bring up ar0544 with 8mp isp on android os
bingyan
Hi  @zoey_li
I need to bring up AR0544 on Android with imx8mp ISP support. Could you help?
Currently I have integrated driver, dtb, ISI lib, and after running camera app of Gallery, I met below error:
09-20 21:51:36.543 546 729 W CameraService: getConcurrentCameraIds: camera id 0 does not exist
09-20 21:51:36.545 1617 1617 W CAM_Camera2OneCamMgr: No back-facing camera found.
09-20 21:51:36.545 1617 1617 W CAM_Camera2OneCamMgr: No external camera found.
09-20 21:51:36.545 1617 1617 D CAM_Camera2OneCamMgr: Getting First FRONT Camera
09-20 21:51:36.545 1617 1617 W CAM_Camera2OneCamMgr: No front-facing camera found.
zoey_li
Hi @bingyan ,
As we discussed offline, to bring up new camera with 8MP ISP on Android OS, you can refer to the section 8 under i.MX Android Frequently Asked Questions - NXP Community.
Generally speaking that, you need to make sure the new sensor dtb/ko/so/cfg/xml/json to be configured correcly. You also need to make sure that the camera_name in camera_config_***.json file to be set correctly. For camera connected to csi0 and isp0, it should be viv_v4l20. And viv_v4l21 for camera connected to csi1 and isp1.
It's glad that you finally make ar0544 work now.
Zoey
zoey_li
Hi @bingyan ,
Zoey
bingyan
Hi @zoey_li
Thank you very much for the great support. Yes sensor works on imx8mp android OS now.
Bing
bingyan
update files and logs,
bingyan
modified the path of lib, still not work.
bingyan
after I did "adb push  device/nxp/imx8m/evk_8mp/camera_config_imx8mp-ar0544.json  /vendor/etc/configs/camera_config_imx8mp.json" and reboot, I got attached error log. I also attach the related setting files .
bingyan
[ 0.121688] platform 32e40000.csi: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a30000/ar0544_mipi@36
[ 7.770907] platform 32e40000.csi: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a30000/ar0544_mipi@36
[ 8.673559] enter ar0544_probe
[ 8.677403] ar0544 1-0036: No sensor pwdn pin available
[ 8.683356] ar0544 1-0036: No sensor reset pin available
[ 8.689405] ar0544 1-0036: supply DOVDD not found, using dummy regulator
[ 8.696943] ar0544 1-0036: supply DVDD not found, using dummy regulator
[ 8.704299] ar0544 1-0036: supply AVDD not found, using dummy regulator
[ 8.716036] ar0544_probe camera mipi ar0544, is found
[ 8.742620] mx8-img-md: Registered sensor subdevice: ar0544 1-0036 (1)
[ 8.749864] mx8-img-md: created link [ar0544 1-0036] => [mxc-mipi-csi2.0]
bingyan
I added json under  device/nxp/imx8m/evk_8mp/camera_config_imx8mp-ar0544.json
and after building I can get out/target/product/evk_8mp/vendor/etc/configs/camera_config_imx8mp-ar0544.json
but on board under path /vendor/etc/configs I can't see file camera_config_imx8mp-ar0544.json
bingyan
log
%3CLINGO-SUB%20id%3D%22lingo-sub-1960330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ebring%20up%20ar0544%20with%208mp%20isp%20on%20android%20os%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1960330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F171692%22%20target%3D%22_blank%22%3E%40zoey_li%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20need%20to%20bring%20up%20AR0544%20on%20Android%20with%20imx8mp%20ISP%20support.%20Could%20you%20help%3F%3C%2FP%3E%3CP%3ECurrently%20I%20have%20integrated%20driver%2C%20dtb%2C%20ISI%20lib%2C%20and%20after%20running%20camera%20app%20of%20Gallery%2C%20I%20met%20below%20error%3A%3C%2FP%3E%3CP%3E09-20%2021%3A51%3A36.543%20546%20729%20W%20CameraService%3A%20getConcurrentCameraIds%3A%20camera%20id%200%20does%20not%20exist%3CBR%20%2F%3E09-20%2021%3A51%3A36.545%201617%201617%20W%20CAM_Camera2OneCamMgr%3A%20No%20back-facing%20camera%20found.%3CBR%20%2F%3E09-20%2021%3A51%3A36.545%201617%201617%20W%20CAM_Camera2OneCamMgr%3A%20No%20external%20camera%20found.%3CBR%20%2F%3E09-20%2021%3A51%3A36.545%201617%201617%20D%20CAM_Camera2OneCamMgr%3A%20Getting%20First%20FRONT%20Camera%3CBR%20%2F%3E09-20%2021%3A51%3A36.545%201617%201617%20W%20CAM_Camera2OneCamMgr%3A%20No%20front-facing%20camera%20found.%3CBR%20%2F%3E09-20%2021%3A51%3A36.545%201617%201617%20W%20CAM_Camera2OneCamMgr%3A%20No%20external%20camera%20found.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1962398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20bring%20up%20ar0544%20with%208mp%20isp%20on%20android%20os%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F171692%22%20target%3D%22_blank%22%3E%40zoey_li%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20the%20great%20support.%20Yes%20sensor%20works%20on%20imx8mp%20android%20OS%20now.