about bitbake fsl-image-validation-imx -c populate_sdk
9,394 次查看
848351313
I get the following error when I create the SDK, the cmd line is :
DISTRO=fsl-imx-wayland MACHINE=imx8mqevk source fsl-setup-release.sh -b imx8m_build/
Transaction Summary
Install  1035 Packages
Total size: 555 M
Installed size: 3.3 G
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Error: Transaction check error:
  file /etc/bluetooth/firmware.conf from install of linux-firmware-qca-1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0.noarch conflicts with file from package firmware-qca6174-2.0.3-r0.noarch
Error Summary
ERROR: fsl-image-validation-imx-1.0-r0 do_populate_sdk: Function failed: do_populate_sdk
ERROR: Logfile of failure stored in: /media/y/data/imx_yocto-bsp/imx8m_build/tmp/work/imx8mqevk-poky-linux/fsl-image-validation-imx/1.0-r0/temp/log.do_populate_sdk.22941
ERROR: Task (/media/y/data/imx_yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-sdk/recipes-fsl/images/fsl-image-validation-imx.bb:do_populate_sdk) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6158 tasks of which 6157 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
8,682 次查看
yann_morvan
I am also having this problem, using:
DISTRO=fsl-imx-xwayland MACHINE=imx8mmevk
bitbake fsl-image-gui -c populate_sdk
bitbake fsl-image-gui succeeds
bitbake meta-toolchain also succeeds, but is not a solution because our image will have additional features and the meta-toolchain recipe will not include the header files and libraries for these in the SDK
I am using Yocto Sumo on Debian 9.
Here is the logfile of the failure (of task do_populate_sdk):
DEBUG: Executing python function sstate_task_prefunc
DEBUG: Python function sstate_task_prefunc finished
DEBUG: Executing python function extend_recipe_sysroot
NOTE: Direct dependencies are ['/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/mklibs/mklibs-native_0.1.43.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-extended/pbzip2/pbzip2_1.1.13.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/opkg/opkg_0.3.6.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/prelink/prelink_git.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_0.3.6.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-extended/pigz/pigz_2.4.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.3.bb:do_populate_sysroot', 'virtual:nativesdk:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-core/glibc/glibc-locale_2.27.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/rpm/rpm_4.14.1.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/createrepo-c/createrepo-c_git.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-core/update-rc.d/update-rc.d_0.7.bb:do_populate_sysroot', '/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/dnf/dnf_2.7.5.bb:do_populate_sysroot', 'virtual:native:/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', '/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-core/glibc/cross-localedef-native_2.27.bb:do_populate_sysroot', '/data/blackbox/imx-yocto-bsp/sources/poky/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_populate_sysroot']
NOTE: Installed into sysroot: []
NOTE: Skipping as already exists in sysroot: ['mklibs-native', 'pbzip2-native', 'opkg-native', 'prelink-native', 'opkg-utils-native', 'makedevs-native', 'pigz-native', 'xz-native', 'nativesdk-glibc-locale', 'rpm-native', 'createrepo-c-native', 'update-rc.d-native', 'qemuwrapper-cross', 'dnf-native', 'pseudo-native', 'cross-localedef-native', 'ldconfig-native', 'libtool-native', 'gettext-minimal-native', 'gnu-config-native', 'automake-native', 'autoconf-native', 'quilt-native', 'systemd-systemctl-native', 'gtk-icon-utils-native', 'gdk-pixbuf-native', 'qemu-native', 'bzip2-native', 'nativesdk-linux-libc-headers', 'curl-native', 'zlib-native', 'expat-native', 'pkgconfig-native', 'python3-native', 'file-native', 'libxml2-native', 'sqlite3-native', 'ninja-native', 'glib-2.0-native', 'openssl-native', 'cmake-native', 'shadow-native', 'libsolv-native', 'libarchive-native', 'kmod-native', 'depmodwrapper-cross', 'debianutils-native', 'popt-native', 'dbus-native', 'db-native', 'elfutils-native', 'nss-native', 'mkfontdir-native', 'mkfontscale-native', 'binutils-native', 'libdnf-native', 'librepo-native', 'python3-iniparse-native', 'libcomps-native', 'texinfo-dummy-native', 'm4-native', 'librsvg-native', 'gobject-introspection-native', 'gtk-doc-native', 'libjpeg-turbo-native', 'shared-mime-info-native', 'libpng-native', 'alsa-lib-native', 'dtc-native', 'libsdl-native', 'pixman-native', 'gdbm-native', 'readline-native', 're2c-native', 'libffi-native', 'libpcre-native', 'util-linux-native', 'e2fsprogs-native', 'lzo-native', 'autoconf-archive-native', 'nspr-native', 'libx11-native', 'util-macros-native', 'xproto-native', 'libfontenc-native', 'freetype-native', 'bison-native', 'flex-native', 'libcheck-native', 'gpgme-native', 'attr-native', 'python3-six-native', 'pango-native', 'libcroco-native', 'cairo-native', 'intltool-native', 'libxrandr-native', 'libxrender-native', 'libxext-native', 'ncurses-native', 'kbproto-native', 'xtrans-native', 'xextproto-native', 'inputproto-native', 'libxcb-native', 'font-util-native', 'swig-native', 'libassuan-native', 'libgpg-error-native', 'python3-setuptools-native', 'harfbuzz-native', 'libxft-native', 'fontconfig-native', 'libsm-native', 'gettext-native', 'libxml-parser-perl-native', 'randrproto-native', 'renderproto-native', 'libxdmcp-native', 'xcb-proto-native', 'libpthread-stubs-native', 'libxau-native', 'unzip-native', 'icu-native', 'gperf-native', 'libice-native', 'perl-native']
DEBUG: Python function extend_recipe_sysroot finished
DEBUG: Executing python function do_populate_sdk
NOTE: Initializing intercept dir for /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux
NOTE: Installing TARGET packages
NOTE: Executing '/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/createrepo_c --update -q /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/oe-sdk-repo' ...
NOTE: Running /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/dnf -y -c /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/dnf/dnf.conf --setopt=reposdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/yum.repos.d --repofrompath=oe-repo,/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/oe-sdk-repo --installroot=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --setopt=logdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/temp makecache --refresh
NOTE: Added oe-repo repo from /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/oe-sdk-repo
oe-repo 263 MB/s | 3.4 MB 00:00
Last metadata expiration check: 0:00:00 ago on Thu 23 Jan 2020 12:02:11 PM UTC.
Metadata cache created.
NOTE: Running /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/dnf -y -c /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/dnf/dnf.conf --setopt=reposdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/yum.repos.d --repofrompath=oe-repo,/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/oe-sdk-repo --installroot=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --setopt=logdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/temp --nogpgcheck install packagegroup-core-ssh-dropbear packagegroup-fsl-gstreamer1.0 packagegroup-core-nfs-server packagegroup-base-extended packagegroup-fsl-tools-gpu-external packagegroup-core-boot packagegroup-core-tools-debug packagegroup-fsl-gstreamer1.0-full packagegroup-core-tools-profile packagegroup-fsl-tools-benchmark weston-init packagegroup-fsl-tools-audio packagegroup-core-tools-testapps target-sdk-provides-dummy psplash run-postinsts packagegroup-tools-bluetooth packagegroup-fsl-optee-imx weston-xwayland xterm packagegroup-core-full-cmdline packagegroup-fsl-tools-gpu packagegroup-fsl-tools-testapps packagegroup-core-standalone-sdk-target
Last metadata expiration check: 0:00:01 ago on Thu 23 Jan 2020 12:02:11 PM UTC.
Dependencies resolved.
Package Arch Version Repository
Size
Installing:
imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-core-boot imx8mmevk 1.0-r17 oe-repo 5.7 k
noarch 1.0-r6 oe-repo 6.2 k
noarch 1.0-r2 oe-repo 5.6 k
noarch 1.0-r1 oe-repo 5.6 k
noarch 1.0-r8 oe-repo 6.0 k
noarch 1.0-r3 oe-repo 5.6 k
imx8mmevk 1.0-r3 oe-repo 5.8 k
imx8mmevk 1.0-r2 oe-repo 5.9 k
imx8mmevk 1.0-r0 oe-repo 5.9 k
noarch 1.0-r0 oe-repo 6.0 k
noarch 1.0-r0 oe-repo 5.6 k
noarch 1.0-r0 oe-repo 5.9 k
imx8mmevk 1.0-r0 oe-repo 5.7 k
imx8mmevk 1.0-r0 oe-repo 5.8 k
imx8mmevk 1.0-r0 oe-repo 6.4 k
psplash aarch64 0.1+git0+2015f7073e-r15
oe-repo 11 k
run-postinsts noarch 1.0-r10 oe-repo 8.6 k
sdk_provides_dummy_target 1.0-r0 oe-repo 5.8 k
weston-init noarch 1.0-r0 oe-repo 9.2 k
weston-xwayland aarch64_mx8mm 5.0.0.imx-r0 oe-repo 34 k
xterm aarch64 330-r0 oe-repo 179 k
Installing dependencies:
acl aarch64 2.2.52-r0 oe-repo 24 k
alsa-conf aarch64_mx8mm 1.1.5-r0 oe-repo 50 k
alsa-plugins-pulseaudio-conf
aarch64 1.1.5-r0 oe-repo 6.9 k
alsa-state imx8mmevk 0.2.0-r5 oe-repo 7.3 k
alsa-tools aarch64 1.1.5-r0 oe-repo 116 k
alsa-utils aarch64 1.1.5-r0 oe-repo 5.9 k
alsa-utils-aconnect aarch64 1.1.5-r0 oe-repo 11 k
alsa-utils-alsactl aarch64 1.1.5-r0 oe-repo 41 k
alsa-utils-alsaloop aarch64 1.1.5-r0 oe-repo 28 k
alsa-utils-alsamixer aarch64 1.1.5-r0 oe-repo 26 k
alsa-utils-alsatplg aarch64 1.1.5-r0 oe-repo 8.7 k
alsa-utils-alsaucm aarch64 1.1.5-r0 oe-repo 11 k
alsa-utils-amixer aarch64 1.1.5-r0 oe-repo 20 k
alsa-utils-aplay aarch64 1.1.5-r0 oe-repo 28 k
alsa-utils-aseqdump aarch64 1.1.5-r0 oe-repo 11 k
alsa-utils-aseqnet aarch64 1.1.5-r0 oe-repo 12 k
alsa-utils-iecset aarch64 1.1.5-r0 oe-repo 12 k
alsa-utils-midi aarch64 1.1.5-r0 oe-repo 22 k
alsa-utils-speakertest aarch64 1.1.5-r0 oe-repo 739 k
arm-compute-library aarch64 18.11+git0+64441b79b8-r0
oe-repo 1.6 M
at aarch64 3.1.20-r0 oe-repo 31 k
attr aarch64 2.4.47-r0 oe-repo 18 k
avahi-daemon aarch64 0.7-r0 oe-repo 54 k
babeltrace aarch64 1.5.4-r0 oe-repo 130 k
base-files imx8mmevk 3.0.14-r89 oe-repo 12 k
base-passwd aarch64 3.5.29-r0 oe-repo 7.1 k
bash aarch64 4.4.12-r0 oe-repo 358 k
bc aarch64 1.06-r3 oe-repo 41 k
blktool aarch64 4+7-r0 oe-repo 15 k
bluez5 aarch64 5.49-r0 oe-repo 695 k
bluez5-noinst-tools aarch64 5.49-r0 oe-repo 348 k
bluez5-obex aarch64 5.49-r0 oe-repo 131 k
bluez5-testtools aarch64 5.49-r0 oe-repo 33 k
bonnie++ aarch64 1.03e-r0 oe-repo 25 k
busybox aarch64 1.27.2-r0 oe-repo 305 k
bzip2 aarch64 1.0.6-r5 oe-repo 23 k
can-utils aarch64 0.0+gitr0+4c8fb05cb4-r0
oe-repo 73 k
connman aarch64 1.35-r0 oe-repo 258 k
connman-client aarch64 1.35-r0 oe-repo 35 k
connman-tests aarch64 1.35-r0 oe-repo 88 k
connman-tools aarch64 1.35-r0 oe-repo 21 k
consolekit aarch64 0.4.6-r0 oe-repo 74 k
coreutils aarch64 8.29-r0 oe-repo 665 k
cpio aarch64 2.12-r0 oe-repo 59 k
cpufrequtils aarch64 008-r5 oe-repo 19 k
cracklib aarch64 2.9.5-r0 oe-repo 225 k
cronie aarch64 1.5.1-r0 oe-repo 42 k
cryptodev-module imx8mmevk 1.9-r0 oe-repo 5.8 k
cryptodev-tests aarch64 1.9-r0 oe-repo 30 k
curl aarch64 7.61.0-r0 oe-repo 108 k
db aarch64 1:5.3.28-r1 oe-repo 385 k
dbench aarch64 4.0-r0 oe-repo 19 k
dbus-1 aarch64 1.12.2-r0 oe-repo 109 k
devil imx8mmevk 1.8.0-r0 oe-repo 189 k
diffutils aarch64 3.6-r0 oe-repo 108 k
dosfstools aarch64 4.1-r0 oe-repo 40 k
dropbear aarch64 2017.75-r0 oe-repo 108 k
e2fsprogs aarch64 1.43.8-r0 oe-repo 110 k
e2fsprogs-badblocks aarch64 1.43.8-r0 oe-repo 16 k
e2fsprogs-mke2fs aarch64 1.43.8-r0 oe-repo 48 k
e2fsprogs-resize2fs aarch64 1.43.8-r0 oe-repo 26 k
ed aarch64 1.14.2-r0 oe-repo 23 k
elfutils aarch64 0.170-r0 oe-repo 90 k
ethtool aarch64 4.13-r0 oe-repo 82 k
evtest aarch64 1.33+0+ab140a2dab-r0
oe-repo 15 k
expect aarch64 5.45.4-r0 oe-repo 150 k
fbset aarch64 2.1-r4 oe-repo 18 k
file aarch64 5.32-r0 oe-repo 235 k
findutils aarch64 4.6.0-r0 oe-repo 144 k
fio aarch64 2.9-r0 oe-repo 249 k
flex-libfl aarch64 2.6.0-r0 oe-repo 8.7 k
fontconfig-utils aarch64 2.12.6-r0 oe-repo 21 k
fsl-rc-local aarch64 1.0-r0 oe-repo 6.9 k
fstests aarch64_mx8mm 0.1+git0+e5939ff608-r0
oe-repo 28 k
fuser aarch64 23.0-r0 oe-repo 18 k
gawk aarch64 4.2.1-r0 oe-repo 249 k
gdb aarch64 8.0.1-r0 oe-repo 2.0 M
gdbserver aarch64 8.0.1-r0 oe-repo 135 k
glibc-gconv aarch64 2.27-r0 oe-repo 13 k
glibc-gconv-cp1252 aarch64 2.27-r0 oe-repo 10 k
glibc-gconv-ibm850 aarch64 2.27-r0 oe-repo 10 k
glibc-gconv-iso8859-1 aarch64 2.27-r0 oe-repo 9.3 k
glibc-gconv-iso8859-15 aarch64 2.27-r0 oe-repo 9.9 k
glibc-localedata-i18n aarch64 2.27-r0 oe-repo 9.7 k
glibc-localedata-i18n-ctype
aarch64 2.27-r0 oe-repo 22 k
glibc-localedata-iso14651-t1
aarch64 2.27-r0 oe-repo 6.9 k
glibc-localedata-iso14651-t1-common
aarch64 2.27-r0 oe-repo 38 k
glibc-localedata-translit-circle
aarch64 2.27-r0 oe-repo 8.6 k
glibc-localedata-translit-cjk-compat
glibc-localedata-translit-compat
aarch64 2.27-r0 oe-repo 14 k
glibc-localedata-translit-font
aarch64 2.27-r0 oe-repo 12 k
glibc-localedata-translit-fraction
aarch64 2.27-r0 oe-repo 7.3 k
glibc-localedata-translit-narrow
aarch64 2.27-r0 oe-repo 7.8 k
glibc-localedata-translit-neutral
aarch64 2.27-r0 oe-repo 11 k
glibc-localedata-translit-small
aarch64 2.27-r0 oe-repo 7.5 k
glibc-localedata-translit-wide
aarch64 2.27-r0 oe-repo 7.7 k
glibc-mtrace aarch64 2.27-r0 oe-repo 8.4 k
glmark2 aarch64_mx8mm 2017.07+0+ed20c633f1-r0
oe-repo 6.5 M
gobject-introspection aarch64 1.54.1-r0 oe-repo 459 k
gputop aarch64_mx8mm 6.2.4.p4.0-r0 oe-repo 27 k
grep aarch64 3.1-r0 oe-repo 94 k
gst-examples aarch64 0.0.1+git0+48247c6ab6-r0
oe-repo 29 k
gstreamer1.0 aarch64 1.14.4.imx-r0 oe-repo 705 k
gstreamer1.0-plugins-bad-accurip
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 11 k
gstreamer1.0-plugins-bad-adpcmdec
gstreamer1.0-plugins-bad-adpcmenc
gstreamer1.0-plugins-bad-aiff
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 23 k
gstreamer1.0-plugins-bad-asfmux
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 30 k
gstreamer1.0-plugins-bad-audiobuffersplit
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 13 k
gstreamer1.0-plugins-bad-audiofxbad
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 10 k
gstreamer1.0-plugins-bad-audiolatency
gstreamer1.0-plugins-bad-audiomixmatrix
gstreamer1.0-plugins-bad-audiovisualizers
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 17 k
gstreamer1.0-plugins-bad-autoconvert
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 16 k
gstreamer1.0-plugins-bad-bayer
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 14 k
gstreamer1.0-plugins-bad-bluez
gstreamer1.0-plugins-bad-bz2
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 12 k
gstreamer1.0-plugins-bad-camerabin
gstreamer1.0-plugins-bad-coloreffects
gstreamer1.0-plugins-bad-compositor
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 24 k
gstreamer1.0-plugins-bad-curl
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 34 k
gstreamer1.0-plugins-bad-dashdemux
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 55 k
gstreamer1.0-plugins-bad-debugutilsbad
gstreamer1.0-plugins-bad-decklink
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 43 k
gstreamer1.0-plugins-bad-dtls
gstreamer1.0-plugins-bad-dvb
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 41 k
gstreamer1.0-plugins-bad-dvbsuboverlay
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 26 k
gstreamer1.0-plugins-bad-dvdspu
gstreamer1.0-plugins-bad-faceoverlay
gstreamer1.0-plugins-bad-fbdevsink
gstreamer1.0-plugins-bad-festival
gstreamer1.0-plugins-bad-fieldanalysis
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 18 k
gstreamer1.0-plugins-bad-freeverb
gstreamer1.0-plugins-bad-frei0r
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 19 k
gstreamer1.0-plugins-bad-gaudieffects
gstreamer1.0-plugins-bad-gdp
gstreamer1.0-plugins-bad-geometrictransform
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 21 k
gstreamer1.0-plugins-bad-hls
gstreamer1.0-plugins-bad-id3tag
gstreamer1.0-plugins-bad-inter
gstreamer1.0-plugins-bad-interlace
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 15 k
gstreamer1.0-plugins-bad-ipcpipeline
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 31 k
gstreamer1.0-plugins-bad-ivfparse
gstreamer1.0-plugins-bad-ivtc
gstreamer1.0-plugins-bad-jp2kdecimator
gstreamer1.0-plugins-bad-jpegformat
gstreamer1.0-plugins-bad-kms
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 29 k
gstreamer1.0-plugins-bad-legacyrawparse
gstreamer1.0-plugins-bad-meta
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 9.3 k
gstreamer1.0-plugins-bad-midi
gstreamer1.0-plugins-bad-mpegpsdemux
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 36 k
gstreamer1.0-plugins-bad-mpegpsmux
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 22 k
gstreamer1.0-plugins-bad-mpegtsdemux
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 63 k
gstreamer1.0-plugins-bad-mpegtsmux
gstreamer1.0-plugins-bad-mxf
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 88 k
gstreamer1.0-plugins-bad-netsim
gstreamer1.0-plugins-bad-openglmixers
gstreamer1.0-plugins-bad-pcapparse
gstreamer1.0-plugins-bad-pnm
gstreamer1.0-plugins-bad-proxy
gstreamer1.0-plugins-bad-removesilence
gstreamer1.0-plugins-bad-rfbsrc
gstreamer1.0-plugins-bad-rsvg
gstreamer1.0-plugins-bad-rtponvif
gstreamer1.0-plugins-bad-sbc
gstreamer1.0-plugins-bad-sdpelem
gstreamer1.0-plugins-bad-segmentclip
gstreamer1.0-plugins-bad-shm
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 20 k
gstreamer1.0-plugins-bad-siren
gstreamer1.0-plugins-bad-smooth
gstreamer1.0-plugins-bad-smoothstreaming
gstreamer1.0-plugins-bad-sndfile
gstreamer1.0-plugins-bad-speed
gstreamer1.0-plugins-bad-stereo
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 9.9 k
gstreamer1.0-plugins-bad-subenc
gstreamer1.0-plugins-bad-timecode
gstreamer1.0-plugins-bad-ttmlsubs
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 38 k
gstreamer1.0-plugins-bad-uvch264
gstreamer1.0-plugins-bad-vcdsrc
gstreamer1.0-plugins-bad-videofiltersbad
gstreamer1.0-plugins-bad-videoframe-audiolevel
gstreamer1.0-plugins-bad-videoparsersbad
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 68 k
gstreamer1.0-plugins-bad-videosignal
gstreamer1.0-plugins-bad-vmnc
gstreamer1.0-plugins-bad-waylandsink
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 27 k
gstreamer1.0-plugins-bad-webp
gstreamer1.0-plugins-bad-y4mdec
gstreamer1.0-plugins-bad-yadif
gstreamer1.0-plugins-base-adder
gstreamer1.0-plugins-base-alsa
gstreamer1.0-plugins-base-app
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 8.5 k
gstreamer1.0-plugins-base-apps
gstreamer1.0-plugins-base-audioconvert
gstreamer1.0-plugins-base-audiomixer
gstreamer1.0-plugins-base-audiorate
gstreamer1.0-plugins-base-audioresample
gstreamer1.0-plugins-base-audiotestsrc
gstreamer1.0-plugins-base-encoding
gstreamer1.0-plugins-base-gio
gstreamer1.0-plugins-base-meta
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 7.1 k
gstreamer1.0-plugins-base-ogg
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 75 k
gstreamer1.0-plugins-base-opengl
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 58 k
gstreamer1.0-plugins-base-pango
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 32 k
gstreamer1.0-plugins-base-pbtypes
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 8.6 k
gstreamer1.0-plugins-base-playback
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 160 k
gstreamer1.0-plugins-base-rawparse
gstreamer1.0-plugins-base-subparse
gstreamer1.0-plugins-base-tcp
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 37 k
gstreamer1.0-plugins-base-theora
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 25 k
gstreamer1.0-plugins-base-typefindfunctions
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 39 k
gstreamer1.0-plugins-base-videoconvert
gstreamer1.0-plugins-base-videorate
gstreamer1.0-plugins-base-videoscale
gstreamer1.0-plugins-base-videotestsrc
gstreamer1.0-plugins-base-volume
gstreamer1.0-plugins-base-vorbis
gstreamer1.0-plugins-base-ximagesink
gstreamer1.0-plugins-base-xvimagesink
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 28 k
gstreamer1.0-plugins-good-alaw
gstreamer1.0-plugins-good-alpha
gstreamer1.0-plugins-good-alphacolor
gstreamer1.0-plugins-good-apetag
gstreamer1.0-plugins-good-audiofx
gstreamer1.0-plugins-good-audioparsers
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 50 k
gstreamer1.0-plugins-good-auparse
gstreamer1.0-plugins-good-autodetect
gstreamer1.0-plugins-good-avi
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 61 k
gstreamer1.0-plugins-good-cairo
gstreamer1.0-plugins-good-cutter
gstreamer1.0-plugins-good-debug
gstreamer1.0-plugins-good-deinterlace
gstreamer1.0-plugins-good-dtmf
gstreamer1.0-plugins-good-effectv
gstreamer1.0-plugins-good-equalizer
gstreamer1.0-plugins-good-flac
gstreamer1.0-plugins-good-flv
gstreamer1.0-plugins-good-flxdec
gstreamer1.0-plugins-good-gdkpixbuf
gstreamer1.0-plugins-good-goom
gstreamer1.0-plugins-good-goom2k1
gstreamer1.0-plugins-good-icydemux
gstreamer1.0-plugins-good-id3demux
gstreamer1.0-plugins-good-imagefreeze
gstreamer1.0-plugins-good-interleave
gstreamer1.0-plugins-good-isomp4
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 162 k
gstreamer1.0-plugins-good-jpeg
gstreamer1.0-plugins-good-level
gstreamer1.0-plugins-good-matroska
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 99 k
gstreamer1.0-plugins-good-meta
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 7.9 k
gstreamer1.0-plugins-good-mulaw
gstreamer1.0-plugins-good-multifile
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 51 k
gstreamer1.0-plugins-good-multipart
gstreamer1.0-plugins-good-navigationtest
gstreamer1.0-plugins-good-ossaudio
gstreamer1.0-plugins-good-png
gstreamer1.0-plugins-good-pulseaudio
gstreamer1.0-plugins-good-replaygain
gstreamer1.0-plugins-good-rtp
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 165 k
gstreamer1.0-plugins-good-rtpmanager
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 111 k
gstreamer1.0-plugins-good-rtsp
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 57 k
gstreamer1.0-plugins-good-shapewipe
gstreamer1.0-plugins-good-smpte
gstreamer1.0-plugins-good-soup
gstreamer1.0-plugins-good-spectrum
gstreamer1.0-plugins-good-speex
gstreamer1.0-plugins-good-taglib
gstreamer1.0-plugins-good-udp
gstreamer1.0-plugins-good-video4linux2
aarch64_mx8mm 1.14.4.imx-r0 oe-repo 89 k
gstreamer1.0-plugins-good-videobox
gstreamer1.0-plugins-good-videocrop
gstreamer1.0-plugins-good-videofilter
gstreamer1.0-plugins-good-videomixer
gstreamer1.0-plugins-good-wavenc
gstreamer1.0-plugins-good-wavparse
gstreamer1.0-plugins-good-ximagesrc
gstreamer1.0-plugins-good-y4menc
gstreamer1.0-rtsp-server aarch64 1.14.4-r0 oe-repo 5.8 k
gstreamer1.0-rtsp-server-rtspclientsink
aarch64 1.14.4-r0 oe-repo 34 k
gtk+3-demo aarch64_mx8mm 3.22.28-r0 oe-repo 734 k
gtkperf aarch64 0.40-r0 oe-repo 24 k
gzip aarch64 1.9-r0 oe-repo 48 k
hicolor-icon-theme noarch 0.17-r0 oe-repo 35 k
hostapd aarch64 2.6-r0 oe-repo 327 k
i2c-tools aarch64 4.0-r0 oe-repo 29 k
imx-codec-g.711 aarch64_mx8mm 4.4.5-r0 oe-repo 11 k
imx-codec-g.723.1 aarch64_mx8mm 4.4.5-r0 oe-repo 63 k
imx-codec-g.726 aarch64_mx8mm 4.4.5-r0 oe-repo 17 k
imx-codec-g.729ab aarch64_mx8mm 4.4.5-r0 oe-repo 57 k
imx-codec-nb aarch64_mx8mm 4.4.5-r0 oe-repo 103 k
imx-codec-test-bin aarch64_mx8mm 4.4.5-r0 oe-repo 62 k
imx-codec-test-source aarch64_mx8mm 4.4.5-r0 oe-repo 103 k
imx-codec-wb aarch64_mx8mm 4.4.5-r0 oe-repo 127 k
imx-gpu-apitrace aarch64_mx8mm 7.1.0-r0 oe-repo 769 k
imx-gpu-apitrace-bin aarch64_mx8mm 7.1.0-r0 oe-repo 545 k
imx-gpu-sdk aarch64_mx8mm 5.3.0-r0 oe-repo 36 M
imx-gpu-viv aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 5.6 k
imx-gpu-viv-demos aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 7.1 M
imx-gpu-viv-tools aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 31 k
imx-gst1.0-plugin aarch64_mx8mm 4.4.5-r0 oe-repo 168 k
imx-gst1.0-plugin-gplay aarch64_mx8mm 4.4.5-r0 oe-repo 18 k
imx-gst1.0-plugin-grecorder
aarch64_mx8mm 4.4.5-r0 oe-repo 12 k
imx-kobs aarch64 5.5+git0+02c01d4a3d-r0
oe-repo 75 k
imx-parser aarch64 4.4.5-r0 oe-repo 208 k
imx-test aarch64_mx8mm 1:7.0+0+d32727a9d7-r0
oe-repo 4.0 M
imx-vpu-hantro aarch64_mx8mm 1.11.0-r0 oe-repo 499 k
initscripts imx8mmevk 1.0-r155 oe-repo 22 k
initscripts-functions imx8mmevk 1.0-r155 oe-repo 7.6 k
iozone3 aarch64 465-r0 oe-repo 108 k
iperf3 aarch64 3.2-r0 oe-repo 50 k
iproute2 aarch64 4.14.1-r0 oe-repo 191 k
iptables aarch64 1.6.2-r0 oe-repo 216 k
iputils-arping aarch64 s20161105-r0 oe-repo 13 k
iputils-clockdiff aarch64 s20161105-r0 oe-repo 11 k
iputils-ping aarch64 s20161105-r0 oe-repo 29 k
iputils aarch64 s20161105-r0 oe-repo 5.8 k
iputils-tracepath aarch64 s20161105-r0 oe-repo 11 k
iputils-traceroute6 aarch64 s20161105-r0 oe-repo 12 k
iw aarch64 4.14-r0 oe-repo 60 k
kbd aarch64 2.0.4-r0 oe-repo 92 k
kernel-4.14.98-imx-4.14.98-2.0.0-ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 14 k
kernel-image-4.14.98-imx-4.14.98-2.0.0-ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 5.8 k
kernel-image-image-4.14.98-imx-4.14.98-2.0.0-ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 7.1 M
kernel-module-8021q-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 19 k
kernel-module-adc-keys-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 10 k
kernel-module-aes-neon-blk-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 13 k
kernel-module-aes-neon-bs-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-analogix-dp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 18 k
kernel-module-asix-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-at25-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 11 k
kernel-module-ax88179-178a-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 15 k
kernel-module-bcm-crypto-spu-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 28 k
kernel-module-bcm-sba-raid-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-bcm2835-dma-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-br-netfilter-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 16 k
kernel-module-brcmfmac-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 109 k
kernel-module-brcmutil-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 12 k
kernel-module-bridge-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 59 k
kernel-module-btrfs-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 369 k
kernel-module-cdc-ether-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-cdc-ncm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 17 k
kernel-module-cdc-subset-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.5 k
kernel-module-ch7006-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-chacha20-neon-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-cppc-cpufreq-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-crc32-ce-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-crct10dif-ce-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-crypto-engine-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-cryptodev-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 1.9-r0 oe-repo 23 k
kernel-module-cuse-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-dm9601-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-dw-drm-dsi-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-dwmac-generic-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-dwmac-ipq806x-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-dwmac-meson-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-dwmac-meson8b-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-dwmac-rk-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-dwmac-sun8i-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-dwmac-sunxi-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-exynos-gsc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 20 k
kernel-module-exynos-lpass-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.6 k
kernel-module-exynosdrm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 38 k
kernel-module-fuse-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 47 k
kernel-module-g-audio-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-g-cdc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-g-mass-storage-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-g-ncm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-g-zero-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-galcore-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 6.2.4.p4.0-r0 oe-repo 120 k
kernel-module-garp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-generic-bl-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.4 k
kernel-module-gspca-main-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 21 k
kernel-module-host1x-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 30 k
kernel-module-i2c-bcm2835-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-imx-gpu-viv
imx8mmevk 6.2.4.p4.0-r0 oe-repo 5.8 k
kernel-module-imx-rpmsg-pingpong-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.3 k
kernel-module-imx-rpmsg-tty-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-ina2xx-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-ip-tables-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-ip-tunnel-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-ip6-tables-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-ip6t-masquerade-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-ip6t-reject-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.7 k
kernel-module-ip6table-filter-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.9 k
kernel-module-ip6table-mangle-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-ip6table-nat-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-ipt-masquerade-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.8 k
kernel-module-ipt-reject-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-iptable-filter-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-iptable-mangle-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-iptable-nat-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-kirin-drm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-lcd-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-libcrc32c-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 8.8 k
kernel-module-lm90-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-lp855x-bl-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-macvlan-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-macvtap-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-marvell-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-mcs7830-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-mdt-loader-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-meson-drm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-meson-dw-hdmi-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-meson-gxbb-wdt-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-meson-gxl-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.2 k
kernel-module-meson-wdt-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-mrp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-msm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 144 k
kernel-module-nbd-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-net1080-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-conntrack-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 44 k
kernel-module-nf-conntrack-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-conntrack-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-defrag-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-defrag-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-log-common-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-log-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-log-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-nat-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-nat-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-nat-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-nat-masquerade-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-nat-masquerade-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-reject-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nf-reject-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nfs-layout-flexfiles-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-nouveau-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 466 k
kernel-module-nvme-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 23 k
kernel-module-nvme-core-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 24 k
kernel-module-overlay-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 33 k
kernel-module-pcie-rockchip-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-pegasus-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-phy-rockchip-pcie-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-plusb-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-pwm-bcm2835-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-pwm-cros-ec-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-pwm-meson-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-pwm-tegra-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-qcom-emac-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 22 k
kernel-module-r8152-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-raid6-pq-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 74 k
kernel-module-rcar-du-drm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-rcar-fcp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-realtek-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-renesas-usbhs-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-rockchip-saradc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-rockchip-thermal-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-rockchipdrm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-rtc-rk808-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-rtl8150-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-s5p-jpeg-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-s5p-mfc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 52 k
kernel-module-sha512-arm64-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-sil164-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-sit-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-smsc75xx-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-smsc95xx-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-snd-hwdep-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-snd-soc-bcm2835-i2s-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-snd-usb-audio-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 65 k
kernel-module-snd-usbmidi-lib-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-spi-bcm2835-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-spi-bcm2835aux-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-spi-meson-spicc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-spi-meson-spifc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-sr9800-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-stmmac-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 45 k
kernel-module-stmmac-platform-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-stp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.0 k
kernel-module-tap-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-tcrypt-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-tegra-drm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-ttm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-tunnel4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-usbtest-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-uvcvideo-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 42 k
kernel-module-vc4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 56 k
kernel-module-veth-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-virtio-crypto-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-vsp1-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 35 k
kernel-module-x-tables-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xen-netback-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xfrm6-mode-beet-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xfrm6-mode-transport-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xfrm6-mode-tunnel-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xor-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xt-addrtype-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xt-checksum-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 9.1 k
kernel-module-xt-conntrack-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xt-log-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xt-nat-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xt-tcpudp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-xxhash-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-zaurus-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-zstd-compress-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 4.14.98-r0 oe-repo 67 k
kernel-module-zstd-decompress-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kexec aarch64 2.0.16-r1 oe-repo 47 k
killall aarch64 23.0-r0 oe-repo 15 k
kmod aarch64 25+git0+aca4eca103-r0
oe-repo 53 k
kmscube aarch64_mx8mm git-r0 oe-repo 62 k
ldd aarch64 2.27-r0 oe-repo 8.6 k
less aarch64 529-r0 oe-repo 64 k
lib-aac-dec-arm-elinux3 aarch64_mx8mm 4.4.5-r0 oe-repo 70 k
lib-bsac-dec-arm-elinux2 aarch64_mx8mm 4.4.5-r0 oe-repo 97 k
lib-mp3-dec-arm-elinux2 aarch64_mx8mm 4.4.5-r0 oe-repo 50 k
lib-oggvorbis-dec-arm-elinux2
aarch64_mx8mm 4.4.5-r0 oe-repo 89 k
libacl1 aarch64 2.2.52-r0 oe-repo 17 k
libaio1 aarch64 0.3.110-r0 oe-repo 8.5 k
libasound-module-conf-pulse
aarch64 1.1.5-r0 oe-repo 8.5 k
libasound-module-ctl-pulse
