cracklib issues during the bitbake <target>
Embedded-world
Dear Experts,
I am trying to build an image with the meta-qt6 feature, but during the Bitbake execution, I encountered the following error. Despite multiple attempts, the issue persists. Could you please help me resolve the error mentioned below?
calixto-systems@calixtosystems-HP-Notebook:/media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/build-xwayland$ bitbake imx-image-full
WARNING: You have included the meta-virtualization layer, but 'virtualization' has not been enabled in your DISTRO_FEATURES. Some bbappend files may not take effect. See the meta-virtualization README for details on enabling virtualization support.
Loading cache: 100% |##########################################################################################################| Time: 0:00:01
Loaded 4742 entries from dependency cache.
Parsing recipes: 100% |########################################################################################################| Time: 0:00:01
Parsing of 3195 .bb files complete (3194 cached, 1 parsed). 4743 targets, 371 skipped, 3 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION           = "2.0.0"
BUILD_SYS            = "x86_64-linux"
NATIVELSBSTRING      = "universal"
TARGET_SYS           = "arm-poky-linux-gnueabi"
MACHINE              = "imx6ull-versa256"
DISTRO               = "fsl-imx-xwayland"
DISTRO_VERSION       = "5.15-kirkstone"
TUNE_FEATURES        = "arm vfp cortexa7 neon thumb callconvention-hard"
TARGET_FPU           = "hard"
meta
meta-poky            = "HEAD:24a3f7b3648185e33133f5d96b184a6cb6524f3d"
meta-oe
meta-multimedia
meta-python          = "HEAD:744a4b6eda88b9a9ca1cf0df6e18be384d9054e3"
meta-freescale       = "HEAD:c82d4634e7aba8bc0de73ce1dfc997b630051571"
meta-freescale-3rdparty = "HEAD:5977197340c7a7db17fe3e02a4e014ad997565ae"
meta-freescale-distro = "HEAD:d5bbb487b2816dfc74984a78b67f7361ce404253"
meta-calixto-nxp     = "HEAD:c547c4347d887a7212bd3d306f0601c21ff36d65"
meta-bsp
meta-sdk
meta-ml
meta-v2x             = "HEAD:ca68ab5d25322b51f54564275c84ab8de3c74ea6"
meta-nxp-demo-experience = "HEAD:52eaf8bf42f8eda2917a1c8c046003c8c2c8f629"
meta-chromium        = "HEAD:e232c2e21b96dc092d9af8bea4b3a528e7a46dd6"
meta-clang           = "HEAD:c728c3f9168c8a4ed05163a51dd48ca1ad8ac21d"
meta-gnome
meta-networking
meta-filesystems     = "HEAD:744a4b6eda88b9a9ca1cf0df6e18be384d9054e3"
meta-qt6             = "HEAD:ed785a25d12e365d1054700d4fc94a053176eb14"
meta-virtualization  = "HEAD:9482648daf0bb42ff3475e7892542cf99f3b8d48"
Initialising tasks: 100% |#####################################################################################################| Time: 0:00:13
Sstate summary: Wanted 3349 Local 0 Mirrors 0 Missed 3349 Current 101 (0% match, 2% complete)
NOTE: Executing Tasks
WARNING: cracklib-2.9.8-r0 do_fetch: Failed to fetch URL git://github.com/cracklib/cracklib;protocol=https;branch=master, attempting MIRRORS if available
ERROR: cracklib-2.9.8-r0 do_fetch: Fetcher failure: Unable to find revision d9e8f9f47718539aeba80f90f4e072549926dc9c in branch master even from upstream
ERROR: cracklib-2.9.8-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/cracklib/cracklib;protocol=https;branch=master')
ERROR: Logfile of failure stored in: /media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/build-xwayland/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/cracklib/2.9.8-r0/temp/log.do_fetch.919291
ERROR: Task (/media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/sources/poky/meta/recipes-extended/cracklib/cracklib_2.9.8.bb:do_fetch) failed with exit code '1'
WARNING: cracklib-native-2.9.8-r0 do_fetch: Failed to fetch URL git://github.com/cracklib/cracklib;protocol=https;branch=master, attempting MIRRORS if available
ERROR: cracklib-native-2.9.8-r0 do_fetch: Fetcher failure: Unable to find revision d9e8f9f47718539aeba80f90f4e072549926dc9c in branch master even from upstream
ERROR: cracklib-native-2.9.8-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/cracklib/cracklib;protocol=https;branch=master')
ERROR: Logfile of failure stored in: /media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/build-xwayland/tmp/work/x86_64-linux/cracklib-native/2.9.8-r0/temp/log.do_fetch.930524
ERROR: Task (virtual:native:/media/drive_A/eagle/nxp-linux-platform/yocto/calixto-yocto-bsp/sources/poky/meta/recipes-extended/cracklib/cracklib_2.9.8.bb:do_fetch) failed with exit code '1'
also Please share proper link to fetch the above respective repo.