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBing%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1962394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20bring%20up%20ar0544%20with%208mp%20isp%20on%20android%20os%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962394%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F209073%22%20target%3D%22_blank%22%3E%40bingyan%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EAs%20we%20discussed%20offline%2C%20to%20bring%20up%20new%20camera%20with%208MP%20ISP%20on%20Android%20OS%2C%20you%20can%20refer%20to%20the%20section%208%20under%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-Android-Frequently-Asked-Questions%2Fta-p%2F1112713%22%20target%3D%22_blank%22%3Ei.MX%20Android%20Frequently%20Asked%20Questions%20-%20NXP%20Community.%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EGenerally%20speaking%20that%2C%20you%20need%20to%20make%20sure%20the%20new%20sensor%20dtb%2Fko%2Fso%2Fcfg%2Fxml%2Fjson%20to%20be%20configured%20correcly.%20You%20also%20need%20to%20make%20sure%20that%20the%20camera_name%20in%20camera_config_***.json%20file%20to%20be%20set%20correctly.%20For%20camera%20connected%20to%20csi0%20and%20isp0%2C%20it%20should%20be%26nbsp%3Bviv_v4l20.%20And%26nbsp%3Bviv_v4l21%20for%20camera%20connected%20to%20csi1%20and%20isp1.%3C%2FP%3E%0A%3CP%3EIt's%20glad%20that%20you%20finally%20make%20ar0544%20work%20now.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EZoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1960454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20bring%20up%20ar0544%20with%208mp%20isp%20on%20android%20os%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1960454%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eupdate%20files%20and%20logs%2C%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1960427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20bring%20up%20ar0544%20with%208mp%20isp%20on%20android%20os%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1960427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Emodified%20the%20path%20of%20lib%2C%20still%20not%20work.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1960384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20bring%20up%20ar0544%20with%208mp%20isp%20on%20android%20os%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1960384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eafter%20I%20did%20%22adb%20push%20%3CSPAN%3E%26nbsp%3Bdevice%2Fnxp%2Fimx8m%2Fevk_8mp%2Fcamera_config_imx8mp-ar0544.json%26nbsp%3B%26nbsp%3B%2Fvendor%2Fetc%2Fconfigs%2Fcamera_config_imx8mp.json%3C%2FSPAN%3E%22%20and%20reboot%2C%20I%20got%20attached%20error%20log.%20I%20also%20attach%20the%20related%20setting%20files%20.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1960356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20bring%20up%20ar0544%20with%208mp%20isp%20on%20android%20os%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1960356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%5B%200.121688%5D%20platform%2032e40000.csi%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4030800000%2Fi2c%4030a30000%2Far0544_mipi%4036%3CBR%20%2F%3E%5B%207.770907%5D%20platform%2032e40000.csi%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fsoc%400%2Fbus%4030800000%2Fi2c%4030a30000%2Far0544_mipi%4036%3CBR%20%2F%3E%5B%208.673559%5D%20enter%20ar0544_probe%3CBR%20%2F%3E%5B%208.677403%5D%20ar0544%201-0036%3A%20No%20sensor%20pwdn%20pin%20available%3CBR%20%2F%3E%5B%208.683356%5D%20ar0544%201-0036%3A%20No%20sensor%20reset%20pin%20available%3CBR%20%2F%3E%5B%208.689405%5D%20ar0544%201-0036%3A%20supply%20DOVDD%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E%5B%208.696943%5D%20ar0544%201-0036%3A%20supply%20DVDD%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E%5B%208.704299%5D%20ar0544%201-0036%3A%20supply%20AVDD%20not%20found%2C%20using%20dummy%20regulator%3CBR%20%2F%3E%5B%208.716036%5D%20ar0544_probe%20camera%20mipi%20ar0544%2C%20is%20found%3CBR%20%2F%3E%5B%208.742620%5D%20mx8-img-md%3A%20Registered%20sensor%20subdevice%3A%20ar0544%201-0036%20(1)%3CBR%20%2F%3E%5B%208.749864%5D%20mx8-img-md%3A%20created%20link%20%5Bar0544%201-0036%5D%20%3D%26gt%3B%20%5Bmxc-mipi-csi2.0%5D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1960351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20bring%20up%20ar0544%20with%208mp%20isp%20on%20android%20os%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1960351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20added%20json%20under%26nbsp%3B%20device%2Fnxp%2Fimx8m%2Fevk_8mp%2Fcamera_config_imx8mp-ar0544.json%3C%2FP%3E%3CP%3Eand%20after%20building%20I%20can%20get%26nbsp%3Bout%2Ftarget%2Fproduct%2Fevk_8mp%2Fvendor%2Fetc%2Fconfigs%2Fcamera_config_imx8mp-ar0544.json%3C%2FP%3E%3CP%3Ebut%20on%20board%20under%20path%26nbsp%3B%2Fvendor%2Fetc%2Fconfigs%20I%20can't%20see%20file%26nbsp%3Bcamera_config_imx8mp-ar0544.json%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1960333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20bring%20up%20ar0544%20with%208mp%20isp%20on%20android%20os%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1960333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Elog%3C%2FP%3E%3C%2FLINGO-BODY%3E
