'%20has%20not%20been%20enabled%20in%20your%20DISTRO_FEATURES.%20Some%20bbappend%20files%20may%20not%20take%20effect.%20See%20the%20meta-virtualization%20README%20for%20details%20on%20enabling%20virtualization%20support.%0ALoading%20cache%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A01%0ALoaded%204742%20entries%20from%20dependency%20cache.%0AParsing%20recipes%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A01%0AParsing%20of%203195%20.bb%20files%20complete%20(3194%20cached%2C%201%20parsed).%204743%20targets%2C%20371%20skipped%2C%203%20masked%2C%200%20errors.%0ANOTE%3A%20Resolving%20any%20missing%20task%20queue%20dependencies%0A%0ABuild%20Configuration%3A%0ABB_VERSION%20%20%20%20%20%20%20%20%20%20%20%3D%20%222.0.0%22%0ABUILD_SYS%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22x86_64-linux%22%0ANATIVELSBSTRING%20%20%20%20%20%20%3D%20%22universal%22%0ATARGET_SYS%20%20%20%20%20%20%20%20%20%20%20%3D%20%22arm-poky-linux-gnueabi%22%0AMACHINE%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22imx6ull-versa256%22%0ADISTRO%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22fsl-imx-xwayland%22%0ADISTRO_VERSION%20%20%20%20%20%20%20%3D%20%225.15-kirkstone%22%0ATUNE_FEATURES%20%20%20%20%20%20%20%20%3D%20%22arm%20vfp%20cortexa7%20neon%20thumb%20callconvention-hard%22%0ATARGET_FPU%20%20%20%20%20%20%20%20%20%20%20%3D%20%22hard%22%0Ameta%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-poky%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3A24a3f7b3648185e33133f5d96b184a6cb6524f3d%22%0Ameta-oe%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-multimedia%20%20%20%20%20%20%0Ameta-python%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3A744a4b6eda88b9a9ca1cf0df6e18be384d9054e3%22%0Ameta-freescale%20%20%20%20%20%20%20%3D%20%22HEAD%3Ac82d4634e7aba8bc0de73ce1dfc997b630051571%22%0Ameta-freescale-3rdparty%20%3D%20%22HEAD%3A5977197340c7a7db17fe3e02a4e014ad997565ae%22%0Ameta-freescale-distro%20%3D%20%22HEAD%3Ad5bbb487b2816dfc74984a78b67f7361ce404253%22%0Ameta-calixto-nxp%20%20%20%20%20%3D%20%22HEAD%3Ac547c4347d887a7212bd3d306f0601c21ff36d65%22%0Ameta-bsp%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-sdk%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-ml%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-v2x%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3Aca68ab5d25322b51f54564275c84ab8de3c74ea6%22%0Ameta-nxp-demo-experience%20%3D%20%22HEAD%3A52eaf8bf42f8eda2917a1c8c046003c8c2c8f629%22%0Ameta-chromium%20%20%20%20%20%20%20%20%3D%20%22HEAD%3Ae232c2e21b96dc092d9af8bea4b3a528e7a46dd6%22%0Ameta-clang%20%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3Ac728c3f9168c8a4ed05163a51dd48ca1ad8ac21d%22%0Ameta-gnome%20%20%20%20%20%20%20%20%20%20%20%0Ameta-networking%20%20%20%20%20%20%0Ameta-filesystems%20%20%20%20%20%3D%20%22HEAD%3A744a4b6eda88b9a9ca1cf0df6e18be384d9054e3%22%0Ameta-qt6%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3Aed785a25d12e365d1054700d4fc94a053176eb14%22%0Ameta-virtualization%20%20%3D%20%22HEAD%3A9482648daf0bb42ff3475e7892542cf99f3b8d48%22%0A%0AInitialising%20tasks%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A13%0ASstate%20summary%3A%20Wanted%203349%20Local%200%20Mirrors%200%20Missed%203349%20Current%20101%20(0%25%20match%2C%202%25%20complete)%0ANOTE%3A%20Executing%20Tasks%0AWARNING%3A%20cracklib-2.9.8-r0%20do_fetch%3A%20Failed%20to%20fetch%20URL%20git%3A%2F%2Fgithub.com%2Fcracklib%2Fcracklib%3Bprotocol%3Dhttps%3Bbranch%3Dmaster%2C%20attempting%20MIRRORS%20if%20available%0AERROR%3A%20cracklib-2.9.8-r0%20do_fetch%3A%20Fetcher%20failure%3A%20Unable%20to%20find%20revision%20d9e8f9f47718539aeba80f90f4e072549926dc9c%20in%20branch%20master%20even%20from%20upstream%0AERROR%3A%20cracklib-2.9.8-r0%20do_fetch%3A%20Bitbake%20Fetcher%20Error%3A%20FetchError('Unable%20to%20fetch%20URL%20from%20any%20source.'%2C%20'git%3A%2F%2Fgithub.com%2Fcracklib%2Fcracklib%3Bprotocol%3Dhttps%3Bbranch%3Dmaster')%0AERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fbuild-xwayland%2Ftmp%2Fwork%2Fcortexa7t2hf-neon-poky-linux-gnueabi%2Fcracklib%2F2.9.8-r0%2Ftemp%2Flog.do_fetch.919291%0AERROR%3A%20Task%20(%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-extended%2Fcracklib%2Fcracklib_2.9.8.bb%3Ado_fetch)%20failed%20with%20exit%20code%20'1'%0AWARNING%3A%20cracklib-native-2.9.8-r0%20do_fetch%3A%20Failed%20to%20fetch%20URL%20git%3A%2F%2Fgithub.com%2Fcracklib%2Fcracklib%3Bprotocol%3Dhttps%3Bbranch%3Dmaster%2C%20attempting%20MIRRORS%20if%20available%0AERROR%3A%20cracklib-native-2.9.8-r0%20do_fetch%3A%20Fetcher%20failure%3A%20Unable%20to%20find%20revision%20d9e8f9f47718539aeba80f90f4e072549926dc9c%20in%20branch%20master%20even%20from%20upstream%0AERROR%3A%20cracklib-native-2.9.8-r0%20do_fetch%3A%20Bitbake%20Fetcher%20Error%3A%20FetchError('Unable%20to%20fetch%20URL%20from%20any%20source.'%2C%20'git%3A%2F%2Fgithub.com%2Fcracklib%2Fcracklib%3Bprotocol%3Dhttps%3Bbranch%3Dmaster')%0AERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fbuild-xwayland%2Ftmp%2Fwork%2Fx86_64-linux%2Fcracklib-native%2F2.9.8-r0%2Ftemp%2Flog.do_fetch.930524%0AERROR%3A%20Task%20(virtual%3Anative%3A%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-extended%2Fcracklib%2Fcracklib_2.9.8.bb%3Ado_fetch)%20failed%20with%20exit%20code%20'1'%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%98%E8%AF%B7%E5%88%86%E4%BA%AB%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%93%BE%E6%8E%A5%E4%BB%A5%E8%8E%B7%E5%8F%96%E4%B8%8A%E8%BF%B0%E7%9B%B8%E5%BA%94%E7%9A%84%20repo%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%E6%8B%89%E7%BB%B4%E5%BA%93%E9%A9%AC%E5%B0%94%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20cracklib%20issues%20during%20the%20bitbake%20%26lt%3Btarget%26gt%3B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%20git%20%E6%8F%90%E4%BA%A4%E5%93%88%E5%B8%8C%20ID%20%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E3%80%82%3C%2FLINGO-BODY%3E%3C%2FLINGO-SUB%3E
