android 4.4.2 hangs at free init memory
thangameenaraje
hi
ng s
i am working in sololite processor. i have custom board.. i am using sd1 as boot. 4 bit. 4.4.2 kitkat
i done the configuration as
https://community.freescale.com/message/455683#455683
my doubt is init file is not executing
how to execute..
Original Attachment has been moved to: mylogsd.txt.zip
GregDyess
EVERY time I have seen this it was due to the fstab file not being set up correctly causing the root file system to not be mounted.
thangameenaraje
ya i verified my myandroid/device/fsl/evk_sl/fstab.freescale file  more times.. eventhough i stuck with this.
i will attach my
