boot from spi flash problem
1,420 次查看
wangcuixmwangcu
I designed imx6q to boot from spi flash. I did the following work:
1. BT_CFG1 [7:0]: 0011xxxx
2.BT_CFG4 [5:3]: 011
3.boot_mode1,boot_mode0:   10
All the changes are through the hardware.
Is it ok to modify this?
1,352 次查看
joanxie
what reference board do you use?? Sabre SD board or Sabre AI board?