aarch64 1.1.5-r0 oe-repo 13 k
libasound-module-pcm-pulse
aarch64 1.1.5-r0 oe-repo 14 k
libasound2 aarch64_mx8mm 1.1.5-r0 oe-repo 274 k
libassimp4 aarch64 4.1.0-r0 oe-repo 1.8 M
libatk-1.0-0 aarch64 2.26.1-r0 oe-repo 52 k
libatomic-dev aarch64 7.3.0-r0 oe-repo 6.4 k
libatomic1 aarch64 7.3.0-r0 oe-repo 12 k
libattr1 aarch64 2.4.47-r0 oe-repo 12 k
libavahi-common3 aarch64 0.7-r0 oe-repo 21 k
libavahi-core7 aarch64 0.7-r0 oe-repo 67 k
libbfd aarch64 2.30-r0 oe-repo 316 k
libblkid1 aarch64 2.32.1-r0 oe-repo 103 k
libbz2-1 aarch64 1.0.6-r5 oe-repo 31 k
libc6 aarch64 2.27-r0 oe-repo 1.0 M
libc6-dbg aarch64 2.27-r0 oe-repo 7.9 M
libc6-dev aarch64 2.27-r0 oe-repo 466 k
libc6-extra-nss aarch64 2.27-r0 oe-repo 43 k
libc6-thread-db aarch64 2.27-r0 oe-repo 15 k
libc6-utils aarch64 2.27-r0 oe-repo 90 k
libcairo-gobject2 aarch64_mx8mm 1.14.12-r0 oe-repo 15 k
libcairo2 aarch64_mx8mm 1.14.12-r0 oe-repo 367 k
libcap2 aarch64 2.25-r0 oe-repo 15 k
libcidn1 aarch64 2.27-r0 oe-repo 38 k
libclc-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 1.4 M
libclutter-1.0-0 aarch64_mx8mm 1.26.2-r0 oe-repo 404 k
libclutter-1.0-examples aarch64_mx8mm 1.26.2-r0 oe-repo 39 k
libcogl-pango20 aarch64_mx8mm 1.22.2-r0 oe-repo 18 k
libcogl-path20 aarch64_mx8mm 1.22.2-r0 oe-repo 29 k
libcogl20 aarch64_mx8mm 1.22.2-r0 oe-repo 206 k
libcom-err2 aarch64 1.43.8-r0 oe-repo 11 k
libcroco aarch64 0.6.12-r0 oe-repo 70 k
libcrypto1.0.2 aarch64 1.0.2p-r0 oe-repo 522 k
libcurl4 aarch64 7.61.0-r0 oe-repo 135 k
libdaemon0 aarch64 0.14-r0 oe-repo 15 k
libdbus-1-3 aarch64 1.12.2-r0 oe-repo 96 k
libdbus-glib-1-2 aarch64 0.108-r0 oe-repo 47 k
libdrm-etnaviv1 aarch64_mx8mm 2.4.91.imx-r0 oe-repo 14 k
libdrm-freedreno1 aarch64_mx8mm 2.4.91.imx-r0 oe-repo 16 k
libdrm-tests aarch64_mx8mm 2.4.91.imx-r0 oe-repo 49 k
libdrm2 aarch64_mx8mm 2.4.91.imx-r0 oe-repo 29 k
libdw1 aarch64 0.170-r0 oe-repo 171 k
libe2p2 aarch64 1.43.8-r0 oe-repo 16 k
libegl-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 343 k
libelf1 aarch64 0.170-r0 oe-repo 38 k
libepoxy0 aarch64_mx8mm 1.5.0-r0 oe-repo 155 k
libevdev aarch64 1.5.8-r0 oe-repo 35 k
libevent aarch64 2.1.8-r0 oe-repo 143 k
libexpat1 aarch64 2.2.5-r0 oe-repo 61 k
libext2fs2 aarch64 1.43.8-r0 oe-repo 124 k
libfdisk1 aarch64 2.32.1-r0 oe-repo 134 k
libffi6 aarch64 3.2.1-r0 oe-repo 20 k
libflac8 aarch64 1.3.2-r0 oe-repo 162 k
libfontconfig1 aarch64 2.12.6-r0 oe-repo 116 k
libfontenc1 aarch64 1:1.1.3-r0 oe-repo 15 k
libformw5 aarch64 6.0+20171125-r0
oe-repo 27 k
libfreetype6 aarch64 2.9-r0 oe-repo 246 k
libfslvpuwrap3 aarch64_mx8mm 4.4.5-r0 oe-repo 21 k
libg2d1.1 aarch64_mx8mm 6.2.4.p4.0-r0 oe-repo 1.2 M
libgal-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 1.6 M
libgbm-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 40 k
libgcc-s-dev aarch64 7.3.0-r0 oe-repo 209 k
libgcc1 aarch64 7.3.0-r0 oe-repo 38 k
libgcrypt aarch64 1.8.2-r0 oe-repo 290 k
libgdbm-compat4 aarch64 1.14.1-r0 oe-repo 10 k
libgdbm5 aarch64 1.14.1-r0 oe-repo 25 k
libgdk-pixbuf-2.0-0 aarch64 2.36.11-r0 oe-repo 55 k
libgl-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 532 k
libglapi0 aarch64_mx8mm 2:17.3.8-r0 oe-repo 28 k
libgles-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 649 k
libgles2-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 1.5 M
libglew2.1 aarch64_mx8mm 2.1.0-r0 oe-repo 133 k
libglib-2.0-0 aarch64 1:2.54.3-r0 oe-repo 768 k
libglib-2.0-utils aarch64 1:2.54.3-r0 oe-repo 70 k
libglslc-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 761 k
libglu1 aarch64_mx8mm 2:9.0.0-0 oe-repo 161 k
libglut3 aarch64_mx8mm 3.0.0-r0 oe-repo 75 k
libgmp10 aarch64 6.1.2-r0 oe-repo 180 k
libgnutls30 aarch64 3.6.1-r0 oe-repo 365 k
libgpg-error0 aarch64 1.27-r0 oe-repo 32 k
libgpuperfcnt1.4.0 aarch64_mx8mm 6.2.4.p4.0-r0 oe-repo 21 k
libgstadaptivedemux-1.0-0
libgstallocators-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 16 k
libgstapp-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 23 k
libgstaudio-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 127 k
libgstbadaudio-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 22 k
libgstbadvideo-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 24 k
libgstbasecamerabinsrc-1.0-0
libgstcodecparsers-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 86 k
libgstfft-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 19 k
libgstfsl-1.0-0 aarch64_mx8mm 4.4.5-r0 oe-repo 39 k
libgstgl-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 114 k
libgstinsertbin-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 13 k
libgstisoff-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 13 k
libgstmpegts-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 45 k
libgstpbutils-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 64 k
libgstphotography-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 14 k
libgstplayer-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 36 k
libgstriff-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 26 k
libgstrtp-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 39 k
libgstrtsp-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 41 k
libgstrtspserver-1.0-0 aarch64 1.14.4-r0 oe-repo 95 k
libgstsdp-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 30 k
libgsttag-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 85 k
libgsturidownloader-1.0-0
libgstvideo-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 139 k
libgstwayland-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 9.9 k
libgstwebrtc-1.0-0 aarch64_mx8mm 1.14.4.imx-r0 oe-repo 14 k
libgtk-2.0 aarch64_mx8mm 2.24.32-r0 oe-repo 1.5 M
libgtk-3.0 aarch64_mx8mm 3.22.28-r0 oe-repo 1.9 M
libgudev-1.0-0 aarch64 232-r0 oe-repo 17 k
libharfbuzz0 aarch64_mx8mm 1.7.5-r0 oe-repo 211 k
libical aarch64 2.0.0-r0 oe-repo 150 k
libice6 aarch64 1:1.0.9-r0 oe-repo 36 k
libicudata60 aarch64 60.2-r0 oe-repo 6.2 M
libicui18n60 aarch64 60.2-r0 oe-repo 783 k
libicuuc60 aarch64 60.2-r0 oe-repo 550 k
libinput10 aarch64 1.9.4-r0 oe-repo 99 k
libjpeg62 aarch64 1:1.5.3-r0 oe-repo 89 k
libjson-c3 aarch64 0.13-r0 oe-repo 25 k
libjson-glib-1.0-0 aarch64 1.4.2-r0 oe-repo 51 k
libkmod2 aarch64 25+git0+aca4eca103-r0
oe-repo 31 k
libkms1 aarch64_mx8mm 2.4.91.imx-r0 oe-repo 11 k
libltdl7 aarch64 2.4.6-r0 oe-repo 19 k
liblzma5 aarch64 5.2.3-r0 oe-repo 68 k
liblzo2-2 aarch64 2.10-r0 oe-repo 40 k
libmenuw5 aarch64 6.0+20171125-r0
oe-repo 17 k
libmnl0 aarch64 1.0.4-r0 oe-repo 12 k
libmount1 aarch64 2.32.1-r0 oe-repo 111 k
libncurses5 aarch64 6.0+20171125-r0
oe-repo 54 k
libncursesw5 aarch64 6.0+20171125-r0
oe-repo 69 k
libnfsidmap0 aarch64 0.25-r0 oe-repo 20 k
libnl-3-200 aarch64 1:3.4.0-r0 oe-repo 45 k
libnl-genl-3-200 aarch64 1:3.4.0-r0 oe-repo 14 k
libnss-mdns aarch64 0.10-r7 oe-repo 16 k
libogg0 aarch64 1.3.3-r0 oe-repo 15 k
libopencl-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 6.5 M
libopenvg-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 439 k
liborc-0.4-0 aarch64 0.4.28-r0 oe-repo 101 k
libpam aarch64 1.3.0-r5 oe-repo 30 k
libpam-runtime aarch64 1.3.0-r5 oe-repo 16 k
libpanel5 aarch64 6.0+20171125-r0
oe-repo 10 k
libpanelw5 aarch64 6.0+20171125-r0
oe-repo 10 k
libpcap1 aarch64 1.8.1-r0 oe-repo 85 k
libpci3 aarch64 3.5.6-r0 oe-repo 22 k
libpciaccess0 aarch64 0.14-r0 oe-repo 17 k
libpcre1 aarch64 8.41-r0 oe-repo 82 k
libperl5 aarch64 5.24.1-r0 oe-repo 601 k
libpixman-1-0 aarch64 1:0.34.0-r0 oe-repo 114 k
libpng16-16 aarch64 1.6.34-r0 oe-repo 79 k
libpopt0 aarch64 1.16-r3 oe-repo 24 k
libpulse0 aarch64_mx8mm 11.1-r0 oe-repo 76 k
libpulsecommon aarch64_mx8mm 11.1-r0 oe-repo 128 k
libpulsecore aarch64_mx8mm 11.1-r0 oe-repo 146 k
libpython2.7-1.0 aarch64 2.7.15-r1 oe-repo 481 k
libpython3.5m1.0 aarch64 3.5.5-r1.0 oe-repo 634 k
libreadline7 aarch64 7.0-r0 oe-repo 101 k
librecorder-engine-1.0-0 aarch64_mx8mm 4.4.5-r0 oe-repo 22 k
librsvg-2-2 aarch64_mx8mm 2.40.20-r0 oe-repo 73 k
libsamplerate0 aarch64 0.1.9-r1 oe-repo 915 k
libsbc1 aarch64 1.3-r0 oe-repo 33 k
libsegfault aarch64 2.27-r0 oe-repo 9.2 k
libsm6 aarch64 1:1.2.2-r0 oe-repo 17 k
libsmartcols1 aarch64 2.32.1-r0 oe-repo 67 k
libsndfile1 aarch64 1.0.28-r0 oe-repo 139 k
libsoup-2.4 aarch64 2.60.3-r0 oe-repo 215 k
libspeex1 aarch64 1.2.0-r0 oe-repo 44 k
libspeexdsp1 aarch64 1.2rc3-r0 oe-repo 35 k
libsqlite3-0 aarch64 3:3.22.0-r0 oe-repo 336 k
libss2 aarch64 1.43.8-r0 oe-repo 14 k
libssl1.0.2 aarch64 1.0.2p-r0 oe-repo 120 k
libstdc++-dev aarch64 7.3.0-r0 oe-repo 923 k
libstdc++6 aarch64 7.3.0-r0 oe-repo 333 k
libsystemd0 aarch64 1:237-r0 oe-repo 183 k
libtag1 aarch64 1.11.1-r0 oe-repo 233 k
libtcl8.6-0 aarch64 8.6.8-r0 oe-repo 522 k
libtheora aarch64 1.1.1-r1 oe-repo 144 k
libtiff5 aarch64 4.0.9-r0 oe-repo 127 k
libtinfo5 aarch64 6.0+20171125-r0
oe-repo 47 k
libtirpc3 aarch64 1.0.2-r0 oe-repo 59 k
libts0 aarch64 1.15-r0 oe-repo 32 k
libudev1 aarch64 1:237-r0 oe-repo 50 k
libunistring2 aarch64 0.9.9-r0 oe-repo 348 k
libunwind aarch64 1.2.1-r0 oe-repo 50 k
liburcu aarch64 0.10.1-r0 oe-repo 44 k
libusb-1.0-0 aarch64 1.0.21-r0 oe-repo 39 k
libuser aarch64 0.62-r0 oe-repo 76 k
libuuid1 aarch64 2.32.1-r0 oe-repo 17 k
libv4l aarch64_mx8mm 1.12.3-r0 oe-repo 167 k
libvdk-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 53 k
libvorbis aarch64 1.3.5-r1 oe-repo 149 k
libvsc-imx aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 2.7 M
libwebp aarch64 0.6.1-r0 oe-repo 155 k
libweston-5 aarch64_mx8mm 5.0.0.imx-r0 oe-repo 179 k
libwrap0 aarch64 7.6-r10 oe-repo 18 k
libx11-6 aarch64 1:1.6.5-r0 oe-repo 502 k
libx11-xcb1 aarch64 1:1.6.5-r0 oe-repo 8.3 k
libxau6 aarch64 1:1.0.8-r0 oe-repo 10 k
libxaw7-7 aarch64 1:1.0.13-r2 oe-repo 138 k
libxcb-composite0 aarch64 1.12-r0 oe-repo 9.1 k
libxcb-render0 aarch64 1.12-r0 oe-repo 16 k
libxcb-shape0 aarch64 1.12-r0 oe-repo 9.6 k
libxcb-shm0 aarch64 1.12-r0 oe-repo 9.4 k
libxcb-xfixes0 aarch64 1.12-r0 oe-repo 12 k
libxcb-xkb1 aarch64 1.12-r0 oe-repo 27 k
libxcb1 aarch64 1.12-r0 oe-repo 35 k
libxcomposite1 aarch64 1:0.4.4-r0 oe-repo 10 k
libxcursor1 aarch64 1:1.1.15-r0 oe-repo 20 k
libxdamage1 aarch64 1:1.1.4-r0 oe-repo 10 k
libxdmcp6 aarch64 1:1.1.2-r0 oe-repo 13 k
libxext6 aarch64 1:1.3.3-r0 oe-repo 25 k
libxfixes3 aarch64 1:5.0.3-r0 oe-repo 12 k
libxfont2-2 aarch64 2.0.3-r0 oe-repo 91 k
libxft2 aarch64 1:2.3.2-r0 oe-repo 35 k
libxi6 aarch64 1:1.7.9-r0 oe-repo 27 k
libxinerama1 aarch64 1:1.1.3-r0 oe-repo 9.6 k
libxkbcommon aarch64 0.8.0-r0 oe-repo 93 k
libxkbfile1 aarch64 1:1.0.9-r0 oe-repo 57 k
libxml2 aarch64 2.9.7-r0 oe-repo 492 k
libxmu6 aarch64 1:1.1.2-r0 oe-repo 40 k
libxmuu1 aarch64 1:1.1.2-r0 oe-repo 12 k
libxpm4 aarch64 1:3.5.12-r0 oe-repo 31 k
libxrandr2 aarch64 1:1.5.1-r0 oe-repo 18 k
libxrender1 aarch64 1:0.9.10-r0 oe-repo 19 k
libxres1 aarch64 1:1.2.0-r0 oe-repo 10 k
libxshmfence1 aarch64 1.2-r0 oe-repo 8.9 k
libxt6 aarch64 1:1.1.5-r0 oe-repo 125 k
libxtst6 aarch64 1:1.2.3-r0 oe-repo 14 k
libxv1 aarch64 1.0.11-r0 oe-repo 12 k
libxxf86vm1 aarch64 1:1.1.4-r0 oe-repo 12 k
libz1 aarch64 1.2.11-r0 oe-repo 44 k
linux-firmware-ath10k-license
noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 7.8 k
linux-firmware-broadcom-license
oe-repo 8.4 k
linux-firmware-cypress-license
oe-repo 9.9 k
linuxptp aarch64 1.8-r0 oe-repo 63 k
lmbench aarch64 3.0+a9-r2 oe-repo 256 k
logrotate aarch64 3.13.0-r0 oe-repo 32 k
lrzsz aarch64 0.12.20-r6 oe-repo 46 k
ltp aarch64 20180118-r0 oe-repo 11 M
lttng-modules imx8mmevk 2.10.6-r0 oe-repo 5.6 k
lttng-tools aarch64 2.9.5-r0 oe-repo 395 k
lttng-ust aarch64 2:2.10.1-r0 oe-repo 146 k
m4 aarch64 1.4.18-r0 oe-repo 82 k
make aarch64 4.2.1-r0 oe-repo 81 k
makedevs aarch64 1.0.1-r0 oe-repo 11 k
mc aarch64 4.8.20-r0 oe-repo 715 k
mc-fish aarch64 4.8.20-r0 oe-repo 13 k
mc-helpers aarch64 4.8.20-r0 oe-repo 32 k
mc-helpers-perl aarch64 4.8.20-r0 oe-repo 25 k
media-ctl aarch64_mx8mm 1.12.3-r0 oe-repo 19 k
memtester aarch64 4.3.0-r0 oe-repo 12 k
mesa-demos aarch64_mx8mm 8.3.0-r0 oe-repo 1.3 M
minicom aarch64 2.7.1-r0 oe-repo 76 k
mktemp aarch64 1.7-r3 oe-repo 10 k
mmc-utils aarch64 0.1-r0 oe-repo 34 k
mtd-utils aarch64 2.0.1+0+9c6173559f-r0
oe-repo 55 k
mtd-utils-ubifs aarch64 2.0.1+0+9c6173559f-r0
oe-repo 86 k
mtdev aarch64 1.1.5-r0 oe-repo 16 k
nano aarch64 2.9.3-r0 oe-repo 141 k
nbench-byte aarch64 2.2.3-r0 oe-repo 25 k
ncurses aarch64 6.0+20171125-r0
oe-repo 18 k
ncurses-terminfo aarch64 6.0+20171125-r0
oe-repo 533 k
ncurses-terminfo-base aarch64 6.0+20171125-r0
oe-repo 14 k
neard aarch64 0.16-r0 oe-repo 103 k
net-tools aarch64 1.60+26-r0 oe-repo 88 k
netbase aarch64 1:5.4-r0 oe-repo 15 k
nettle aarch64 3.4-r0 oe-repo 229 k
nfs-utils aarch64 2.1.1-r0 oe-repo 59 k
nfs-utils-client aarch64 2.1.1-r0 oe-repo 67 k
nfs-utils-mount aarch64 2.1.1-r0 oe-repo 41 k
ntpdate aarch64 4.2.8p11-r0 oe-repo 57 k
numactl aarch64 2.0.11+git0+ea3a70681c-r0
oe-repo 52 k
ofono aarch64 1.22-r0 oe-repo 423 k
ofono-tests aarch64 1.22-r0 oe-repo 36 k
openssl aarch64 1.0.2p-r0 oe-repo 169 k
openssl-conf aarch64 1.0.2p-r0 oe-repo 9.9 k
optee-client-imx aarch64 git-r0 oe-repo 24 k
optee-os-imx imx8mmevk git-r0 oe-repo 122 k
optee-test-imx aarch64 git-r0 oe-repo 344 k
packagegroup-base imx8mmevk 1.0-r83 oe-repo 6.2 k
packagegroup-base-3g imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-alsa imx8mmevk 1.0-r83 oe-repo 5.8 k
packagegroup-base-bluetooth
imx8mmevk 1.0-r83 oe-repo 5.9 k
packagegroup-base-ipv6 imx8mmevk 1.0-r83 oe-repo 5.6 k
packagegroup-base-nfc imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-nfs imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-pci imx8mmevk 1.0-r83 oe-repo 5.6 k
packagegroup-base-usbgadget
packagegroup-base-usbhost
imx8mmevk 1.0-r83 oe-repo 6.0 k
packagegroup-base-wifi imx8mmevk 1.0-r83 oe-repo 6.0 k
packagegroup-base-zeroconf
packagegroup-core-full-cmdline-dev-utils
noarch 1.0-r6 oe-repo 6.0 k
packagegroup-core-full-cmdline-extended
packagegroup-core-full-cmdline-initscripts
packagegroup-core-full-cmdline-libs
noarch 1.0-r6 oe-repo 5.9 k
packagegroup-core-full-cmdline-multiuser
packagegroup-core-full-cmdline-sys-services
noarch 1.0-r6 oe-repo 6.1 k
packagegroup-core-full-cmdline-utils
noarch 1.0-r6 oe-repo 6.3 k
packagegroup-distro-base imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-fsl-gstreamer1.0-audio
imx8mmevk 1.0-r0 oe-repo 6.1 k
packagegroup-fsl-gstreamer1.0-base
packagegroup-fsl-gstreamer1.0-debug
imx8mmevk 1.0-r0 oe-repo 6.0 k
packagegroup-fsl-gstreamer1.0-network-base
packagegroup-fsl-gstreamer1.0-video
packagegroup-fsl-tools-testapps-fslcodec-testapps
packagegroup-machine-base
pam-plugin-access aarch64 1.3.0-r5 oe-repo 12 k
pam-plugin-deny aarch64 1.3.0-r5 oe-repo 7.7 k
pam-plugin-env aarch64 1.3.0-r5 oe-repo 11 k
pam-plugin-faildelay aarch64 1.3.0-r5 oe-repo 8.7 k
pam-plugin-group aarch64 1.3.0-r5 oe-repo 11 k
pam-plugin-keyinit aarch64 1.3.0-r5 oe-repo 9.2 k
pam-plugin-lastlog aarch64 1.3.0-r5 oe-repo 11 k
pam-plugin-limits aarch64 1.3.0-r5 oe-repo 13 k
pam-plugin-loginuid aarch64 1.3.0-r5 oe-repo 8.6 k
pam-plugin-mail aarch64 1.3.0-r5 oe-repo 10 k
pam-plugin-motd aarch64 1.3.0-r5 oe-repo 8.4 k
pam-plugin-nologin aarch64 1.3.0-r5 oe-repo 8.6 k
pam-plugin-permit aarch64 1.3.0-r5 oe-repo 7.9 k
pam-plugin-rootok aarch64 1.3.0-r5 oe-repo 8.1 k
pam-plugin-securetty aarch64 1.3.0-r5 oe-repo 9.3 k
pam-plugin-shells aarch64 1.3.0-r5 oe-repo 8.4 k
pam-plugin-unix aarch64 1.3.0-r5 oe-repo 27 k
pam-plugin-warn aarch64 1.3.0-r5 oe-repo 8.2 k
pango aarch64_mx8mm 1.40.14-r0 oe-repo 149 k
patch aarch64 2.7.6-r0 oe-repo 75 k
pciutils aarch64 3.5.6-r0 oe-repo 39 k
pciutils-ids aarch64 3.5.6-r0 oe-repo 255 k
perl aarch64 5.24.1-r0 oe-repo 24 k
perl-module-carp aarch64 5.24.1-r0 oe-repo 16 k
perl-module-constant aarch64 5.24.1-r0 oe-repo 12 k
perl-module-cwd aarch64 5.24.1-r0 oe-repo 20 k
perl-module-dynaloader aarch64 5.24.1-r0 oe-repo 15 k
perl-module-exporter aarch64 5.24.1-r0 oe-repo 13 k
perl-module-exporter-heavy
aarch64 5.24.1-r0 oe-repo 9.2 k
perl-module-file-spec aarch64 5.24.1-r0 oe-repo 10 k
perl-module-file-spec-unix
perl-module-getopt-long aarch64 5.24.1-r0 oe-repo 30 k
perl-module-list-util aarch64 5.24.1-r0 oe-repo 26 k
perl-module-mro aarch64 5.24.1-r0 oe-repo 17 k
perl-module-overload aarch64 5.24.1-r0 oe-repo 23 k
perl-module-overload-numbers
aarch64 5.24.1-r0 oe-repo 7.4 k
perl-module-overloading aarch64 5.24.1-r0 oe-repo 7.3 k
perl-module-pod-usage aarch64 5.24.1-r0 oe-repo 16 k
perl-module-scalar-util aarch64 5.24.1-r0 oe-repo 10 k
perl-module-text-parsewords
aarch64 5.24.1-r0 oe-repo 9.6 k
perl-module-xsloader aarch64 5.24.1-r0 oe-repo 11 k
powertop aarch64 2.9-r0 oe-repo 160 k
procps aarch64 3.3.12-r0 oe-repo 143 k
psmisc aarch64 23.0-r0 oe-repo 6.0 k
pstree aarch64 23.0-r0 oe-repo 16 k
ptpd aarch64 2.3.1-r0 oe-repo 112 k
pulseaudio-lib-alsa-util aarch64_mx8mm 11.1-r0 oe-repo 82 k
pulseaudio-lib-bluez5-util
aarch64_mx8mm 11.1-r0 oe-repo 29 k
pulseaudio-lib-cli aarch64_mx8mm 11.1-r0 oe-repo 10 k
pulseaudio-lib-protocol-cli
pulseaudio-lib-protocol-native
aarch64_mx8mm 11.1-r0 oe-repo 38 k
pulseaudio-misc aarch64_mx8mm 11.1-r0 oe-repo 40 k
pulseaudio-module-alsa-card
aarch64_mx8mm 11.1-r0 oe-repo 34 k
pulseaudio-module-alsa-sink
pulseaudio-module-alsa-source
pulseaudio-module-always-sink
aarch64_mx8mm 11.1-r0 oe-repo 11 k
pulseaudio-module-augment-properties
aarch64_mx8mm 11.1-r0 oe-repo 12 k
pulseaudio-module-bluetooth-discover
aarch64_mx8mm 11.1-r0 oe-repo 9.8 k
pulseaudio-module-bluetooth-policy
pulseaudio-module-bluez5-device
aarch64_mx8mm 11.1-r0 oe-repo 22 k
pulseaudio-module-bluez5-discover
pulseaudio-module-card-restore
aarch64_mx8mm 11.1-r0 oe-repo 13 k
pulseaudio-module-cli aarch64_mx8mm 11.1-r0 oe-repo 10 k
pulseaudio-module-cli-protocol-unix
pulseaudio-module-console-kit
pulseaudio-module-default-device-restore
pulseaudio-module-detect aarch64_mx8mm 11.1-r0 oe-repo 11 k
pulseaudio-module-device-manager
aarch64_mx8mm 11.1-r0 oe-repo 19 k
pulseaudio-module-device-restore
aarch64_mx8mm 11.1-r0 oe-repo 17 k
pulseaudio-module-filter-apply
aarch64_mx8mm 11.1-r0 oe-repo 14 k
pulseaudio-module-filter-heuristics
pulseaudio-module-intended-roles
pulseaudio-module-loopback
aarch64_mx8mm 11.1-r0 oe-repo 18 k
pulseaudio-module-native-protocol-unix
pulseaudio-module-null-sink
pulseaudio-module-position-event-sounds
pulseaudio-module-rescue-streams
pulseaudio-module-role-cork
pulseaudio-module-stream-restore
aarch64_mx8mm 11.1-r0 oe-repo 25 k
pulseaudio-module-suspend-on-idle
pulseaudio-module-switch-on-connect
pulseaudio-module-switch-on-port-available
pulseaudio-module-udev-detect
aarch64_mx8mm 11.1-r0 oe-repo 15 k
pulseaudio-module-x11-bell
pulseaudio-module-x11-cork-request
pulseaudio-module-x11-publish
pulseaudio-module-x11-xsmp
pulseaudio-server aarch64_mx8mm 11.1-r0 oe-repo 63 k
python-2to3 aarch64 2.7.15-r1 oe-repo 244 k
python-argparse aarch64 2.7.15-r1 oe-repo 39 k
python-audio aarch64 2.7.15-r1 oe-repo 42 k
python-bsddb aarch64 2.7.15-r1 oe-repo 163 k
python-codecs aarch64 2.7.15-r1 oe-repo 507 k
python-compile aarch64 2.7.15-r1 oe-repo 14 k
python-compiler aarch64 2.7.15-r1 oe-repo 81 k
python-compression aarch64 2.7.15-r1 oe-repo 88 k
python-contextlib aarch64 2.7.15-r1 oe-repo 9.2 k
python-core aarch64 2.7.15-r1 oe-repo 420 k
python-crypt aarch64 2.7.15-r1 oe-repo 20 k
python-ctypes aarch64 2.7.15-r1 oe-repo 173 k
python-curses aarch64 2.7.15-r1 oe-repo 36 k
python-datetime aarch64 2.7.15-r1 oe-repo 57 k
python-db aarch64 2.7.15-r1 oe-repo 20 k
python-debugger aarch64 2.7.15-r1 oe-repo 36 k
python-difflib aarch64 2.7.15-r1 oe-repo 36 k
python-distutils aarch64 2.7.15-r1 oe-repo 562 k
python-doctest aarch64 2.7.15-r1 oe-repo 45 k
python-email aarch64 2.7.15-r1 oe-repo 192 k
python-fcntl aarch64 2.7.15-r1 oe-repo 12 k
python-gdbm aarch64 2.7.15-r1 oe-repo 12 k
python-hotshot aarch64 2.7.15-r1 oe-repo 23 k
python-html aarch64 2.7.15-r1 oe-repo 45 k
python-idle aarch64 2.7.15-r1 oe-repo 435 k
python-image aarch64 2.7.15-r1 oe-repo 11 k
python-io aarch64 2.7.15-r1 oe-repo 172 k
python-json aarch64 2.7.15-r1 oe-repo 59 k
python-lang aarch64 2.7.15-r1 oe-repo 96 k
python-logging aarch64 2.7.15-r1 oe-repo 62 k
python-mailbox aarch64 2.7.15-r1 oe-repo 37 k
python-math aarch64 2.7.15-r1 oe-repo 53 k
python-mime aarch64 2.7.15-r1 oe-repo 45 k
python-misc aarch64 2.7.15-r1 oe-repo 1.8 M
python-mmap aarch64 2.7.15-r1 oe-repo 13 k
python-modules aarch64 2.7.15-r1 oe-repo 6.8 k
python-multiprocessing aarch64 2.7.15-r1 oe-repo 89 k
python-netclient aarch64 2.7.15-r1 oe-repo 192 k
python-netserver aarch64 2.7.15-r1 oe-repo 52 k
python-numbers aarch64 2.7.15-r1 oe-repo 82 k
python-pickle aarch64 2.7.15-r1 oe-repo 77 k
python-pip aarch64 9.0.3-r0 oe-repo 1.4 M
python-pkgutil aarch64 2.7.15-r1 oe-repo 16 k
python-plistlib aarch64 2.7.15-r1 oe-repo 15 k
python-pprint aarch64 2.7.15-r1 oe-repo 12 k
python-profile aarch64 2.7.15-r1 oe-repo 37 k
python-pydoc aarch64 2.7.15-r1 oe-repo 181 k
python-re aarch64 2.7.15-r1 oe-repo 7.0 k
python-resource aarch64 2.7.15-r1 oe-repo 9.9 k
python-robotparser aarch64 2.7.15-r1 oe-repo 11 k
python-runpy aarch64 2.7.15-r1 oe-repo 12 k
python-setuptools aarch64 39.0.0-r0 oe-repo 480 k
python-shell aarch64 2.7.15-r1 oe-repo 38 k
python-smtpd aarch64 2.7.15-r1 oe-repo 32 k
python-sqlite3 aarch64 2.7.15-r1 oe-repo 27 k
python-stringold aarch64 2.7.15-r1 oe-repo 12 k
python-subprocess aarch64 2.7.15-r1 oe-repo 26 k
python-syslog aarch64 2.7.15-r1 oe-repo 9.4 k
python-terminal aarch64 2.7.15-r1 oe-repo 11 k
python-textutils aarch64 2.7.15-r1 oe-repo 55 k
python-threading aarch64 2.7.15-r1 oe-repo 36 k
python-tkinter aarch64 2.7.15-r1 oe-repo 269 k
python-unittest aarch64 2.7.15-r1 oe-repo 112 k
python-unixadmin aarch64 2.7.15-r1 oe-repo 16 k
python-xml aarch64 2.7.15-r1 oe-repo 193 k
python-xmlrpc aarch64 2.7.15-r1 oe-repo 23 k
python-zlib aarch64 2.7.15-r1 oe-repo 14 k
python3-2to3 aarch64 3.5.5-r1.0 oe-repo 289 k
python3-asyncio aarch64 3.5.5-r1.0 oe-repo 202 k
python3-audio aarch64 3.5.5-r1.0 oe-repo 46 k
python3-codecs aarch64 3.5.5-r1.0 oe-repo 20 k
python3-compile aarch64 3.5.5-r1.0 oe-repo 18 k
python3-compression aarch64 3.5.5-r1.0 oe-repo 123 k
python3-core aarch64 3.5.5-r1.0 oe-repo 1.1 M
python3-crypt aarch64 3.5.5-r1.0 oe-repo 31 k
python3-ctypes aarch64 3.5.5-r1.0 oe-repo 196 k
python3-curses aarch64 3.5.5-r1.0 oe-repo 40 k
python3-datetime aarch64 3.5.5-r1.0 oe-repo 84 k
python3-db aarch64 3.5.5-r1.0 oe-repo 22 k
python3-dbus aarch64 1.2.6-r0 oe-repo 99 k
python3-debugger aarch64 3.5.5-r1.0 oe-repo 48 k
python3-difflib aarch64 3.5.5-r1.0 oe-repo 40 k
python3-distutils aarch64 3.5.5-r1.0 oe-repo 1.0 M
python3-doctest aarch64 3.5.5-r1.0 oe-repo 49 k
python3-email aarch64 3.5.5-r1.0 oe-repo 197 k
python3-fcntl aarch64 3.5.5-r1.0 oe-repo 12 k
python3-html aarch64 3.5.5-r1.0 oe-repo 60 k
python3-idle aarch64 3.5.5-r1.0 oe-repo 501 k
python3-image aarch64 3.5.5-r1.0 oe-repo 13 k
python3-io aarch64 3.5.5-r1.0 oe-repo 168 k
python3-json aarch64 3.5.5-r1.0 oe-repo 39 k
python3-logging aarch64 3.5.5-r1.0 oe-repo 76 k
python3-mailbox aarch64 3.5.5-r1.0 oe-repo 42 k
python3-math aarch64 3.5.5-r1.0 oe-repo 33 k
python3-mime aarch64 3.5.5-r1.0 oe-repo 17 k
python3-mmap aarch64 3.5.5-r1.0 oe-repo 13 k
python3-modules aarch64 3.5.5-r1.0 oe-repo 6.7 k
python3-multiprocessing aarch64 3.5.5-r1.0 oe-repo 132 k
python3-netclient aarch64 3.5.5-r1.0 oe-repo 271 k
python3-netserver aarch64 3.5.5-r1.0 oe-repo 36 k
python3-numbers aarch64 3.5.5-r1.0 oe-repo 159 k
python3-pickle aarch64 3.5.5-r1.0 oe-repo 97 k
python3-pkgutil aarch64 3.5.5-r1.0 oe-repo 18 k
python3-plistlib aarch64 3.5.5-r1.0 oe-repo 25 k
python3-pprint aarch64 3.5.5-r1.0 oe-repo 17 k
python3-profile aarch64 3.5.5-r1.0 oe-repo 39 k
python3-pycairo aarch64_mx8mm 1.15.6-r0 oe-repo 46 k
python3-pydoc aarch64 3.5.5-r1.0 oe-repo 184 k
python3-pygobject aarch64_mx8mm 3.28.1-r0 oe-repo 209 k
python3-resource aarch64 3.5.5-r1.0 oe-repo 10 k
python3-runpy aarch64 3.5.5-r1.0 oe-repo 14 k
python3-setuptools aarch64 39.0.0-r0 oe-repo 483 k
python3-shell aarch64 3.5.5-r1.0 oe-repo 45 k
python3-smtpd aarch64 3.5.5-r1.0 oe-repo 39 k
python3-sqlite3 aarch64 3.5.5-r1.0 oe-repo 32 k
python3-stringold aarch64 3.5.5-r1.0 oe-repo 13 k
python3-syslog aarch64 3.5.5-r1.0 oe-repo 9.5 k
python3-terminal aarch64 3.5.5-r1.0 oe-repo 12 k
python3-threading aarch64 3.5.5-r1.0 oe-repo 21 k
python3-tkinter aarch64 3.5.5-r1.0 oe-repo 253 k
python3-typing aarch64 3.5.5-r1.0 oe-repo 45 k
python3-unittest aarch64 3.5.5-r1.0 oe-repo 270 k
python3-unixadmin aarch64 3.5.5-r1.0 oe-repo 17 k
python3-xml aarch64 3.5.5-r1.0 oe-repo 205 k
python3-xmlrpc aarch64 3.5.5-r1.0 oe-repo 48 k
rpcbind aarch64 0.2.4-r0 oe-repo 38 k
sed aarch64 4.2.2-r0 oe-repo 57 k
shadow aarch64 4.2.1-r0 oe-repo 172 k
shadow-base aarch64 4.2.1-r0 oe-repo 40 k
shadow-securetty imx8mmevk 4.2.1-r3 oe-repo 6.8 k
shared-mime-info aarch64 1.9-r0 oe-repo 394 k
sigma-dut aarch64 git-r0 oe-repo 124 k
slang aarch64 2.3.2-r0 oe-repo 406 k
strace aarch64 4.20-r0 oe-repo 158 k
sudo aarch64 1.8.22-r0 oe-repo 230 k
sysklogd aarch64 1.5.1-r0 oe-repo 29 k
systemd aarch64 1:237-r0 oe-repo 1.5 M
systemd-container aarch64 1:237-r0 oe-repo 118 k
systemd-gpuconfig aarch64 1.0-r0 oe-repo 7.4 k
systemd-serialgetty imx8mmevk 1.0-r5 oe-repo 7.6 k
systemd-vconsole-setup aarch64 1:237-r0 oe-repo 13 k
systemtap aarch64 3.2-r0 oe-repo 1.7 M
tar aarch64 1.30-r0 oe-repo 173 k
tcl aarch64 8.6.8-r0 oe-repo 257 k
tcp-wrappers aarch64 7.6-r10 oe-repo 21 k
time aarch64 1.8-r0 oe-repo 15 k
tinycompress aarch64 1.1.6-r0 oe-repo 19 k
tiobench aarch64 0.3.3-r1 oe-repo 20 k
tk aarch64 8.6.8-r0 oe-repo 443 k
tk-lib aarch64 8.6.8-r0 oe-repo 411 k
tslib-conf aarch64 1.15-r0 oe-repo 7.0 k
tzdata noarch 2018f-r0 oe-repo 44 k
udev aarch64 1:237-r0 oe-repo 281 k
udev-extraconf aarch64 1.1-r0 oe-repo 9.9 k
unzip aarch64 1:6.0-r5 oe-repo 97 k
update-alternatives-opkg aarch64 0.3.6-r0 oe-repo 8.5 k
update-rc.d noarch 0.7-r5 oe-repo 8.3 k
usbutils aarch64 009-r0 oe-repo 56 k
util-linux aarch64 2.32.1-r0 oe-repo 321 k
util-linux-agetty aarch64 2.32.1-r0 oe-repo 24 k
util-linux-losetup aarch64 2.32.1-r0 oe-repo 31 k
util-linux-lsblk aarch64 2.32.1-r0 oe-repo 29 k
util-linux-mount aarch64 2.32.1-r0 oe-repo 20 k
util-linux-runuser aarch64 2.32.1-r0 oe-repo 19 k
util-linux-su aarch64 2.32.1-r0 oe-repo 6.5 k
util-linux-sulogin aarch64 2.32.1-r0 oe-repo 21 k
util-linux-swaponoff aarch64 2.32.1-r0 oe-repo 25 k
util-linux-umount aarch64 2.32.1-r0 oe-repo 15 k
v4l-utils aarch64_mx8mm 1.12.3-r0 oe-repo 348 k
valgrind aarch64 3.13.0-r0 oe-repo 1.7 M
vlan aarch64 1.9-r0 oe-repo 10 k
volatile-binds noarch 1.0-r0 oe-repo 9.3 k
wayland aarch64 1.16.0-r0 oe-repo 42 k
weston aarch64_mx8mm 5.0.0.imx-r0 oe-repo 686 k
weston-examples aarch64_mx8mm 5.0.0.imx-r0 oe-repo 183 k
which aarch64 2.21-r3 oe-repo 15 k
wireless-tools aarch64 1:30.pre9-r0 oe-repo 35 k
wpa-supplicant aarch64 2.6-r0 oe-repo 499 k
x11perf aarch64 1:1.6.0-r0 oe-repo 47 k
xkeyboard-config aarch64 2.22-r0 oe-repo 332 k
xprop aarch64 1:1.2.2-r0 oe-repo 20 k
xrestop aarch64 0.4-r3 oe-repo 12 k
xserver-xorg aarch64_mx8mm 2:1.19.6-r0 oe-repo 757 k
xserver-xorg-xwayland aarch64_mx8mm 2:1.19.6-r0 oe-repo 567 k
xvideo-tests aarch64 0.1+git0+7d38b881e9-r0
oe-repo 13 k
xwininfo aarch64 1.1.3-r0 oe-repo 20 k
Installing weak dependencies:
adwaita-icon-theme-symbolic
noarch 3.26.1-r0 oe-repo 365 k
alsa-states imx8mmevk 0.2.0-r5 oe-repo 13 k
blktrace aarch64 1.2.0+git0+cca113f2fe-r0
oe-repo 93 k
busybox-udhcpc aarch64 1.27.2-r0 oe-repo 8.1 k
ca-certificates noarch 20170717-r0 oe-repo 160 k
e2fsprogs-e2fsck aarch64 1.43.8-r0 oe-repo 102 k
fbset-modes imx8mmevk 0.1.0-r6 oe-repo 6.3 k
firmware-imx-sdma noarch 1:8.1-r0 oe-repo 8.3 k
firmware-qca6174 noarch 2.0.3-r0 oe-repo 596 k
firmware-qca9377 noarch 2.0.3-r0 oe-repo 508 k
glib-networking aarch64 2.54.1-r0 oe-repo 28 k
gnome-theme-adwaita aarch64 3.22.3-r0 oe-repo 67 k
gstreamer1.0-rtsp-server-meta
imx-alsa-plugins aarch64_mx8mm 1.0.26-r0 oe-repo 10 k
kbd-consolefonts aarch64 2.0.4-r0 oe-repo 424 k
kbd-keymaps aarch64 2.0.4-r0 oe-repo 460 k
kernel-module-cdc-acm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-g-ether-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-g-serial-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-qca6174-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
imx8mmevk 2.1-r0 oe-repo 1.0 M
kernel-module-qca9377-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-module-usbnet-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c
kernel-modules imx8mmevk 4.14.98-r0 oe-repo 18 k
liberation-fonts noarch 1:2.00.1-r0 oe-repo 1.4 M
libgdk-pixbuf-2.0-loader-gif
aarch64 2.36.11-r0 oe-repo 18 k
libgdk-pixbuf-2.0-loader-jpeg
aarch64 2.36.11-r0 oe-repo 17 k
libgdk-pixbuf-2.0-loader-png
aarch64 2.36.11-r0 oe-repo 16 k
libgdk-pixbuf-2.0-loader-xpm
libssp-dev aarch64 7.3.0-r0 oe-repo 11 k
libssp0 aarch64 7.3.0-r0 oe-repo 9.5 k
linux-firmware-ath10k noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 2.5 M
linux-firmware-bcm43455 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 388 k
linux-firmware-bcm4356-pcie
oe-repo 365 k
linux-firmware-bcm4359-pcie
oe-repo 359 k
linux-libc-headers-dev aarch64 4.14-r0 oe-repo 997 k
mobile-broadband-provider-info
aarch64 1:20170310-r0 oe-repo 46 k
os-release noarch 1.0-r0 oe-repo 6.5 k
perf imx8mmevk 4.14.98-r9 oe-repo 1.2 M
pointercal imx8mmevk 0.0-r11 oe-repo 5.5 k
psplash-default aarch64 0.1+git0+2015f7073e-r15
oe-repo 21 k
qca-tools aarch64 2.0.3-r0 oe-repo 82 k
rgb aarch64 1:1.0.6-r0 oe-repo 13 k
systemd-analyze aarch64 1:237-r0 oe-repo 357 k
systemd-compat-units aarch64 1.0-r29 oe-repo 6.2 k
systemd-extra-utils aarch64 1:237-r0 oe-repo 82 k
trace-cmd aarch64 2.7-r0 oe-repo 130 k
udev-hwdb aarch64 1:237-r0 oe-repo 712 k
udev-rules-imx aarch64 1.0-r0 oe-repo 6.7 k
util-linux-cfdisk aarch64 2.32.1-r0 oe-repo 35 k
util-linux-fdisk aarch64 2.32.1-r0 oe-repo 42 k
util-linux-fsck aarch64 2.32.1-r0 oe-repo 22 k
util-linux-ionice aarch64 2.32.1-r0 oe-repo 14 k
util-linux-mkfs aarch64 2.32.1-r0 oe-repo 9.7 k
util-linux-mountpoint aarch64 2.32.1-r0 oe-repo 11 k
util-linux-prlimit aarch64 2.32.1-r0 oe-repo 16 k
util-linux-readprofile aarch64 2.32.1-r0 oe-repo 12 k
util-linux-sfdisk aarch64 2.32.1-r0 oe-repo 38 k
util-linux-switch-root aarch64 2.32.1-r0 oe-repo 10 k
wpa-supplicant-cli aarch64 2.6-r0 oe-repo 35 k
wpa-supplicant-passphrase
aarch64 2.6-r0 oe-repo 19 k
xf86-input-libinput aarch64 2:0.26.0-r0 oe-repo 28 k
xkbcomp aarch64 1.4.0-r8.0 oe-repo 70 k
xserver-xf86-config imx8mmevk 0.1-r33 oe-repo 6.5 k
Transaction Summary
Install 1174 Packages
Total size: 209 M
Installed size: 983 M
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : update-alternatives-opkg-0.3.6-r0.aarch64 1/1174
Installing : libc6-2.27-r0.aarch64 2/1174
Running scriptlet: libc6-2.27-r0.aarch64 2/1174
Installing : busybox-1.27.2-r0.aarch64 3/1174
Running scriptlet: busybox-1.27.2-r0.aarch64 3/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ash to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/cat to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/chattr to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/chgrp to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/chmod to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/chown to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/cp to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/cpio to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/date to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/dd to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/df to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/dmesg to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/dnsdomainname to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/dumpkmap to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/echo to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/egrep to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/false to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/fgrep to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/getopt to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/grep to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/gunzip to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/gzip to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/hostname to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/kill to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ln to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ls to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mkdir to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mknod to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mktemp to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/more to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mount to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mv to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/netstat to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/pidof to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ps to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/pwd to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/rm to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/rmdir to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/run-parts to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/sed to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/sh to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/sleep to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/stat to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/stty to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/sync to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/tar to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/touch to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/true to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/umount to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/uname to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/usleep to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/vi to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/watch to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/zcat to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/blkid to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/depmod to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/fdisk to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/fsck to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/fstrim to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/getty to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/hwclock to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/ifconfig to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/ifdown to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/ifup to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/insmod to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/ip to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/klogd to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/loadkmap to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/logread to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/losetup to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/lsmod to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/mkswap to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/modprobe to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/pivot_root to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/rmmod to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/route to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/setconsole to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/start-stop-daemon to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/sulogin to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/swapoff to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/swapon to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/switch_root to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/sysctl to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/syslogd to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/udhcpc to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/[ to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/[[ to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/awk to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/basename to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/bunzip2 to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/bzcat to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/chvt to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/clear to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/cmp to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/cut to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/dc to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/deallocvt to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/diff to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/dirname to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/du to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/dumpleases to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/env to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/expr to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/find to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/flock to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/free to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/ftpget to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/fuser to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/groups to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/head to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/hexdump to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/id to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/killall to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/less to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/logger to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/logname to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/lzcat to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/md5sum to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/mesg to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/microcom to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/mkfifo to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/nc to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/nohup to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/nproc to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/nslookup to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/od to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/openvt to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/patch to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/printf to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/readlink to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/realpath to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/renice to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/reset to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/resize to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/seq to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sha1sum to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sha256sum to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/shuf to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sort to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/strings to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tail to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tee to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/telnet to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/test to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tftp to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/time to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/top to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tr to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tty to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/uniq to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/unlink to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/unzip to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/uptime to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/users to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/wc to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/wget to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/which to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/who to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/whoami to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/xargs to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/xzcat to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/yes to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/addgroup to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/adduser to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/chroot to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/delgroup to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/deluser to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/fbset to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/loadfont to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/rdate to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/rfkill to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/udhcpd to /bin/busybox.nosuid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/login to /bin/busybox.suid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ping to /bin/busybox.suid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ping6 to /bin/busybox.suid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/su to /bin/busybox.suid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/passwd to /bin/busybox.suid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/traceroute to /bin/busybox.suid