Ravikumar
x85446
Its a problem of the cracklib changing their github from master to main.
hack: after you get the error (or before on a clean machine), dive into the code, and change master to main
$editor ./layers/openembedded-core/meta/recipes-extended/cracklib/cracklib_2.9.8.bb
SRC_URI = "git://github.com/cracklib/cracklib;protocol=https;branch=master \
           file://0001-packlib.c-support-dictionary-byte-order-dependent.patch \
           file://0002-craklib-fix-testnum-and-teststr-failed.patch \
SRC_URI = "git://github.com/cracklib/cracklib;protocol=https;branch=main \
higher quality fix:  write a bbappend, that changes the SRC_URI... Like we did here back in the day when runc did the same master/main change...
Travis
Izuma Networks - lightest possible way to orchestrate kubernetes at the edge
Chavira
Hi  @Embedded-world!
Thank you for contacting NXP Support!
What BSP version are you using?
I will try to reproduce the error by my side.
Best Regards!
Chavira
Embedded-world
Hi Chavira
This is the BSP source i cloned for my build.
https://github.com/nxp-imx/meta-imx/tree/kirkstone-5.15.71-2.2.2
Thanks & Regards,
Ravikumar
TFSchuhmacher
Hello Chavira,
I have the same issue with cracklib-2.9.8
I am using a versalogic swordtail imx6 with kirkstone and manifest imx-5.15.71-2.2.2.xml
I tried also the "original" 5.15.32-2.0.0 with the same result:
NATIVELSBSTRING = "ubuntu-18.04"
MACHINE = "imx6swordtail"
TUNE_FEATURES = "arm vfp cortexa9 neon thumb callconvention-hard"
TARGET_FPU = "hard"
meta
meta-oe
meta-multimedia
meta-versalogic = "kirkstone:16df027b80ac33f80e9062bd8048e23d8e5dc2e1"
meta-bsp
meta-sdk
meta-ml
meta-gnome
meta-networking
NOTE: Fetching uninative binary shim http://downloads.yoctoproject.org/releases/uninative/3.7/x86_64-nativesdk-libc-3.7.tar.xz;sha256sum=... (will check PREMIRRORS first)
Initialising tasks: 100% |##############################################################################################################| Time: 0:00:03
Sstate summary: Wanted 1358 Local 0 Mirrors 0 Missed 1358 Current 0 (0% match, 0% complete)
ERROR: Logfile of failure stored in: /data/swordtail/v100/tmp/work/x86_64-linux/cracklib-native/2.9.8-r0/temp/log.do_fetch.14842
ERROR: Task (virtual:native:/data/swordtail/sources/poky/meta/recipes-extended/cracklib/cracklib_2.9.8.bb:do_fetch) failed with exit code '1'
ERROR: Logfile of failure stored in: /data/swordtail/v100/tmp/work/cortexa9t2hf-neon-poky-linux-gnueabi/cracklib/2.9.8-r0/temp/log.do_fetch.18742
ERROR: Task (/data/swordtail/sources/poky/meta/recipes-extended/cracklib/cracklib_2.9.8.bb:do_fetch) failed with exit code '1'
Thank you and best regards,
Thomas
x85446
Travis
Chavira
HI all!
