boot.scr
boot.scr
10,586件の閲覧回数
Afeefah
The boot process failed to load boot.scr. Getting a print "Failed to load 'boot.scr'" while booting device.
10 返答(返信)
10,569件の閲覧回数
Afeefah
I'm using imx6ull and BSP version is 5.15.52
10,572件の閲覧回数
Rita_Wang
Can you tell us which board and which version BSP are you using?
10,553件の閲覧回数
Afeefah
Hi Nxp community,
I'm using 5.15.52 BSP version and iMx6ull board. The booting gets completed but failure prints are observed. Could you please let me know what is causing this? Also please let me know how I can solve this.
Thank you,
Afeefah Fathima
10,547件の閲覧回数
Rita_Wang
can you share the boot log file to us?
10,541件の閲覧回数
Rita_Wang
Are you using the NXP reference board or the board you designed yourself? Here ignore this information, your kernel can not boot up success and the boot.scr can not cause your kernel can not boot.
Can you share us your boot command for the kernel boot? When u-boot boot up, press print and share us your boot command for the kernel boot.
10,528件の閲覧回数
Afeefah
We have our own board in which we are using NXP's iMx6ull processor. I have shared details about kernel boot.
10,517件の閲覧回数
Rita_Wang
you can try to add the earlycon=ec_imx6q,uart baseaddress,115200 in your boot command mmcargs.
For the uart baseaddress you need to confirm your use.
10,510件の閲覧回数
Afeefah
Hi @Rita_Wang
The value for earlycon is already set as
bootargs = "console=ttymxc2,115200 earlycon=ec_imx6q,0x30880000,115200";
what could be the other possibilities? Is there any other suggestion.
10,536件の閲覧回数
Afeefah
Below is the screenshot attached of boot log.
8,437件の閲覧回数
chillinwithscb
Since the kernel loads, I wonder whether the message about boot.scr is important or not.
