building QtWebEngine5.7.0 on imx6qp board
1,153 次查看
lavakumars
hi,
I am trying to build QtWebEngine with Qt5.7 .
i am able to build the Qt_base and related dependencies but when i try to build the qtwebengine i am getting the following error :
"/home/pase/freescale/fsl-release-ivi/build-xwayland/tmp/sysroots/i686-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: fatal error: libQt5WebEngineCore.so.5.7.0: mmap: failed to allocate 2029845748 bytes for output file: Cannot allocate memory
Please also find the attached files helpful . and do suggest me the correct way of building.
Platfor: imx6qp sabre ai board.
             version :fsl-yocto-L4.1.15_1.1.0-ga.
Please suggest the answer.
Lavakumar S
Original Attachment has been moved to: log.do_compile.zip
Original Attachment has been moved to: log.do_compile.24188.zip
942 次查看
jimmychan