As @x85446! mention, the problem is the name of the branch because cracklib doesn´t have master branch the library has instead main branch.
Changing the branch the line Yocto is able to fetch and compile the library without problem.
Best Regards!
Alejandro
Embedded-world
Hi @Chavira@x85446
Now i got the issues with bmap-tools_git.bb source fetching so is there any proper source/repo link to resolve this error.
Ref Build log:
$ bitbake -f imx-image-full
Loading cache: 100% |#########################################################################################################################################################| Time: 0:00:00
Parsing recipes: 100% |#######################################################################################################################################################| Time: 0:00:01
TARGET_FPU           = "hard"
meta
meta-oe
meta-multimedia
meta-bsp
meta-sdk
meta-ml
meta-gnome
meta-networking
NOTE: Tainting hash to force rebuild of task /home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/sources/meta-imx/meta-sdk/dynamic-layers/qt6-layer/recipes-fsl/images/imx-image-full.bb, do_build
WARNING: /home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/sources/meta-imx/meta-sdk/dynamic-layers/qt6-layer/recipes-fsl/images/imx-image-full.bb:do_build is tainted from a forced run
Initialising tasks: 100% |####################################################################################################################################################| Time: 0:00:06
Sstate summary: Wanted 2424 Local 0 Mirrors 0 Missed 2424 Current 1026 (0% match, 29% complete)
WARNING: bmap-tools-native-3.6+gitAUTOINC+c0673962a8-r0 do_fetch: Failed to fetch URL git://github.com/intel/bmap-tools;branch=master;protocol=https, attempting MIRRORS if available
ERROR: bmap-tools-native-3.6+gitAUTOINC+c0673962a8-r0 do_fetch: Fetcher failure: Unable to find revision c0673962a8ec1624b5189dc1d24f33fe4f06785a in branch master even from upstream
ERROR: bmap-tools-native-3.6+gitAUTOINC+c0673962a8-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'git://github.com/intel/bmap-tools;branch=master;protocol=https')
ERROR: Logfile of failure stored in: /home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/build-xwayland/tmp/work/x86_64-linux/bmap-tools-native/3.6+gitAUTOINC+c0673962a8-r0/temp/log.do_fetch.853925
ERROR: Task (virtual:native:/home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/sources/poky/meta/recipes-support/bmap-tools/bmap-tools_git.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3519 tasks of which 3348 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 3 WARNING messages.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
Thanks & Regards,
Ravikumar
swathi
I'm also facing same issue, please help me with proper git commit hash ID to resolve it.
Embedded-world
Hi @Chavira,
I got an issue with the bmap-tools_git.bb file:
Solved: I just changed the branch for this.
Now, I'm getting a compile error for the linux-imx_5.15.bb file.
Ref Log Error:
ERROR: Task (/home/calixto_admin/calixto_workdir/ravi/calixto-yocto-bsp/sources/meta-imx/meta-bsp/recipes-kernel/linux/linux-imx_5.15.bb:do_compile) failed with exit code '1'.
I've tried running bitbake imx-image-full multiple times, but the same error keeps appearing. Could you guide me on this issue or provide the appropriate upstream source to resolve it?
