hi, Patel:
I can't find ldb_data.transfer_mode in our code , can you let me know which file i can change it . now our driver use ldb.c
Only place i can find set LDB_BIT_MAP_CH0_SPWG | LDB_BIT_MAP_CH1_SPWG is in ldb.c . the code is :
/* TODO: now only use SPWG data mapping for both channel */
reg &= ~(LDB_BIT_MAP_CH0_MASK | LDB_BIT_MAP_CH1_MASK);
reg |= LDB_BIT_MAP_CH0_SPWG | LDB_BIT_MAP_CH1_SPWG;
Thanks.