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/vlock to /bin/busybox.suid
Installing : libz1-1.2.11-r0.aarch64 4/1174
Running scriptlet: libz1-1.2.11-r0.aarch64 4/1174
Installing : libcap2-2.25-r0.aarch64 5/1174
Running scriptlet: libcap2-2.25-r0.aarch64 5/1174
Installing : libice6-1:1.0.9-r0.aarch64 6/1174
Running scriptlet: libice6-1:1.0.9-r0.aarch64 6/1174
Installing : libx11-xcb1-1:1.6.5-r0.aarch64 7/1174
Running scriptlet: libx11-xcb1-1:1.6.5-r0.aarch64 7/1174
Installing : libsm6-1:1.2.2-r0.aarch64 8/1174
Running scriptlet: libsm6-1:1.2.2-r0.aarch64 8/1174
Installing : liborc-0.4-0-0.4.28-r0.aarch64 9/1174
Running scriptlet: liborc-0.4-0-0.4.28-r0.aarch64 9/1174
Installing : libltdl7-2.4.6-r0.aarch64 10/1174
Running scriptlet: libltdl7-2.4.6-r0.aarch64 10/1174
Installing : libspeexdsp1-1.2rc3-r0.aarch64 11/1174
Running scriptlet: libspeexdsp1-1.2rc3-r0.aarch64 11/1174
Installing : target-sdk-provides-dummy-1.0-r0.sdk_provides_ 12/1174
Installing : libpam-1.3.0-r5.aarch64 13/1174
Running scriptlet: libpam-1.3.0-r5.aarch64 13/1174
Installing : libpython2.7-1.0-2.7.15-r1.aarch64 14/1174
Running scriptlet: libpython2.7-1.0-2.7.15-r1.aarch64 14/1174
Installing : libtinfo5-6.0+20171125-r0.aarch64 15/1174
Running scriptlet: libtinfo5-6.0+20171125-r0.aarch64 15/1174
Installing : libgcc1-7.3.0-r0.aarch64 16/1174
Running scriptlet: libgcc1-7.3.0-r0.aarch64 16/1174
Installing : libstdc++6-7.3.0-r0.aarch64 17/1174
Running scriptlet: libstdc++6-7.3.0-r0.aarch64 17/1174
Installing : libpython3.5m1.0-3.5.5-r1.0.aarch64 18/1174
Running scriptlet: libpython3.5m1.0-3.5.5-r1.0.aarch64 18/1174
Installing : libpng16-16-1.6.34-r0.aarch64 19/1174
Running scriptlet: libpng16-16-1.6.34-r0.aarch64 19/1174
Installing : libudev1-1:237-r0.aarch64 20/1174
Running scriptlet: libudev1-1:237-r0.aarch64 20/1174
Installing : libdrm2-2.4.91.imx-r0.aarch64_mx8mm 21/1174
Running scriptlet: libdrm2-2.4.91.imx-r0.aarch64_mx8mm 21/1174
Installing : libfreetype6-2.9-r0.aarch64 22/1174
Running scriptlet: libfreetype6-2.9-r0.aarch64 22/1174
Installing : libcrypto1.0.2-1.0.2p-r0.aarch64 23/1174
Running scriptlet: libcrypto1.0.2-1.0.2p-r0.aarch64 23/1174
Running scriptlet: base-files-3.0.14-r89.imx8mmevk 24/1174
Installing : base-files-3.0.14-r89.imx8mmevk 24/1174
Running scriptlet: base-passwd-3.5.29-r0.aarch64 25/1174
Installing : base-passwd-3.5.29-r0.aarch64 25/1174
Installing : libjpeg62-1:1.5.3-r0.aarch64 26/1174
Running scriptlet: libjpeg62-1:1.5.3-r0.aarch64 26/1174
Installing : libuuid1-2.32.1-r0.aarch64 27/1174
Running scriptlet: libuuid1-2.32.1-r0.aarch64 27/1174
Installing : libblkid1-2.32.1-r0.aarch64 28/1174
Running scriptlet: libblkid1-2.32.1-r0.aarch64 28/1174
Installing : libmount1-2.32.1-r0.aarch64 29/1174
Running scriptlet: libmount1-2.32.1-r0.aarch64 29/1174
Installing : libxau6-1:1.0.8-r0.aarch64 30/1174
Running scriptlet: libxau6-1:1.0.8-r0.aarch64 30/1174
Installing : libxdmcp6-1:1.1.2-r0.aarch64 31/1174
Running scriptlet: libxdmcp6-1:1.1.2-r0.aarch64 31/1174
Installing : libxcb1-1.12-r0.aarch64 32/1174
Running scriptlet: libxcb1-1.12-r0.aarch64 32/1174
Installing : libx11-6-1:1.6.5-r0.aarch64 33/1174
Running scriptlet: libx11-6-1:1.6.5-r0.aarch64 33/1174
Installing : libxext6-1:1.3.3-r0.aarch64 34/1174
Running scriptlet: libxext6-1:1.3.3-r0.aarch64 34/1174
Installing : libxrender1-1:0.9.10-r0.aarch64 35/1174
Running scriptlet: libxrender1-1:0.9.10-r0.aarch64 35/1174
Installing : libreadline7-7.0-r0.aarch64 36/1174
Running scriptlet: libreadline7-7.0-r0.aarch64 36/1174
Installing : python-core-2.7.15-r1.aarch64 37/1174
Installing : python3-core-3.5.5-r1.0.aarch64 38/1174
Installing : python-lang-2.7.15-r1.aarch64 39/1174
Installing : python3-stringold-3.5.5-r1.0.aarch64 40/1174
Installing : python-fcntl-2.7.15-r1.aarch64 41/1174
Installing : python-crypt-2.7.15-r1.aarch64 42/1174
Installing : python-math-2.7.15-r1.aarch64 43/1174
Installing : python3-math-3.5.5-r1.0.aarch64 44/1174
Installing : python3-crypt-3.5.5-r1.0.aarch64 45/1174
Installing : python-contextlib-2.7.15-r1.aarch64 46/1174
Installing : python3-datetime-3.5.5-r1.0.aarch64 47/1174
Installing : python-threading-2.7.15-r1.aarch64 48/1174
Installing : libncursesw5-6.0+20171125-r0.aarch64 49/1174
Running scriptlet: libncursesw5-6.0+20171125-r0.aarch64 49/1174
Installing : libxml2-2.9.7-r0.aarch64 50/1174
Running scriptlet: libxml2-2.9.7-r0.aarch64 50/1174
Installing : libpixman-1-0-1:0.34.0-r0.aarch64 51/1174
Running scriptlet: libpixman-1-0-1:0.34.0-r0.aarch64 51/1174
Installing : libsmartcols1-2.32.1-r0.aarch64 52/1174
Running scriptlet: libsmartcols1-2.32.1-r0.aarch64 52/1174
Installing : libnl-3-200-1:3.4.0-r0.aarch64 53/1174
Running scriptlet: libnl-3-200-1:3.4.0-r0.aarch64 53/1174
Installing : libcom-err2-1.43.8-r0.aarch64 54/1174
Running scriptlet: libcom-err2-1.43.8-r0.aarch64 54/1174
Installing : libnl-genl-3-200-1:3.4.0-r0.aarch64 55/1174
Running scriptlet: libnl-genl-3-200-1:3.4.0-r0.aarch64 55/1174
Installing : python3-logging-3.5.5-r1.0.aarch64 56/1174
Installing : bash-4.4.12-r0.aarch64 57/1174
Running scriptlet: bash-4.4.12-r0.aarch64 57/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/bash to /bin/bash.bash
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/sh to /bin/bash.bash
Installing : libncurses5-6.0+20171125-r0.aarch64 58/1174
Running scriptlet: libncurses5-6.0+20171125-r0.aarch64 58/1174
Installing : liblzma5-5.2.3-r0.aarch64 59/1174
Running scriptlet: liblzma5-5.2.3-r0.aarch64 59/1174
Installing : libsystemd0-1:237-r0.aarch64 60/1174
Running scriptlet: libsystemd0-1:237-r0.aarch64 60/1174
Installing : libdbus-1-3-1.12.2-r0.aarch64 61/1174
Running scriptlet: libdbus-1-3-1.12.2-r0.aarch64 61/1174
Installing : libpopt0-1.16-r3.aarch64 62/1174
Running scriptlet: libpopt0-1.16-r3.aarch64 62/1174
Installing : libffi6-3.2.1-r0.aarch64 63/1174
Running scriptlet: libffi6-3.2.1-r0.aarch64 63/1174
Installing : wayland-1.16.0-r0.aarch64 64/1174
Running scriptlet: wayland-1.16.0-r0.aarch64 64/1174
Installing : libogg0-1.3.3-r0.aarch64 65/1174
Running scriptlet: libogg0-1.3.3-r0.aarch64 65/1174
Installing : libbz2-1-1.0.6-r5.aarch64 66/1174
Running scriptlet: libbz2-1-1.0.6-r5.aarch64 66/1174
Installing : libext2fs2-1.43.8-r0.aarch64 67/1174
Running scriptlet: libext2fs2-1.43.8-r0.aarch64 67/1174
Installing : python3-mime-3.5.5-r1.0.aarch64 68/1174
Installing : python3-threading-3.5.5-r1.0.aarch64 69/1174
Installing : python3-xml-3.5.5-r1.0.aarch64 70/1174
Installing : python-pkgutil-2.7.15-r1.aarch64 71/1174
Installing : python-zlib-2.7.15-r1.aarch64 72/1174
Installing : libxfixes3-1:5.0.3-r0.aarch64 73/1174
Running scriptlet: libxfixes3-1:5.0.3-r0.aarch64 73/1174
Installing : libssl1.0.2-1.0.2p-r0.aarch64 74/1174
Running scriptlet: libssl1.0.2-1.0.2p-r0.aarch64 74/1174
Installing : libelf1-0.170-r0.aarch64 75/1174
Running scriptlet: libelf1-0.170-r0.aarch64 75/1174
Installing : libattr1-2.4.47-r0.aarch64 76/1174
Running scriptlet: libattr1-2.4.47-r0.aarch64 76/1174
Installing : libacl1-2.2.52-r0.aarch64 77/1174
Running scriptlet: libacl1-2.2.52-r0.aarch64 77/1174
Installing : procps-3.3.12-r0.aarch64 78/1174
Running scriptlet: procps-3.3.12-r0.aarch64 78/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/free to /usr/bin/free.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/pkill to /usr/bin/pkill.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/pmap to /usr/bin/pmap.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/pgrep to /usr/bin/pgrep.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/pwdx to /usr/bin/pwdx.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/skill to /usr/bin/skill.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/snice to /usr/bin/snice.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/top to /usr/bin/top.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/uptime to /usr/bin/uptime.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/w to /usr/bin/w.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/kill to /bin/kill.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/pidof to /bin/pidof.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ps to /bin/ps.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/watch to /bin/watch.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/sysctl to /sbin/sysctl.procps
Installing : python3-pkgutil-3.5.5-r1.0.aarch64 79/1174
Installing : python3-pprint-3.5.5-r1.0.aarch64 80/1174
Installing : libtirpc3-1.0.2-r0.aarch64 81/1174
Running scriptlet: libtirpc3-1.0.2-r0.aarch64 81/1174
Installing : libexpat1-2.2.5-r0.aarch64 82/1174
Running scriptlet: libexpat1-2.2.5-r0.aarch64 82/1174
Installing : libfontconfig1-2.12.6-r0.aarch64 83/1174
Running scriptlet: libfontconfig1-2.12.6-r0.aarch64 83/1174
Installing : libsqlite3-0-3:3.22.0-r0.aarch64 84/1174
Running scriptlet: libsqlite3-0-3:3.22.0-r0.aarch64 84/1174
Installing : libgmp10-6.1.2-r0.aarch64 85/1174
Running scriptlet: libgmp10-6.1.2-r0.aarch64 85/1174
Installing : nettle-3.4-r0.aarch64 86/1174
Running scriptlet: nettle-3.4-r0.aarch64 86/1174
Installing : libe2p2-1.43.8-r0.aarch64 87/1174
Running scriptlet: libe2p2-1.43.8-r0.aarch64 87/1174
Installing : glibc-gconv-2.27-r0.aarch64 88/1174
Installing : libxft2-1:2.3.2-r0.aarch64 89/1174
Running scriptlet: libxft2-1:2.3.2-r0.aarch64 89/1174
Installing : libdw1-0.170-r0.aarch64 90/1174
Running scriptlet: libdw1-0.170-r0.aarch64 90/1174
Installing : libxdamage1-1:1.1.4-r0.aarch64 91/1174
Running scriptlet: libxdamage1-1:1.1.4-r0.aarch64 91/1174
Installing : python3-ctypes-3.5.5-r1.0.aarch64 92/1174
Installing : python3-email-3.5.5-r1.0.aarch64 93/1174
Installing : python3-compression-3.5.5-r1.0.aarch64 94/1174
Installing : python3-shell-3.5.5-r1.0.aarch64 95/1174
Installing : python3-unixadmin-3.5.5-r1.0.aarch64 96/1174
Installing : python3-io-3.5.5-r1.0.aarch64 97/1174
Installing : python3-netclient-3.5.5-r1.0.aarch64 98/1174
Installing : python-ctypes-2.7.15-r1.aarch64 99/1174
Installing : python-datetime-2.7.15-r1.aarch64 100/1174
Installing : python-codecs-2.7.15-r1.aarch64 101/1174
Installing : python-subprocess-2.7.15-r1.aarch64 102/1174
Installing : python-pickle-2.7.15-r1.aarch64 103/1174
Installing : python-textutils-2.7.15-r1.aarch64 104/1174
Installing : python-io-2.7.15-r1.aarch64 105/1174
Installing : python-email-2.7.15-r1.aarch64 106/1174
Installing : python-mime-2.7.15-r1.aarch64 107/1174
Installing : python-netclient-2.7.15-r1.aarch64 108/1174
Installing : python-pprint-2.7.15-r1.aarch64 109/1174
Installing : python-unixadmin-2.7.15-r1.aarch64 110/1174
Installing : python-compression-2.7.15-r1.aarch64 111/1174
Installing : python-shell-2.7.15-r1.aarch64 112/1174
Installing : python-netserver-2.7.15-r1.aarch64 113/1174
Installing : python-difflib-2.7.15-r1.aarch64 114/1174
Installing : python-unittest-2.7.15-r1.aarch64 115/1174
Installing : python3-difflib-3.5.5-r1.0.aarch64 116/1174
Installing : python3-unittest-3.5.5-r1.0.aarch64 117/1174
Installing : python3-html-3.5.5-r1.0.aarch64 118/1174
Installing : python3-multiprocessing-3.5.5-r1.0.aarch64 119/1174
Installing : python3-pickle-3.5.5-r1.0.aarch64 120/1174
Installing : python-xml-2.7.15-r1.aarch64 121/1174
Installing : libxt6-1:1.1.5-r0.aarch64 122/1174
Running scriptlet: libxt6-1:1.1.5-r0.aarch64 122/1174
Installing : libxcb-render0-1.12-r0.aarch64 123/1174
Running scriptlet: libxcb-render0-1.12-r0.aarch64 123/1174
Installing : libxcb-shm0-1.12-r0.aarch64 124/1174
Running scriptlet: libxcb-shm0-1.12-r0.aarch64 124/1174
Installing : libfdisk1-2.32.1-r0.aarch64 125/1174
Running scriptlet: libfdisk1-2.32.1-r0.aarch64 125/1174
Installing : pam-plugin-unix-1.3.0-r5.aarch64 126/1174
Installing : pam-plugin-limits-1.3.0-r5.aarch64 127/1174
Installing : kmod-25+git0+aca4eca103-r0.aarch64 128/1174
Running scriptlet: kmod-25+git0+aca4eca103-r0.aarch64 128/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/insmod to /sbin/insmod.kmod
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/modprobe to /sbin/modprobe.kmod
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/rmmod to /sbin/rmmod.kmod
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/modinfo to /sbin/modinfo.kmod
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/lsmod to /bin/lsmod.kmod
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/lsmod to /bin/lsmod.kmod
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/depmod to /sbin/depmod.kmod
Installing : libkmod2-25+git0+aca4eca103-r0.aarch64 129/1174
Running scriptlet: libkmod2-25+git0+aca4eca103-r0.aarch64 129/1174
Installing : udev-1:237-r0.aarch64 130/1174
Installing : libtcl8.6-0-8.6.8-r0.aarch64 131/1174
Running scriptlet: libtcl8.6-0-8.6.8-r0.aarch64 131/1174
Installing : libwrap0-7.6-r10.aarch64 132/1174
Running scriptlet: libwrap0-7.6-r10.aarch64 132/1174
Installing : libaio1-0.3.110-r0.aarch64 133/1174
Running scriptlet: libaio1-0.3.110-r0.aarch64 133/1174
Installing : iptables-1.6.2-r0.aarch64 134/1174
Running scriptlet: iptables-1.6.2-r0.aarch64 134/1174
Installing : gzip-1.9-r0.aarch64 135/1174
Running scriptlet: gzip-1.9-r0.aarch64 135/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/gunzip to /bin/gunzip.gzip
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/gzip to /bin/gzip.gzip
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/zcat to /bin/zcat.gzip
Installing : libpcre1-8.41-r0.aarch64 136/1174
Running scriptlet: libpcre1-8.41-r0.aarch64 136/1174
Installing : libglib-2.0-0-1:2.54.3-r0.aarch64 137/1174
Running scriptlet: libglib-2.0-0-1:2.54.3-r0.aarch64 137/1174
Installing : gstreamer1.0-1.14.4.imx-r0.aarch64 138/1174
Running scriptlet: gstreamer1.0-1.14.4.imx-r0.aarch64 138/1174
Installing : libgstvideo-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 139/1174
Running scriptlet: libgstvideo-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 139/1174
Installing : libgsttag-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 140/1174
Running scriptlet: libgsttag-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 140/1174
Installing : libgstaudio-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 141/1174
Running scriptlet: libgstaudio-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 141/1174
Installing : libgstpbutils-1.0-0-1.14.4.imx-r0.aarch64_mx8m 142/1174
Running scriptlet: libgstpbutils-1.0-0-1.14.4.imx-r0.aarch64_mx8m 142/1174
Installing : libgstapp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 143/1174
Running scriptlet: libgstapp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 143/1174
Installing : libgstrtp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 144/1174
Running scriptlet: libgstrtp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 144/1174
Installing : libgstallocators-1.0-0-1.14.4.imx-r0.aarch64_m 145/1174
Running scriptlet: libgstallocators-1.0-0-1.14.4.imx-r0.aarch64_m 145/1174
Installing : libgstriff-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 146/1174
Running scriptlet: libgstriff-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 146/1174
Installing : libgstsdp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 147/1174
Running scriptlet: libgstsdp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 147/1174
Installing : libatk-1.0-0-2.26.1-r0.aarch64 148/1174
Running scriptlet: libatk-1.0-0-2.26.1-r0.aarch64 148/1174
Installing : libgsturidownloader-1.0-0-1.14.4.imx-r0.aarch6 149/1174
Running scriptlet: libgsturidownloader-1.0-0-1.14.4.imx-r0.aarch6 149/1174
Installing : libgstadaptivedemux-1.0-0-1.14.4.imx-r0.aarch6 150/1174
Running scriptlet: libgstadaptivedemux-1.0-0-1.14.4.imx-r0.aarch6 150/1174
Installing : libgstbadvideo-1.0-0-1.14.4.imx-r0.aarch64_mx8 151/1174
Running scriptlet: libgstbadvideo-1.0-0-1.14.4.imx-r0.aarch64_mx8 151/1174
Installing : libgstcodecparsers-1.0-0-1.14.4.imx-r0.aarch64 152/1174
Running scriptlet: libgstcodecparsers-1.0-0-1.14.4.imx-r0.aarch64 152/1174
Installing : libgstmpegts-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 153/1174
Running scriptlet: libgstmpegts-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 153/1174
Installing : libgstfft-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 154/1174
Running scriptlet: libgstfft-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 154/1174
Installing : libgstrtsp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 155/1174
Running scriptlet: libgstrtsp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 155/1174
Installing : libgstbasecamerabinsrc-1.0-0-1.14.4.imx-r0.aar 156/1174
Running scriptlet: libgstbasecamerabinsrc-1.0-0-1.14.4.imx-r0.aar 156/1174
Installing : gstreamer1.0-plugins-good-id3demux-1.14.4.imx- 157/1174
Installing : libgstplayer-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 158/1174
Running scriptlet: libgstplayer-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 158/1174
Installing : gstreamer1.0-plugins-base-playback-1.14.4.imx- 159/1174
Installing : libgstisoff-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 160/1174
Running scriptlet: libgstisoff-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 160/1174
Installing : libgstrtspserver-1.0-0-1.14.4-r0.aarch64 161/1174
Running scriptlet: libgstrtspserver-1.0-0-1.14.4-r0.aarch64 161/1174
Installing : gstreamer1.0-plugins-base-ogg-1.14.4.imx-r0.aa 162/1174
Installing : gstreamer1.0-plugins-good-wavparse-1.14.4.imx- 163/1174
Installing : gstreamer1.0-plugins-good-avi-1.14.4.imx-r0.aa 164/1174
Installing : gstreamer1.0-plugins-good-isomp4-1.14.4.imx-r0 165/1174
Installing : gstreamer1.0-plugins-good-matroska-1.14.4.imx- 166/1174
Installing : gstreamer1.0-plugins-good-audioparsers-1.14.4. 167/1174
Installing : gstreamer1.0-plugins-good-flv-1.14.4.imx-r0.aa 168/1174
Installing : gstreamer1.0-plugins-base-typefindfunctions-1. 169/1174
Installing : gstreamer1.0-plugins-base-audiotestsrc-1.14.4. 170/1174
Installing : gstreamer1.0-plugins-base-audioconvert-1.14.4. 171/1174
Installing : gstreamer1.0-plugins-base-audioresample-1.14.4 172/1174
Installing : gstreamer1.0-plugins-base-volume-1.14.4.imx-r0 173/1174
Installing : gstreamer1.0-plugins-good-icydemux-1.14.4.imx- 174/1174
Installing : gstreamer1.0-plugins-base-videotestsrc-1.14.4. 175/1174
Installing : gstreamer1.0-plugins-good-navigationtest-1.14. 176/1174
Installing : libgstwayland-1.0-0-1.14.4.imx-r0.aarch64_mx8m 177/1174
Running scriptlet: libgstwayland-1.0-0-1.14.4.imx-r0.aarch64_mx8m 177/1174
Installing : gstreamer1.0-plugins-base-videoconvert-1.14.4. 178/1174
Installing : gstreamer1.0-plugins-base-videoscale-1.14.4.im 179/1174
Installing : gstreamer1.0-plugins-good-debug-1.14.4.imx-r0. 180/1174
Installing : gstreamer1.0-plugins-base-tcp-1.14.4.imx-r0.aa 181/1174
Installing : gstreamer1.0-plugins-good-udp-1.14.4.imx-r0.aa 182/1174
Installing : gstreamer1.0-plugins-base-subparse-1.14.4.imx- 183/1174
Installing : libgstphotography-1.0-0-1.14.4.imx-r0.aarch64_ 184/1174
Running scriptlet: libgstphotography-1.0-0-1.14.4.imx-r0.aarch64_ 184/1174
Installing : gstreamer1.0-plugins-base-gio-1.14.4.imx-r0.aa 185/1174
Installing : gstreamer1.0-plugins-good-autodetect-1.14.4.im 186/1174
Installing : python3-dbus-1.2.6-r0.aarch64 187/1174
Installing : libharfbuzz0-1.7.5-r0.aarch64_mx8mm 188/1174
Running scriptlet: libharfbuzz0-1.7.5-r0.aarch64_mx8mm 188/1174
Installing : bluez5-5.49-r0.aarch64 189/1174
Running scriptlet: bluez5-5.49-r0.aarch64 189/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable bluetooth.service
Try to find location of bluetooth.service...
Found bluetooth.service in /lib/systemd/system/bluetooth.service
WantedBy=bluetooth.target found in bluetooth.service
Enabled bluetooth.service for bluetooth.target.
Enabled bluetooth.service for dbus-org.bluez.service.
Installing : libgudev-1.0-0-232-r0.aarch64 190/1174
Running scriptlet: libgudev-1.0-0-232-r0.aarch64 190/1174
Installing : libxmu6-1:1.1.2-r0.aarch64 191/1174
Running scriptlet: libxmu6-1:1.1.2-r0.aarch64 191/1174
Installing : python3-asyncio-3.5.5-r1.0.aarch64 192/1174
Installing : python3-compile-3.5.5-r1.0.aarch64 193/1174
Installing : python3-netserver-3.5.5-r1.0.aarch64 194/1174
Installing : python-debugger-2.7.15-r1.aarch64 195/1174
Installing : python-plistlib-2.7.15-r1.aarch64 196/1174
Installing : python-numbers-2.7.15-r1.aarch64 197/1174
Installing : python-pydoc-2.7.15-r1.aarch64 198/1174
Installing : python3-debugger-3.5.5-r1.0.aarch64 199/1174
Installing : elfutils-0.170-r0.aarch64 200/1174
Installing : e2fsprogs-mke2fs-1.43.8-r0.aarch64 201/1174
Installing : coreutils-8.29-r0.aarch64 202/1174
Running scriptlet: coreutils-8.29-r0.aarch64 202/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/[ to /usr/bin/lbracket.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/arch to /usr/bin/arch.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/basename to /usr/bin/basename.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/chcon to /usr/bin/chcon.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/cksum to /usr/bin/cksum.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/comm to /usr/bin/comm.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/csplit to /usr/bin/csplit.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/cut to /usr/bin/cut.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/dir to /usr/bin/dir.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/dircolors to /usr/bin/dircolors.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/dirname to /usr/bin/dirname.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/du to /usr/bin/du.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/env to /usr/bin/env.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/expand to /usr/bin/expand.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/expr to /usr/bin/expr.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/factor to /usr/bin/factor.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/fmt to /usr/bin/fmt.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/fold to /usr/bin/fold.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/groups to /usr/bin/groups.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/head to /usr/bin/head.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/hostid to /usr/bin/hostid.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/id to /usr/bin/id.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/install to /usr/bin/install.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/join to /usr/bin/join.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/link to /usr/bin/link.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/logname to /usr/bin/logname.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/md5sum to /usr/bin/md5sum.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/mkfifo to /usr/bin/mkfifo.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/nice to /usr/bin/nice.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/nl to /usr/bin/nl.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/nohup to /usr/bin/nohup.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/nproc to /usr/bin/nproc.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/od to /usr/bin/od.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/paste to /usr/bin/paste.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/pathchk to /usr/bin/pathchk.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/pinky to /usr/bin/pinky.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/pr to /usr/bin/pr.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/printenv to /usr/bin/printenv.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/printf to /usr/bin/printf.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/ptx to /usr/bin/ptx.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/readlink to /usr/bin/readlink.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/realpath to /usr/bin/realpath.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/runcon to /usr/bin/runcon.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/seq to /usr/bin/seq.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sha1sum to /usr/bin/sha1sum.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sha224sum to /usr/bin/sha224sum.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sha256sum to /usr/bin/sha256sum.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sha384sum to /usr/bin/sha384sum.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sha512sum to /usr/bin/sha512sum.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/shred to /usr/bin/shred.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/shuf to /usr/bin/shuf.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sort to /usr/bin/sort.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/split to /usr/bin/split.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/stdbuf to /usr/bin/stdbuf.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sum to /usr/bin/sum.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tac to /usr/bin/tac.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tail to /usr/bin/tail.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tee to /usr/bin/tee.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/test to /usr/bin/test.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/timeout to /usr/bin/timeout.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tr to /usr/bin/tr.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/truncate to /usr/bin/truncate.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tsort to /usr/bin/tsort.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/tty to /usr/bin/tty.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/unexpand to /usr/bin/unexpand.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/uniq to /usr/bin/uniq.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/unlink to /usr/bin/unlink.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/users to /usr/bin/users.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/vdir to /usr/bin/vdir.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/wc to /usr/bin/wc.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/who to /usr/bin/who.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/whoami to /usr/bin/whoami.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/yes to /usr/bin/yes.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/cat to /bin/cat.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/chgrp to /bin/chgrp.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/chmod to /bin/chmod.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/chown to /bin/chown.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/cp to /bin/cp.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/date to /bin/date.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/dd to /bin/dd.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/echo to /bin/echo.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/false to /bin/false.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/hostname to /bin/hostname.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ln to /bin/ln.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ls to /bin/ls.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mkdir to /bin/mkdir.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mknod to /bin/mknod.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mv to /bin/mv.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/pwd to /bin/pwd.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/rm to /bin/rm.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/rmdir to /bin/rmdir.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/sleep to /bin/sleep.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/stty to /bin/stty.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/sync to /bin/sync.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/touch to /bin/touch.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/true to /bin/true.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/uname to /bin/uname.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/stat to /bin/stat.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/chroot to /usr/sbin/chroot.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/base64 to /usr/bin/base64.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mktemp to /usr/bin/mktemp.coreutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/df to /usr/bin/df.coreutils
Installing : acl-2.2.52-r0.aarch64 203/1174
Installing : logrotate-3.13.0-r0.aarch64 204/1174
Running scriptlet: logrotate-3.13.0-r0.aarch64 204/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable logrotate.service logrotate.timer
Try to find location of logrotate.service...
Found logrotate.service in /lib/systemd/system/logrotate.service
Try to find location of logrotate.timer...
Found logrotate.timer in /lib/systemd/system/logrotate.timer
WantedBy=timers.target found in logrotate.timer
Enabled logrotate.timer for timers.target.
Installing : attr-2.4.47-r0.aarch64 205/1174
Installing : libxcursor1-1:1.1.15-r0.aarch64 206/1174
Running scriptlet: libxcursor1-1:1.1.15-r0.aarch64 206/1174
Installing : python3-plistlib-3.5.5-r1.0.aarch64 207/1174
Installing : libflac8-1.3.2-r0.aarch64 208/1174
Running scriptlet: libflac8-1.3.2-r0.aarch64 208/1174
Installing : gstreamer1.0-plugins-good-flac-1.14.4.imx-r0.a 209/1174
Installing : libvorbis-1.3.5-r1.aarch64 210/1174
Running scriptlet: libvorbis-1.3.5-r1.aarch64 210/1174
Installing : libsndfile1-1.0.28-r0.aarch64 211/1174
Running scriptlet: libsndfile1-1.0.28-r0.aarch64 211/1174
Installing : libpanel5-6.0+20171125-r0.aarch64 212/1174
Running scriptlet: libpanel5-6.0+20171125-r0.aarch64 212/1174
Installing : iw-4.14-r0.aarch64 213/1174
Installing : libpanelw5-6.0+20171125-r0.aarch64 214/1174
Running scriptlet: libpanelw5-6.0+20171125-r0.aarch64 214/1174
Installing : python3-codecs-3.5.5-r1.0.aarch64 215/1174
Installing : python3-distutils-3.5.5-r1.0.aarch64 216/1174
Installing : python3-fcntl-3.5.5-r1.0.aarch64 217/1174
Installing : python3-numbers-3.5.5-r1.0.aarch64 218/1174
Installing : python-json-2.7.15-r1.aarch64 219/1174
Installing : python-compile-2.7.15-r1.aarch64 220/1174
Installing : python-distutils-2.7.15-r1.aarch64 221/1174
Installing : python-html-2.7.15-r1.aarch64 222/1174
Installing : python-resource-2.7.15-r1.aarch64 223/1174
Installing : python-stringold-2.7.15-r1.aarch64 224/1174
Installing : gawk-4.2.1-r0.aarch64 225/1174
Running scriptlet: gawk-4.2.1-r0.aarch64 225/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/awk to /usr/bin/gawk
Installing : libxrandr2-1:1.5.1-r0.aarch64 226/1174
Running scriptlet: libxrandr2-1:1.5.1-r0.aarch64 226/1174
Installing : libxv1-1.0.11-r0.aarch64 227/1174
Running scriptlet: libxv1-1.0.11-r0.aarch64 227/1174
Installing : libxi6-1:1.7.9-r0.aarch64 228/1174
Running scriptlet: libxi6-1:1.7.9-r0.aarch64 228/1174
Installing : libxtst6-1:1.2.3-r0.aarch64 229/1174
Running scriptlet: libxtst6-1:1.2.3-r0.aarch64 229/1174
Installing : libpulsecommon-11.1-r0.aarch64_mx8mm 230/1174
Installing : libpulse0-11.1-r0.aarch64_mx8mm 231/1174
Running scriptlet: libpulse0-11.1-r0.aarch64_mx8mm 231/1174
Installing : libpulsecore-11.1-r0.aarch64_mx8mm 232/1174
Installing : pulseaudio-lib-protocol-native-11.1-r0.aarch64 233/1174
Installing : pulseaudio-lib-cli-11.1-r0.aarch64_mx8mm 234/1174
Installing : pulseaudio-module-device-manager-11.1-r0.aarch 235/1174
Installing : pulseaudio-module-x11-publish-11.1-r0.aarch64_ 236/1174
Installing : pulseaudio-module-x11-cork-request-11.1-r0.aar 237/1174
Installing : pulseaudio-module-x11-xsmp-11.1-r0.aarch64_mx8 238/1174
Installing : pulseaudio-lib-bluez5-util-11.1-r0.aarch64_mx8 239/1174
Installing : libxpm4-1:3.5.12-r0.aarch64 240/1174
Running scriptlet: libxpm4-1:3.5.12-r0.aarch64 240/1174
Installing : libxcb-shape0-1.12-r0.aarch64 241/1174
Running scriptlet: libxcb-shape0-1.12-r0.aarch64 241/1174
Installing : libxcb-xkb1-1.12-r0.aarch64 242/1174
Running scriptlet: libxcb-xkb1-1.12-r0.aarch64 242/1174
Installing : libxkbcommon-0.8.0-r0.aarch64 243/1174
Running scriptlet: libxkbcommon-0.8.0-r0.aarch64 243/1174
Installing : libv4l-1.12.3-r0.aarch64_mx8mm 244/1174
Running scriptlet: libv4l-1.12.3-r0.aarch64_mx8mm 244/1174
Installing : media-ctl-1.12.3-r0.aarch64_mx8mm 245/1174
Running scriptlet: media-ctl-1.12.3-r0.aarch64_mx8mm 245/1174
Installing : libdrm-etnaviv1-2.4.91.imx-r0.aarch64_mx8mm 246/1174
Running scriptlet: libdrm-etnaviv1-2.4.91.imx-r0.aarch64_mx8mm 246/1174
Installing : libpci3-3.5.6-r0.aarch64 247/1174
Running scriptlet: libpci3-3.5.6-r0.aarch64 247/1174
Installing : pam-plugin-deny-1.3.0-r5.aarch64 248/1174
Installing : pam-plugin-permit-1.3.0-r5.aarch64 249/1174
Installing : pam-plugin-keyinit-1.3.0-r5.aarch64 250/1174
Installing : pam-plugin-loginuid-1.3.0-r5.aarch64 251/1174
Installing : pam-plugin-env-1.3.0-r5.aarch64 252/1174
Installing : file-5.32-r0.aarch64 253/1174
Running scriptlet: file-5.32-r0.aarch64 253/1174
Installing : optee-client-imx-git-r0.aarch64 254/1174
Running scriptlet: optee-client-imx-git-r0.aarch64 254/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable tee-supplicant.service
Try to find location of tee-supplicant.service...
Found tee-supplicant.service in /lib/systemd/system/tee-supplicant.service
WantedBy=basic.target found in tee-supplicant.service
Enabled tee-supplicant.service for basic.target.