Thanks and regards,
Ravikumar
%3CLINGO-SUB%20id%3D%22lingo-sub-1978262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ecracklib%20issues%20during%20the%20bitbake%20%3CTARGET%3E%3C%2FTARGET%3E%3CLINGO-BODY%20id%3D%22lingo-body-1978262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EDear%20Experts%2C%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20build%20an%20image%20with%20the%20meta-qt6%20feature%2C%20but%20during%20the%20Bitbake%20execution%2C%20I%20encountered%20the%20following%20error.%20Despite%20multiple%20attempts%2C%20the%20issue%20persists.%20Could%20you%20please%20help%20me%20resolve%20the%20error%20mentioned%20below%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Ecalixto-systems%40calixtosystems-HP-Notebook%3A%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fbuild-xwayland%24%20bitbake%20imx-image-full%0AWARNING%3A%20You%20have%20included%20the%20meta-virtualization%20layer%2C%20but%20'virtualization'%20has%20not%20been%20enabled%20in%20your%20DISTRO_FEATURES.%20Some%20bbappend%20files%20may%20not%20take%20effect.%20See%20the%20meta-virtualization%20README%20for%20details%20on%20enabling%20virtualization%20support.%0ALoading%20cache%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A01%0ALoaded%204742%20entries%20from%20dependency%20cache.%0AParsing%20recipes%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A01%0AParsing%20of%203195%20.bb%20files%20complete%20(3194%20cached%2C%201%20parsed).%204743%20targets%2C%20371%20skipped%2C%203%20masked%2C%200%20errors.%0ANOTE%3A%20Resolving%20any%20missing%20task%20queue%20dependencies%0A%0ABuild%20Configuration%3A%0ABB_VERSION%20%20%20%20%20%20%20%20%20%20%20%3D%20%222.0.0%22%0ABUILD_SYS%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22x86_64-linux%22%0ANATIVELSBSTRING%20%20%20%20%20%20%3D%20%22universal%22%0ATARGET_SYS%20%20%20%20%20%20%20%20%20%20%20%3D%20%22arm-poky-linux-gnueabi%22%0AMACHINE%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22imx6ull-versa256%22%0ADISTRO%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22fsl-imx-xwayland%22%0ADISTRO_VERSION%20%20%20%20%20%20%20%3D%20%225.15-kirkstone%22%0ATUNE_FEATURES%20%20%20%20%20%20%20%20%3D%20%22arm%20vfp%20cortexa7%20neon%20thumb%20callconvention-hard%22%0ATARGET_FPU%20%20%20%20%20%20%20%20%20%20%20%3D%20%22hard%22%0Ameta%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-poky%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3A24a3f7b3648185e33133f5d96b184a6cb6524f3d%22%0Ameta-oe%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-multimedia%20%20%20%20%20%20%0Ameta-python%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3A744a4b6eda88b9a9ca1cf0df6e18be384d9054e3%22%0Ameta-freescale%20%20%20%20%20%20%20%3D%20%22HEAD%3Ac82d4634e7aba8bc0de73ce1dfc997b630051571%22%0Ameta-freescale-3rdparty%20%3D%20%22HEAD%3A5977197340c7a7db17fe3e02a4e014ad997565ae%22%0Ameta-freescale-distro%20%3D%20%22HEAD%3Ad5bbb487b2816dfc74984a78b67f7361ce404253%22%0Ameta-calixto-nxp%20%20%20%20%20%3D%20%22HEAD%3Ac547c4347d887a7212bd3d306f0601c21ff36d65%22%0Ameta-bsp%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-sdk%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-ml%20%20%20%20%20%20%20%20%20%20%20%20%20%20%0Ameta-v2x%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3Aca68ab5d25322b51f54564275c84ab8de3c74ea6%22%0Ameta-nxp-demo-experience%20%3D%20%22HEAD%3A52eaf8bf42f8eda2917a1c8c046003c8c2c8f629%22%0Ameta-chromium%20%20%20%20%20%20%20%20%3D%20%22HEAD%3Ae232c2e