colour image not capture imx8mn processor from ar0521 sensor
1,209 次查看
khodifadlalit
i am working on imx8mn (part no:-MIMX8MN1CVTIZAA) processor. and camera sensor ar0521
i am successfully captured black and white image from sensor.
but now i want to captured color image from  sensor
i change the imx8-isi-cap.c file function,
mxc_isi_subdev_get_fmt(struct v4l2_subdev *sd,
struct v4l2_subdev_pad_config *cfg,
struct v4l2_subdev_format *fmt)
and
other function
static int mxc_isi_cap_g_fmt_mplane(struct file *file, void *fh,
struct v4l2_format *f)
give a color format
 pix->colorspace = V4L2_COLORSPACE_SRGB;
but i new for v4l2 and camera sensor driver so help me what are change required (imx8-isi-cap.c or imx8-mipi-csi2-sam.c or other file) need to change for capture colour image from camera sensor ar0521
thanks
1,203 次查看
joanxie
what capture format do you use? and what bsp version do you use?
1,197 次查看
khodifadlalit
i use capture format
src_fmt.pad = source_pad->index;
src_fmt.which = V4L2_SUBDEV_FORMAT_ACTIVE;
src_fmt.format.code = MEDIA_BUS_FMT_SGRBG8_1X8;
src_fmt.format.width = dst_f->width;//2592
src_fmt.format.height = dst_f->height;//1944
and i use  BSP is based on version 5.4.70
thanks
1,184 次查看
joanxie
how about use v4l2 to test?
v4l2-ctl -d /dev/videox --set-fmt-video=width=xx,height=xx,pixelformat=format --stream-mmap
replace x and format as your own request