Installing : libatomic1-7.3.0-r0.aarch64 255/1174
Running scriptlet: libatomic1-7.3.0-r0.aarch64 255/1174
Installing : libc6-thread-db-2.27-r0.aarch64 256/1174
Running scriptlet: libc6-thread-db-2.27-r0.aarch64 256/1174
Installing : liburcu-0.10.1-r0.aarch64 257/1174
Running scriptlet: liburcu-0.10.1-r0.aarch64 257/1174
Installing : lttng-ust-2:2.10.1-r0.aarch64 258/1174
Running scriptlet: lttng-ust-2:2.10.1-r0.aarch64 258/1174
Installing : cpio-2.12-r0.aarch64 259/1174
Running scriptlet: cpio-2.12-r0.aarch64 259/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/cpio to /bin/cpio.cpio
Installing : tar-1.30-r0.aarch64 260/1174
Running scriptlet: tar-1.30-r0.aarch64 260/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/tar to /bin/tar.tar
Installing : libsbc1-1.3-r0.aarch64 261/1174
Running scriptlet: libsbc1-1.3-r0.aarch64 261/1174
Installing : libxshmfence1-1.2-r0.aarch64 262/1174
Running scriptlet: libxshmfence1-1.2-r0.aarch64 262/1174
Installing : libepoxy0-1.5.0-r0.aarch64_mx8mm 263/1174
Running scriptlet: libepoxy0-1.5.0-r0.aarch64_mx8mm 263/1174
Installing : util-linux-sulogin-2.32.1-r0.aarch64 264/1174
Running scriptlet: util-linux-sulogin-2.32.1-r0.aarch64 264/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/sulogin to /sbin/sulogin.util-linux
Installing : libperl5-5.24.1-r0.aarch64 265/1174
Running scriptlet: libperl5-5.24.1-r0.aarch64 265/1174
Installing : perl-5.24.1-r0.aarch64 266/1174
Installing : perl-module-exporter-heavy-5.24.1-r0.aarch64 267/1174
Installing : perl-module-exporter-5.24.1-r0.aarch64 268/1174
Installing : perl-module-carp-5.24.1-r0.aarch64 269/1174
Installing : perl-module-constant-5.24.1-r0.aarch64 270/1174
Installing : perl-module-dynaloader-5.24.1-r0.aarch64 271/1174
Installing : perl-module-xsloader-5.24.1-r0.aarch64 272/1174
Installing : libusb-1.0-0-1.0.21-r0.aarch64 273/1174
Running scriptlet: libusb-1.0-0-1.0.21-r0.aarch64 273/1174
Installing : lib-aac-dec-arm-elinux3-4.4.5-r0.aarch64_mx8mm 274/1174
Running scriptlet: lib-aac-dec-arm-elinux3-4.4.5-r0.aarch64_mx8mm 274/1174
Installing : lib-mp3-dec-arm-elinux2-4.4.5-r0.aarch64_mx8mm 275/1174
Running scriptlet: lib-mp3-dec-arm-elinux2-4.4.5-r0.aarch64_mx8mm 275/1174
Installing : lib-oggvorbis-dec-arm-elinux2-4.4.5-r0.aarch64 276/1174
Running scriptlet: lib-oggvorbis-dec-arm-elinux2-4.4.5-r0.aarch64 276/1174
Installing : libavahi-common3-0.7-r0.aarch64 277/1174
Running scriptlet: libavahi-common3-0.7-r0.aarch64 277/1174
Installing : libicudata60-60.2-r0.aarch64 278/1174
Running scriptlet: libicudata60-60.2-r0.aarch64 278/1174
Installing : libicuuc60-60.2-r0.aarch64 279/1174
Running scriptlet: libicuuc60-60.2-r0.aarch64 279/1174
Installing : libgdbm5-1.14.1-r0.aarch64 280/1174
Running scriptlet: libgdbm5-1.14.1-r0.aarch64 280/1174
Installing : python-gdbm-2.7.15-r1.aarch64 281/1174
Installing : libgdbm-compat4-1.14.1-r0.aarch64 282/1174
Running scriptlet: libgdbm-compat4-1.14.1-r0.aarch64 282/1174
Installing : ethtool-4.13-r0.aarch64 283/1174
Installing : linux-firmware-cypress-license-1:0.0+git0+d114 284/1174
Installing : python3-db-3.5.5-r1.0.aarch64 285/1174
Installing : libicui18n60-60.2-r0.aarch64 286/1174
Running scriptlet: libicui18n60-60.2-r0.aarch64 286/1174
Installing : libical-2.0.0-r0.aarch64 287/1174
Running scriptlet: libical-2.0.0-r0.aarch64 287/1174
Installing : bluez5-obex-5.49-r0.aarch64 288/1174
Installing : libavahi-core7-0.7-r0.aarch64 289/1174
Running scriptlet: libavahi-core7-0.7-r0.aarch64 289/1174
Installing : gstreamer1.0-plugins-bad-uvch264-1.14.4.imx-r0 290/1174
Installing : usbutils-009-r0.aarch64 291/1174
Running scriptlet: usbutils-009-r0.aarch64 291/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/lsusb to /usr/bin/lsusb.usbutils
Installing : packagegroup-base-usbhost-1.0-r83.imx8mmevk 292/1174
Installing : perl-module-mro-5.24.1-r0.aarch64 293/1174
Installing : perl-module-list-util-5.24.1-r0.aarch64 294/1174
Installing : perl-module-scalar-util-5.24.1-r0.aarch64 295/1174
Installing : perl-module-file-spec-5.24.1-r0.aarch64 296/1174
Installing : perl-module-cwd-5.24.1-r0.aarch64 297/1174
Installing : perl-module-file-spec-unix-5.24.1-r0.aarch64 298/1174
Installing : perl-module-pod-usage-5.24.1-r0.aarch64 299/1174
Installing : perl-module-text-parsewords-5.24.1-r0.aarch64 300/1174
Installing : glibc-mtrace-2.27-r0.aarch64 301/1174
Installing : valgrind-3.13.0-r0.aarch64 302/1174
Installing : lmbench-3.0+a9-r2.aarch64 303/1174
Running scriptlet: lmbench-3.0+a9-r2.aarch64 303/1174
Installing : numactl-2.0.11+git0+ea3a70681c-r0.aarch64 304/1174
Running scriptlet: numactl-2.0.11+git0+ea3a70681c-r0.aarch64 304/1174
Installing : fio-2.9-r0.aarch64 305/1174
Installing : mc-helpers-perl-4.8.20-r0.aarch64 306/1174
Installing : perl-module-overload-numbers-5.24.1-r0.aarch64 307/1174
Installing : perl-module-overloading-5.24.1-r0.aarch64 308/1174
Installing : perl-module-overload-5.24.1-r0.aarch64 309/1174
Installing : perl-module-getopt-long-5.24.1-r0.aarch64 310/1174
Installing : tiobench-0.3.3-r1.aarch64 311/1174
Installing : pulseaudio-module-bluez5-device-11.1-r0.aarch6 312/1174
Installing : gstreamer1.0-plugins-bad-sbc-1.14.4.imx-r0.aar 313/1174
Installing : libatomic-dev-7.3.0-r0.aarch64 314/1174
Installing : optee-test-imx-git-r0.aarch64 315/1174
Installing : sudo-1.8.22-r0.aarch64 316/1174
Installing : powertop-2.9-r0.aarch64 317/1174
Running scriptlet: powertop-2.9-r0.aarch64 317/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/powertop to /usr/sbin/powertop.powertop
Installing : v4l-utils-1.12.3-r0.aarch64_mx8mm 318/1174
Installing : xwininfo-1.1.3-r0.aarch64 319/1174
Installing : libxaw7-7-1:1.0.13-r2.aarch64 320/1174
Running scriptlet: libxaw7-7-1:1.0.13-r2.aarch64 320/1174
Installing : pulseaudio-module-bluez5-discover-11.1-r0.aarc 321/1174
Installing : pulseaudio-module-cli-11.1-r0.aarch64_mx8mm 322/1174
Installing : pulseaudio-lib-protocol-cli-11.1-r0.aarch64_mx 323/1174
Installing : pulseaudio-module-cli-protocol-unix-11.1-r0.aa 324/1174
Installing : pulseaudio-misc-11.1-r0.aarch64_mx8mm 325/1174
Installing : pulseaudio-module-device-restore-11.1-r0.aarch 326/1174
Installing : pulseaudio-module-native-protocol-unix-11.1-r0 327/1174
Installing : pulseaudio-module-stream-restore-11.1-r0.aarch 328/1174
Installing : pulseaudio-module-x11-bell-11.1-r0.aarch64_mx8 329/1174
Installing : pulseaudio-module-bluetooth-discover-11.1-r0.a 330/1174
Installing : pulseaudio-module-bluetooth-policy-11.1-r0.aar 331/1174
Installing : pulseaudio-module-loopback-11.1-r0.aarch64_mx8 332/1174
Installing : pulseaudio-module-switch-on-connect-11.1-r0.aa 333/1174
Installing : pulseaudio-module-always-sink-11.1-r0.aarch64_ 334/1174
Installing : pulseaudio-module-augment-properties-11.1-r0.a 335/1174
Installing : pulseaudio-module-card-restore-11.1-r0.aarch64 336/1174
Installing : pulseaudio-module-default-device-restore-11.1- 337/1174
Installing : pulseaudio-module-detect-11.1-r0.aarch64_mx8mm 338/1174
Installing : pulseaudio-module-filter-apply-11.1-r0.aarch64 339/1174
Installing : pulseaudio-module-filter-heuristics-11.1-r0.aa 340/1174
Installing : pulseaudio-module-intended-roles-11.1-r0.aarch 341/1174
Installing : pulseaudio-module-null-sink-11.1-r0.aarch64_mx 342/1174
Installing : pulseaudio-module-position-event-sounds-11.1-r 343/1174
Installing : pulseaudio-module-rescue-streams-11.1-r0.aarch 344/1174
Installing : pulseaudio-module-role-cork-11.1-r0.aarch64_mx 345/1174
Installing : pulseaudio-module-suspend-on-idle-11.1-r0.aarc 346/1174
Installing : pulseaudio-module-switch-on-port-available-11. 347/1174
Installing : pulseaudio-module-udev-detect-11.1-r0.aarch64_ 348/1174
Installing : gstreamer1.0-plugins-good-pulseaudio-1.14.4.im 349/1174
Installing : xvideo-tests-0.1+git0+7d38b881e9-r0.aarch64 350/1174
Installing : gstreamer1.0-plugins-base-xvimagesink-1.14.4.i 351/1174
Installing : python-setuptools-39.0.0-r0.aarch64 352/1174
Installing : python-profile-2.7.15-r1.aarch64 353/1174
Installing : python3-setuptools-39.0.0-r0.aarch64 354/1174
Installing : python3-mailbox-3.5.5-r1.0.aarch64 355/1174
Installing : python-curses-2.7.15-r1.aarch64 356/1174
Installing : python3-curses-3.5.5-r1.0.aarch64 357/1174
Installing : gstreamer1.0-plugins-bad-sndfile-1.14.4.imx-r0 358/1174
Installing : libsamplerate0-0.1.9-r1.aarch64 359/1174
Running scriptlet: libsamplerate0-0.1.9-r1.aarch64 359/1174
Installing : gstreamer1.0-plugins-base-vorbis-1.14.4.imx-r0 360/1174
Installing : python3-doctest-3.5.5-r1.0.aarch64 361/1174
Installing : python-xmlrpc-2.7.15-r1.aarch64 362/1174
Installing : python-doctest-2.7.15-r1.aarch64 363/1174
Installing : gstreamer1.0-plugins-good-video4linux2-1.14.4. 364/1174
Installing : packagegroup-base-bluetooth-1.0-r83.imx8mmevk 365/1174
Installing : gstreamer1.0-plugins-bad-camerabin-1.14.4.imx- 366/1174
Installing : gstreamer1.0-plugins-bad-waylandsink-1.14.4.im 367/1174
Installing : gstreamer1.0-rtsp-server-rtspclientsink-1.14.4 368/1174
Installing : gstreamer1.0-plugins-bad-dashdemux-1.14.4.imx- 369/1174
Installing : gstreamer1.0-plugins-bad-smoothstreaming-1.14. 370/1174
Installing : imx-gst1.0-plugin-gplay-4.4.5-r0.aarch64_mx8mm 371/1174
Installing : gstreamer1.0-plugins-good-rtsp-1.14.4.imx-r0.a 372/1174
Installing : gstreamer1.0-plugins-bad-audiovisualizers-1.14 373/1174
Installing : gstreamer1.0-plugins-good-audiofx-1.14.4.imx-r 374/1174
Installing : gstreamer1.0-plugins-good-spectrum-1.14.4.imx- 375/1174
Installing : gstreamer1.0-plugins-bad-dvb-1.14.4.imx-r0.aar 376/1174
Installing : gstreamer1.0-plugins-bad-mpegtsdemux-1.14.4.im 377/1174
Installing : gstreamer1.0-plugins-bad-mpegtsmux-1.14.4.imx- 378/1174
Installing : gstreamer1.0-plugins-bad-videoparsersbad-1.14. 379/1174
Installing : gstreamer1.0-plugins-bad-compositor-1.14.4.imx 380/1174
Installing : gstreamer1.0-plugins-bad-hls-1.14.4.imx-r0.aar 381/1174
Installing : gstreamer1.0-plugins-bad-sdpelem-1.14.4.imx-r0 382/1174
Installing : libgstwebrtc-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 383/1174
Running scriptlet: libgstwebrtc-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 383/1174
Installing : gstreamer1.0-plugins-good-wavenc-1.14.4.imx-r0 384/1174
Installing : gstreamer1.0-plugins-bad-kms-1.14.4.imx-r0.aar 385/1174
Installing : gstreamer1.0-plugins-bad-asfmux-1.14.4.imx-r0. 386/1174
Installing : gstreamer1.0-plugins-bad-bluez-1.14.4.imx-r0.a 387/1174
Installing : gstreamer1.0-plugins-bad-rtponvif-1.14.4.imx-r 388/1174
Installing : gstreamer1.0-plugins-good-dtmf-1.14.4.imx-r0.a 389/1174
Installing : gstreamer1.0-plugins-good-rtp-1.14.4.imx-r0.aa 390/1174
Installing : gstreamer1.0-plugins-good-rtpmanager-1.14.4.im 391/1174
Installing : gstreamer1.0-plugins-base-app-1.14.4.imx-r0.aa 392/1174
Installing : gstreamer1.0-plugins-bad-aiff-1.14.4.imx-r0.aa 393/1174
Installing : gstreamer1.0-plugins-bad-mpegpsdemux-1.14.4.im 394/1174
Installing : gstreamer1.0-plugins-base-apps-1.14.4.imx-r0.a 395/1174
Installing : gstreamer1.0-plugins-base-encoding-1.14.4.imx- 396/1174
Installing : gstreamer1.0-plugins-good-apetag-1.14.4.imx-r0 397/1174
Installing : gstreamer1.0-plugins-good-goom-1.14.4.imx-r0.a 398/1174
Installing : gstreamer1.0-plugins-good-goom2k1-1.14.4.imx-r 399/1174
Installing : gstreamer1.0-plugins-good-replaygain-1.14.4.im 400/1174
Installing : librecorder-engine-1.0-0-4.4.5-r0.aarch64_mx8m 401/1174
Running scriptlet: librecorder-engine-1.0-0-4.4.5-r0.aarch64_mx8m 401/1174
Installing : imx-gst1.0-plugin-grecorder-4.4.5-r0.aarch64_m 402/1174
Installing : gstreamer1.0-plugins-bad-accurip-1.14.4.imx-r0 403/1174
Installing : gstreamer1.0-plugins-bad-adpcmdec-1.14.4.imx-r 404/1174
Installing : gstreamer1.0-plugins-bad-adpcmenc-1.14.4.imx-r 405/1174
Installing : gstreamer1.0-plugins-bad-audiobuffersplit-1.14 406/1174
Installing : gstreamer1.0-plugins-bad-audiofxbad-1.14.4.imx 407/1174
Installing : gstreamer1.0-plugins-bad-audiomixmatrix-1.14.4 408/1174
Installing : gstreamer1.0-plugins-bad-decklink-1.14.4.imx-r 409/1174
Installing : gstreamer1.0-plugins-bad-festival-1.14.4.imx-r 410/1174
Installing : gstreamer1.0-plugins-bad-freeverb-1.14.4.imx-r 411/1174
Installing : gstreamer1.0-plugins-bad-inter-1.14.4.imx-r0.a 412/1174
Installing : gstreamer1.0-plugins-bad-legacyrawparse-1.14.4 413/1174
Installing : gstreamer1.0-plugins-bad-mxf-1.14.4.imx-r0.aar 414/1174
Installing : gstreamer1.0-plugins-bad-segmentclip-1.14.4.im 415/1174
Installing : gstreamer1.0-plugins-bad-siren-1.14.4.imx-r0.a 416/1174
Installing : gstreamer1.0-plugins-bad-speed-1.14.4.imx-r0.a 417/1174
Installing : gstreamer1.0-plugins-bad-stereo-1.14.4.imx-r0. 418/1174
Installing : gstreamer1.0-plugins-bad-timecode-1.14.4.imx-r 419/1174
Installing : gstreamer1.0-plugins-bad-videoframe-audiolevel 420/1174
Installing : libgstbadaudio-1.0-0-1.14.4.imx-r0.aarch64_mx8 421/1174
Running scriptlet: libgstbadaudio-1.0-0-1.14.4.imx-r0.aarch64_mx8 421/1174
Installing : gstreamer1.0-plugins-base-adder-1.14.4.imx-r0. 422/1174
Installing : gstreamer1.0-plugins-base-audiomixer-1.14.4.im 423/1174
Installing : gstreamer1.0-plugins-base-audiorate-1.14.4.imx 424/1174
Installing : gstreamer1.0-plugins-base-rawparse-1.14.4.imx- 425/1174
Installing : gstreamer1.0-plugins-good-alaw-1.14.4.imx-r0.a 426/1174
Installing : gstreamer1.0-plugins-good-auparse-1.14.4.imx-r 427/1174
Installing : gstreamer1.0-plugins-good-cutter-1.14.4.imx-r0 428/1174
Installing : gstreamer1.0-plugins-good-equalizer-1.14.4.imx 429/1174
Installing : gstreamer1.0-plugins-good-interleave-1.14.4.im 430/1174
Installing : gstreamer1.0-plugins-good-level-1.14.4.imx-r0. 431/1174
Installing : gstreamer1.0-plugins-good-mulaw-1.14.4.imx-r0. 432/1174
Installing : gstreamer1.0-plugins-good-ossaudio-1.14.4.imx- 433/1174
Installing : gstreamer1.0-plugins-bad-id3tag-1.14.4.imx-r0. 434/1174
Installing : gstreamer1.0-plugins-bad-jpegformat-1.14.4.imx 435/1174
Installing : gstreamer1.0-plugins-bad-midi-1.14.4.imx-r0.aa 436/1174
Installing : gstreamer1.0-plugins-bad-bayer-1.14.4.imx-r0.a 437/1174
Installing : gstreamer1.0-plugins-bad-coloreffects-1.14.4.i 438/1174
Installing : gstreamer1.0-plugins-bad-debugutilsbad-1.14.4. 439/1174
Installing : gstreamer1.0-plugins-bad-dvbsuboverlay-1.14.4. 440/1174
Installing : gstreamer1.0-plugins-bad-dvdspu-1.14.4.imx-r0. 441/1174
Installing : gstreamer1.0-plugins-bad-faceoverlay-1.14.4.im 442/1174
Installing : gstreamer1.0-plugins-bad-fbdevsink-1.14.4.imx- 443/1174
Installing : gstreamer1.0-plugins-bad-fieldanalysis-1.14.4. 444/1174
Installing : gstreamer1.0-plugins-bad-frei0r-1.14.4.imx-r0. 445/1174
Installing : gstreamer1.0-plugins-bad-gaudieffects-1.14.4.i 446/1174
Installing : gstreamer1.0-plugins-bad-geometrictransform-1. 447/1174
Installing : gstreamer1.0-plugins-bad-interlace-1.14.4.imx- 448/1174
Installing : gstreamer1.0-plugins-bad-ivtc-1.14.4.imx-r0.aa 449/1174
Installing : gstreamer1.0-plugins-bad-pnm-1.14.4.imx-r0.aar 450/1174
Installing : gstreamer1.0-plugins-bad-rfbsrc-1.14.4.imx-r0. 451/1174
Installing : gstreamer1.0-plugins-bad-smooth-1.14.4.imx-r0. 452/1174
Installing : gstreamer1.0-plugins-bad-videofiltersbad-1.14. 453/1174
Installing : gstreamer1.0-plugins-bad-videosignal-1.14.4.im 454/1174
Installing : gstreamer1.0-plugins-bad-vmnc-1.14.4.imx-r0.aa 455/1174
Installing : gstreamer1.0-plugins-bad-y4mdec-1.14.4.imx-r0. 456/1174
Installing : gstreamer1.0-plugins-bad-yadif-1.14.4.imx-r0.a 457/1174
Installing : gstreamer1.0-plugins-base-pbtypes-1.14.4.imx-r 458/1174
Installing : gstreamer1.0-plugins-base-videorate-1.14.4.imx 459/1174
Installing : gstreamer1.0-plugins-base-ximagesink-1.14.4.im 460/1174
Installing : gstreamer1.0-plugins-good-alpha-1.14.4.imx-r0. 461/1174
Installing : gstreamer1.0-plugins-good-alphacolor-1.14.4.im 462/1174
Installing : gstreamer1.0-plugins-good-deinterlace-1.14.4.i 463/1174
Installing : gstreamer1.0-plugins-good-effectv-1.14.4.imx-r 464/1174
Installing : gstreamer1.0-plugins-good-jpeg-1.14.4.imx-r0.a 465/1174
Installing : gstreamer1.0-plugins-good-multifile-1.14.4.imx 466/1174
Installing : gstreamer1.0-plugins-good-png-1.14.4.imx-r0.aa 467/1174
Installing : gstreamer1.0-plugins-good-shapewipe-1.14.4.imx 468/1174
Installing : gstreamer1.0-plugins-good-smpte-1.14.4.imx-r0. 469/1174
Installing : gstreamer1.0-plugins-good-videobox-1.14.4.imx- 470/1174
Installing : gstreamer1.0-plugins-good-videocrop-1.14.4.imx 471/1174
Installing : gstreamer1.0-plugins-good-videofilter-1.14.4.i 472/1174
Installing : gstreamer1.0-plugins-good-videomixer-1.14.4.im 473/1174
Installing : gstreamer1.0-plugins-good-ximagesrc-1.14.4.imx 474/1174
Installing : gstreamer1.0-plugins-good-y4menc-1.14.4.imx-r0 475/1174
Installing : gstreamer1.0-plugins-bad-audiolatency-1.14.4.i 476/1174
Installing : gstreamer1.0-plugins-bad-autoconvert-1.14.4.im 477/1174
Installing : gstreamer1.0-plugins-bad-bz2-1.14.4.imx-r0.aar 478/1174
Installing : gstreamer1.0-plugins-bad-dtls-1.14.4.imx-r0.aa 479/1174
Installing : gstreamer1.0-plugins-bad-gdp-1.14.4.imx-r0.aar 480/1174
Installing : gstreamer1.0-plugins-bad-ipcpipeline-1.14.4.im 481/1174
Installing : gstreamer1.0-plugins-bad-ivfparse-1.14.4.imx-r 482/1174
Installing : gstreamer1.0-plugins-bad-jp2kdecimator-1.14.4. 483/1174
Installing : gstreamer1.0-plugins-bad-mpegpsmux-1.14.4.imx- 484/1174
Installing : gstreamer1.0-plugins-bad-netsim-1.14.4.imx-r0. 485/1174
Installing : gstreamer1.0-plugins-bad-pcapparse-1.14.4.imx- 486/1174
Installing : gstreamer1.0-plugins-bad-proxy-1.14.4.imx-r0.a 487/1174
Installing : gstreamer1.0-plugins-bad-removesilence-1.14.4. 488/1174
Installing : gstreamer1.0-plugins-bad-shm-1.14.4.imx-r0.aar 489/1174
Installing : gstreamer1.0-plugins-bad-subenc-1.14.4.imx-r0. 490/1174
Installing : gstreamer1.0-plugins-bad-vcdsrc-1.14.4.imx-r0. 491/1174
Installing : libgstinsertbin-1.0-0-1.14.4.imx-r0.aarch64_mx 492/1174
Running scriptlet: libgstinsertbin-1.0-0-1.14.4.imx-r0.aarch64_mx 492/1174
Installing : gstreamer1.0-plugins-good-flxdec-1.14.4.imx-r0 493/1174
Installing : gstreamer1.0-plugins-good-imagefreeze-1.14.4.i 494/1174
Installing : gstreamer1.0-plugins-good-multipart-1.14.4.imx 495/1174
Installing : babeltrace-1.5.4-r0.aarch64 496/1174
Running scriptlet: babeltrace-1.5.4-r0.aarch64 496/1174
Installing : blktool-4+7-r0.aarch64 497/1174
Installing : bluez5-noinst-tools-5.49-r0.aarch64 498/1174
Installing : packagegroup-core-full-cmdline-libs-1.0-r6.noa 499/1174
Installing : libdbus-glib-1-2-0.108-r0.aarch64 500/1174
Running scriptlet: libdbus-glib-1-2-0.108-r0.aarch64 500/1174
Installing : consolekit-0.4.6-r0.aarch64 501/1174
Running scriptlet: consolekit-0.4.6-r0.aarch64 501/1174
Installing : pulseaudio-module-console-kit-11.1-r0.aarch64_ 502/1174
Installing : libuser-0.62-r0.aarch64 503/1174
Running scriptlet: libuser-0.62-r0.aarch64 503/1174
Installing : libsoup-2.4-2.60.3-r0.aarch64 504/1174
Running scriptlet: libsoup-2.4-2.60.3-r0.aarch64 504/1174
Installing : gstreamer1.0-plugins-good-soup-1.14.4.imx-r0.a 505/1174
Installing : packagegroup-fsl-gstreamer1.0-network-base-1.0 506/1174
Installing : shared-mime-info-1.9-r0.aarch64 507/1174
Installing : libgdk-pixbuf-2.0-0-2.36.11-r0.aarch64 508/1174
Running scriptlet: libgdk-pixbuf-2.0-0-2.36.11-r0.aarch64 508/1174
Installing : gstreamer1.0-plugins-good-gdkpixbuf-1.14.4.imx 509/1174
Installing : libglib-2.0-utils-1:2.54.3-r0.aarch64 510/1174
Installing : gobject-introspection-1.54.1-r0.aarch64 511/1174
Running scriptlet: gobject-introspection-1.54.1-r0.aarch64 511/1174
Installing : libjson-glib-1.0-0-1.4.2-r0.aarch64 512/1174
Running scriptlet: libjson-glib-1.0-0-1.4.2-r0.aarch64 512/1174
Installing : libcroco-0.6.12-r0.aarch64 513/1174
Running scriptlet: libcroco-0.6.12-r0.aarch64 513/1174
Installing : grep-3.1-r0.aarch64 514/1174
Running scriptlet: grep-3.1-r0.aarch64 514/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/grep to /bin/grep.grep
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/egrep to /bin/egrep.grep
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/fgrep to /bin/fgrep.grep
Installing : slang-2.3.2-r0.aarch64 515/1174
Running scriptlet: slang-2.3.2-r0.aarch64 515/1174
Installing : tcp-wrappers-7.6-r10.aarch64 516/1174
Installing : tcl-8.6.8-r0.aarch64 517/1174
Installing : expect-5.45.4-r0.aarch64 518/1174
Running scriptlet: expect-5.45.4-r0.aarch64 518/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/mkpasswd to /usr/bin/mkpasswd.expect
Installing : udev-extraconf-1.1-r0.aarch64 519/1174
Installing : python-mailbox-2.7.15-r1.aarch64 520/1174
Installing : python-robotparser-2.7.15-r1.aarch64 521/1174
Installing : python-audio-2.7.15-r1.aarch64 522/1174
Installing : python-compiler-2.7.15-r1.aarch64 523/1174
Installing : python-logging-2.7.15-r1.aarch64 524/1174
Installing : python-multiprocessing-2.7.15-r1.aarch64 525/1174
Installing : python-smtpd-2.7.15-r1.aarch64 526/1174
Installing : python-terminal-2.7.15-r1.aarch64 527/1174
Installing : python-argparse-2.7.15-r1.aarch64 528/1174
Installing : python3-pydoc-3.5.5-r1.0.aarch64 529/1174
Installing : python3-smtpd-3.5.5-r1.0.aarch64 530/1174
Installing : python3-terminal-3.5.5-r1.0.aarch64 531/1174
Installing : glibc-gconv-cp1252-2.27-r0.aarch64 532/1174
Installing : glibc-gconv-ibm850-2.27-r0.aarch64 533/1174
Installing : glibc-gconv-iso8859-1-2.27-r0.aarch64 534/1174
Installing : glibc-gconv-iso8859-15-2.27-r0.aarch64 535/1174
Installing : e2fsprogs-resize2fs-1.43.8-r0.aarch64 536/1174
Installing : iputils-ping-s20161105-r0.aarch64 537/1174
Running scriptlet: iputils-ping-s20161105-r0.aarch64 537/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ping to /bin/ping.iputils
Installing : python3-sqlite3-3.5.5-r1.0.aarch64 538/1174
Installing : python-sqlite3-2.7.15-r1.aarch64 539/1174
Installing : fontconfig-utils-2.12.6-r0.aarch64 540/1174
Installing : nfs-utils-mount-2.1.1-r0.aarch64 541/1174
Installing : python3-runpy-3.5.5-r1.0.aarch64 542/1174
Installing : patch-2.7.6-r0.aarch64 543/1174
Running scriptlet: patch-2.7.6-r0.aarch64 543/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/patch to /usr/bin/patch.patch
Installing : hostapd-2.6-r0.aarch64 544/1174
Running scriptlet: hostapd-2.6-r0.aarch64 544/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux disable hostapd.service
Try to find location of hostapd.service...
Found hostapd.service in /lib/systemd/system/hostapd.service
WantedBy=multi-user.target found in hostapd.service
Disabled hostapd.service for multi-user.target.
Installing : python-runpy-2.7.15-r1.aarch64 545/1174
Installing : python3-xmlrpc-3.5.5-r1.0.aarch64 546/1174
Installing : e2fsprogs-badblocks-1.43.8-r0.aarch64 547/1174
Installing : bzip2-1.0.6-r5.aarch64 548/1174
Running scriptlet: bzip2-1.0.6-r5.aarch64 548/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/bunzip2 to /usr/bin/bunzip2.bzip2
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/bzcat to /usr/bin/bzcat.bzip2
Installing : libtheora-1.1.1-r1.aarch64 549/1174
Running scriptlet: libtheora-1.1.1-r1.aarch64 549/1174
Installing : gstreamer1.0-plugins-base-theora-1.14.4.imx-r0 550/1174
Installing : dbench-4.0-r0.aarch64 551/1174
Installing : kexec-2.0.16-r1.aarch64 552/1174
Installing : libtiff5-4.0.9-r0.aarch64 553/1174
Running scriptlet: libtiff5-4.0.9-r0.aarch64 553/1174
Installing : devil-1.8.0-r0.imx8mmevk 554/1174
Running scriptlet: devil-1.8.0-r0.imx8mmevk 554/1174
Installing : libss2-1.43.8-r0.aarch64 555/1174
Running scriptlet: libss2-1.43.8-r0.aarch64 555/1174
Installing : e2fsprogs-1.43.8-r0.aarch64 556/1174
Running scriptlet: e2fsprogs-1.43.8-r0.aarch64 556/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/chattr to /bin/chattr.e2fsprogs
Installing : util-linux-losetup-2.32.1-r0.aarch64 557/1174
Running scriptlet: util-linux-losetup-2.32.1-r0.aarch64 557/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/losetup to /sbin/losetup.util-linux
Installing : util-linux-lsblk-2.32.1-r0.aarch64 558/1174
Installing : util-linux-swaponoff-2.32.1-r0.aarch64 559/1174
Running scriptlet: util-linux-swaponoff-2.32.1-r0.aarch64 559/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/swapoff to /sbin/swapoff.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/swapon to /sbin/swapon.util-linux
Installing : libformw5-6.0+20171125-r0.aarch64 560/1174
Running scriptlet: libformw5-6.0+20171125-r0.aarch64 560/1174
Installing : libmenuw5-6.0+20171125-r0.aarch64 561/1174
Running scriptlet: libmenuw5-6.0+20171125-r0.aarch64 561/1174
Installing : python3-2to3-3.5.5-r1.0.aarch64 562/1174
Installing : python3-audio-3.5.5-r1.0.aarch64 563/1174
Installing : python3-idle-3.5.5-r1.0.aarch64 564/1174
Installing : python3-image-3.5.5-r1.0.aarch64 565/1174
Installing : python3-json-3.5.5-r1.0.aarch64 566/1174
Installing : python3-mmap-3.5.5-r1.0.aarch64 567/1174
Installing : python3-profile-3.5.5-r1.0.aarch64 568/1174
Installing : python3-resource-3.5.5-r1.0.aarch64 569/1174
Installing : python3-syslog-3.5.5-r1.0.aarch64 570/1174
Installing : python3-tkinter-3.5.5-r1.0.aarch64 571/1174
Installing : python3-typing-3.5.5-r1.0.aarch64 572/1174
Installing : python3-modules-3.5.5-r1.0.aarch64 573/1174
Installing : gdb-8.0.1-r0.aarch64 574/1174
Installing : python-2to3-2.7.15-r1.aarch64 575/1174
Installing : python-hotshot-2.7.15-r1.aarch64 576/1174
Installing : python-idle-2.7.15-r1.aarch64 577/1174
Installing : python-image-2.7.15-r1.aarch64 578/1174
Installing : python-mmap-2.7.15-r1.aarch64 579/1174
Installing : python-re-2.7.15-r1.aarch64 580/1174
Installing : python-syslog-2.7.15-r1.aarch64 581/1174
Installing : python-tkinter-2.7.15-r1.aarch64 582/1174
Installing : libxinerama1-1:1.1.3-r0.aarch64 583/1174
Running scriptlet: libxinerama1-1:1.1.3-r0.aarch64 583/1174
Installing : libxres1-1:1.2.0-r0.aarch64 584/1174
Running scriptlet: libxres1-1:1.2.0-r0.aarch64 584/1174
Installing : xrestop-0.4-r3.aarch64 585/1174
Installing : libxxf86vm1-1:1.1.4-r0.aarch64 586/1174
Running scriptlet: libxxf86vm1-1:1.1.4-r0.aarch64 586/1174
Installing : xprop-1:1.2.2-r0.aarch64 587/1174
Installing : libxmuu1-1:1.1.2-r0.aarch64 588/1174
Running scriptlet: libxmuu1-1:1.1.2-r0.aarch64 588/1174
Installing : x11perf-1:1.6.0-r0.aarch64 589/1174
Installing : tk-lib-8.6.8-r0.aarch64 590/1174
Installing : tk-8.6.8-r0.aarch64 591/1174
Installing : libxcomposite1-1:0.4.4-r0.aarch64 592/1174
Running scriptlet: libxcomposite1-1:0.4.4-r0.aarch64 592/1174
Installing : libxkbfile1-1:1.0.9-r0.aarch64 593/1174
Running scriptlet: libxkbfile1-1:1.0.9-r0.aarch64 593/1174
Installing : libxcb-composite0-1.12-r0.aarch64 594/1174
Running scriptlet: libxcb-composite0-1.12-r0.aarch64 594/1174
Installing : libxcb-xfixes0-1.12-r0.aarch64 595/1174
Running scriptlet: libxcb-xfixes0-1.12-r0.aarch64 595/1174
Installing : util-linux-mount-2.32.1-r0.aarch64 596/1174
Running scriptlet: util-linux-mount-2.32.1-r0.aarch64 596/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mount to /bin/mount.util-linux
Installing : util-linux-umount-2.32.1-r0.aarch64 597/1174
Running scriptlet: util-linux-umount-2.32.1-r0.aarch64 597/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/umount to /bin/umount.util-linux
Installing : cryptodev-tests-1.9-r0.aarch64 598/1174
Installing : ntpdate-4.2.8p11-r0.aarch64 599/1174
Running scriptlet: ntpdate-4.2.8p11-r0.aarch64 599/1174
adding crontab
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable ntpdate.service
Try to find location of ntpdate.service...
Found ntpdate.service in /lib/systemd/system/ntpdate.service
WantedBy=multi-user.target found in ntpdate.service
Enabled ntpdate.service for multi-user.target.
Installing : libkms1-2.4.91.imx-r0.aarch64_mx8mm 600/1174
Running scriptlet: libkms1-2.4.91.imx-r0.aarch64_mx8mm 600/1174
Installing : libdrm-tests-2.4.91.imx-r0.aarch64_mx8mm 601/1174
Installing : libdrm-freedreno1-2.4.91.imx-r0.aarch64_mx8mm 602/1174
Running scriptlet: libdrm-freedreno1-2.4.91.imx-r0.aarch64_mx8mm 602/1174
Installing : arm-compute-library-18.11+git0+64441b79b8-r0.a 603/1174
Running scriptlet: arm-compute-library-18.11+git0+64441b79b8-r0.a 603/1174
Installing : gdbserver-8.0.1-r0.aarch64 604/1174
Installing : bonnie++-1.03e-r0.aarch64 605/1174
Installing : libstdc++-dev-7.3.0-r0.aarch64 606/1174
Installing : libassimp4-4.1.0-r0.aarch64 607/1174
Running scriptlet: libassimp4-4.1.0-r0.aarch64 607/1174
Installing : libtag1-1.11.1-r0.aarch64 608/1174
Running scriptlet: libtag1-1.11.1-r0.aarch64 608/1174
Installing : gstreamer1.0-plugins-good-taglib-1.14.4.imx-r0 609/1174
Installing : libgcc-s-dev-7.3.0-r0.aarch64 610/1174
Installing : libunwind-1.2.1-r0.aarch64 611/1174
Running scriptlet: libunwind-1.2.1-r0.aarch64 611/1174
Installing : minicom-2.7.1-r0.aarch64 612/1174
Installing : less-529-r0.aarch64 613/1174
Running scriptlet: less-529-r0.aarch64 613/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/less to /usr/bin/less.less
Installing : ncurses-6.0+20171125-r0.aarch64 614/1174
Installing : pstree-23.0-r0.aarch64 615/1174
Installing : python-misc-2.7.15-r1.aarch64 616/1174
Installing : pam-plugin-warn-1.3.0-r5.aarch64 617/1174
Installing : libpam-runtime-1.3.0-r5.aarch64 618/1174
Installing : dropbear-2017.75-r0.aarch64 619/1174
Running scriptlet: dropbear-2017.75-r0.aarch64 619/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/scp to /usr/sbin/dropbearmulti
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/ssh to /usr/sbin/dropbearmulti
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable dropbear.socket
Try to find location of dropbear.socket...
Found dropbear.socket in /lib/systemd/system/dropbear.socket
WantedBy=sockets.target found in dropbear.socket
Enabled dropbear.socket for sockets.target.
Also=dropbearkey.service found in dropbear.socket
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable dropbearkey.service
Try to find location of dropbearkey.service...
Found dropbearkey.service in /lib/systemd/system/dropbearkey.service
Installing : pam-plugin-faildelay-1.3.0-r5.aarch64 620/1174
Installing : pam-plugin-group-1.3.0-r5.aarch64 621/1174
Installing : pam-plugin-lastlog-1.3.0-r5.aarch64 622/1174
Installing : pam-plugin-mail-1.3.0-r5.aarch64 623/1174
Installing : pam-plugin-motd-1.3.0-r5.aarch64 624/1174
Installing : pam-plugin-nologin-1.3.0-r5.aarch64 625/1174
Installing : pam-plugin-rootok-1.3.0-r5.aarch64 626/1174
Installing : pam-plugin-securetty-1.3.0-r5.aarch64 627/1174
Installing : pam-plugin-shells-1.3.0-r5.aarch64 628/1174
Installing : shadow-base-4.2.1-r0.aarch64 629/1174
Running scriptlet: shadow-base-4.2.1-r0.aarch64 629/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/newgrp to /usr/bin/newgrp.shadow
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/groups to /usr/bin/groups.shadow
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/login to /bin/login.shadow
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/su to /bin/su.shadow
Installing : pam-plugin-access-1.3.0-r5.aarch64 630/1174
Installing : util-linux-runuser-2.32.1-r0.aarch64 631/1174
Installing : util-linux-su-2.32.1-r0.aarch64 632/1174
Installing : util-linux-2.32.1-r0.aarch64 633/1174
Running scriptlet: util-linux-2.32.1-r0.aarch64 633/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/dmesg to /bin/dmesg.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/kill to /bin/kill.procps
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/more to /bin/more.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/mkswap to /sbin/mkswap.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/blockdev to /sbin/blockdev.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/pivot_root to /sbin/pivot_root.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/switch_root to /sbin/switch_root.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/hexdump to /usr/bin/hexdump.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/last to /usr/bin/last.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/lastb to /usr/bin/lastb.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/logger to /usr/bin/logger.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/mesg to /usr/bin/mesg.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/renice to /usr/bin/renice.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/wall to /usr/bin/wall.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/setsid to /usr/bin/setsid.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/chrt to /usr/bin/chrt.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/flock to /usr/bin/flock.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/utmpdump to /usr/bin/utmpdump.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/eject to /usr/bin/eject.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/nologin to /sbin/nologin.util-linux
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/taskset to /usr/bin/taskset.util-linux
Installing : imx-gpu-apitrace-7.1.0-r0.aarch64_mx8mm 634/1174
Installing : libevent-2.1.8-r0.aarch64 635/1174
Running scriptlet: libevent-2.1.8-r0.aarch64 635/1174
Installing : iputils-arping-s20161105-r0.aarch64 636/1174
Installing : iputils-clockdiff-s20161105-r0.aarch64 637/1174
Installing : iputils-traceroute6-s20161105-r0.aarch64 638/1174
Installing : cracklib-2.9.5-r0.aarch64 639/1174
Running scriptlet: cracklib-2.9.5-r0.aarch64 639/1174
Installing : libfontenc1-1:1.1.3-r0.aarch64 640/1174
Running scriptlet: libfontenc1-1:1.1.3-r0.aarch64 640/1174
Installing : libxfont2-2-2.0.3-r0.aarch64 641/1174
Running scriptlet: libxfont2-2-2.0.3-r0.aarch64 641/1174
Installing : libbfd-2.30-r0.aarch64 642/1174
Running scriptlet: libbfd-2.30-r0.aarch64 642/1174
Installing : psplash-0.1+git0+2015f7073e-r15.aarch64 643/1174
Running scriptlet: psplash-0.1+git0+2015f7073e-r15.aarch64 643/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask psplash.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/psplash.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable psplash-start.service psplash-basic.service psplash-network.service psplash-quit.service
Try to find location of psplash-start.service...