21b96dc092d9af8bea4b3a528e7a46dd6%22%0Ameta-clang%20%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3Ac728c3f9168c8a4ed05163a51dd48ca1ad8ac21d%22%0Ameta-gnome%20%20%20%20%20%20%20%20%20%20%20%0Ameta-networking%20%20%20%20%20%20%0Ameta-filesystems%20%20%20%20%20%3D%20%22HEAD%3A744a4b6eda88b9a9ca1cf0df6e18be384d9054e3%22%0Ameta-qt6%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20%22HEAD%3Aed785a25d12e365d1054700d4fc94a053176eb14%22%0Ameta-virtualization%20%20%3D%20%22HEAD%3A9482648daf0bb42ff3475e7892542cf99f3b8d48%22%0A%0AInitialising%20tasks%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A13%0ASstate%20summary%3A%20Wanted%203349%20Local%200%20Mirrors%200%20Missed%203349%20Current%20101%20(0%25%20match%2C%202%25%20complete)%0ANOTE%3A%20Executing%20Tasks%0AWARNING%3A%20cracklib-2.9.8-r0%20do_fetch%3A%20Failed%20to%20fetch%20URL%20git%3A%2F%2Fgithub.com%2Fcracklib%2Fcracklib%3Bprotocol%3Dhttps%3Bbranch%3Dmaster%2C%20attempting%20MIRRORS%20if%20available%0AERROR%3A%20cracklib-2.9.8-r0%20do_fetch%3A%20Fetcher%20failure%3A%20Unable%20to%20find%20revision%20d9e8f9f47718539aeba80f90f4e072549926dc9c%20in%20branch%20master%20even%20from%20upstream%0AERROR%3A%20cracklib-2.9.8-r0%20do_fetch%3A%20Bitbake%20Fetcher%20Error%3A%20FetchError('Unable%20to%20fetch%20URL%20from%20any%20source.'%2C%20'git%3A%2F%2Fgithub.com%2Fcracklib%2Fcracklib%3Bprotocol%3Dhttps%3Bbranch%3Dmaster')%0AERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fbuild-xwayland%2Ftmp%2Fwork%2Fcortexa7t2hf-neon-poky-linux-gnueabi%2Fcracklib%2F2.9.8-r0%2Ftemp%2Flog.do_fetch.919291%0AERROR%3A%20Task%20(%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-extended%2Fcracklib%2Fcracklib_2.9.8.bb%3Ado_fetch)%20failed%20with%20exit%20code%20'1'%0AWARNING%3A%20cracklib-native-2.9.8-r0%20do_fetch%3A%20Failed%20to%20fetch%20URL%20git%3A%2F%2Fgithub.com%2Fcracklib%2Fcracklib%3Bprotocol%3Dhttps%3Bbranch%3Dmaster%2C%20attempting%20MIRRORS%20if%20available%0AERROR%3A%20cracklib-native-2.9.8-r0%20do_fetch%3A%20Fetcher%20failure%3A%20Unable%20to%20find%20revision%20d9e8f9f47718539aeba80f90f4e072549926dc9c%20in%20branch%20master%20even%20from%20upstream%0AERROR%3A%20cracklib-native-2.9.8-r0%20do_fetch%3A%20Bitbake%20Fetcher%20Error%3A%20FetchError('Unable%20to%20fetch%20URL%20from%20any%20source.'%2C%20'git%3A%2F%2Fgithub.com%2Fcracklib%2Fcracklib%3Bprotocol%3Dhttps%3Bbranch%3Dmaster')%0AERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fbuild-xwayland%2Ftmp%2Fwork%2Fx86_64-linux%2Fcracklib-native%2F2.9.8-r0%2Ftemp%2Flog.do_fetch.930524%0AERROR%3A%20Task%20(virtual%3Anative%3A%2Fmedia%2Fdrive_A%2Feagle%2Fnxp-linux-platform%2Fyocto%2Fcalixto-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-extended%2Fcracklib%2Fcracklib_2.9.8.bb%3Ado_fetch)%20failed%20with%20exit%20code%20'1'%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3Ealso%20Please%20share%20proper%20link%20to%20fetch%20the%20above%20respective%20repo.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3ERegards%2C%3CBR%20%2F%3ERavikumar%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2168610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20cracklib%20issues%20during%20the%20bitbake%20%26lt%3Btarget%26gt%3B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2168610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI'm%20also%20facing%20same%20issue%2C%20please%20help%20me%20with%20proper%20git%20commit%20hash%20ID%20to%20resolve%20it.%3C%2FLINGO-BODY%3E%3C%2FLINGO-SUB%3E
