bootloader jump works with debug image but not with release
1,718 次查看
OM120
we have a bootloader that performs a simple jump to a certain address in the flash, it works perfectly fine with the debug image (axf) but with release without changing anything we get these errors:
4 回复数
1,679 次查看
Bio_TICFSL
That happens at moment of compiling or happens when you try the program on the board, since the error log is from your debugger I mean you miss something in the process.
1,677 次查看
OM120
it happens when running the program right after calling the jump function
1,659 次查看
Bio_TICFSL
I can not reproduce it here, but you might build your code again without debug symbols.
1,599 次查看
OM120
by "build your code again without debug symbols." do you mean to change debug level to none ?