Found psplash-start.service in /lib/systemd/system/psplash-start.service
WantedBy=sysinit.target found in psplash-start.service
Enabled psplash-start.service for sysinit.target.
Try to find location of psplash-basic.service...
Found psplash-basic.service in /lib/systemd/system/psplash-basic.service
WantedBy=basic.target found in psplash-basic.service
Enabled psplash-basic.service for basic.target.
Try to find location of psplash-network.service...
Found psplash-network.service in /lib/systemd/system/psplash-network.service
WantedBy=network.target found in psplash-network.service
Enabled psplash-network.service for network.target.
Try to find location of psplash-quit.service...
Found psplash-quit.service in /lib/systemd/system/psplash-quit.service
WantedBy=multi-user.target found in psplash-quit.service
Enabled psplash-quit.service for multi-user.target.
Installing : strace-4.20-r0.aarch64 644/1174
Installing : iperf3-3.2-r0.aarch64 645/1174
Running scriptlet: iperf3-3.2-r0.aarch64 645/1174
Installing : kbd-2.0.4-r0.aarch64 646/1174
Running scriptlet: kbd-2.0.4-r0.aarch64 646/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/chvt to /usr/bin/chvt.kbd
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/deallocvt to /usr/bin/deallocvt.kbd
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/fgconsole to /usr/bin/fgconsole.kbd
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/openvt to /usr/bin/openvt.kbd
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/showkey to /usr/bin/showkey.kbd
Installing : tinycompress-1.1.6-r0.aarch64 647/1174
Running scriptlet: tinycompress-1.1.6-r0.aarch64 647/1174
Installing : lrzsz-0.12.20-r6.aarch64 648/1174
Running scriptlet: lrzsz-0.12.20-r6.aarch64 648/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/rz to /usr/bin/lrz
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/rx to /usr/bin/lrz
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/rb to /usr/bin/lrz
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sz to /usr/bin/lsz
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sx to /usr/bin/lsz
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/sb to /usr/bin/lsz
Installing : cpufrequtils-008-r5.aarch64 649/1174
Running scriptlet: cpufrequtils-008-r5.aarch64 649/1174
Installing : fbset-2.1-r4.aarch64 650/1174
Running scriptlet: fbset-2.1-r4.aarch64 650/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/fbset to /usr/sbin/fbset.real
Installing : fsl-rc-local-1.0-r0.aarch64 651/1174
Installing : i2c-tools-4.0-r0.aarch64 652/1174
Running scriptlet: i2c-tools-4.0-r0.aarch64 652/1174
Installing : mtd-utils-2.0.1+0+9c6173559f-r0.aarch64 653/1174
Running scriptlet: mtd-utils-2.0.1+0+9c6173559f-r0.aarch64 653/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/flashcp to /usr/sbin/flashcp.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/flash_eraseall to /usr/sbin/flash_eraseall.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/flash_lock to /usr/sbin/flash_lock.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/flash_unlock to /usr/sbin/flash_unlock.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/nanddump to /usr/sbin/nanddump.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/nandwrite to /usr/sbin/nandwrite.mtd-utils
Installing : vlan-1.9-r0.aarch64 654/1174
Running scriptlet: vlan-1.9-r0.aarch64 654/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/vconfig to /sbin/vconfig.vlan
Installing : libsegfault-2.27-r0.aarch64 655/1174
Running scriptlet: libsegfault-2.27-r0.aarch64 655/1174
Installing : libnfsidmap0-0.25-r0.aarch64 656/1174
Running scriptlet: libnfsidmap0-0.25-r0.aarch64 656/1174
Installing : update-rc.d-0.7-r5.noarch 657/1174
Installing : util-linux-agetty-2.32.1-r0.aarch64 658/1174
Running scriptlet: util-linux-agetty-2.32.1-r0.aarch64 658/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/getty to /sbin/agetty
Installing : volatile-binds-1.0-r0.noarch 659/1174
Running scriptlet: volatile-binds-1.0-r0.noarch 659/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable var-volatile-lib.service var-volatile-cache.service var-volatile-spool.service var-volatile-srv.service
Try to find location of var-volatile-lib.service...
Found var-volatile-lib.service in /lib/systemd/system/var-volatile-lib.service
WantedBy=local-fs.target found in var-volatile-lib.service
Enabled var-volatile-lib.service for local-fs.target.
WantedBy=systemd-random-seed.service found in var-volatile-lib.service
Enabled var-volatile-lib.service for systemd-random-seed.service.
Try to find location of var-volatile-cache.service...
Found var-volatile-cache.service in /lib/systemd/system/var-volatile-cache.service
WantedBy=local-fs.target found in var-volatile-cache.service
Enabled var-volatile-cache.service for local-fs.target.
Try to find location of var-volatile-spool.service...
Found var-volatile-spool.service in /lib/systemd/system/var-volatile-spool.service
WantedBy=local-fs.target found in var-volatile-spool.service
Enabled var-volatile-spool.service for local-fs.target.
Try to find location of var-volatile-srv.service...
Found var-volatile-srv.service in /lib/systemd/system/var-volatile-srv.service
WantedBy=local-fs.target found in var-volatile-srv.service
Enabled var-volatile-srv.service for local-fs.target.
Installing : libjson-c3-0.13-r0.aarch64 660/1174
Running scriptlet: libjson-c3-0.13-r0.aarch64 660/1174
Installing : systemtap-3.2-r0.aarch64 661/1174
Installing : tslib-conf-1.15-r0.aarch64 662/1174
Installing : libts0-1.15-r0.aarch64 663/1174
Running scriptlet: libts0-1.15-r0.aarch64 663/1174
Installing : ldd-2.27-r0.aarch64 664/1174
Installing : unzip-1:6.0-r5.aarch64 665/1174
Running scriptlet: unzip-1:6.0-r5.aarch64 665/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/unzip to /usr/bin/unzip.unzip
Installing : which-2.21-r3.aarch64 666/1174
Running scriptlet: which-2.21-r3.aarch64 666/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/which to /usr/bin/which.which
Installing : libevdev-1.5.8-r0.aarch64 667/1174
Running scriptlet: libevdev-1.5.8-r0.aarch64 667/1174
Installing : mtdev-1.1.5-r0.aarch64 668/1174
Running scriptlet: mtdev-1.1.5-r0.aarch64 668/1174
Installing : libinput10-1.9.4-r0.aarch64 669/1174
Running scriptlet: libinput10-1.9.4-r0.aarch64 669/1174
Installing : diffutils-3.6-r0.aarch64 670/1174
Running scriptlet: diffutils-3.6-r0.aarch64 670/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/diff to /usr/bin/diff.diffutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/cmp to /usr/bin/cmp.diffutils
Installing : sysklogd-1.5.1-r0.aarch64 671/1174
Running scriptlet: sysklogd-1.5.1-r0.aarch64 671/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable syslogd.service klogd.service
Try to find location of syslogd.service...
Found syslogd.service in /lib/systemd/system/syslogd.service
WantedBy=multi-user.target found in syslogd.service
Enabled syslogd.service for multi-user.target.
Enabled syslogd.service for syslog.service.
Try to find location of klogd.service...
Found klogd.service in /lib/systemd/system/klogd.service
WantedBy=multi-user.target found in klogd.service
Enabled klogd.service for multi-user.target.
Installing : tzdata-2018f-r0.noarch 672/1174
Running scriptlet: tzdata-2018f-r0.noarch 672/1174
Installing : bc-1.06-r3.aarch64 673/1174
Running scriptlet: bc-1.06-r3.aarch64 673/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/dc to /usr/bin/dc.bc
Installing : ed-1.14.2-r0.aarch64 674/1174
Installing : findutils-4.6.0-r0.aarch64 675/1174
Running scriptlet: findutils-4.6.0-r0.aarch64 675/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/find to /usr/bin/find.findutils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/xargs to /usr/bin/xargs.findutils
Installing : mc-helpers-4.8.20-r0.aarch64 676/1174
Installing : mktemp-1.7-r3.aarch64 677/1174
Running scriptlet: mktemp-1.7-r3.aarch64 677/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mktemp to /usr/bin/mktemp.coreutils
Installing : net-tools-1.60+26-r0.aarch64 678/1174
Running scriptlet: net-tools-1.60+26-r0.aarch64 678/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/arp to /sbin/arp.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/ifconfig to /sbin/ifconfig.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/ipmaddr to /sbin/ipmaddr.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/iptunnel to /sbin/iptunnel.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/mii-tool to /sbin/mii-tool.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/nameif to /sbin/nameif.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/plipconfig to /sbin/plipconfig.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/rarp to /sbin/rarp.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/route to /sbin/route.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/slattach to /sbin/slattach.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/dnsdomainname to /bin/dnsdomainname.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/domainname to /bin/domainname.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/hostname to /bin/hostname.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/netstat to /bin/netstat.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/nisdomainname to /bin/nisdomainname.net-tools
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/ypdomainname to /bin/ypdomainname.net-tools
Installing : sed-4.2.2-r0.aarch64 679/1174
Running scriptlet: sed-4.2.2-r0.aarch64 679/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/sed to /bin/sed.sed
Installing : time-1.8-r0.aarch64 680/1174
Running scriptlet: time-1.8-r0.aarch64 680/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/time to /usr/bin/time.time
Installing : libmnl0-1.0.4-r0.aarch64 681/1174
Running scriptlet: libmnl0-1.0.4-r0.aarch64 681/1174
Installing : iproute2-4.14.1-r0.aarch64 682/1174
Running scriptlet: iproute2-4.14.1-r0.aarch64 682/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/ip to /sbin/ip.iproute2
Installing : liblzo2-2-2.10-r0.aarch64 683/1174
Running scriptlet: liblzo2-2-2.10-r0.aarch64 683/1174
Installing : mtd-utils-ubifs-2.0.1+0+9c6173559f-r0.aarch64 684/1174
Running scriptlet: mtd-utils-ubifs-2.0.1+0+9c6173559f-r0.aarch64 684/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/ubiattach to /usr/sbin/ubiattach.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/ubidetach to /usr/sbin/ubidetach.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/ubimkvol to /usr/sbin/ubimkvol.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/ubirename to /usr/sbin/ubirename.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/ubirmvol to /usr/sbin/ubirmvol.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/ubirsvol to /usr/sbin/ubirsvol.mtd-utils
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/ubiupdatevol to /usr/sbin/ubiupdatevol.mtd-utils
Installing : libpcap1-1.8.1-r0.aarch64 685/1174
Running scriptlet: libpcap1-1.8.1-r0.aarch64 685/1174
Installing : ptpd-2.3.1-r0.aarch64 686/1174
Running scriptlet: ptpd-2.3.1-r0.aarch64 686/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux disable ptpd.service
Try to find location of ptpd.service...
Found ptpd.service in /lib/systemd/system/ptpd.service
WantedBy=multi-user.target found in ptpd.service
Disabled ptpd.service for multi-user.target.
Installing : libc6-extra-nss-2.27-r0.aarch64 687/1174
Running scriptlet: libc6-extra-nss-2.27-r0.aarch64 687/1174
Installing : libcidn1-2.27-r0.aarch64 688/1174
Running scriptlet: libcidn1-2.27-r0.aarch64 688/1174
Installing : libc6-dev-2.27-r0.aarch64 689/1174
Installing : libspeex1-1.2.0-r0.aarch64 690/1174
Running scriptlet: libspeex1-1.2.0-r0.aarch64 690/1174
Installing : gstreamer1.0-plugins-good-speex-1.14.4.imx-r0. 691/1174
Installing : libglapi0-2:17.3.8-r0.aarch64_mx8mm 692/1174
Running scriptlet: libglapi0-2:17.3.8-r0.aarch64_mx8mm 692/1174
Installing : libwebp-0.6.1-r0.aarch64 693/1174
Running scriptlet: libwebp-0.6.1-r0.aarch64 693/1174
Installing : gstreamer1.0-plugins-bad-webp-1.14.4.imx-r0.aa 694/1174
Installing : libunistring2-0.9.9-r0.aarch64 695/1174
Running scriptlet: libunistring2-0.9.9-r0.aarch64 695/1174
Installing : libgnutls30-3.6.1-r0.aarch64 696/1174
Running scriptlet: libgnutls30-3.6.1-r0.aarch64 696/1174
Installing : libcurl4-7.61.0-r0.aarch64 697/1174
Running scriptlet: libcurl4-7.61.0-r0.aarch64 697/1174
Installing : gstreamer1.0-plugins-bad-curl-1.14.4.imx-r0.aa 698/1174
Installing : curl-7.61.0-r0.aarch64 699/1174
Installing : connman-tests-1.35-r0.aarch64 700/1174
Installing : flex-libfl-2.6.0-r0.aarch64 701/1174
Running scriptlet: flex-libfl-2.6.0-r0.aarch64 701/1174
Installing : at-3.1.20-r0.aarch64 702/1174
Running scriptlet: at-3.1.20-r0.aarch64 702/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable atd.service
Try to find location of atd.service...
Found atd.service in /lib/systemd/system/atd.service
WantedBy=multi-user.target found in atd.service
Enabled atd.service for multi-user.target.
Installing : fuser-23.0-r0.aarch64 703/1174
Running scriptlet: fuser-23.0-r0.aarch64 703/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/fuser to /usr/bin/fuser.psmisc
Installing : killall-23.0-r0.aarch64 704/1174
Running scriptlet: killall-23.0-r0.aarch64 704/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/killall to /usr/bin/killall.psmisc
Installing : psmisc-23.0-r0.aarch64 705/1174
Installing : imx-codec-g.711-4.4.5-r0.aarch64_mx8mm 706/1174
Running scriptlet: imx-codec-g.711-4.4.5-r0.aarch64_mx8mm 706/1174
Installing : imx-codec-g.723.1-4.4.5-r0.aarch64_mx8mm 707/1174
Running scriptlet: imx-codec-g.723.1-4.4.5-r0.aarch64_mx8mm 707/1174
Installing : imx-codec-g.726-4.4.5-r0.aarch64_mx8mm 708/1174
Running scriptlet: imx-codec-g.726-4.4.5-r0.aarch64_mx8mm 708/1174
Installing : imx-codec-g.729ab-4.4.5-r0.aarch64_mx8mm 709/1174
Running scriptlet: imx-codec-g.729ab-4.4.5-r0.aarch64_mx8mm 709/1174
Installing : imx-codec-nb-4.4.5-r0.aarch64_mx8mm 710/1174
Running scriptlet: imx-codec-nb-4.4.5-r0.aarch64_mx8mm 710/1174
Installing : imx-codec-wb-4.4.5-r0.aarch64_mx8mm 711/1174
Running scriptlet: imx-codec-wb-4.4.5-r0.aarch64_mx8mm 711/1174
Installing : lib-bsac-dec-arm-elinux2-4.4.5-r0.aarch64_mx8m 712/1174
Running scriptlet: lib-bsac-dec-arm-elinux2-4.4.5-r0.aarch64_mx8m 712/1174
Installing : imx-codec-test-bin-4.4.5-r0.aarch64_mx8mm 713/1174
Installing : libdaemon0-0.14-r0.aarch64 714/1174
Running scriptlet: libdaemon0-0.14-r0.aarch64 714/1174
Installing : db-1:5.3.28-r1.aarch64 715/1174
Running scriptlet: db-1:5.3.28-r1.aarch64 715/1174
Installing : python-bsddb-2.7.15-r1.aarch64 716/1174
Installing : python-db-2.7.15-r1.aarch64 717/1174
Installing : python-modules-2.7.15-r1.aarch64 718/1174
Installing : python-pip-9.0.3-r0.aarch64 719/1174
Installing : imx-vpu-hantro-1.11.0-r0.aarch64_mx8mm 720/1174
Running scriptlet: imx-vpu-hantro-1.11.0-r0.aarch64_mx8mm 720/1174
Installing : libfslvpuwrap3-4.4.5-r0.aarch64_mx8mm 721/1174
Running scriptlet: libfslvpuwrap3-4.4.5-r0.aarch64_mx8mm 721/1174
Installing : libgpg-error0-1.27-r0.aarch64 722/1174
Running scriptlet: libgpg-error0-1.27-r0.aarch64 722/1174
Installing : libgcrypt-1.8.2-r0.aarch64 723/1174
Running scriptlet: libgcrypt-1.8.2-r0.aarch64 723/1174
Installing : wpa-supplicant-2.6-r0.aarch64 724/1174
Running scriptlet: wpa-supplicant-2.6-r0.aarch64 724/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux disable wpa_supplicant.service wpa_supplicant-nl80211@.service wpa_supplicant-wired@.service
Try to find location of wpa_supplicant.service...
Found wpa_supplicant.service in /lib/systemd/system/wpa_supplicant.service
WantedBy=multi-user.target found in wpa_supplicant.service
Disabled wpa_supplicant.service for multi-user.target.
Disabled wpa_supplicant.service for dbus-fi.w1.wpa_supplicant1.service.
Try to find location of template wpa_supplicant-nl80211@.service of instance wpa_supplicant-nl80211@.service...
Found wpa_supplicant-nl80211@.service in /lib/systemd/system/wpa_supplicant-nl80211@.service
Disabled wpa_supplicant-nl80211@.service for multi-user.target.wants/wpa_supplicant-nl80211@%i.service.
Try to find location of template wpa_supplicant-wired@.service of instance wpa_supplicant-wired@.service...
Found wpa_supplicant-wired@.service in /lib/systemd/system/wpa_supplicant-wired@.service
Disabled wpa_supplicant-wired@.service for multi-user.target.wants/wpa_supplicant-wired@%i.service.
Installing : libssp0-7.3.0-r0.aarch64 725/1174
Running scriptlet: libssp0-7.3.0-r0.aarch64 725/1174
Installing : libpciaccess0-0.14-r0.aarch64 726/1174
Running scriptlet: libpciaccess0-0.14-r0.aarch64 726/1174
Installing : xserver-xorg-2:1.19.6-r0.aarch64_mx8mm 727/1174
Installing : iozone3-465-r0.aarch64 728/1174
Installing : nbench-byte-2.2.3-r0.aarch64 729/1174
Installing : can-utils-0.0+gitr0+4c8fb05cb4-r0.aarch64 730/1174
Installing : dosfstools-4.1-r0.aarch64 731/1174
Installing : evtest-1.33+0+ab140a2dab-r0.aarch64 732/1174
Installing : imx-kobs-5.5+git0+02c01d4a3d-r0.aarch64 733/1174
Installing : linuxptp-1.8-r0.aarch64 734/1174
Installing : memtester-4.3.0-r0.aarch64 735/1174
Installing : mmc-utils-0.1-r0.aarch64 736/1174
Installing : sigma-dut-git-r0.aarch64 737/1174
Installing : libc6-utils-2.27-r0.aarch64 738/1174
Installing : m4-1.4.18-r0.aarch64 739/1174
Installing : make-4.2.1-r0.aarch64 740/1174
Installing : packagegroup-core-full-cmdline-dev-utils-1.0-r 741/1174
Installing : makedevs-1.0.1-r0.aarch64 742/1174
Installing : wireless-tools-1:30.pre9-r0.aarch64 743/1174
Installing : packagegroup-base-wifi-1.0-r83.imx8mmevk 744/1174
Installing : iputils-tracepath-s20161105-r0.aarch64 745/1174
Installing : iputils-s20161105-r0.aarch64 746/1174
Installing : imx-parser-4.4.5-r0.aarch64 747/1174
Installing : hicolor-icon-theme-0.17-r0.noarch 748/1174
Installing : linux-firmware-broadcom-license-1:0.0+git0+d11 749/1174
Installing : linux-firmware-ath10k-license-1:0.0+git0+d1147 750/1174
Installing : kernel-image-image-4.14.98-imx-4.14.98-2.0.0-g 751/1174
Installing : kernel-image-4.14.98-imx-4.14.98-2.0.0-ga+g5d6 752/1174
Installing : kernel-4.14.98-imx-4.14.98-2.0.0-ga+g5d6cbeafb 753/1174
Running scriptlet: kernel-4.14.98-imx-4.14.98-2.0.0-ga+g5d6cbeafb 753/1174
Installing : kernel-module-x-tables-4.14.98-imx_4.14.98_2.0 754/1174
Running scriptlet: kernel-module-x-tables-4.14.98-imx_4.14.98_2.0 754/1174
Installing : kernel-module-usbnet-4.14.98-imx_4.14.98_2.0.0 755/1174
Running scriptlet: kernel-module-usbnet-4.14.98-imx_4.14.98_2.0.0 755/1174
Installing : kernel-module-stmmac-4.14.98-imx_4.14.98_2.0.0 756/1174
Running scriptlet: kernel-module-stmmac-4.14.98-imx_4.14.98_2.0.0 756/1174
Installing : kernel-module-stmmac-platform-4.14.98-imx_4.14 757/1174
Running scriptlet: kernel-module-stmmac-platform-4.14.98-imx_4.14 757/1174
Installing : kernel-module-ip-tables-4.14.98-imx_4.14.98_2. 758/1174
Running scriptlet: kernel-module-ip-tables-4.14.98-imx_4.14.98_2. 758/1174
Installing : kernel-module-ip6-tables-4.14.98-imx_4.14.98_2 759/1174
Running scriptlet: kernel-module-ip6-tables-4.14.98-imx_4.14.98_2 759/1174
Installing : kernel-module-libcrc32c-4.14.98-imx_4.14.98_2. 760/1174
Running scriptlet: kernel-module-libcrc32c-4.14.98-imx_4.14.98_2. 760/1174
Installing : kernel-module-nf-conntrack-4.14.98-imx_4.14.98 761/1174
Running scriptlet: kernel-module-nf-conntrack-4.14.98-imx_4.14.98 761/1174
Installing : kernel-module-nf-nat-4.14.98-imx_4.14.98_2.0.0 762/1174
Running scriptlet: kernel-module-nf-nat-4.14.98-imx_4.14.98_2.0.0 762/1174
Installing : kernel-module-nf-log-common-4.14.98-imx_4.14.9 763/1174
Running scriptlet: kernel-module-nf-log-common-4.14.98-imx_4.14.9 763/1174
Installing : kernel-module-raid6-pq-4.14.98-imx_4.14.98_2.0 764/1174
Running scriptlet: kernel-module-raid6-pq-4.14.98-imx_4.14.98_2.0 764/1174
Installing : kernel-module-stp-4.14.98-imx_4.14.98_2.0.0_ga 765/1174
Running scriptlet: kernel-module-stp-4.14.98-imx_4.14.98_2.0.0_ga 765/1174
Installing : kernel-module-xxhash-4.14.98-imx_4.14.98_2.0.0 766/1174
Running scriptlet: kernel-module-xxhash-4.14.98-imx_4.14.98_2.0.0 766/1174
Installing : kernel-module-zstd-compress-4.14.98-imx_4.14.9 767/1174
Running scriptlet: kernel-module-zstd-compress-4.14.98-imx_4.14.9 767/1174
Installing : kernel-module-zstd-decompress-4.14.98-imx_4.14 768/1174
Running scriptlet: kernel-module-zstd-decompress-4.14.98-imx_4.14 768/1174
Installing : kernel-module-bridge-4.14.98-imx_4.14.98_2.0.0 769/1174
Running scriptlet: kernel-module-bridge-4.14.98-imx_4.14.98_2.0.0 769/1174
Installing : kernel-module-garp-4.14.98-imx_4.14.98_2.0.0_g 770/1174
Running scriptlet: kernel-module-garp-4.14.98-imx_4.14.98_2.0.0_g 770/1174
Installing : kernel-module-nf-nat-ipv4-4.14.98-imx_4.14.98_ 771/1174
Running scriptlet: kernel-module-nf-nat-ipv4-4.14.98-imx_4.14.98_ 771/1174
Installing : kernel-module-nf-nat-ipv6-4.14.98-imx_4.14.98_ 772/1174
Running scriptlet: kernel-module-nf-nat-ipv6-4.14.98-imx_4.14.98_ 772/1174
Installing : kernel-module-nf-nat-masquerade-ipv4-4.14.98-i 773/1174
Running scriptlet: kernel-module-nf-nat-masquerade-ipv4-4.14.98-i 773/1174
Installing : kernel-module-nf-nat-masquerade-ipv6-4.14.98-i 774/1174
Running scriptlet: kernel-module-nf-nat-masquerade-ipv6-4.14.98-i 774/1174
Installing : kernel-module-cdc-ether-4.14.98-imx_4.14.98_2. 775/1174
Running scriptlet: kernel-module-cdc-ether-4.14.98-imx_4.14.98_2. 775/1174
Installing : kernel-module-aes-neon-blk-4.14.98-imx_4.14.98 776/1174
Running scriptlet: kernel-module-aes-neon-blk-4.14.98-imx_4.14.98 776/1174
Installing : kernel-module-analogix-dp-4.14.98-imx_4.14.98_ 777/1174
Running scriptlet: kernel-module-analogix-dp-4.14.98-imx_4.14.98_ 777/1174
Installing : kernel-module-brcmutil-4.14.98-imx_4.14.98_2.0 778/1174
Running scriptlet: kernel-module-brcmutil-4.14.98-imx_4.14.98_2.0 778/1174
Installing : kernel-module-crypto-engine-4.14.98-imx_4.14.9 779/1174
Running scriptlet: kernel-module-crypto-engine-4.14.98-imx_4.14.9 779/1174
Installing : kernel-module-fuse-4.14.98-imx_4.14.98_2.0.0_g 780/1174
Running scriptlet: kernel-module-fuse-4.14.98-imx_4.14.98_2.0.0_g 780/1174
Installing : kernel-module-host1x-4.14.98-imx_4.14.98_2.0.0 781/1174
Running scriptlet: kernel-module-host1x-4.14.98-imx_4.14.98_2.0.0 781/1174
Installing : kernel-module-ip-tunnel-4.14.98-imx_4.14.98_2. 782/1174
Running scriptlet: kernel-module-ip-tunnel-4.14.98-imx_4.14.98_2. 782/1174
Installing : kernel-module-macvlan-4.14.98-imx_4.14.98_2.0. 783/1174
Running scriptlet: kernel-module-macvlan-4.14.98-imx_4.14.98_2.0. 783/1174
Installing : kernel-module-mdt-loader-4.14.98-imx_4.14.98_2 784/1174
Running scriptlet: kernel-module-mdt-loader-4.14.98-imx_4.14.98_2 784/1174
Installing : kernel-module-meson-drm-4.14.98-imx_4.14.98_2. 785/1174
Running scriptlet: kernel-module-meson-drm-4.14.98-imx_4.14.98_2. 785/1174
Installing : kernel-module-mrp-4.14.98-imx_4.14.98_2.0.0_ga 786/1174
Running scriptlet: kernel-module-mrp-4.14.98-imx_4.14.98_2.0.0_ga 786/1174
Installing : kernel-module-nf-defrag-ipv4-4.14.98-imx_4.14. 787/1174
Running scriptlet: kernel-module-nf-defrag-ipv4-4.14.98-imx_4.14. 787/1174
Installing : kernel-module-nf-defrag-ipv6-4.14.98-imx_4.14. 788/1174
Running scriptlet: kernel-module-nf-defrag-ipv6-4.14.98-imx_4.14. 788/1174
Installing : kernel-module-nf-reject-ipv4-4.14.98-imx_4.14. 789/1174
Running scriptlet: kernel-module-nf-reject-ipv4-4.14.98-imx_4.14. 789/1174
Installing : kernel-module-nf-reject-ipv6-4.14.98-imx_4.14. 790/1174
Running scriptlet: kernel-module-nf-reject-ipv6-4.14.98-imx_4.14. 790/1174
Installing : kernel-module-nvme-core-4.14.98-imx_4.14.98_2. 791/1174
Running scriptlet: kernel-module-nvme-core-4.14.98-imx_4.14.98_2. 791/1174
Installing : kernel-module-rcar-fcp-4.14.98-imx_4.14.98_2.0 792/1174
Running scriptlet: kernel-module-rcar-fcp-4.14.98-imx_4.14.98_2.0 792/1174
Installing : kernel-module-vsp1-4.14.98-imx_4.14.98_2.0.0_g 793/1174
Running scriptlet: kernel-module-vsp1-4.14.98-imx_4.14.98_2.0.0_g 793/1174
Installing : kernel-module-snd-hwdep-4.14.98-imx_4.14.98_2. 794/1174
Running scriptlet: kernel-module-snd-hwdep-4.14.98-imx_4.14.98_2. 794/1174
Installing : kernel-module-snd-usbmidi-lib-4.14.98-imx_4.14 795/1174
Running scriptlet: kernel-module-snd-usbmidi-lib-4.14.98-imx_4.14 795/1174
Installing : kernel-module-tap-4.14.98-imx_4.14.98_2.0.0_ga 796/1174
Running scriptlet: kernel-module-tap-4.14.98-imx_4.14.98_2.0.0_ga 796/1174
Installing : kernel-module-ttm-4.14.98-imx_4.14.98_2.0.0_ga 797/1174
Running scriptlet: kernel-module-ttm-4.14.98-imx_4.14.98_2.0.0_ga 797/1174
Installing : kernel-module-tunnel4-4.14.98-imx_4.14.98_2.0. 798/1174
Running scriptlet: kernel-module-tunnel4-4.14.98-imx_4.14.98_2.0. 798/1174
Installing : kernel-module-xor-4.14.98-imx_4.14.98_2.0.0_ga 799/1174
Running scriptlet: kernel-module-xor-4.14.98-imx_4.14.98_2.0.0_ga 799/1174
Installing : kernel-module-btrfs-4.14.98-imx_4.14.98_2.0.0_ 800/1174
Running scriptlet: kernel-module-btrfs-4.14.98-imx_4.14.98_2.0.0_ 800/1174
Installing : kernel-module-sit-4.14.98-imx_4.14.98_2.0.0_ga 801/1174
Running scriptlet: kernel-module-sit-4.14.98-imx_4.14.98_2.0.0_ga 801/1174
Installing : kernel-module-nouveau-4.14.98-imx_4.14.98_2.0. 802/1174
Running scriptlet: kernel-module-nouveau-4.14.98-imx_4.14.98_2.0. 802/1174
Installing : kernel-module-macvtap-4.14.98-imx_4.14.98_2.0. 803/1174
Running scriptlet: kernel-module-macvtap-4.14.98-imx_4.14.98_2.0. 803/1174
Installing : kernel-module-snd-usb-audio-4.14.98-imx_4.14.9 804/1174
Running scriptlet: kernel-module-snd-usb-audio-4.14.98-imx_4.14.9 804/1174
Installing : kernel-module-rcar-du-drm-4.14.98-imx_4.14.98_ 805/1174
Running scriptlet: kernel-module-rcar-du-drm-4.14.98-imx_4.14.98_ 805/1174
Installing : kernel-module-nvme-4.14.98-imx_4.14.98_2.0.0_g 806/1174
Running scriptlet: kernel-module-nvme-4.14.98-imx_4.14.98_2.0.0_g 806/1174
Installing : kernel-module-ip6t-reject-4.14.98-imx_4.14.98_ 807/1174
Running scriptlet: kernel-module-ip6t-reject-4.14.98-imx_4.14.98_ 807/1174
Installing : kernel-module-ipt-reject-4.14.98-imx_4.14.98_2 808/1174
Running scriptlet: kernel-module-ipt-reject-4.14.98-imx_4.14.98_2 808/1174
Installing : kernel-module-nf-conntrack-ipv6-4.14.98-imx_4. 809/1174
Running scriptlet: kernel-module-nf-conntrack-ipv6-4.14.98-imx_4. 809/1174
Installing : kernel-module-nf-conntrack-ipv4-4.14.98-imx_4. 810/1174
Running scriptlet: kernel-module-nf-conntrack-ipv4-4.14.98-imx_4. 810/1174
Installing : kernel-module-8021q-4.14.98-imx_4.14.98_2.0.0_ 811/1174
Running scriptlet: kernel-module-8021q-4.14.98-imx_4.14.98_2.0.0_ 811/1174
Installing : kernel-module-meson-dw-hdmi-4.14.98-imx_4.14.9 812/1174
Running scriptlet: kernel-module-meson-dw-hdmi-4.14.98-imx_4.14.9 812/1174
Installing : kernel-module-msm-4.14.98-imx_4.14.98_2.0.0_ga 813/1174
Running scriptlet: kernel-module-msm-4.14.98-imx_4.14.98_2.0.0_ga 813/1174
Installing : kernel-module-tegra-drm-4.14.98-imx_4.14.98_2. 814/1174
Running scriptlet: kernel-module-tegra-drm-4.14.98-imx_4.14.98_2. 814/1174
Installing : kernel-module-cuse-4.14.98-imx_4.14.98_2.0.0_g 815/1174
Running scriptlet: kernel-module-cuse-4.14.98-imx_4.14.98_2.0.0_g 815/1174
Installing : kernel-module-virtio-crypto-4.14.98-imx_4.14.9 816/1174
Running scriptlet: kernel-module-virtio-crypto-4.14.98-imx_4.14.9 816/1174
Installing : kernel-module-brcmfmac-4.14.98-imx_4.14.98_2.0 817/1174
Running scriptlet: kernel-module-brcmfmac-4.14.98-imx_4.14.98_2.0 817/1174
Installing : kernel-module-rockchipdrm-4.14.98-imx_4.14.98_ 818/1174
Running scriptlet: kernel-module-rockchipdrm-4.14.98-imx_4.14.98_ 818/1174
Installing : kernel-module-aes-neon-bs-4.14.98-imx_4.14.98_ 819/1174
Running scriptlet: kernel-module-aes-neon-bs-4.14.98-imx_4.14.98_ 819/1174
Installing : kernel-module-zaurus-4.14.98-imx_4.14.98_2.0.0 820/1174
Running scriptlet: kernel-module-zaurus-4.14.98-imx_4.14.98_2.0.0 820/1174
Installing : kernel-module-ip6t-masquerade-4.14.98-imx_4.14 821/1174
Running scriptlet: kernel-module-ip6t-masquerade-4.14.98-imx_4.14 821/1174
Installing : kernel-module-ipt-masquerade-4.14.98-imx_4.14. 822/1174
Running scriptlet: kernel-module-ipt-masquerade-4.14.98-imx_4.14. 822/1174
Installing : kernel-module-ip6table-nat-4.14.98-imx_4.14.98 823/1174
Running scriptlet: kernel-module-ip6table-nat-4.14.98-imx_4.14.98 823/1174
Installing : kernel-module-iptable-nat-4.14.98-imx_4.14.98_ 824/1174
Running scriptlet: kernel-module-iptable-nat-4.14.98-imx_4.14.98_ 824/1174
Installing : kernel-module-br-netfilter-4.14.98-imx_4.14.98 825/1174
Running scriptlet: kernel-module-br-netfilter-4.14.98-imx_4.14.98 825/1174
Installing : kernel-module-bcm-sba-raid-4.14.98-imx_4.14.98 826/1174
Running scriptlet: kernel-module-bcm-sba-raid-4.14.98-imx_4.14.98 826/1174
Installing : kernel-module-nf-log-ipv4-4.14.98-imx_4.14.98_ 827/1174
Running scriptlet: kernel-module-nf-log-ipv4-4.14.98-imx_4.14.98_ 827/1174
Installing : kernel-module-nf-log-ipv6-4.14.98-imx_4.14.98_ 828/1174
Running scriptlet: kernel-module-nf-log-ipv6-4.14.98-imx_4.14.98_ 828/1174
Installing : kernel-module-xt-nat-4.14.98-imx_4.14.98_2.0.0 829/1174
Running scriptlet: kernel-module-xt-nat-4.14.98-imx_4.14.98_2.0.0 829/1174
Installing : kernel-module-xt-conntrack-4.14.98-imx_4.14.98 830/1174
Running scriptlet: kernel-module-xt-conntrack-4.14.98-imx_4.14.98 830/1174
Installing : kernel-module-ip6table-filter-4.14.98-imx_4.14 831/1174
Running scriptlet: kernel-module-ip6table-filter-4.14.98-imx_4.14 831/1174
Installing : kernel-module-ip6table-mangle-4.14.98-imx_4.14 832/1174
Running scriptlet: kernel-module-ip6table-mangle-4.14.98-imx_4.14 832/1174
Installing : kernel-module-iptable-filter-4.14.98-imx_4.14. 833/1174
Running scriptlet: kernel-module-iptable-filter-4.14.98-imx_4.14. 833/1174
Installing : kernel-module-iptable-mangle-4.14.98-imx_4.14. 834/1174
Running scriptlet: kernel-module-iptable-mangle-4.14.98-imx_4.14. 834/1174
Installing : kernel-module-dwmac-generic-4.14.98-imx_4.14.9 835/1174
Running scriptlet: kernel-module-dwmac-generic-4.14.98-imx_4.14.9 835/1174
Installing : kernel-module-dwmac-ipq806x-4.14.98-imx_4.14.9 836/1174
Running scriptlet: kernel-module-dwmac-ipq806x-4.14.98-imx_4.14.9 836/1174
Installing : kernel-module-dwmac-meson-4.14.98-imx_4.14.98_ 837/1174
Running scriptlet: kernel-module-dwmac-meson-4.14.98-imx_4.14.98_ 837/1174
Installing : kernel-module-dwmac-meson8b-4.14.98-imx_4.14.9 838/1174
Running scriptlet: kernel-module-dwmac-meson8b-4.14.98-imx_4.14.9 838/1174
Installing : kernel-module-dwmac-rk-4.14.98-imx_4.14.98_2.0 839/1174
Running scriptlet: kernel-module-dwmac-rk-4.14.98-imx_4.14.98_2.0 839/1174
Installing : kernel-module-dwmac-sun8i-4.14.98-imx_4.14.98_ 840/1174
Running scriptlet: kernel-module-dwmac-sun8i-4.14.98-imx_4.14.98_ 840/1174
Installing : kernel-module-dwmac-sunxi-4.14.98-imx_4.14.98_ 841/1174
Running scriptlet: kernel-module-dwmac-sunxi-4.14.98-imx_4.14.98_ 841/1174
Installing : kernel-module-asix-4.14.98-imx_4.14.98_2.0.0_g 842/1174
Running scriptlet: kernel-module-asix-4.14.98-imx_4.14.98_2.0.0_g 842/1174
Installing : kernel-module-ax88179-178a-4.14.98-imx_4.14.98 843/1174
Running scriptlet: kernel-module-ax88179-178a-4.14.98-imx_4.14.98 843/1174
Installing : kernel-module-cdc-ncm-4.14.98-imx_4.14.98_2.0. 844/1174
Running scriptlet: kernel-module-cdc-ncm-4.14.98-imx_4.14.98_2.0. 844/1174
Installing : kernel-module-cdc-subset-4.14.98-imx_4.14.98_2 845/1174
Running scriptlet: kernel-module-cdc-subset-4.14.98-imx_4.14.98_2 845/1174
Installing : kernel-module-dm9601-4.14.98-imx_4.14.98_2.0.0 846/1174
Running scriptlet: kernel-module-dm9601-4.14.98-imx_4.14.98_2.0.0 846/1174
Installing : kernel-module-mcs7830-4.14.98-imx_4.14.98_2.0. 847/1174
Running scriptlet: kernel-module-mcs7830-4.14.98-imx_4.14.98_2.0. 847/1174
Installing : kernel-module-net1080-4.14.98-imx_4.14.98_2.0. 848/1174
Running scriptlet: kernel-module-net1080-4.14.98-imx_4.14.98_2.0. 848/1174
Installing : kernel-module-plusb-4.14.98-imx_4.14.98_2.0.0_ 849/1174
Running scriptlet: kernel-module-plusb-4.14.98-imx_4.14.98_2.0.0_ 849/1174
Installing : kernel-module-smsc75xx-4.14.98-imx_4.14.98_2.0 850/1174
Running scriptlet: kernel-module-smsc75xx-4.14.98-imx_4.14.98_2.0 850/1174
Installing : kernel-module-smsc95xx-4.14.98-imx_4.14.98_2.0 851/1174
Running scriptlet: kernel-module-smsc95xx-4.14.98-imx_4.14.98_2.0 851/1174
Installing : kernel-module-sr9800-4.14.98-imx_4.14.98_2.0.0 852/1174
Running scriptlet: kernel-module-sr9800-4.14.98-imx_4.14.98_2.0.0 852/1174
Installing : kernel-module-xt-addrtype-4.14.98-imx_4.14.98_ 853/1174
Running scriptlet: kernel-module-xt-addrtype-4.14.98-imx_4.14.98_ 853/1174
Installing : kernel-module-xt-checksum-4.14.98-imx_4.14.98_ 854/1174
Running scriptlet: kernel-module-xt-checksum-4.14.98-imx_4.14.98_ 854/1174
Installing : kernel-module-xt-log-4.14.98-imx_4.14.98_2.0.0 855/1174
Running scriptlet: kernel-module-xt-log-4.14.98-imx_4.14.98_2.0.0 855/1174
Installing : kernel-module-xt-tcpudp-4.14.98-imx_4.14.98_2. 856/1174
Running scriptlet: kernel-module-xt-tcpudp-4.14.98-imx_4.14.98_2. 856/1174
Installing : kernel-module-cryptodev-4.14.98-imx_4.14.98_2. 857/1174
Running scriptlet: kernel-module-cryptodev-4.14.98-imx_4.14.98_2. 857/1174
Installing : cryptodev-module-1.9-r0.imx8mmevk 858/1174
Installing : kernel-module-galcore-4.14.98-imx_4.14.98_2.0. 859/1174
Running scriptlet: kernel-module-galcore-4.14.98-imx_4.14.98_2.0. 859/1174
Installing : kernel-module-imx-gpu-viv-6.2.4.p4.0-r0.imx8mm 860/1174
Installing : libgal-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 861/1174
Running scriptlet: libgal-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 861/1174
Installing : libgl-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8m 862/1174
Running scriptlet: libgl-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8m 862/1174
Installing : libvsc-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 863/1174
Running scriptlet: libvsc-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 863/1174
Installing : libg2d1.1-6.2.4.p4.0-r0.aarch64_mx8mm 864/1174
Running scriptlet: libg2d1.1-6.2.4.p4.0-r0.aarch64_mx8mm 864/1174
Installing : libgbm-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 865/1174
Running scriptlet: libgbm-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 865/1174
Installing : libegl-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 866/1174
Running scriptlet: libegl-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 866/1174
Installing : libcogl20-1.22.2-r0.aarch64_mx8mm 867/1174
Running scriptlet: libcogl20-1.22.2-r0.aarch64_mx8mm 867/1174
Installing : libvdk-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 868/1174
Running scriptlet: libvdk-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 868/1174
Installing : imx-gpu-apitrace-bin-7.1.0-r0.aarch64_mx8mm 869/1174
Installing : libcogl-path20-1.22.2-r0.aarch64_mx8mm 870/1174
Running scriptlet: libcogl-path20-1.22.2-r0.aarch64_mx8mm 870/1174
Installing : libgstfsl-1.0-0-4.4.5-r0.aarch64_mx8mm 871/1174
Running scriptlet: libgstfsl-1.0-0-4.4.5-r0.aarch64_mx8mm 871/1174
Installing : imx-gst1.0-plugin-4.4.5-r0.aarch64_mx8mm 872/1174
Installing : libgles-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx 873/1174
Running scriptlet: libgles-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx 873/1174
Installing : libglslc-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_m 874/1174
Running scriptlet: libglslc-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_m 874/1174
Installing : libgles2-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_m 875/1174
Running scriptlet: libgles2-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_m 875/1174
Installing : libcairo2-1.14.12-r0.aarch64_mx8mm 876/1174
Running scriptlet: libcairo2-1.14.12-r0.aarch64_mx8mm 876/1174
Installing : pango-1.40.14-r0.aarch64_mx8mm 877/1174
Running scriptlet: pango-1.40.14-r0.aarch64_mx8mm 877/1174
Installing : libgtk-2.0-2.24.32-r0.aarch64_mx8mm 878/1174
Running scriptlet: libgtk-2.0-2.24.32-r0.aarch64_mx8mm 878/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/gtk-update-icon-cache to /usr/bin/gtk-update-icon-cache-2.0
Installing : libcairo-gobject2-1.14.12-r0.aarch64_mx8mm 879/1174
Running scriptlet: libcairo-gobject2-1.14.12-r0.aarch64_mx8mm 879/1174
Installing : libgtk-3.0-3.22.28-r0.aarch64_mx8mm 880/1174
Running scriptlet: libgtk-3.0-3.22.28-r0.aarch64_mx8mm 880/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/gtk-update-icon-cache to /usr/bin/gtk-update-icon-cache-3.0
Installing : libgstgl-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 881/1174
Running scriptlet: libgstgl-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 881/1174
Installing : libweston-5-5.0.0.imx-r0.aarch64_mx8mm 882/1174
Running scriptlet: libweston-5-5.0.0.imx-r0.aarch64_mx8mm 882/1174
Installing : libclc-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 883/1174
Running scriptlet: libclc-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 883/1174
Installing : libopencl-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_ 884/1174
Running scriptlet: libopencl-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_ 884/1174
Installing : gstreamer1.0-plugins-bad-openglmixers-1.14.4.i 885/1174
Installing : gstreamer1.0-plugins-base-opengl-1.14.4.imx-r0 886/1174
Installing : gst-examples-0.0.1+git0+48247c6ab6-r0.aarch64 887/1174
Installing : gtk+3-demo-3.22.28-r0.aarch64_mx8mm 888/1174
Installing : gstreamer1.0-plugins-good-cairo-1.14.4.imx-r0. 889/1174
Installing : gstreamer1.0-plugins-good-meta-1.14.4.imx-r0.a 890/1174
Installing : gtkperf-0.40-r0.aarch64 891/1174
Installing : fstests-0.1+git0+e5939ff608-r0.aarch64_mx8mm 892/1174
Installing : weston-examples-5.0.0.imx-r0.aarch64_mx8mm 893/1174
Installing : gstreamer1.0-plugins-bad-ttmlsubs-1.14.4.imx-r 894/1174
Installing : gstreamer1.0-plugins-base-pango-1.14.4.imx-r0. 895/1174
Installing : librsvg-2-2-2.40.20-r0.aarch64_mx8mm 896/1174
Running scriptlet: librsvg-2-2-2.40.20-r0.aarch64_mx8mm 896/1174
Installing : gstreamer1.0-plugins-bad-rsvg-1.14.4.imx-r0.aa 897/1174
Installing : gstreamer1.0-plugins-bad-meta-1.14.4.imx-r0.aa 898/1174
Installing : libcogl-pango20-1.22.2-r0.aarch64_mx8mm 899/1174
Running scriptlet: libcogl-pango20-1.22.2-r0.aarch64_mx8mm 899/1174
Installing : libclutter-1.0-0-1.26.2-r0.aarch64_mx8mm 900/1174
Running scriptlet: libclutter-1.0-0-1.26.2-r0.aarch64_mx8mm 900/1174
Installing : libclutter-1.0-examples-1.26.2-r0.aarch64_mx8m 901/1174
Installing : python3-pycairo-1.15.6-r0.aarch64_mx8mm 902/1174
Installing : python3-pygobject-3.28.1-r0.aarch64_mx8mm 903/1174
Installing : ofono-tests-1.22-r0.aarch64 904/1174
Installing : bluez5-testtools-5.49-r0.aarch64 905/1174
Installing : glmark2-2017.07+0+ed20c633f1-r0.aarch64_mx8mm 906/1174
Installing : kmscube-git-r0.aarch64_mx8mm 907/1174
Installing : xserver-xorg-xwayland-2:1.19.6-r0.aarch64_mx8m 908/1174
Installing : libglew2.1-2.1.0-r0.aarch64_mx8mm 909/1174
Running scriptlet: libglew2.1-2.1.0-r0.aarch64_mx8mm 909/1174
Installing : libglu1-2:9.0.0-0.aarch64_mx8mm 910/1174
Running scriptlet: libglu1-2:9.0.0-0.aarch64_mx8mm 910/1174
Installing : libglut3-3.0.0-r0.aarch64_mx8mm 911/1174
Running scriptlet: libglut3-3.0.0-r0.aarch64_mx8mm 911/1174
Installing : imx-gpu-viv-tools-1:6.2.4.p4.0+aarch64-r0.aarc 912/1174
Installing : kernel-module-cdc-acm-4.14.98-imx_4.14.98_2.0. 913/1174
Running scriptlet: kernel-module-cdc-acm-4.14.98-imx_4.14.98_2.0. 913/1174
Installing : kernel-module-g-ether-4.14.98-imx_4.14.98_2.0. 914/1174
Running scriptlet: kernel-module-g-ether-4.14.98-imx_4.14.98_2.0. 914/1174
Installing : kernel-module-g-serial-4.14.98-imx_4.14.98_2.0 915/1174
Running scriptlet: kernel-module-g-serial-4.14.98-imx_4.14.98_2.0 915/1174
Installing : kernel-module-adc-keys-4.14.98-imx_4.14.98_2.0 916/1174
Running scriptlet: kernel-module-adc-keys-4.14.98-imx_4.14.98_2.0 916/1174
Installing : kernel-module-at25-4.14.98-imx_4.14.98_2.0.0_g 917/1174
Running scriptlet: kernel-module-at25-4.14.98-imx_4.14.98_2.0.0_g 917/1174
Installing : kernel-module-bcm-crypto-spu-4.14.98-imx_4.14. 918/1174
Running scriptlet: kernel-module-bcm-crypto-spu-4.14.98-imx_4.14. 918/1174
Installing : kernel-module-bcm2835-dma-4.14.98-imx_4.14.98_ 919/1174
Running scriptlet: kernel-module-bcm2835-dma-4.14.98-imx_4.14.98_ 919/1174
Installing : kernel-module-ch7006-4.14.98-imx_4.14.98_2.0.0 920/1174
Running scriptlet: kernel-module-ch7006-4.14.98-imx_4.14.98_2.0.0 920/1174
Installing : kernel-module-chacha20-neon-4.14.98-imx_4.14.9 921/1174
Running scriptlet: kernel-module-chacha20-neon-4.14.98-imx_4.14.9 921/1174
Installing : kernel-module-cppc-cpufreq-4.14.98-imx_4.14.98 922/1174
Running scriptlet: kernel-module-cppc-cpufreq-4.14.98-imx_4.14.98 922/1174
Installing : kernel-module-crc32-ce-4.14.98-imx_4.14.98_2.0 923/1174
Running scriptlet: kernel-module-crc32-ce-4.14.98-imx_4.14.98_2.0 923/1174
Installing : kernel-module-crct10dif-ce-4.14.98-imx_4.14.98 924/1174
Running scriptlet: kernel-module-crct10dif-ce-4.14.98-imx_4.14.98 924/1174
Installing : kernel-module-dw-drm-dsi-4.14.98-imx_4.14.98_2 925/1174
Running scriptlet: kernel-module-dw-drm-dsi-4.14.98-imx_4.14.98_2 925/1174
Installing : kernel-module-exynos-gsc-4.14.98-imx_4.14.98_2 926/1174
Running scriptlet: kernel-module-exynos-gsc-4.14.98-imx_4.14.98_2 926/1174
Installing : kernel-module-exynos-lpass-4.14.98-imx_4.14.98 927/1174
Running scriptlet: kernel-module-exynos-lpass-4.14.98-imx_4.14.98 927/1174
Installing : kernel-module-exynosdrm-4.14.98-imx_4.14.98_2. 928/1174
Running scriptlet: kernel-module-exynosdrm-4.14.98-imx_4.14.98_2. 928/1174
Installing : kernel-module-g-audio-4.14.98-imx_4.14.98_2.0. 929/1174
Running scriptlet: kernel-module-g-audio-4.14.98-imx_4.14.98_2.0. 929/1174
Installing : kernel-module-g-cdc-4.14.98-imx_4.14.98_2.0.0_ 930/1174
Running scriptlet: kernel-module-g-cdc-4.14.98-imx_4.14.98_2.0.0_ 930/1174
Installing : kernel-module-g-mass-storage-4.14.98-imx_4.14. 931/1174
Running scriptlet: kernel-module-g-mass-storage-4.14.98-imx_4.14. 931/1174
Installing : kernel-module-g-ncm-4.14.98-imx_4.14.98_2.0.0_ 932/1174
Running scriptlet: kernel-module-g-ncm-4.14.98-imx_4.14.98_2.0.0_ 932/1174
Installing : kernel-module-g-zero-4.14.98-imx_4.14.98_2.0.0 933/1174
Running scriptlet: kernel-module-g-zero-4.14.98-imx_4.14.98_2.0.0 933/1174
Installing : kernel-module-generic-bl-4.14.98-imx_4.14.98_2 934/1174
Running scriptlet: kernel-module-generic-bl-4.14.98-imx_4.14.98_2 934/1174
Installing : kernel-module-gspca-main-4.14.98-imx_4.14.98_2 935/1174
Running scriptlet: kernel-module-gspca-main-4.14.98-imx_4.14.98_2 935/1174
Installing : kernel-module-i2c-bcm2835-4.14.98-imx_4.14.98_ 936/1174
Running scriptlet: kernel-module-i2c-bcm2835-4.14.98-imx_4.14.98_ 936/1174
Installing : kernel-module-imx-rpmsg-pingpong-4.14.98-imx_4 937/1174
Running scriptlet: kernel-module-imx-rpmsg-pingpong-4.14.98-imx_4 937/1174
Installing : kernel-module-imx-rpmsg-tty-4.14.98-imx_4.14.9 938/1174
Running scriptlet: kernel-module-imx-rpmsg-tty-4.14.98-imx_4.14.9 938/1174
Installing : kernel-module-ina2xx-4.14.98-imx_4.14.98_2.0.0 939/1174
Running scriptlet: kernel-module-ina2xx-4.14.98-imx_4.14.98_2.0.0 939/1174
Installing : kernel-module-kirin-drm-4.14.98-imx_4.14.98_2. 940/1174
Running scriptlet: kernel-module-kirin-drm-4.14.98-imx_4.14.98_2. 940/1174
Installing : kernel-module-lcd-4.14.98-imx_4.14.98_2.0.0_ga 941/1174
Running scriptlet: kernel-module-lcd-4.14.98-imx_4.14.98_2.0.0_ga 941/1174
Installing : kernel-module-lm90-4.14.98-imx_4.14.98_2.0.0_g 942/1174
Running scriptlet: kernel-module-lm90-4.14.98-imx_4.14.98_2.0.0_g 942/1174
Installing : kernel-module-lp855x-bl-4.14.98-imx_4.14.98_2. 943/1174
Running scriptlet: kernel-module-lp855x-bl-4.14.98-imx_4.14.98_2. 943/1174
Installing : kernel-module-marvell-4.14.98-imx_4.14.98_2.0. 944/1174
Running scriptlet: kernel-module-marvell-4.14.98-imx_4.14.98_2.0. 944/1174
Installing : kernel-module-meson-gxbb-wdt-4.14.98-imx_4.14. 945/1174
Running scriptlet: kernel-module-meson-gxbb-wdt-4.14.98-imx_4.14. 945/1174
Installing : kernel-module-meson-gxl-4.14.98-imx_4.14.98_2. 946/1174
Running scriptlet: kernel-module-meson-gxl-4.14.98-imx_4.14.98_2. 946/1174
Installing : kernel-module-meson-wdt-4.14.98-imx_4.14.98_2. 947/1174
Running scriptlet: kernel-module-meson-wdt-4.14.98-imx_4.14.98_2. 947/1174
Installing : kernel-module-nbd-4.14.98-imx_4.14.98_2.0.0_ga 948/1174
Running scriptlet: kernel-module-nbd-4.14.98-imx_4.14.98_2.0.0_ga 948/1174
Installing : kernel-module-nfs-layout-flexfiles-4.14.98-imx 949/1174
Running scriptlet: kernel-module-nfs-layout-flexfiles-4.14.98-imx 949/1174
Installing : kernel-module-overlay-4.14.98-imx_4.14.98_2.0. 950/1174
Running scriptlet: kernel-module-overlay-4.14.98-imx_4.14.98_2.0. 950/1174
Installing : kernel-module-pcie-rockchip-4.14.98-imx_4.14.9 951/1174
Running scriptlet: kernel-module-pcie-rockchip-4.14.98-imx_4.14.9 951/1174
Installing : kernel-module-pegasus-4.14.98-imx_4.14.98_2.0. 952/1174
Running scriptlet: kernel-module-pegasus-4.14.98-imx_4.14.98_2.0. 952/1174
Installing : kernel-module-phy-rockchip-pcie-4.14.98-imx_4. 953/1174
Running scriptlet: kernel-module-phy-rockchip-pcie-4.14.98-imx_4. 953/1174
Installing : kernel-module-pwm-bcm2835-4.14.98-imx_4.14.98_ 954/1174
Running scriptlet: kernel-module-pwm-bcm2835-4.14.98-imx_4.14.98_ 954/1174
Installing : kernel-module-pwm-cros-ec-4.14.98-imx_4.14.98_ 955/1174
Running scriptlet: kernel-module-pwm-cros-ec-4.14.98-imx_4.14.98_ 955/1174
Installing : kernel-module-pwm-meson-4.14.98-imx_4.14.98_2. 956/1174
Running scriptlet: kernel-module-pwm-meson-4.14.98-imx_4.14.98_2. 956/1174
Installing : kernel-module-pwm-tegra-4.14.98-imx_4.14.98_2. 957/1174
Running scriptlet: kernel-module-pwm-tegra-4.14.98-imx_4.14.98_2. 957/1174
Installing : kernel-module-qcom-emac-4.14.98-imx_4.14.98_2. 958/1174
Running scriptlet: kernel-module-qcom-emac-4.14.98-imx_4.14.98_2. 958/1174
Installing : kernel-module-r8152-4.14.98-imx_4.14.98_2.0.0_ 959/1174
Running scriptlet: kernel-module-r8152-4.14.98-imx_4.14.98_2.0.0_ 959/1174
Installing : kernel-module-realtek-4.14.98-imx_4.14.98_2.0. 960/1174
Running scriptlet: kernel-module-realtek-4.14.98-imx_4.14.98_2.0. 960/1174
Installing : kernel-module-renesas-usbhs-4.14.98-imx_4.14.9 961/1174
Running scriptlet: kernel-module-renesas-usbhs-4.14.98-imx_4.14.9 961/1174
Installing : kernel-module-rockchip-saradc-4.14.98-imx_4.14 962/1174
Running scriptlet: kernel-module-rockchip-saradc-4.14.98-imx_4.14 962/1174
Installing : kernel-module-rockchip-thermal-4.14.98-imx_4.1 963/1174
Running scriptlet: kernel-module-rockchip-thermal-4.14.98-imx_4.1 963/1174
Installing : kernel-module-rtc-rk808-4.14.98-imx_4.14.98_2. 964/1174
Running scriptlet: kernel-module-rtc-rk808-4.14.98-imx_4.14.98_2. 964/1174
Installing : kernel-module-rtl8150-4.14.98-imx_4.14.98_2.0. 965/1174
Running scriptlet: kernel-module-rtl8150-4.14.98-imx_4.14.98_2.0. 965/1174
Installing : kernel-module-s5p-jpeg-4.14.98-imx_4.14.98_2.0 966/1174
Running scriptlet: kernel-module-s5p-jpeg-4.14.98-imx_4.14.98_2.0 966/1174
Installing : kernel-module-s5p-mfc-4.14.98-imx_4.14.98_2.0. 967/1174
Running scriptlet: kernel-module-s5p-mfc-4.14.98-imx_4.14.98_2.0. 967/1174
Installing : kernel-module-sha512-arm64-4.14.98-imx_4.14.98 968/1174
Running scriptlet: kernel-module-sha512-arm64-4.14.98-imx_4.14.98 968/1174
Installing : kernel-module-sil164-4.14.98-imx_4.14.98_2.0.0 969/1174
Running scriptlet: kernel-module-sil164-4.14.98-imx_4.14.98_2.0.0 969/1174
Installing : kernel-module-snd-soc-bcm2835-i2s-4.14.98-imx_ 970/1174
Running scriptlet: kernel-module-snd-soc-bcm2835-i2s-4.14.98-imx_ 970/1174
Installing : kernel-module-spi-bcm2835-4.14.98-imx_4.14.98_ 971/1174
Running scriptlet: kernel-module-spi-bcm2835-4.14.98-imx_4.14.98_ 971/1174
Installing : kernel-module-spi-bcm2835aux-4.14.98-imx_4.14. 972/1174
Running scriptlet: kernel-module-spi-bcm2835aux-4.14.98-imx_4.14. 972/1174
Installing : kernel-module-spi-meson-spicc-4.14.98-imx_4.14 973/1174
Running scriptlet: kernel-module-spi-meson-spicc-4.14.98-imx_4.14 973/1174
Installing : kernel-module-spi-meson-spifc-4.14.98-imx_4.14 974/1174
Running scriptlet: kernel-module-spi-meson-spifc-4.14.98-imx_4.14 974/1174
Installing : kernel-module-tcrypt-4.14.98-imx_4.14.98_2.0.0 975/1174
Running scriptlet: kernel-module-tcrypt-4.14.98-imx_4.14.98_2.0.0 975/1174
Installing : kernel-module-usbtest-4.14.98-imx_4.14.98_2.0. 976/1174
Running scriptlet: kernel-module-usbtest-4.14.98-imx_4.14.98_2.0. 976/1174
Installing : kernel-module-uvcvideo-4.14.98-imx_4.14.98_2.0 977/1174
Running scriptlet: kernel-module-uvcvideo-4.14.98-imx_4.14.98_2.0 977/1174
Installing : kernel-module-vc4-4.14.98-imx_4.14.98_2.0.0_ga 978/1174
Running scriptlet: kernel-module-vc4-4.14.98-imx_4.14.98_2.0.0_ga 978/1174
Installing : kernel-module-veth-4.14.98-imx_4.14.98_2.0.0_g 979/1174
Running scriptlet: kernel-module-veth-4.14.98-imx_4.14.98_2.0.0_g 979/1174
Installing : kernel-module-xen-netback-4.14.98-imx_4.14.98_ 980/1174
Running scriptlet: kernel-module-xen-netback-4.14.98-imx_4.14.98_ 980/1174
Installing : kernel-module-xfrm6-mode-beet-4.14.98-imx_4.14 981/1174
Running scriptlet: kernel-module-xfrm6-mode-beet-4.14.98-imx_4.14 981/1174
Installing : kernel-module-xfrm6-mode-transport-4.14.98-imx 982/1174
Running scriptlet: kernel-module-xfrm6-mode-transport-4.14.98-imx 982/1174
Installing : kernel-module-xfrm6-mode-tunnel-4.14.98-imx_4. 983/1174
Running scriptlet: kernel-module-xfrm6-mode-tunnel-4.14.98-imx_4. 983/1174
Installing : glibc-localedata-translit-wide-2.27-r0.aarch64 984/1174
Installing : glibc-localedata-translit-small-2.27-r0.aarch6 985/1174
Installing : glibc-localedata-translit-narrow-2.27-r0.aarch 986/1174
Installing : glibc-localedata-translit-fraction-2.27-r0.aar 987/1174
Installing : glibc-localedata-translit-font-2.27-r0.aarch64 988/1174
Installing : glibc-localedata-translit-compat-2.27-r0.aarch 989/1174
Installing : glibc-localedata-translit-cjk-compat-2.27-r0.a 990/1174
Installing : glibc-localedata-translit-circle-2.27-r0.aarch 991/1174
Installing : glibc-localedata-translit-neutral-2.27-r0.aarc 992/1174
Installing : glibc-localedata-iso14651-t1-common-2.27-r0.aa 993/1174
Installing : glibc-localedata-iso14651-t1-2.27-r0.aarch64 994/1174
Installing : ncurses-terminfo-base-6.0+20171125-r0.aarch64 995/1174
Installing : ncurses-terminfo-6.0+20171125-r0.aarch64 996/1174
Installing : nano-2.9.3-r0.aarch64 997/1174
Installing : mc-4.8.20-r0.aarch64 998/1174
Installing : imx-gpu-viv-1:6.2.4.p4.0+aarch64-r0.aarch64_mx 999/1174
Installing : libgpuperfcnt1.4.0-6.2.4.p4.0-r0.aarch64_mx8mm 1000/1174
Running scriptlet: libgpuperfcnt1.4.0-6.2.4.p4.0-r0.aarch64_mx8mm 1000/1174
Installing : gputop-6.2.4.p4.0-r0.aarch64_mx8mm 1001/1174
Installing : pciutils-ids-3.5.6-r0.aarch64 1002/1174
Installing : pciutils-3.5.6-r0.aarch64 1003/1174
Installing : packagegroup-base-pci-1.0-r83.imx8mmevk 1004/1174
Installing : initscripts-functions-1.0-r155.imx8mmevk 1005/1174
Installing : initscripts-1.0-r155.imx8mmevk 1006/1174
Running scriptlet: initscripts-1.0-r155.imx8mmevk 1006/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask banner.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/banner.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask bootmisc.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/bootmisc.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask checkfs.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/checkfs.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask checkroot.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/checkroot.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask devpts.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/devpts.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask dmesg.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/dmesg.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask hostname.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/hostname.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask mountall.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/mountall.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask mountnfs.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/mountnfs.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask populate-volatile.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/populate-volatile.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask read-only-rootfs-hook.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/read-only-rootfs-hook.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask rmnologin.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/rmnologin.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask sysfs.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/sysfs.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux mask urandom.service
ln -s /dev/null /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/systemd/system/urandom.service
Installing : openssl-conf-1.0.2p-r0.aarch64 1007/1174
Installing : openssl-1.0.2p-r0.aarch64 1008/1174
Installing : packagegroup-core-full-cmdline-extended-1.0-r6 1009/1174
Installing : alsa-conf-1.1.5-r0.aarch64_mx8mm 1010/1174
Installing : libasound2-1.1.5-r0.aarch64_mx8mm 1011/1174
Running scriptlet: libasound2-1.1.5-r0.aarch64_mx8mm 1011/1174
Installing : alsa-utils-alsactl-1.1.5-r0.aarch64 1012/1174
Installing : pulseaudio-lib-alsa-util-11.1-r0.aarch64_mx8mm 1013/1174
Installing : alsa-tools-1.1.5-r0.aarch64 1014/1174
Installing : alsa-utils-amixer-1.1.5-r0.aarch64 1015/1174
Installing : alsa-utils-aplay-1.1.5-r0.aarch64 1016/1174
Installing : gstreamer1.0-plugins-base-alsa-1.14.4.imx-r0.a 1017/1174
Installing : packagegroup-fsl-gstreamer1.0-base-1.0-r0.imx8 1018/1174
Installing : alsa-utils-alsamixer-1.1.5-r0.aarch64 1019/1174
Installing : packagegroup-fsl-gstreamer1.0-audio-1.0-r0.imx 1020/1174
Installing : packagegroup-fsl-gstreamer1.0-debug-1.0-r0.imx 1021/1174
Installing : packagegroup-fsl-gstreamer1.0-video-1.0-r0.imx 1022/1174
Installing : gstreamer1.0-plugins-base-meta-1.14.4.imx-r0.a 1023/1174
Installing : pulseaudio-module-alsa-card-11.1-r0.aarch64_mx 1024/1174
Installing : pulseaudio-module-alsa-sink-11.1-r0.aarch64_mx 1025/1174
Installing : pulseaudio-module-alsa-source-11.1-r0.aarch64_ 1026/1174
Installing : alsa-state-0.2.0-r5.imx8mmevk 1027/1174
Running scriptlet: alsa-state-0.2.0-r5.imx8mmevk 1027/1174
Installing : packagegroup-base-alsa-1.0-r83.imx8mmevk 1028/1174
Installing : imx-test-1:7.0+0+d32727a9d7-r0.aarch64_mx8mm 1029/1174
Installing : alsa-utils-aconnect-1.1.5-r0.aarch64 1030/1174
Installing : alsa-utils-alsaloop-1.1.5-r0.aarch64 1031/1174
Installing : alsa-utils-alsatplg-1.1.5-r0.aarch64 1032/1174
Installing : alsa-utils-alsaucm-1.1.5-r0.aarch64 1033/1174
Installing : alsa-utils-aseqdump-1.1.5-r0.aarch64 1034/1174
Installing : alsa-utils-aseqnet-1.1.5-r0.aarch64 1035/1174
Installing : alsa-utils-iecset-1.1.5-r0.aarch64 1036/1174
Installing : alsa-utils-midi-1.1.5-r0.aarch64 1037/1174
Installing : alsa-utils-speakertest-1.1.5-r0.aarch64 1038/1174
Installing : alsa-utils-1.1.5-r0.aarch64 1039/1174
Installing : libasound-module-conf-pulse-1.1.5-r0.aarch64 1040/1174
Installing : libasound-module-ctl-pulse-1.1.5-r0.aarch64 1041/1174
Installing : libasound-module-pcm-pulse-1.1.5-r0.aarch64 1042/1174
Installing : alsa-plugins-pulseaudio-conf-1.1.5-r0.aarch64 1043/1174
Installing : shadow-securetty-4.2.1-r3.imx8mmevk 1044/1174
Installing : shadow-4.2.1-r0.aarch64 1045/1174
Running scriptlet: shadow-4.2.1-r0.aarch64 1045/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/passwd to /usr/bin/passwd.shadow
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/chfn to /usr/bin/chfn.shadow
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/chsh to /usr/bin/chsh.shadow
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/chpasswd to /usr/sbin/chpasswd.shadow
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/vipw to /sbin/vipw.shadow
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/vigr to /sbin/vigr.shadow
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/nologin to /sbin/nologin.shadow
Running scriptlet: dbus-1-1.12.2-r0.aarch64 1046/1174
Running groupadd commands...
NOTE: dbus: Performing groupadd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux -r netdev]
Running useradd commands...
NOTE: dbus: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system --home /var/lib/dbus --no-create-home --shell /bin/false --user-group messagebus]
Installing : dbus-1-1.12.2-r0.aarch64 1046/1174
Running scriptlet: rpcbind-0.2.4-r0.aarch64 1047/1174
NOTE: rpcbind: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system --no-create-home --home-dir / --shell /bin/false --user-group rpc]
Installing : rpcbind-0.2.4-r0.aarch64 1047/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable rpcbind.service
Try to find location of rpcbind.service...
Found rpcbind.service in /lib/systemd/system/rpcbind.service
Also=rpcbind.socket found in rpcbind.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable rpcbind.socket
Try to find location of rpcbind.socket...
Found rpcbind.socket in /lib/systemd/system/rpcbind.socket
WantedBy=sockets.target found in rpcbind.socket
Enabled rpcbind.socket for sockets.target.
Running scriptlet: nfs-utils-client-2.1.1-r0.aarch64 1048/1174
NOTE: nfs-utils: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system --home-dir /var/lib/nfs --shell /bin/false --user-group rpcuser]
Installing : nfs-utils-client-2.1.1-r0.aarch64 1048/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable nfs-statd.service
Try to find location of nfs-statd.service...
Found nfs-statd.service in /lib/systemd/system/nfs-statd.service
WantedBy=multi-user.target found in nfs-statd.service
Enabled nfs-statd.service for multi-user.target.
Installing : nfs-utils-2.1.1-r0.aarch64 1049/1174
Running scriptlet: nfs-utils-2.1.1-r0.aarch64 1049/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable nfs-server.service nfs-mountd.service
Try to find location of nfs-server.service...
Found nfs-server.service in /lib/systemd/system/nfs-server.service
WantedBy=multi-user.target found in nfs-server.service
Enabled nfs-server.service for multi-user.target.
Try to find location of nfs-mountd.service...
Found nfs-mountd.service in /lib/systemd/system/nfs-mountd.service
WantedBy=multi-user.target found in nfs-mountd.service
Enabled nfs-mountd.service for multi-user.target.
Installing : ofono-1.22-r0.aarch64 1050/1174
Running scriptlet: ofono-1.22-r0.aarch64 1050/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable ofono.service
Try to find location of ofono.service...
Found ofono.service in /lib/systemd/system/ofono.service
WantedBy=multi-user.target found in ofono.service
Enabled ofono.service for multi-user.target.
Installing : connman-1.35-r0.aarch64 1051/1174
Running scriptlet: connman-1.35-r0.aarch64 1051/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/resolv.conf to /etc/resolv-conf.connman
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable connman.service connman-env.service
Try to find location of connman.service...
Found connman.service in /lib/systemd/system/connman.service
WantedBy=multi-user.target found in connman.service
Enabled connman.service for multi-user.target.
Try to find location of connman-env.service...
Found connman-env.service in /lib/systemd/system/connman-env.service
WantedBy=connman.service found in connman-env.service
Enabled connman-env.service for connman.service.
Running scriptlet: cronie-1.5.1-r0.aarch64 1052/1174
NOTE: cronie: Performing groupadd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system crontab]
Installing : cronie-1.5.1-r0.aarch64 1052/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable crond.service
Try to find location of crond.service...
Found crond.service in /lib/systemd/system/crond.service
WantedBy=multi-user.target found in crond.service
Enabled crond.service for multi-user.target.
Running scriptlet: avahi-daemon-0.7-r0.aarch64 1053/1174
NOTE: avahi: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system --home /run/avahi-daemon --no-create-home --shell /bin/false --user-group avahi]
Installing : avahi-daemon-0.7-r0.aarch64 1053/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable avahi-daemon.service
Try to find location of avahi-daemon.service...
Found avahi-daemon.service in /lib/systemd/system/avahi-daemon.service
WantedBy=multi-user.target found in avahi-daemon.service
Enabled avahi-daemon.service for multi-user.target.
Enabled avahi-daemon.service for dbus-org.freedesktop.Avahi.service.
Also=avahi-daemon.socket found in avahi-daemon.service
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable avahi-daemon.socket
Try to find location of avahi-daemon.socket...
Found avahi-daemon.socket in /lib/systemd/system/avahi-daemon.socket
WantedBy=sockets.target found in avahi-daemon.socket
Enabled avahi-daemon.socket for sockets.target.
Installing : libnss-mdns-0.10-r7.aarch64 1054/1174
Running scriptlet: libnss-mdns-0.10-r7.aarch64 1054/1174
Installing : packagegroup-base-zeroconf-1.0-r83.imx8mmevk 1055/1174
Installing : ltp-20180118-r0.aarch64 1056/1174
Installing : packagegroup-core-full-cmdline-sys-services-1. 1057/1174
Installing : connman-client-1.35-r0.aarch64 1058/1174
Installing : connman-tools-1.35-r0.aarch64 1059/1174
Installing : packagegroup-base-3g-1.0-r83.imx8mmevk 1060/1174
Installing : packagegroup-base-nfs-1.0-r83.imx8mmevk 1061/1174
Installing : neard-0.16-r0.aarch64 1062/1174
Running scriptlet: neard-0.16-r0.aarch64 1062/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable neard.service
Try to find location of neard.service...
Found neard.service in /lib/systemd/system/neard.service
Enabled neard.service for dbus-org.neard.service.
Installing : packagegroup-base-nfc-1.0-r83.imx8mmevk 1063/1174
Running scriptlet: lttng-tools-2.9.5-r0.aarch64 1064/1174
NOTE: lttng-tools: Performing groupadd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux tracing]
Installing : lttng-tools-2.9.5-r0.aarch64 1064/1174
Running scriptlet: pulseaudio-server-11.1-r0.aarch64_mx8mm 1065/1174
NOTE: pulseaudio: Performing groupadd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system pulse]
NOTE: pulseaudio: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system --home /var/run/pulse --no-create-home --shell /bin/false --groups audio,pulse --gid pulse pulse]
Installing : pulseaudio-server-11.1-r0.aarch64_mx8mm 1065/1174
Installing : packagegroup-core-full-cmdline-multiuser-1.0-r 1066/1174
Installing : glibc-localedata-i18n-ctype-2.27-r0.aarch64 1067/1174
Installing : glibc-localedata-i18n-2.27-r0.aarch64 1068/1174
Installing : imx-codec-test-source-4.4.5-r0.aarch64_mx8mm 1069/1174
Installing : packagegroup-fsl-tools-testapps-fslcodec-testa 1070/1174
Installing : mc-fish-4.8.20-r0.aarch64 1071/1174
Installing : packagegroup-core-full-cmdline-utils-1.0-r6.no 1072/1174
Installing : xkeyboard-config-2.22-r0.aarch64 1073/1174
Running scriptlet: weston-5.0.0.imx-r0.aarch64_mx8mm 1074/1174
NOTE: weston: Performing groupadd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system weston-launch]
Installing : weston-5.0.0.imx-r0.aarch64_mx8mm 1074/1174
Installing : systemd-serialgetty-1.0-r5.imx8mmevk 1075/1174
Installing : systemd-container-1:237-r0.aarch64 1076/1174
Installing : systemd-vconsole-setup-1:237-r0.aarch64 1077/1174
Running scriptlet: systemd-1:237-r0.aarch64 1078/1174
NOTE: systemd: Performing groupadd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux -r systemd-journal]
NOTE: systemd: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system -d / -M --shell /bin/nologin systemd-timesync]
NOTE: systemd: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system -d / -M --shell /bin/nologin systemd-network]
NOTE: systemd: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system -d / -M --shell /bin/nologin systemd-resolve]
NOTE: systemd: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system --no-create-home --user-group --home-dir /etc/polkit-1 polkitd]
Installing : systemd-1:237-r0.aarch64 1078/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/init to /lib/systemd/systemd
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/halt to /bin/systemctl
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/reboot to /bin/systemctl
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/shutdown to /bin/systemctl
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/poweroff to /bin/systemctl
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/runlevel to /bin/systemctl
Installing : packagegroup-core-full-cmdline-initscripts-1.0 1079/1174
Installing : systemd-gpuconfig-1.0-r0.aarch64 1080/1174
Installing : libopenvg-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_ 1081/1174
Running scriptlet: libopenvg-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_ 1081/1174
Installing : mesa-demos-8.3.0-r0.aarch64_mx8mm 1082/1174
Installing : imx-gpu-sdk-5.3.0-r0.aarch64_mx8mm 1083/1174
Installing : imx-gpu-viv-demos-1:6.2.4.p4.0+aarch64-r0.aarc 1084/1174
Installing : packagegroup-machine-base-1.0-r83.imx8mmevk 1085/1174
Installing : packagegroup-base-usbgadget-1.0-r83.imx8mmevk 1086/1174
Installing : packagegroup-base-ipv6-1.0-r83.imx8mmevk 1087/1174
Installing : libc6-dbg-2.27-r0.aarch64 1088/1174
Installing : optee-os-imx-git-r0.imx8mmevk 1089/1174
Installing : lttng-modules-2.10.6-r0.imx8mmevk 1090/1174
Installing : netbase-1:5.4-r0.aarch64 1091/1174
Installing : packagegroup-core-boot-1.0-r17.imx8mmevk 1092/1174
Installing : packagegroup-distro-base-1.0-r83.imx8mmevk 1093/1174
Installing : packagegroup-base-1.0-r83.imx8mmevk 1094/1174
Installing : gstreamer1.0-rtsp-server-1.14.4-r0.aarch64 1095/1174
Installing : packagegroup-fsl-gstreamer1.0-1.0-r0.imx8mmevk 1096/1174
Installing : packagegroup-fsl-gstreamer1.0-full-1.0-r0.noar 1097/1174
Installing : packagegroup-base-extended-1.0-r83.imx8mmevk 1098/1174
Installing : packagegroup-core-tools-profile-1.0-r3.imx8mme 1099/1174
Installing : packagegroup-fsl-optee-imx-1.0-r0.noarch 1100/1174
Installing : packagegroup-core-standalone-sdk-target-1.0-r8 1101/1174
Installing : packagegroup-fsl-tools-testapps-1.0-r0.imx8mme 1102/1174
Installing : packagegroup-fsl-tools-gpu-1.0-r0.imx8mmevk 1103/1174
Installing : packagegroup-fsl-tools-gpu-external-1.0-r0.imx 1104/1174
Installing : packagegroup-core-tools-testapps-1.0-r2.imx8mm 1105/1174
Installing : packagegroup-core-full-cmdline-1.0-r6.noarch 1106/1174
Installing : systemd-analyze-1:237-r0.aarch64 1107/1174
Installing : systemd-compat-units-1.0-r29.aarch64 1108/1174
Running scriptlet: systemd-compat-units-1.0-r29.aarch64 1108/1174
Disabling the following sysv scripts:
Running scriptlet: systemd-extra-utils-1:237-r0.aarch64 1109/1174
NOTE: systemd: Performing useradd with [--root /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --system -d / -M --shell /bin/nologin systemd-bus-proxy]
Installing : systemd-extra-utils-1:237-r0.aarch64 1109/1174
Installing : weston-init-1.0-r0.noarch 1110/1174
Running scriptlet: weston-init-1.0-r0.noarch 1110/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable weston.service
Try to find location of weston.service...
Found weston.service in /lib/systemd/system/weston.service
WantedBy=multi-user.target found in weston.service
Enabled weston.service for multi-user.target.
Installing : packagegroup-fsl-tools-audio-1.0-r0.noarch 1111/1174
Installing : packagegroup-core-nfs-server-1.0-r2.noarch 1112/1174
Installing : imx-alsa-plugins-1.0.26-r0.aarch64_mx8mm 1113/1174
Installing : ca-certificates-20170717-r0.noarch 1114/1174
Running scriptlet: ca-certificates-20170717-r0.noarch 1114/1174
Updating certificates in /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/ssl/certs...
148 added, 0 removed; done.
Running hooks in /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/ca-certificates/update.d...
done.
Installing : kernel-modules-4.14.98-r0.imx8mmevk 1115/1174
Installing : weston-xwayland-5.0.0.imx-r0.aarch64_mx8mm 1116/1174
Installing : packagegroup-tools-bluetooth-1.0-r0.noarch 1117/1174
Installing : gnome-theme-adwaita-3.22.3-r0.aarch64 1118/1174
Installing : kernel-module-qca6174-4.14.98-imx_4.14.98_2.0. 1119/1174
Running scriptlet: kernel-module-qca6174-4.14.98-imx_4.14.98_2.0. 1119/1174
Installing : kernel-module-qca9377-4.14.98-imx_4.14.98_2.0. 1120/1174
Running scriptlet: kernel-module-qca9377-4.14.98-imx_4.14.98_2.0. 1120/1174
Installing : linux-firmware-ath10k-1:0.0+git0+d114732723_a0 1121/1174
Installing : linux-firmware-bcm43455-1:0.0+git0+d114732723_ 1122/1174
Installing : adwaita-icon-theme-symbolic-3.26.1-r0.noarch 1123/1174
Running scriptlet: adwaita-icon-theme-symbolic-3.26.1-r0.noarch 1123/1174
Installing : packagegroup-fsl-tools-benchmark-1.0-r0.imx8mm 1124/1174
Installing : xf86-input-libinput-2:0.26.0-r0.aarch64 1125/1174
Installing : libssp-dev-7.3.0-r0.aarch64 1126/1174
Installing : wpa-supplicant-passphrase-2.6-r0.aarch64 1127/1174
Installing : glib-networking-2.54.1-r0.aarch64 1128/1174
Running scriptlet: glib-networking-2.54.1-r0.aarch64 1128/1174
Installing : packagegroup-core-tools-debug-1.0-r3.noarch 1129/1174
Installing : psplash-default-0.1+git0+2015f7073e-r15.aarch6 1130/1174
Running scriptlet: psplash-default-0.1+git0+2015f7073e-r15.aarch6 1130/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/psplash to /usr/bin/psplash-default
Installing : perf-4.14.98-r9.imx8mmevk 1131/1174
Installing : packagegroup-core-ssh-dropbear-1.0-r1.noarch 1132/1174
Installing : xkbcomp-1.4.0-r8.0.aarch64 1133/1174
Installing : xterm-330-r0.aarch64 1134/1174
Running scriptlet: xterm-330-r0.aarch64 1134/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/bin/resize to /bin/busybox.nosuid
Installing : liberation-fonts-1:2.00.1-r0.noarch 1135/1174
Running scriptlet: liberation-fonts-1:2.00.1-r0.noarch 1135/1174
Installing : libgdk-pixbuf-2.0-loader-gif-2.36.11-r0.aarch6 1136/1174
Running scriptlet: libgdk-pixbuf-2.0-loader-gif-2.36.11-r0.aarch6 1136/1174
Installing : libgdk-pixbuf-2.0-loader-jpeg-2.36.11-r0.aarch 1137/1174
Running scriptlet: libgdk-pixbuf-2.0-loader-jpeg-2.36.11-r0.aarch 1137/1174
Installing : libgdk-pixbuf-2.0-loader-png-2.36.11-r0.aarch6 1138/1174
Running scriptlet: libgdk-pixbuf-2.0-loader-png-2.36.11-r0.aarch6 1138/1174
Installing : libgdk-pixbuf-2.0-loader-xpm-2.36.11-r0.aarch6 1139/1174
Running scriptlet: libgdk-pixbuf-2.0-loader-xpm-2.36.11-r0.aarch6 1139/1174
Installing : gstreamer1.0-rtsp-server-meta-1.14.4-r0.aarch6 1140/1174
Installing : linux-firmware-bcm4356-pcie-1:0.0+git0+d114732 1141/1174
Installing : linux-firmware-bcm4359-pcie-1:0.0+git0+d114732 1142/1174
Installing : blktrace-1.2.0+git0+cca113f2fe-r0.aarch64 1143/1174
Installing : udev-hwdb-1:237-r0.aarch64 1144/1174
Running scriptlet: udev-hwdb-1:237-r0.aarch64 1144/1174
Installing : util-linux-cfdisk-2.32.1-r0.aarch64 1145/1174
Installing : util-linux-fdisk-2.32.1-r0.aarch64 1146/1174
Running scriptlet: util-linux-fdisk-2.32.1-r0.aarch64 1146/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/fdisk to /sbin/fdisk.util-linux
Installing : util-linux-sfdisk-2.32.1-r0.aarch64 1147/1174
Installing : e2fsprogs-e2fsck-1.43.8-r0.aarch64 1148/1174
Installing : qca-tools-2.0.3-r0.aarch64 1149/1174
Installing : util-linux-prlimit-2.32.1-r0.aarch64 1150/1174
Installing : util-linux-fsck-2.32.1-r0.aarch64 1151/1174
Running scriptlet: util-linux-fsck-2.32.1-r0.aarch64 1151/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/sbin/fsck to /sbin/fsck.util-linux
Installing : util-linux-mountpoint-2.32.1-r0.aarch64 1152/1174
Running scriptlet: util-linux-mountpoint-2.32.1-r0.aarch64 1152/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/bin/mountpoint to /bin/mountpoint.util-linux
Installing : run-postinsts-1.0-r10.noarch 1153/1174
Running scriptlet: run-postinsts-1.0-r10.noarch 1153/1174
Started /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/systemctl --root=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux enable run-postinsts.service
Try to find location of run-postinsts.service...
Found run-postinsts.service in /lib/systemd/system/run-postinsts.service
WantedBy=sysinit.target found in run-postinsts.service
Enabled run-postinsts.service for sysinit.target.
Installing : busybox-udhcpc-1.27.2-r0.aarch64 1154/1174
Installing : util-linux-readprofile-2.32.1-r0.aarch64 1155/1174
Running scriptlet: util-linux-readprofile-2.32.1-r0.aarch64 1155/1174
update-alternatives: Linking /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/usr/sbin/readprofile to /usr/sbin/readprofile.util-linux
Installing : trace-cmd-2.7-r0.aarch64 1156/1174
Installing : rgb-1:1.0.6-r0.aarch64 1157/1174
Installing : util-linux-ionice-2.32.1-r0.aarch64 1158/1174
Installing : util-linux-mkfs-2.32.1-r0.aarch64 1159/1174
Installing : util-linux-switch-root-2.32.1-r0.aarch64 1160/1174
Installing : wpa-supplicant-cli-2.6-r0.aarch64 1161/1174
Installing : kbd-keymaps-2.0.4-r0.aarch64 1162/1174
Installing : kbd-consolefonts-2.0.4-r0.aarch64 1163/1174
Installing : mobile-broadband-provider-info-1:20170310-r0.a 1164/1174
Installing : udev-rules-imx-1.0-r0.aarch64 1165/1174
Installing : linux-libc-headers-dev-4.14-r0.aarch64 1166/1174
Installing : alsa-states-0.2.0-r5.imx8mmevk 1167/1174
Installing : firmware-imx-sdma-1:8.1-r0.noarch 1168/1174
Installing : firmware-qca9377-2.0.3-r0.noarch 1169/1174
Installing : firmware-qca6174-2.0.3-r0.noarch 1170/1174
Installing : fbset-modes-0.1.0-r6.imx8mmevk 1171/1174
Installing : xserver-xf86-config-0.1-r33.imx8mmevk 1172/1174
Installing : pointercal-0.0-r11.imx8mmevk 1173/1174
Installing : os-release-1.0-r0.noarch 1174/1174
Verifying : packagegroup-core-ssh-dropbear-1.0-r1.noarch 1/1174
Verifying : packagegroup-fsl-gstreamer1.0-1.0-r0.imx8mmevk 2/1174
Verifying : packagegroup-core-nfs-server-1.0-r2.noarch 3/1174
Verifying : packagegroup-base-extended-1.0-r83.imx8mmevk 4/1174
Verifying : packagegroup-fsl-tools-gpu-external-1.0-r0.imx 5/1174
Verifying : packagegroup-core-boot-1.0-r17.imx8mmevk 6/1174
Verifying : packagegroup-core-tools-debug-1.0-r3.noarch 7/1174
Verifying : packagegroup-fsl-gstreamer1.0-full-1.0-r0.noar 8/1174
Verifying : packagegroup-core-tools-profile-1.0-r3.imx8mme 9/1174
Verifying : packagegroup-fsl-tools-benchmark-1.0-r0.imx8mm 10/1174
Verifying : weston-init-1.0-r0.noarch 11/1174
Verifying : packagegroup-fsl-tools-audio-1.0-r0.noarch 12/1174
Verifying : packagegroup-core-tools-testapps-1.0-r2.imx8mm 13/1174
Verifying : target-sdk-provides-dummy-1.0-r0.sdk_provides_ 14/1174
Verifying : psplash-0.1+git0+2015f7073e-r15.aarch64 15/1174
Verifying : run-postinsts-1.0-r10.noarch 16/1174
Verifying : packagegroup-tools-bluetooth-1.0-r0.noarch 17/1174
Verifying : packagegroup-fsl-optee-imx-1.0-r0.noarch 18/1174
Verifying : weston-xwayland-5.0.0.imx-r0.aarch64_mx8mm 19/1174
Verifying : xterm-330-r0.aarch64 20/1174
Verifying : packagegroup-core-full-cmdline-1.0-r6.noarch 21/1174
Verifying : packagegroup-fsl-tools-gpu-1.0-r0.imx8mmevk 22/1174
Verifying : packagegroup-fsl-tools-testapps-1.0-r0.imx8mme 23/1174
Verifying : packagegroup-core-standalone-sdk-target-1.0-r8 24/1174
Verifying : dropbear-2017.75-r0.aarch64 25/1174
Verifying : gstreamer1.0-rtsp-server-1.14.4-r0.aarch64 26/1174
Verifying : packagegroup-fsl-gstreamer1.0-audio-1.0-r0.imx 27/1174
Verifying : packagegroup-fsl-gstreamer1.0-debug-1.0-r0.imx 28/1174
Verifying : packagegroup-fsl-gstreamer1.0-network-base-1.0 29/1174
Verifying : packagegroup-fsl-gstreamer1.0-video-1.0-r0.imx 30/1174
Verifying : nfs-utils-2.1.1-r0.aarch64 31/1174
Verifying : nfs-utils-client-2.1.1-r0.aarch64 32/1174
Verifying : packagegroup-base-1.0-r83.imx8mmevk 33/1174
Verifying : packagegroup-base-3g-1.0-r83.imx8mmevk 34/1174
Verifying : packagegroup-base-nfc-1.0-r83.imx8mmevk 35/1174
Verifying : arm-compute-library-18.11+git0+64441b79b8-r0.a 36/1174
Verifying : glmark2-2017.07+0+ed20c633f1-r0.aarch64_mx8mm 37/1174
Verifying : gtkperf-0.40-r0.aarch64 38/1174
Verifying : kmscube-git-r0.aarch64_mx8mm 39/1174
Verifying : mesa-demos-8.3.0-r0.aarch64_mx8mm 40/1174
Verifying : base-files-3.0.14-r89.imx8mmevk 41/1174
Verifying : base-passwd-3.5.29-r0.aarch64 42/1174
Verifying : busybox-1.27.2-r0.aarch64 43/1174
Verifying : netbase-1:5.4-r0.aarch64 44/1174
Verifying : systemd-1:237-r0.aarch64 45/1174
Verifying : udev-1:237-r0.aarch64 46/1174
Verifying : update-alternatives-opkg-0.3.6-r0.aarch64 47/1174
Verifying : gdb-8.0.1-r0.aarch64 48/1174
Verifying : gdbserver-8.0.1-r0.aarch64 49/1174
Verifying : glibc-mtrace-2.27-r0.aarch64 50/1174
Verifying : strace-4.20-r0.aarch64 51/1174
Verifying : gstreamer1.0-plugins-bad-meta-1.14.4.imx-r0.aa 52/1174
Verifying : gstreamer1.0-plugins-base-meta-1.14.4.imx-r0.a 53/1174
Verifying : gstreamer1.0-plugins-good-meta-1.14.4.imx-r0.a 54/1174
Verifying : babeltrace-1.5.4-r0.aarch64 55/1174
Verifying : lttng-modules-2.10.6-r0.imx8mmevk 56/1174
Verifying : lttng-tools-2.9.5-r0.aarch64 57/1174
Verifying : lttng-ust-2:2.10.1-r0.aarch64 58/1174
Verifying : powertop-2.9-r0.aarch64 59/1174
Verifying : systemtap-3.2-r0.aarch64 60/1174
Verifying : valgrind-3.13.0-r0.aarch64 61/1174
Verifying : bonnie++-1.03e-r0.aarch64 62/1174
Verifying : dbench-4.0-r0.aarch64 63/1174
Verifying : fio-2.9-r0.aarch64 64/1174
Verifying : iozone3-465-r0.aarch64 65/1174
Verifying : iperf3-3.2-r0.aarch64 66/1174
Verifying : lmbench-3.0+a9-r2.aarch64 67/1174
Verifying : nbench-byte-2.2.3-r0.aarch64 68/1174
Verifying : tiobench-0.3.3-r1.aarch64 69/1174
Verifying : kbd-2.0.4-r0.aarch64 70/1174
Verifying : weston-5.0.0.imx-r0.aarch64_mx8mm 71/1174
Verifying : alsa-tools-1.1.5-r0.aarch64 72/1174
Verifying : alsa-utils-1.1.5-r0.aarch64 73/1174
Verifying : consolekit-0.4.6-r0.aarch64 74/1174
Verifying : pulseaudio-misc-11.1-r0.aarch64_mx8mm 75/1174
Verifying : pulseaudio-module-cli-11.1-r0.aarch64_mx8mm 76/1174
Verifying : pulseaudio-module-device-manager-11.1-r0.aarch 77/1174
Verifying : pulseaudio-module-x11-bell-11.1-r0.aarch64_mx8 78/1174
Verifying : pulseaudio-module-x11-cork-request-11.1-r0.aar 79/1174
Verifying : pulseaudio-module-x11-publish-11.1-r0.aarch64_ 80/1174
Verifying : pulseaudio-module-x11-xsmp-11.1-r0.aarch64_mx8 81/1174
Verifying : pulseaudio-server-11.1-r0.aarch64_mx8mm 82/1174
Verifying : tinycompress-1.1.6-r0.aarch64 83/1174
Verifying : alsa-utils-amixer-1.1.5-r0.aarch64 84/1174
Verifying : alsa-utils-aplay-1.1.5-r0.aarch64 85/1174
Verifying : blktool-4+7-r0.aarch64 86/1174
Verifying : connman-client-1.35-r0.aarch64 87/1174
Verifying : connman-tests-1.35-r0.aarch64 88/1174
Verifying : connman-tools-1.35-r0.aarch64 89/1174
Verifying : fstests-0.1+git0+e5939ff608-r0.aarch64_mx8mm 90/1174
Verifying : gst-examples-0.0.1+git0+48247c6ab6-r0.aarch64 91/1174
Verifying : kexec-2.0.16-r1.aarch64 92/1174
Verifying : libts0-1.15-r0.aarch64 93/1174
Verifying : lrzsz-0.12.20-r6.aarch64 94/1174
Verifying : ltp-20180118-r0.aarch64 95/1174
Verifying : ofono-tests-1.22-r0.aarch64 96/1174
Verifying : x11perf-1:1.6.0-r0.aarch64 97/1174
Verifying : xprop-1:1.2.2-r0.aarch64 98/1174
Verifying : xrestop-0.4-r3.aarch64 99/1174
Verifying : xvideo-tests-0.1+git0+7d38b881e9-r0.aarch64 100/1174
Verifying : xwininfo-1.1.3-r0.aarch64 101/1174
Verifying : libc6-2.27-r0.aarch64 102/1174
Verifying : bluez5-noinst-tools-5.49-r0.aarch64 103/1174
Verifying : bluez5-obex-5.49-r0.aarch64 104/1174
Verifying : bluez5-testtools-5.49-r0.aarch64 105/1174
Verifying : pulseaudio-module-bluetooth-discover-11.1-r0.a 106/1174
Verifying : pulseaudio-module-bluetooth-policy-11.1-r0.aar 107/1174
Verifying : pulseaudio-module-bluez5-device-11.1-r0.aarch6 108/1174
Verifying : pulseaudio-module-bluez5-discover-11.1-r0.aarc 109/1174
Verifying : pulseaudio-module-loopback-11.1-r0.aarch64_mx8 110/1174
Verifying : pulseaudio-module-switch-on-connect-11.1-r0.aa 111/1174
Verifying : optee-client-imx-git-r0.aarch64 112/1174
Verifying : optee-os-imx-git-r0.imx8mmevk 113/1174
Verifying : optee-test-imx-git-r0.aarch64 114/1174
Verifying : libcairo2-1.14.12-r0.aarch64_mx8mm 115/1174
Verifying : libegl-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 116/1174
Verifying : libglib-2.0-0-1:2.54.3-r0.aarch64 117/1174
Verifying : libinput10-1.9.4-r0.aarch64 118/1174
Verifying : libjpeg62-1:1.5.3-r0.aarch64 119/1174
Verifying : libpixman-1-0-1:0.34.0-r0.aarch64 120/1174
Verifying : libpng16-16-1.6.34-r0.aarch64 121/1174
Verifying : libweston-5-5.0.0.imx-r0.aarch64_mx8mm 122/1174
Verifying : libxcb-composite0-1.12-r0.aarch64 123/1174
Verifying : libxcb-render0-1.12-r0.aarch64 124/1174
Verifying : libxcb-shape0-1.12-r0.aarch64 125/1174
Verifying : libxcb-xfixes0-1.12-r0.aarch64 126/1174
Verifying : libxcb1-1.12-r0.aarch64 127/1174
Verifying : libxcursor1-1:1.1.15-r0.aarch64 128/1174
Verifying : libxkbcommon-0.8.0-r0.aarch64 129/1174
Verifying : libz1-1.2.11-r0.aarch64 130/1174
Verifying : pango-1.40.14-r0.aarch64_mx8mm 131/1174
Verifying : wayland-1.16.0-r0.aarch64 132/1174
Verifying : xserver-xorg-xwayland-2:1.19.6-r0.aarch64_mx8m 133/1174
Verifying : libice6-1:1.0.9-r0.aarch64 134/1174
Verifying : libtinfo5-6.0+20171125-r0.aarch64 135/1174
Verifying : libx11-6-1:1.6.5-r0.aarch64 136/1174
Verifying : libxaw7-7-1:1.0.13-r2.aarch64 137/1174
Verifying : libxinerama1-1:1.1.3-r0.aarch64 138/1174
Verifying : libxmu6-1:1.1.2-r0.aarch64 139/1174
Verifying : libxpm4-1:3.5.12-r0.aarch64 140/1174
Verifying : libxt6-1:1.1.5-r0.aarch64 141/1174
Verifying : packagegroup-core-full-cmdline-dev-utils-1.0-r 142/1174
Verifying : packagegroup-core-full-cmdline-extended-1.0-r6 143/1174
Verifying : packagegroup-core-full-cmdline-initscripts-1.0 144/1174
Verifying : packagegroup-core-full-cmdline-libs-1.0-r6.noa 145/1174
Verifying : packagegroup-core-full-cmdline-multiuser-1.0-r 146/1174
Verifying : packagegroup-core-full-cmdline-sys-services-1. 147/1174
Verifying : packagegroup-core-full-cmdline-utils-1.0-r6.no 148/1174
Verifying : gputop-6.2.4.p4.0-r0.aarch64_mx8mm 149/1174
Verifying : imx-gpu-apitrace-7.1.0-r0.aarch64_mx8mm 150/1174
Verifying : imx-gpu-apitrace-bin-7.1.0-r0.aarch64_mx8mm 151/1174
Verifying : imx-gpu-sdk-5.3.0-r0.aarch64_mx8mm 152/1174
Verifying : imx-gpu-viv-tools-1:6.2.4.p4.0+aarch64-r0.aarc 153/1174
Verifying : libdrm-tests-2.4.91.imx-r0.aarch64_mx8mm 154/1174
Verifying : can-utils-0.0+gitr0+4c8fb05cb4-r0.aarch64 155/1174
Verifying : coreutils-8.29-r0.aarch64 156/1174
Verifying : cpufrequtils-008-r5.aarch64 157/1174
Verifying : cryptodev-module-1.9-r0.imx8mmevk 158/1174
Verifying : cryptodev-tests-1.9-r0.aarch64 159/1174
Verifying : dosfstools-4.1-r0.aarch64 160/1174
Verifying : e2fsprogs-mke2fs-1.43.8-r0.aarch64 161/1174
Verifying : e2fsprogs-resize2fs-1.43.8-r0.aarch64 162/1174
Verifying : ethtool-4.13-r0.aarch64 163/1174
Verifying : evtest-1.33+0+ab140a2dab-r0.aarch64 164/1174
Verifying : fbset-2.1-r4.aarch64 165/1174
Verifying : fsl-rc-local-1.0-r0.aarch64 166/1174
Verifying : gtk+3-demo-3.22.28-r0.aarch64_mx8mm 167/1174
Verifying : hostapd-2.6-r0.aarch64 168/1174
Verifying : i2c-tools-4.0-r0.aarch64 169/1174
Verifying : imx-gpu-viv-demos-1:6.2.4.p4.0+aarch64-r0.aarc 170/1174
Verifying : imx-kobs-5.5+git0+02c01d4a3d-r0.aarch64 171/1174
Verifying : imx-test-1:7.0+0+d32727a9d7-r0.aarch64_mx8mm 172/1174
Verifying : iproute2-4.14.1-r0.aarch64 173/1174
Verifying : iw-4.14-r0.aarch64 174/1174
Verifying : libclutter-1.0-examples-1.26.2-r0.aarch64_mx8m 175/1174
Verifying : linuxptp-1.8-r0.aarch64 176/1174
Verifying : memtester-4.3.0-r0.aarch64 177/1174
Verifying : minicom-2.7.1-r0.aarch64 178/1174
Verifying : mmc-utils-0.1-r0.aarch64 179/1174
Verifying : mtd-utils-2.0.1+0+9c6173559f-r0.aarch64 180/1174
Verifying : mtd-utils-ubifs-2.0.1+0+9c6173559f-r0.aarch64 181/1174
Verifying : nano-2.9.3-r0.aarch64 182/1174
Verifying : ntpdate-4.2.8p11-r0.aarch64 183/1174
Verifying : packagegroup-fsl-tools-testapps-fslcodec-testa 184/1174
Verifying : procps-3.3.12-r0.aarch64 185/1174
Verifying : ptpd-2.3.1-r0.aarch64 186/1174
Verifying : python-datetime-2.7.15-r1.aarch64 187/1174
Verifying : python-json-2.7.15-r1.aarch64 188/1174
Verifying : python-pip-9.0.3-r0.aarch64 189/1174
Verifying : python-subprocess-2.7.15-r1.aarch64 190/1174
Verifying : sigma-dut-git-r0.aarch64 191/1174
Verifying : tk-8.6.8-r0.aarch64 192/1174
Verifying : udev-extraconf-1.1-r0.aarch64 193/1174
Verifying : v4l-utils-1.12.3-r0.aarch64_mx8mm 194/1174
Verifying : vlan-1.9-r0.aarch64 195/1174
Verifying : weston-examples-5.0.0.imx-r0.aarch64_mx8mm 196/1174
Verifying : glibc-gconv-cp1252-2.27-r0.aarch64 197/1174
Verifying : glibc-gconv-ibm850-2.27-r0.aarch64 198/1174
Verifying : glibc-gconv-iso8859-1-2.27-r0.aarch64 199/1174
Verifying : glibc-gconv-iso8859-15-2.27-r0.aarch64 200/1174
Verifying : glibc-localedata-i18n-2.27-r0.aarch64 201/1174
Verifying : libatomic-dev-7.3.0-r0.aarch64 202/1174
Verifying : libatomic1-7.3.0-r0.aarch64 203/1174
Verifying : libc6-dbg-2.27-r0.aarch64 204/1174
Verifying : libc6-dev-2.27-r0.aarch64 205/1174
Verifying : libc6-thread-db-2.27-r0.aarch64 206/1174
Verifying : libc6-utils-2.27-r0.aarch64 207/1174
Verifying : libgcc-s-dev-7.3.0-r0.aarch64 208/1174
Verifying : libgcc1-7.3.0-r0.aarch64 209/1174
Verifying : libsegfault-2.27-r0.aarch64 210/1174
Verifying : libstdc++-dev-7.3.0-r0.aarch64 211/1174
Verifying : libstdc++6-7.3.0-r0.aarch64 212/1174
Verifying : libpam-1.3.0-r5.aarch64 213/1174
Verifying : libpam-runtime-1.3.0-r5.aarch64 214/1174
Verifying : pam-plugin-deny-1.3.0-r5.aarch64 215/1174
Verifying : pam-plugin-permit-1.3.0-r5.aarch64 216/1174
Verifying : pam-plugin-unix-1.3.0-r5.aarch64 217/1174
Verifying : gstreamer1.0-plugins-base-ogg-1.14.4.imx-r0.aa 218/1174
Verifying : gstreamer1.0-plugins-good-audioparsers-1.14.4. 219/1174
Verifying : gstreamer1.0-plugins-good-flac-1.14.4.imx-r0.a 220/1174
Verifying : gstreamer1.0-plugins-good-icydemux-1.14.4.imx- 221/1174
Verifying : gstreamer1.0-plugins-good-id3demux-1.14.4.imx- 222/1174
Verifying : gstreamer1.0-plugins-good-speex-1.14.4.imx-r0. 223/1174
Verifying : gstreamer1.0-plugins-good-wavparse-1.14.4.imx- 224/1174
Verifying : packagegroup-fsl-gstreamer1.0-base-1.0-r0.imx8 225/1174
Verifying : gstreamer1.0-plugins-base-audiotestsrc-1.14.4. 226/1174
Verifying : gstreamer1.0-plugins-base-videotestsrc-1.14.4. 227/1174
Verifying : gstreamer1.0-plugins-good-debug-1.14.4.imx-r0. 228/1174
Verifying : gstreamer1.0-plugins-good-navigationtest-1.14. 229/1174
Verifying : gstreamer1.0-plugins-base-tcp-1.14.4.imx-r0.aa 230/1174
Verifying : gstreamer1.0-plugins-good-soup-1.14.4.imx-r0.a 231/1174
Verifying : gstreamer1.0-plugins-good-udp-1.14.4.imx-r0.aa 232/1174
Verifying : gstreamer1.0-plugins-base-subparse-1.14.4.imx- 233/1174
Verifying : gstreamer1.0-plugins-base-theora-1.14.4.imx-r0 234/1174
Verifying : gstreamer1.0-plugins-good-avi-1.14.4.imx-r0.aa 235/1174
Verifying : gstreamer1.0-plugins-good-flv-1.14.4.imx-r0.aa 236/1174
Verifying : gstreamer1.0-plugins-good-isomp4-1.14.4.imx-r0 237/1174
Verifying : gstreamer1.0-plugins-good-matroska-1.14.4.imx- 238/1174
Verifying : bash-4.4.12-r0.aarch64 239/1174
Verifying : libblkid1-2.32.1-r0.aarch64 240/1174
Verifying : libtirpc3-1.0.2-r0.aarch64 241/1174
Verifying : libwrap0-7.6-r10.aarch64 242/1174
Verifying : libcap2-2.25-r0.aarch64 243/1174
Verifying : libevent-2.1.8-r0.aarch64 244/1174
Verifying : libnfsidmap0-0.25-r0.aarch64 245/1174
Verifying : nfs-utils-mount-2.1.1-r0.aarch64 246/1174
Verifying : rpcbind-0.2.4-r0.aarch64 247/1174
Verifying : shadow-4.2.1-r0.aarch64 248/1174
Verifying : kmod-25+git0+aca4eca103-r0.aarch64 249/1174
Verifying : packagegroup-base-alsa-1.0-r83.imx8mmevk 250/1174
Verifying : packagegroup-base-bluetooth-1.0-r83.imx8mmevk 251/1174
Verifying : packagegroup-base-ipv6-1.0-r83.imx8mmevk 252/1174
Verifying : packagegroup-base-nfs-1.0-r83.imx8mmevk 253/1174
Verifying : packagegroup-base-pci-1.0-r83.imx8mmevk 254/1174
Verifying : packagegroup-base-usbgadget-1.0-r83.imx8mmevk 255/1174
Verifying : packagegroup-base-usbhost-1.0-r83.imx8mmevk 256/1174
Verifying : packagegroup-base-wifi-1.0-r83.imx8mmevk 257/1174
Verifying : packagegroup-base-zeroconf-1.0-r83.imx8mmevk 258/1174
Verifying : packagegroup-distro-base-1.0-r83.imx8mmevk 259/1174
Verifying : packagegroup-machine-base-1.0-r83.imx8mmevk 260/1174
Verifying : ofono-1.22-r0.aarch64 261/1174
Verifying : neard-0.16-r0.aarch64 262/1174
Verifying : libgles2-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_m 263/1174
Verifying : libatk-1.0-0-2.26.1-r0.aarch64 264/1174
Verifying : libgdk-pixbuf-2.0-0-2.36.11-r0.aarch64 265/1174
Verifying : libgtk-2.0-2.24.32-r0.aarch64_mx8mm 266/1174
Verifying : gstreamer1.0-1.14.4.imx-r0.aarch64 267/1174
Verifying : libdrm2-2.4.91.imx-r0.aarch64_mx8mm 268/1174
Verifying : libgbm-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 269/1174
Verifying : libgstallocators-1.0-0-1.14.4.imx-r0.aarch64_m 270/1174
Verifying : libgstapp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 271/1174
Verifying : libgstvideo-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 272/1174
Verifying : libfreetype6-2.9-r0.aarch64 273/1174
Verifying : libgl-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8m 274/1174
Verifying : libglew2.1-2.1.0-r0.aarch64_mx8mm 275/1174
Verifying : libglu1-2:9.0.0-0.aarch64_mx8mm 276/1174
Verifying : libglut3-3.0.0-r0.aarch64_mx8mm 277/1174
Verifying : libopenvg-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_ 278/1174
Verifying : dbus-1-1.12.2-r0.aarch64 279/1174
Verifying : libacl1-2.2.52-r0.aarch64 280/1174
Verifying : libkmod2-25+git0+aca4eca103-r0.aarch64 281/1174
Verifying : liblzma5-5.2.3-r0.aarch64 282/1174
Verifying : libmount1-2.32.1-r0.aarch64 283/1174
Verifying : pam-plugin-keyinit-1.3.0-r5.aarch64 284/1174
Verifying : pam-plugin-loginuid-1.3.0-r5.aarch64 285/1174
Verifying : systemd-container-1:237-r0.aarch64 286/1174
Verifying : systemd-serialgetty-1.0-r5.imx8mmevk 287/1174
Verifying : systemd-vconsole-setup-1:237-r0.aarch64 288/1174
Verifying : update-rc.d-0.7-r5.noarch 289/1174
Verifying : util-linux-agetty-2.32.1-r0.aarch64 290/1174
Verifying : util-linux-mount-2.32.1-r0.aarch64 291/1174
Verifying : volatile-binds-1.0-r0.noarch 292/1174
Verifying : libexpat1-2.2.5-r0.aarch64 293/1174
Verifying : libpython3.5m1.0-3.5.5-r1.0.aarch64 294/1174
Verifying : libreadline7-7.0-r0.aarch64 295/1174
Verifying : python3-codecs-3.5.5-r1.0.aarch64 296/1174
Verifying : python3-modules-3.5.5-r1.0.aarch64 297/1174
Verifying : perl-5.24.1-r0.aarch64 298/1174
Verifying : gstreamer1.0-plugins-bad-accurip-1.14.4.imx-r0 299/1174
Verifying : gstreamer1.0-plugins-bad-adpcmdec-1.14.4.imx-r 300/1174
Verifying : gstreamer1.0-plugins-bad-adpcmenc-1.14.4.imx-r 301/1174
Verifying : gstreamer1.0-plugins-bad-aiff-1.14.4.imx-r0.aa 302/1174
Verifying : gstreamer1.0-plugins-bad-asfmux-1.14.4.imx-r0. 303/1174
Verifying : gstreamer1.0-plugins-bad-audiobuffersplit-1.14 304/1174
Verifying : gstreamer1.0-plugins-bad-audiofxbad-1.14.4.imx 305/1174
Verifying : gstreamer1.0-plugins-bad-audiolatency-1.14.4.i 306/1174
Verifying : gstreamer1.0-plugins-bad-audiomixmatrix-1.14.4 307/1174
Verifying : gstreamer1.0-plugins-bad-audiovisualizers-1.14 308/1174
Verifying : gstreamer1.0-plugins-bad-autoconvert-1.14.4.im 309/1174
Verifying : gstreamer1.0-plugins-bad-bayer-1.14.4.imx-r0.a 310/1174
Verifying : gstreamer1.0-plugins-bad-bluez-1.14.4.imx-r0.a 311/1174
Verifying : gstreamer1.0-plugins-bad-bz2-1.14.4.imx-r0.aar 312/1174
Verifying : gstreamer1.0-plugins-bad-camerabin-1.14.4.imx- 313/1174
Verifying : gstreamer1.0-plugins-bad-coloreffects-1.14.4.i 314/1174
Verifying : gstreamer1.0-plugins-bad-compositor-1.14.4.imx 315/1174
Verifying : gstreamer1.0-plugins-bad-curl-1.14.4.imx-r0.aa 316/1174
Verifying : gstreamer1.0-plugins-bad-dashdemux-1.14.4.imx- 317/1174
Verifying : gstreamer1.0-plugins-bad-debugutilsbad-1.14.4. 318/1174
Verifying : gstreamer1.0-plugins-bad-decklink-1.14.4.imx-r 319/1174
Verifying : gstreamer1.0-plugins-bad-dtls-1.14.4.imx-r0.aa 320/1174
Verifying : gstreamer1.0-plugins-bad-dvb-1.14.4.imx-r0.aar 321/1174
Verifying : gstreamer1.0-plugins-bad-dvbsuboverlay-1.14.4. 322/1174
Verifying : gstreamer1.0-plugins-bad-dvdspu-1.14.4.imx-r0. 323/1174
Verifying : gstreamer1.0-plugins-bad-faceoverlay-1.14.4.im 324/1174
Verifying : gstreamer1.0-plugins-bad-fbdevsink-1.14.4.imx- 325/1174
Verifying : gstreamer1.0-plugins-bad-festival-1.14.4.imx-r 326/1174
Verifying : gstreamer1.0-plugins-bad-fieldanalysis-1.14.4. 327/1174
Verifying : gstreamer1.0-plugins-bad-freeverb-1.14.4.imx-r 328/1174
Verifying : gstreamer1.0-plugins-bad-frei0r-1.14.4.imx-r0. 329/1174
Verifying : gstreamer1.0-plugins-bad-gaudieffects-1.14.4.i 330/1174
Verifying : gstreamer1.0-plugins-bad-gdp-1.14.4.imx-r0.aar 331/1174
Verifying : gstreamer1.0-plugins-bad-geometrictransform-1. 332/1174
Verifying : gstreamer1.0-plugins-bad-hls-1.14.4.imx-r0.aar 333/1174
Verifying : gstreamer1.0-plugins-bad-id3tag-1.14.4.imx-r0. 334/1174
Verifying : gstreamer1.0-plugins-bad-inter-1.14.4.imx-r0.a 335/1174
Verifying : gstreamer1.0-plugins-bad-interlace-1.14.4.imx- 336/1174
Verifying : gstreamer1.0-plugins-bad-ipcpipeline-1.14.4.im 337/1174
Verifying : gstreamer1.0-plugins-bad-ivfparse-1.14.4.imx-r 338/1174
Verifying : gstreamer1.0-plugins-bad-ivtc-1.14.4.imx-r0.aa 339/1174
Verifying : gstreamer1.0-plugins-bad-jp2kdecimator-1.14.4. 340/1174
Verifying : gstreamer1.0-plugins-bad-jpegformat-1.14.4.imx 341/1174
Verifying : gstreamer1.0-plugins-bad-kms-1.14.4.imx-r0.aar 342/1174
Verifying : gstreamer1.0-plugins-bad-legacyrawparse-1.14.4 343/1174
Verifying : gstreamer1.0-plugins-bad-midi-1.14.4.imx-r0.aa 344/1174
Verifying : gstreamer1.0-plugins-bad-mpegpsdemux-1.14.4.im 345/1174
Verifying : gstreamer1.0-plugins-bad-mpegpsmux-1.14.4.imx- 346/1174
Verifying : gstreamer1.0-plugins-bad-mpegtsdemux-1.14.4.im 347/1174
Verifying : gstreamer1.0-plugins-bad-mpegtsmux-1.14.4.imx- 348/1174
Verifying : gstreamer1.0-plugins-bad-mxf-1.14.4.imx-r0.aar 349/1174
Verifying : gstreamer1.0-plugins-bad-netsim-1.14.4.imx-r0. 350/1174
Verifying : gstreamer1.0-plugins-bad-openglmixers-1.14.4.i 351/1174
Verifying : gstreamer1.0-plugins-bad-pcapparse-1.14.4.imx- 352/1174
Verifying : gstreamer1.0-plugins-bad-pnm-1.14.4.imx-r0.aar 353/1174
Verifying : gstreamer1.0-plugins-bad-proxy-1.14.4.imx-r0.a 354/1174
Verifying : gstreamer1.0-plugins-bad-removesilence-1.14.4. 355/1174
Verifying : gstreamer1.0-plugins-bad-rfbsrc-1.14.4.imx-r0. 356/1174
Verifying : gstreamer1.0-plugins-bad-rsvg-1.14.4.imx-r0.aa 357/1174
Verifying : gstreamer1.0-plugins-bad-rtponvif-1.14.4.imx-r 358/1174
Verifying : gstreamer1.0-plugins-bad-sbc-1.14.4.imx-r0.aar 359/1174
Verifying : gstreamer1.0-plugins-bad-sdpelem-1.14.4.imx-r0 360/1174
Verifying : gstreamer1.0-plugins-bad-segmentclip-1.14.4.im 361/1174
Verifying : gstreamer1.0-plugins-bad-shm-1.14.4.imx-r0.aar 362/1174
Verifying : gstreamer1.0-plugins-bad-siren-1.14.4.imx-r0.a 363/1174
Verifying : gstreamer1.0-plugins-bad-smooth-1.14.4.imx-r0. 364/1174
Verifying : gstreamer1.0-plugins-bad-smoothstreaming-1.14. 365/1174
Verifying : gstreamer1.0-plugins-bad-sndfile-1.14.4.imx-r0 366/1174
Verifying : gstreamer1.0-plugins-bad-speed-1.14.4.imx-r0.a 367/1174
Verifying : gstreamer1.0-plugins-bad-stereo-1.14.4.imx-r0. 368/1174
Verifying : gstreamer1.0-plugins-bad-subenc-1.14.4.imx-r0. 369/1174
Verifying : gstreamer1.0-plugins-bad-timecode-1.14.4.imx-r 370/1174
Verifying : gstreamer1.0-plugins-bad-ttmlsubs-1.14.4.imx-r 371/1174
Verifying : gstreamer1.0-plugins-bad-uvch264-1.14.4.imx-r0 372/1174
Verifying : gstreamer1.0-plugins-bad-vcdsrc-1.14.4.imx-r0. 373/1174
Verifying : gstreamer1.0-plugins-bad-videofiltersbad-1.14. 374/1174
Verifying : gstreamer1.0-plugins-bad-videoframe-audiolevel 375/1174
Verifying : gstreamer1.0-plugins-bad-videoparsersbad-1.14. 376/1174
Verifying : gstreamer1.0-plugins-bad-videosignal-1.14.4.im 377/1174
Verifying : gstreamer1.0-plugins-bad-vmnc-1.14.4.imx-r0.aa 378/1174
Verifying : gstreamer1.0-plugins-bad-waylandsink-1.14.4.im 379/1174
Verifying : gstreamer1.0-plugins-bad-webp-1.14.4.imx-r0.aa 380/1174
Verifying : gstreamer1.0-plugins-bad-y4mdec-1.14.4.imx-r0. 381/1174
Verifying : gstreamer1.0-plugins-bad-yadif-1.14.4.imx-r0.a 382/1174
Verifying : libgstadaptivedemux-1.0-0-1.14.4.imx-r0.aarch6 383/1174
Verifying : libgstbadaudio-1.0-0-1.14.4.imx-r0.aarch64_mx8 384/1174
Verifying : libgstbadvideo-1.0-0-1.14.4.imx-r0.aarch64_mx8 385/1174
Verifying : libgstbasecamerabinsrc-1.0-0-1.14.4.imx-r0.aar 386/1174
Verifying : libgstcodecparsers-1.0-0-1.14.4.imx-r0.aarch64 387/1174
Verifying : libgstinsertbin-1.0-0-1.14.4.imx-r0.aarch64_mx 388/1174
Verifying : libgstisoff-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 389/1174
Verifying : libgstmpegts-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 390/1174
Verifying : libgstphotography-1.0-0-1.14.4.imx-r0.aarch64_ 391/1174
Verifying : libgstplayer-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 392/1174
Verifying : libgsturidownloader-1.0-0-1.14.4.imx-r0.aarch6 393/1174
Verifying : libgstwayland-1.0-0-1.14.4.imx-r0.aarch64_mx8m 394/1174
Verifying : libgstwebrtc-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 395/1174
Verifying : gstreamer1.0-plugins-base-adder-1.14.4.imx-r0. 396/1174
Verifying : gstreamer1.0-plugins-base-alsa-1.14.4.imx-r0.a 397/1174
Verifying : gstreamer1.0-plugins-base-app-1.14.4.imx-r0.aa 398/1174
Verifying : gstreamer1.0-plugins-base-apps-1.14.4.imx-r0.a 399/1174
Verifying : gstreamer1.0-plugins-base-audioconvert-1.14.4. 400/1174
Verifying : gstreamer1.0-plugins-base-audiomixer-1.14.4.im 401/1174
Verifying : gstreamer1.0-plugins-base-audiorate-1.14.4.imx 402/1174
Verifying : gstreamer1.0-plugins-base-audioresample-1.14.4 403/1174
Verifying : gstreamer1.0-plugins-base-encoding-1.14.4.imx- 404/1174
Verifying : gstreamer1.0-plugins-base-gio-1.14.4.imx-r0.aa 405/1174
Verifying : gstreamer1.0-plugins-base-opengl-1.14.4.imx-r0 406/1174
Verifying : gstreamer1.0-plugins-base-pango-1.14.4.imx-r0. 407/1174
Verifying : gstreamer1.0-plugins-base-pbtypes-1.14.4.imx-r 408/1174
Verifying : gstreamer1.0-plugins-base-playback-1.14.4.imx- 409/1174
Verifying : gstreamer1.0-plugins-base-rawparse-1.14.4.imx- 410/1174
Verifying : gstreamer1.0-plugins-base-typefindfunctions-1. 411/1174
Verifying : gstreamer1.0-plugins-base-videoconvert-1.14.4. 412/1174
Verifying : gstreamer1.0-plugins-base-videorate-1.14.4.imx 413/1174
Verifying : gstreamer1.0-plugins-base-videoscale-1.14.4.im 414/1174
Verifying : gstreamer1.0-plugins-base-volume-1.14.4.imx-r0 415/1174
Verifying : gstreamer1.0-plugins-base-vorbis-1.14.4.imx-r0 416/1174
Verifying : gstreamer1.0-plugins-base-ximagesink-1.14.4.im 417/1174
Verifying : gstreamer1.0-plugins-base-xvimagesink-1.14.4.i 418/1174
Verifying : libgstaudio-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 419/1174
Verifying : libgstfft-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 420/1174
Verifying : libgstgl-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 421/1174
Verifying : libgstpbutils-1.0-0-1.14.4.imx-r0.aarch64_mx8m 422/1174
Verifying : libgstriff-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 423/1174
Verifying : libgstrtp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 424/1174
Verifying : libgstrtsp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 425/1174
Verifying : libgstsdp-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 426/1174
Verifying : libgsttag-1.0-0-1.14.4.imx-r0.aarch64_mx8mm 427/1174
Verifying : gstreamer1.0-plugins-good-alaw-1.14.4.imx-r0.a 428/1174
Verifying : gstreamer1.0-plugins-good-alpha-1.14.4.imx-r0. 429/1174
Verifying : gstreamer1.0-plugins-good-alphacolor-1.14.4.im 430/1174
Verifying : gstreamer1.0-plugins-good-apetag-1.14.4.imx-r0 431/1174
Verifying : gstreamer1.0-plugins-good-audiofx-1.14.4.imx-r 432/1174
Verifying : gstreamer1.0-plugins-good-auparse-1.14.4.imx-r 433/1174
Verifying : gstreamer1.0-plugins-good-autodetect-1.14.4.im 434/1174
Verifying : gstreamer1.0-plugins-good-cairo-1.14.4.imx-r0. 435/1174
Verifying : gstreamer1.0-plugins-good-cutter-1.14.4.imx-r0 436/1174
Verifying : gstreamer1.0-plugins-good-deinterlace-1.14.4.i 437/1174
Verifying : gstreamer1.0-plugins-good-dtmf-1.14.4.imx-r0.a 438/1174
Verifying : gstreamer1.0-plugins-good-effectv-1.14.4.imx-r 439/1174
Verifying : gstreamer1.0-plugins-good-equalizer-1.14.4.imx 440/1174
Verifying : gstreamer1.0-plugins-good-flxdec-1.14.4.imx-r0 441/1174
Verifying : gstreamer1.0-plugins-good-gdkpixbuf-1.14.4.imx 442/1174
Verifying : gstreamer1.0-plugins-good-goom-1.14.4.imx-r0.a 443/1174
Verifying : gstreamer1.0-plugins-good-goom2k1-1.14.4.imx-r 444/1174
Verifying : gstreamer1.0-plugins-good-imagefreeze-1.14.4.i 445/1174
Verifying : gstreamer1.0-plugins-good-interleave-1.14.4.im 446/1174
Verifying : gstreamer1.0-plugins-good-jpeg-1.14.4.imx-r0.a 447/1174
Verifying : gstreamer1.0-plugins-good-level-1.14.4.imx-r0. 448/1174
Verifying : gstreamer1.0-plugins-good-mulaw-1.14.4.imx-r0. 449/1174
Verifying : gstreamer1.0-plugins-good-multifile-1.14.4.imx 450/1174
Verifying : gstreamer1.0-plugins-good-multipart-1.14.4.imx 451/1174
Verifying : gstreamer1.0-plugins-good-ossaudio-1.14.4.imx- 452/1174
Verifying : gstreamer1.0-plugins-good-png-1.14.4.imx-r0.aa 453/1174
Verifying : gstreamer1.0-plugins-good-pulseaudio-1.14.4.im 454/1174
Verifying : gstreamer1.0-plugins-good-replaygain-1.14.4.im 455/1174
Verifying : gstreamer1.0-plugins-good-rtp-1.14.4.imx-r0.aa 456/1174
Verifying : gstreamer1.0-plugins-good-rtpmanager-1.14.4.im 457/1174
Verifying : gstreamer1.0-plugins-good-rtsp-1.14.4.imx-r0.a 458/1174
Verifying : gstreamer1.0-plugins-good-shapewipe-1.14.4.imx 459/1174
Verifying : gstreamer1.0-plugins-good-smpte-1.14.4.imx-r0. 460/1174
Verifying : gstreamer1.0-plugins-good-spectrum-1.14.4.imx- 461/1174
Verifying : gstreamer1.0-plugins-good-taglib-1.14.4.imx-r0 462/1174
Verifying : gstreamer1.0-plugins-good-video4linux2-1.14.4. 463/1174
Verifying : gstreamer1.0-plugins-good-videobox-1.14.4.imx- 464/1174
Verifying : gstreamer1.0-plugins-good-videocrop-1.14.4.imx 465/1174
Verifying : gstreamer1.0-plugins-good-videofilter-1.14.4.i 466/1174
Verifying : gstreamer1.0-plugins-good-videomixer-1.14.4.im 467/1174
Verifying : gstreamer1.0-plugins-good-wavenc-1.14.4.imx-r0 468/1174
Verifying : gstreamer1.0-plugins-good-ximagesrc-1.14.4.imx 469/1174
Verifying : gstreamer1.0-plugins-good-y4menc-1.14.4.imx-r0 470/1174
Verifying : libpopt0-1.16-r3.aarch64 471/1174
Verifying : libuuid1-2.32.1-r0.aarch64 472/1174
Verifying : liburcu-0.10.1-r0.aarch64 473/1174
Verifying : libxml2-2.9.7-r0.aarch64 474/1174
Verifying : libncurses5-6.0+20171125-r0.aarch64 475/1174
Verifying : libnl-3-200-1:3.4.0-r0.aarch64 476/1174
Verifying : libnl-genl-3-200-1:3.4.0-r0.aarch64 477/1174
Verifying : libpci3-3.5.6-r0.aarch64 478/1174
Verifying : libdw1-0.170-r0.aarch64 479/1174
Verifying : libelf1-0.170-r0.aarch64 480/1174
Verifying : libjson-c3-0.13-r0.aarch64 481/1174
Verifying : libpanel5-6.0+20171125-r0.aarch64 482/1174
Verifying : libsqlite3-0-3:3.22.0-r0.aarch64 483/1174
Verifying : python3-core-3.5.5-r1.0.aarch64 484/1174
Verifying : libaio1-0.3.110-r0.aarch64 485/1174
Verifying : numactl-2.0.11+git0+ea3a70681c-r0.aarch64 486/1174
Verifying : perl-module-exporter-heavy-5.24.1-r0.aarch64 487/1174
Verifying : perl-module-getopt-long-5.24.1-r0.aarch64 488/1174
Verifying : perl-module-overload-5.24.1-r0.aarch64 489/1174
Verifying : libsystemd0-1:237-r0.aarch64 490/1174
Verifying : xkeyboard-config-2.22-r0.aarch64 491/1174
Verifying : libasound2-1.1.5-r0.aarch64_mx8mm 492/1174
Verifying : libgtk-3.0-3.22.28-r0.aarch64_mx8mm 493/1174
Verifying : alsa-utils-aconnect-1.1.5-r0.aarch64 494/1174
Verifying : alsa-utils-alsactl-1.1.5-r0.aarch64 495/1174
Verifying : alsa-utils-alsaloop-1.1.5-r0.aarch64 496/1174
Verifying : alsa-utils-alsamixer-1.1.5-r0.aarch64 497/1174
Verifying : alsa-utils-alsatplg-1.1.5-r0.aarch64 498/1174
Verifying : alsa-utils-alsaucm-1.1.5-r0.aarch64 499/1174
Verifying : alsa-utils-aseqdump-1.1.5-r0.aarch64 500/1174
Verifying : alsa-utils-aseqnet-1.1.5-r0.aarch64 501/1174
Verifying : alsa-utils-iecset-1.1.5-r0.aarch64 502/1174
Verifying : alsa-utils-midi-1.1.5-r0.aarch64 503/1174
Verifying : alsa-utils-speakertest-1.1.5-r0.aarch64 504/1174
Verifying : libdbus-1-3-1.12.2-r0.aarch64 505/1174
Verifying : libdbus-glib-1-2-0.108-r0.aarch64 506/1174
Verifying : libpulse0-11.1-r0.aarch64_mx8mm 507/1174
Verifying : libpulsecommon-11.1-r0.aarch64_mx8mm 508/1174
Verifying : libsm6-1:1.2.2-r0.aarch64 509/1174
Verifying : libsndfile1-1.0.28-r0.aarch64 510/1174
Verifying : libx11-xcb1-1:1.6.5-r0.aarch64 511/1174
Verifying : libxtst6-1:1.2.3-r0.aarch64 512/1174
Verifying : pulseaudio-module-cli-protocol-unix-11.1-r0.aa 513/1174
Verifying : libltdl7-2.4.6-r0.aarch64 514/1174
Verifying : libpulsecore-11.1-r0.aarch64_mx8mm 515/1174
Verifying : libspeexdsp1-1.2rc3-r0.aarch64 516/1174
Verifying : pulseaudio-lib-cli-11.1-r0.aarch64_mx8mm 517/1174
Verifying : pulseaudio-lib-protocol-native-11.1-r0.aarch64 518/1174
Verifying : alsa-plugins-pulseaudio-conf-1.1.5-r0.aarch64 519/1174
Verifying : pulseaudio-module-alsa-card-11.1-r0.aarch64_mx 520/1174
Verifying : pulseaudio-module-alsa-sink-11.1-r0.aarch64_mx 521/1174
Verifying : pulseaudio-module-alsa-source-11.1-r0.aarch64_ 522/1174
Verifying : pulseaudio-module-always-sink-11.1-r0.aarch64_ 523/1174
Verifying : pulseaudio-module-augment-properties-11.1-r0.a 524/1174
Verifying : pulseaudio-module-card-restore-11.1-r0.aarch64 525/1174
Verifying : pulseaudio-module-console-kit-11.1-r0.aarch64_ 526/1174
Verifying : pulseaudio-module-default-device-restore-11.1- 527/1174
Verifying : pulseaudio-module-detect-11.1-r0.aarch64_mx8mm 528/1174
Verifying : pulseaudio-module-device-restore-11.1-r0.aarch 529/1174
Verifying : pulseaudio-module-filter-apply-11.1-r0.aarch64 530/1174
Verifying : pulseaudio-module-filter-heuristics-11.1-r0.aa 531/1174
Verifying : pulseaudio-module-intended-roles-11.1-r0.aarch 532/1174
Verifying : pulseaudio-module-native-protocol-unix-11.1-r0 533/1174
Verifying : pulseaudio-module-null-sink-11.1-r0.aarch64_mx 534/1174
Verifying : pulseaudio-module-position-event-sounds-11.1-r 535/1174
Verifying : pulseaudio-module-rescue-streams-11.1-r0.aarch 536/1174
Verifying : pulseaudio-module-role-cork-11.1-r0.aarch64_mx 537/1174
Verifying : pulseaudio-module-stream-restore-11.1-r0.aarch 538/1174
Verifying : pulseaudio-module-suspend-on-idle-11.1-r0.aarc 539/1174
Verifying : pulseaudio-module-switch-on-port-available-11. 540/1174
Verifying : pulseaudio-module-udev-detect-11.1-r0.aarch64_ 541/1174
Verifying : connman-1.35-r0.aarch64 542/1174
Verifying : iptables-1.6.2-r0.aarch64 543/1174
Verifying : libgnutls30-3.6.1-r0.aarch64 544/1174
Verifying : libxext6-1:1.3.3-r0.aarch64 545/1174
Verifying : libxft2-1:2.3.2-r0.aarch64 546/1174
Verifying : tslib-conf-1.15-r0.aarch64 547/1174
Verifying : acl-2.2.52-r0.aarch64 548/1174
Verifying : at-3.1.20-r0.aarch64 549/1174
Verifying : attr-2.4.47-r0.aarch64 550/1174
Verifying : cpio-2.12-r0.aarch64 551/1174
Verifying : cronie-1.5.1-r0.aarch64 552/1174
Verifying : curl-7.61.0-r0.aarch64 553/1174
Verifying : expect-5.45.4-r0.aarch64 554/1174
Verifying : gawk-4.2.1-r0.aarch64 555/1174
Verifying : gzip-1.9-r0.aarch64 556/1174
Verifying : ldd-2.27-r0.aarch64 557/1174
Verifying : libcrypto1.0.2-1.0.2p-r0.aarch64 558/1174
Verifying : logrotate-3.13.0-r0.aarch64 559/1174
Verifying : python-core-2.7.15-r1.aarch64 560/1174
Verifying : tar-1.30-r0.aarch64 561/1174
Verifying : unzip-1:6.0-r5.aarch64 562/1174
Verifying : util-linux-2.32.1-r0.aarch64 563/1174
Verifying : which-2.21-r3.aarch64 564/1174
Verifying : python3-dbus-1.2.6-r0.aarch64 565/1174
Verifying : python3-pygobject-3.28.1-r0.aarch64_mx8mm 566/1174
Verifying : libxmuu1-1:1.1.2-r0.aarch64 567/1174
Verifying : libxrender1-1:0.9.10-r0.aarch64 568/1174
Verifying : libxres1-1:1.2.0-r0.aarch64 569/1174
Verifying : libxv1-1.0.11-r0.aarch64 570/1174
Verifying : libudev1-1:237-r0.aarch64 571/1174
Verifying : libical-2.0.0-r0.aarch64 572/1174
Verifying : libsbc1-1.3-r0.aarch64 573/1174
Verifying : pulseaudio-lib-bluez5-util-11.1-r0.aarch64_mx8 574/1174
Verifying : libfontconfig1-2.12.6-r0.aarch64 575/1174
Verifying : libxcb-shm0-1.12-r0.aarch64 576/1174
Verifying : libgal-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 577/1174
Verifying : libffi6-3.2.1-r0.aarch64 578/1174
Verifying : libpcre1-8.41-r0.aarch64 579/1174
Verifying : libevdev-1.5.8-r0.aarch64 580/1174
Verifying : mtdev-1.1.5-r0.aarch64 581/1174
Verifying : libg2d1.1-6.2.4.p4.0-r0.aarch64_mx8mm 582/1174
Verifying : libxcb-xkb1-1.12-r0.aarch64 583/1174
Verifying : libxau6-1:1.0.8-r0.aarch64 584/1174
Verifying : libxdmcp6-1:1.1.2-r0.aarch64 585/1174
Verifying : libxfixes3-1:5.0.3-r0.aarch64 586/1174
Verifying : libharfbuzz0-1.7.5-r0.aarch64_mx8mm 587/1174
Verifying : libxfont2-2-2.0.3-r0.aarch64 588/1174
Verifying : libxshmfence1-1.2-r0.aarch64 589/1174
Verifying : diffutils-3.6-r0.aarch64 590/1174
Verifying : m4-1.4.18-r0.aarch64 591/1174
Verifying : make-4.2.1-r0.aarch64 592/1174
Verifying : patch-2.7.6-r0.aarch64 593/1174
Verifying : iputils-s20161105-r0.aarch64 594/1174
Verifying : openssl-1.0.2p-r0.aarch64 595/1174
Verifying : initscripts-1.0-r155.imx8mmevk 596/1174
Verifying : sysklogd-1.5.1-r0.aarch64 597/1174
Verifying : cracklib-2.9.5-r0.aarch64 598/1174
Verifying : libuser-0.62-r0.aarch64 599/1174
Verifying : sudo-1.8.22-r0.aarch64 600/1174
Verifying : bzip2-1.0.6-r5.aarch64 601/1174
Verifying : elfutils-0.170-r0.aarch64 602/1174
Verifying : less-529-r0.aarch64 603/1174
Verifying : pciutils-3.5.6-r0.aarch64 604/1174
Verifying : tcp-wrappers-7.6-r10.aarch64 605/1174
Verifying : tzdata-2018f-r0.noarch 606/1174
Verifying : bc-1.06-r3.aarch64 607/1174
Verifying : e2fsprogs-1.43.8-r0.aarch64 608/1174
Verifying : ed-1.14.2-r0.aarch64 609/1174
Verifying : file-5.32-r0.aarch64 610/1174
Verifying : findutils-4.6.0-r0.aarch64 611/1174
Verifying : grep-3.1-r0.aarch64 612/1174
Verifying : libgmp10-6.1.2-r0.aarch64 613/1174
Verifying : makedevs-1.0.1-r0.aarch64 614/1174
Verifying : mc-4.8.20-r0.aarch64 615/1174
Verifying : mc-fish-4.8.20-r0.aarch64 616/1174
Verifying : mc-helpers-4.8.20-r0.aarch64 617/1174
Verifying : mc-helpers-perl-4.8.20-r0.aarch64 618/1174
Verifying : mktemp-1.7-r3.aarch64 619/1174
Verifying : ncurses-6.0+20171125-r0.aarch64 620/1174
Verifying : net-tools-1.60+26-r0.aarch64 621/1174
Verifying : psmisc-23.0-r0.aarch64 622/1174
Verifying : sed-4.2.2-r0.aarch64 623/1174
Verifying : time-1.8-r0.aarch64 624/1174
Verifying : libgpuperfcnt1.4.0-6.2.4.p4.0-r0.aarch64_mx8mm 625/1174
Verifying : libvdk-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 626/1174
Verifying : devil-1.8.0-r0.imx8mmevk 627/1174
Verifying : libassimp4-4.1.0-r0.aarch64 628/1174
Verifying : libdrm-etnaviv1-2.4.91.imx-r0.aarch64_mx8mm 629/1174
Verifying : libkms1-2.4.91.imx-r0.aarch64_mx8mm 630/1174
Verifying : libattr1-2.4.47-r0.aarch64 631/1174
Verifying : kernel-module-cryptodev-4.14.98-imx_4.14.98_2. 632/1174
Verifying : libcom-err2-1.43.8-r0.aarch64 633/1174
Verifying : libe2p2-1.43.8-r0.aarch64 634/1174
Verifying : libext2fs2-1.43.8-r0.aarch64 635/1174
Verifying : libepoxy0-1.5.0-r0.aarch64_mx8mm 636/1174
Verifying : libssl1.0.2-1.0.2p-r0.aarch64 637/1174
Verifying : libclc-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 638/1174
Verifying : libgles-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx 639/1174
Verifying : libopencl-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_ 640/1174
Verifying : libmnl0-1.0.4-r0.aarch64 641/1174
Verifying : libclutter-1.0-0-1.26.2-r0.aarch64_mx8mm 642/1174
Verifying : liblzo2-2-2.10-r0.aarch64 643/1174
Verifying : libncursesw5-6.0+20171125-r0.aarch64 644/1174
Verifying : ncurses-terminfo-6.0+20171125-r0.aarch64 645/1174
Verifying : imx-codec-test-bin-4.4.5-r0.aarch64_mx8mm 646/1174
Verifying : imx-codec-test-source-4.4.5-r0.aarch64_mx8mm 647/1174
Verifying : libpcap1-1.8.1-r0.aarch64 648/1174
Verifying : libpython2.7-1.0-2.7.15-r1.aarch64 649/1174
Verifying : python-codecs-2.7.15-r1.aarch64 650/1174
Verifying : python-lang-2.7.15-r1.aarch64 651/1174
Verifying : python-misc-2.7.15-r1.aarch64 652/1174
Verifying : python-modules-2.7.15-r1.aarch64 653/1174
Verifying : python-setuptools-39.0.0-r0.aarch64 654/1174
Verifying : python-fcntl-2.7.15-r1.aarch64 655/1174
Verifying : python-io-2.7.15-r1.aarch64 656/1174
Verifying : python-pickle-2.7.15-r1.aarch64 657/1174
Verifying : libtcl8.6-0-8.6.8-r0.aarch64 658/1174
Verifying : tk-lib-8.6.8-r0.aarch64 659/1174
Verifying : libv4l-1.12.3-r0.aarch64_mx8mm 660/1174
Verifying : libdrm-freedreno1-2.4.91.imx-r0.aarch64_mx8mm 661/1174
Verifying : glibc-gconv-2.27-r0.aarch64 662/1174
Verifying : glibc-localedata-i18n-ctype-2.27-r0.aarch64 663/1174
Verifying : glibc-localedata-iso14651-t1-2.27-r0.aarch64 664/1174
Verifying : glibc-localedata-translit-neutral-2.27-r0.aarc 665/1174
Verifying : libc6-extra-nss-2.27-r0.aarch64 666/1174
Verifying : libcidn1-2.27-r0.aarch64 667/1174
Verifying : pam-plugin-warn-1.3.0-r5.aarch64 668/1174
Verifying : libogg0-1.3.3-r0.aarch64 669/1174
Verifying : liborc-0.4-0-0.4.28-r0.aarch64 670/1174
Verifying : libflac8-1.3.2-r0.aarch64 671/1174
Verifying : libspeex1-1.2.0-r0.aarch64 672/1174
Verifying : imx-gst1.0-plugin-4.4.5-r0.aarch64_mx8mm 673/1174
Verifying : imx-gst1.0-plugin-gplay-4.4.5-r0.aarch64_mx8mm 674/1174
Verifying : imx-gst1.0-plugin-grecorder-4.4.5-r0.aarch64_m 675/1174
Verifying : libsoup-2.4-2.60.3-r0.aarch64 676/1174
Verifying : libtheora-1.1.1-r1.aarch64 677/1174
Verifying : libbz2-1-1.0.6-r5.aarch64 678/1174
Verifying : pam-plugin-env-1.3.0-r5.aarch64 679/1174
Verifying : pam-plugin-faildelay-1.3.0-r5.aarch64 680/1174
Verifying : pam-plugin-group-1.3.0-r5.aarch64 681/1174
Verifying : pam-plugin-lastlog-1.3.0-r5.aarch64 682/1174
Verifying : pam-plugin-limits-1.3.0-r5.aarch64 683/1174
Verifying : pam-plugin-mail-1.3.0-r5.aarch64 684/1174
Verifying : pam-plugin-motd-1.3.0-r5.aarch64 685/1174
Verifying : pam-plugin-nologin-1.3.0-r5.aarch64 686/1174
Verifying : pam-plugin-rootok-1.3.0-r5.aarch64 687/1174
Verifying : pam-plugin-securetty-1.3.0-r5.aarch64 688/1174
Verifying : pam-plugin-shells-1.3.0-r5.aarch64 689/1174
Verifying : shadow-base-4.2.1-r0.aarch64 690/1174
Verifying : shadow-securetty-4.2.1-r3.imx8mmevk 691/1174
Verifying : util-linux-sulogin-2.32.1-r0.aarch64 692/1174
Verifying : alsa-state-0.2.0-r5.imx8mmevk 693/1174
Verifying : bluez5-5.49-r0.aarch64 694/1174
Verifying : usbutils-009-r0.aarch64 695/1174
Verifying : wireless-tools-1:30.pre9-r0.aarch64 696/1174
Verifying : wpa-supplicant-2.6-r0.aarch64 697/1174
Verifying : avahi-daemon-0.7-r0.aarch64 698/1174
Verifying : libnss-mdns-0.10-r7.aarch64 699/1174
Verifying : libglslc-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_m 700/1174
Verifying : libvsc-imx-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8 701/1174
Verifying : shared-mime-info-1.9-r0.aarch64 702/1174
Verifying : libxcomposite1-1:0.4.4-r0.aarch64 703/1174
Verifying : libxdamage1-1:1.1.4-r0.aarch64 704/1174
Verifying : libxrandr2-1:1.5.1-r0.aarch64 705/1174
Verifying : libglapi0-2:17.3.8-r0.aarch64_mx8mm 706/1174
Verifying : libxi6-1:1.7.9-r0.aarch64 707/1174
Verifying : libxxf86vm1-1:1.1.4-r0.aarch64 708/1174
Verifying : systemd-gpuconfig-1.0-r0.aarch64 709/1174
Verifying : python3-2to3-3.5.5-r1.0.aarch64 710/1174
Verifying : python3-asyncio-3.5.5-r1.0.aarch64 711/1174
Verifying : python3-audio-3.5.5-r1.0.aarch64 712/1174
Verifying : python3-compile-3.5.5-r1.0.aarch64 713/1174
Verifying : python3-compression-3.5.5-r1.0.aarch64 714/1174
Verifying : python3-crypt-3.5.5-r1.0.aarch64 715/1174
Verifying : python3-ctypes-3.5.5-r1.0.aarch64 716/1174
Verifying : python3-curses-3.5.5-r1.0.aarch64 717/1174
Verifying : python3-datetime-3.5.5-r1.0.aarch64 718/1174
Verifying : python3-db-3.5.5-r1.0.aarch64 719/1174
Verifying : python3-debugger-3.5.5-r1.0.aarch64 720/1174
Verifying : python3-difflib-3.5.5-r1.0.aarch64 721/1174
Verifying : python3-distutils-3.5.5-r1.0.aarch64 722/1174
Verifying : python3-doctest-3.5.5-r1.0.aarch64 723/1174
Verifying : python3-email-3.5.5-r1.0.aarch64 724/1174
Verifying : python3-fcntl-3.5.5-r1.0.aarch64 725/1174
Verifying : python3-html-3.5.5-r1.0.aarch64 726/1174
Verifying : python3-idle-3.5.5-r1.0.aarch64 727/1174
Verifying : python3-image-3.5.5-r1.0.aarch64 728/1174
Verifying : python3-io-3.5.5-r1.0.aarch64 729/1174
Verifying : python3-json-3.5.5-r1.0.aarch64 730/1174
Verifying : python3-logging-3.5.5-r1.0.aarch64 731/1174
Verifying : python3-mailbox-3.5.5-r1.0.aarch64 732/1174
Verifying : python3-math-3.5.5-r1.0.aarch64 733/1174
Verifying : python3-mime-3.5.5-r1.0.aarch64 734/1174
Verifying : python3-mmap-3.5.5-r1.0.aarch64 735/1174
Verifying : python3-multiprocessing-3.5.5-r1.0.aarch64 736/1174
Verifying : python3-netclient-3.5.5-r1.0.aarch64 737/1174
Verifying : python3-netserver-3.5.5-r1.0.aarch64 738/1174
Verifying : python3-numbers-3.5.5-r1.0.aarch64 739/1174
Verifying : python3-pickle-3.5.5-r1.0.aarch64 740/1174
Verifying : python3-pkgutil-3.5.5-r1.0.aarch64 741/1174
Verifying : python3-plistlib-3.5.5-r1.0.aarch64 742/1174
Verifying : python3-pprint-3.5.5-r1.0.aarch64 743/1174
Verifying : python3-profile-3.5.5-r1.0.aarch64 744/1174
Verifying : python3-pydoc-3.5.5-r1.0.aarch64 745/1174
Verifying : python3-resource-3.5.5-r1.0.aarch64 746/1174
Verifying : python3-runpy-3.5.5-r1.0.aarch64 747/1174
Verifying : python3-shell-3.5.5-r1.0.aarch64 748/1174
Verifying : python3-smtpd-3.5.5-r1.0.aarch64 749/1174
Verifying : python3-sqlite3-3.5.5-r1.0.aarch64 750/1174
Verifying : python3-stringold-3.5.5-r1.0.aarch64 751/1174
Verifying : python3-syslog-3.5.5-r1.0.aarch64 752/1174
Verifying : python3-terminal-3.5.5-r1.0.aarch64 753/1174
Verifying : python3-threading-3.5.5-r1.0.aarch64 754/1174
Verifying : python3-tkinter-3.5.5-r1.0.aarch64 755/1174
Verifying : python3-typing-3.5.5-r1.0.aarch64 756/1174
Verifying : python3-unittest-3.5.5-r1.0.aarch64 757/1174
Verifying : python3-unixadmin-3.5.5-r1.0.aarch64 758/1174
Verifying : python3-xml-3.5.5-r1.0.aarch64 759/1174
Verifying : python3-xmlrpc-3.5.5-r1.0.aarch64 760/1174
Verifying : libperl5-5.24.1-r0.aarch64 761/1174
Verifying : libcurl4-7.61.0-r0.aarch64 762/1174
Verifying : nettle-3.4-r0.aarch64 763/1174
Verifying : librsvg-2-2-2.40.20-r0.aarch64_mx8mm 764/1174
Verifying : libgudev-1.0-0-232-r0.aarch64 765/1174
Verifying : libusb-1.0-0-1.0.21-r0.aarch64 766/1174
Verifying : libwebp-0.6.1-r0.aarch64 767/1174
Verifying : libvorbis-1.3.5-r1.aarch64 768/1174
Verifying : libcairo-gobject2-1.14.12-r0.aarch64_mx8mm 769/1174
Verifying : libtag1-1.11.1-r0.aarch64 770/1174
Verifying : perl-module-carp-5.24.1-r0.aarch64 771/1174
Verifying : perl-module-exporter-5.24.1-r0.aarch64 772/1174
Verifying : perl-module-constant-5.24.1-r0.aarch64 773/1174
Verifying : perl-module-pod-usage-5.24.1-r0.aarch64 774/1174
Verifying : perl-module-text-parsewords-5.24.1-r0.aarch64 775/1174
Verifying : perl-module-mro-5.24.1-r0.aarch64 776/1174
Verifying : perl-module-overloading-5.24.1-r0.aarch64 777/1174
Verifying : perl-module-scalar-util-5.24.1-r0.aarch64 778/1174
Verifying : alsa-conf-1.1.5-r0.aarch64_mx8mm 779/1174
Verifying : libglib-2.0-utils-1:2.54.3-r0.aarch64 780/1174
Verifying : libsamplerate0-0.1.9-r1.aarch64 781/1174
Verifying : libformw5-6.0+20171125-r0.aarch64 782/1174
Verifying : libmenuw5-6.0+20171125-r0.aarch64 783/1174
Verifying : libpanelw5-6.0+20171125-r0.aarch64 784/1174
Verifying : pulseaudio-lib-protocol-cli-11.1-r0.aarch64_mx 785/1174
Verifying : libasound-module-conf-pulse-1.1.5-r0.aarch64 786/1174
Verifying : libasound-module-ctl-pulse-1.1.5-r0.aarch64 787/1174
Verifying : libasound-module-pcm-pulse-1.1.5-r0.aarch64 788/1174
Verifying : pulseaudio-lib-alsa-util-11.1-r0.aarch64_mx8mm 789/1174
Verifying : libunistring2-0.9.9-r0.aarch64 790/1174
Verifying : flex-libfl-2.6.0-r0.aarch64 791/1174
Verifying : pam-plugin-access-1.3.0-r5.aarch64 792/1174
Verifying : tcl-8.6.8-r0.aarch64 793/1174
Verifying : libsmartcols1-2.32.1-r0.aarch64 794/1174
Verifying : util-linux-losetup-2.32.1-r0.aarch64 795/1174
Verifying : util-linux-lsblk-2.32.1-r0.aarch64 796/1174
Verifying : util-linux-runuser-2.32.1-r0.aarch64 797/1174
Verifying : util-linux-su-2.32.1-r0.aarch64 798/1174
Verifying : util-linux-swaponoff-2.32.1-r0.aarch64 799/1174
Verifying : util-linux-umount-2.32.1-r0.aarch64 800/1174
Verifying : gobject-introspection-1.54.1-r0.aarch64 801/1174
Verifying : python3-pycairo-1.15.6-r0.aarch64_mx8mm 802/1174
Verifying : python3-setuptools-39.0.0-r0.aarch64 803/1174
Verifying : libicui18n60-60.2-r0.aarch64 804/1174
Verifying : libicuuc60-60.2-r0.aarch64 805/1174
Verifying : kernel-module-imx-gpu-viv-6.2.4.p4.0-r0.imx8mm 806/1174
Verifying : libfontenc1-1:1.1.3-r0.aarch64 807/1174
Verifying : iputils-arping-s20161105-r0.aarch64 808/1174
Verifying : iputils-clockdiff-s20161105-r0.aarch64 809/1174
Verifying : iputils-ping-s20161105-r0.aarch64 810/1174
Verifying : iputils-tracepath-s20161105-r0.aarch64 811/1174
Verifying : iputils-traceroute6-s20161105-r0.aarch64 812/1174
Verifying : openssl-conf-1.0.2p-r0.aarch64 813/1174
Verifying : initscripts-functions-1.0-r155.imx8mmevk 814/1174
Verifying : pciutils-ids-3.5.6-r0.aarch64 815/1174
Verifying : e2fsprogs-badblocks-1.43.8-r0.aarch64 816/1174
Verifying : libss2-1.43.8-r0.aarch64 817/1174
Verifying : fuser-23.0-r0.aarch64 818/1174
Verifying : killall-23.0-r0.aarch64 819/1174
Verifying : pstree-23.0-r0.aarch64 820/1174
Verifying : imx-gpu-viv-1:6.2.4.p4.0+aarch64-r0.aarch64_mx 821/1174
Verifying : libtiff5-4.0.9-r0.aarch64 822/1174
Verifying : kernel-4.14.98-imx-4.14.98-2.0.0-ga+g5d6cbeafb 823/1174
Verifying : libcogl-pango20-1.22.2-r0.aarch64_mx8mm 824/1174
Verifying : libcogl-path20-1.22.2-r0.aarch64_mx8mm 825/1174
Verifying : libcogl20-1.22.2-r0.aarch64_mx8mm 826/1174
Verifying : libjson-glib-1.0-0-1.4.2-r0.aarch64 827/1174
Verifying : ncurses-terminfo-base-6.0+20171125-r0.aarch64 828/1174
Verifying : imx-codec-g.711-4.4.5-r0.aarch64_mx8mm 829/1174
Verifying : imx-codec-g.723.1-4.4.5-r0.aarch64_mx8mm 830/1174
Verifying : imx-codec-g.726-4.4.5-r0.aarch64_mx8mm 831/1174
Verifying : imx-codec-g.729ab-4.4.5-r0.aarch64_mx8mm 832/1174
Verifying : imx-codec-nb-4.4.5-r0.aarch64_mx8mm 833/1174
Verifying : imx-codec-wb-4.4.5-r0.aarch64_mx8mm 834/1174
Verifying : lib-aac-dec-arm-elinux3-4.4.5-r0.aarch64_mx8mm 835/1174
Verifying : lib-bsac-dec-arm-elinux2-4.4.5-r0.aarch64_mx8m 836/1174
Verifying : lib-mp3-dec-arm-elinux2-4.4.5-r0.aarch64_mx8mm 837/1174
Verifying : lib-oggvorbis-dec-arm-elinux2-4.4.5-r0.aarch64 838/1174
Verifying : python-2to3-2.7.15-r1.aarch64 839/1174
Verifying : python-argparse-2.7.15-r1.aarch64 840/1174
Verifying : python-audio-2.7.15-r1.aarch64 841/1174
Verifying : python-bsddb-2.7.15-r1.aarch64 842/1174
Verifying : python-compile-2.7.15-r1.aarch64 843/1174
Verifying : python-compiler-2.7.15-r1.aarch64 844/1174
Verifying : python-compression-2.7.15-r1.aarch64 845/1174
Verifying : python-contextlib-2.7.15-r1.aarch64 846/1174
Verifying : python-crypt-2.7.15-r1.aarch64 847/1174
Verifying : python-ctypes-2.7.15-r1.aarch64 848/1174
Verifying : python-curses-2.7.15-r1.aarch64 849/1174
Verifying : python-db-2.7.15-r1.aarch64 850/1174
Verifying : python-debugger-2.7.15-r1.aarch64 851/1174
Verifying : python-difflib-2.7.15-r1.aarch64 852/1174
Verifying : python-distutils-2.7.15-r1.aarch64 853/1174
Verifying : python-doctest-2.7.15-r1.aarch64 854/1174
Verifying : python-email-2.7.15-r1.aarch64 855/1174
Verifying : python-gdbm-2.7.15-r1.aarch64 856/1174
Verifying : python-hotshot-2.7.15-r1.aarch64 857/1174
Verifying : python-html-2.7.15-r1.aarch64 858/1174
Verifying : python-idle-2.7.15-r1.aarch64 859/1174
Verifying : python-image-2.7.15-r1.aarch64 860/1174
Verifying : python-logging-2.7.15-r1.aarch64 861/1174
Verifying : python-mailbox-2.7.15-r1.aarch64 862/1174
Verifying : python-math-2.7.15-r1.aarch64 863/1174
Verifying : python-mime-2.7.15-r1.aarch64 864/1174
Verifying : python-mmap-2.7.15-r1.aarch64 865/1174
Verifying : python-multiprocessing-2.7.15-r1.aarch64 866/1174
Verifying : python-netclient-2.7.15-r1.aarch64 867/1174
Verifying : python-netserver-2.7.15-r1.aarch64 868/1174
Verifying : python-numbers-2.7.15-r1.aarch64 869/1174
Verifying : python-pkgutil-2.7.15-r1.aarch64 870/1174
Verifying : python-plistlib-2.7.15-r1.aarch64 871/1174
Verifying : python-pprint-2.7.15-r1.aarch64 872/1174
Verifying : python-profile-2.7.15-r1.aarch64 873/1174
Verifying : python-pydoc-2.7.15-r1.aarch64 874/1174
Verifying : python-re-2.7.15-r1.aarch64 875/1174
Verifying : python-resource-2.7.15-r1.aarch64 876/1174
Verifying : python-robotparser-2.7.15-r1.aarch64 877/1174
Verifying : python-runpy-2.7.15-r1.aarch64 878/1174
Verifying : python-shell-2.7.15-r1.aarch64 879/1174
Verifying : python-smtpd-2.7.15-r1.aarch64 880/1174
Verifying : python-sqlite3-2.7.15-r1.aarch64 881/1174
Verifying : python-stringold-2.7.15-r1.aarch64 882/1174
Verifying : python-syslog-2.7.15-r1.aarch64 883/1174
Verifying : python-terminal-2.7.15-r1.aarch64 884/1174
Verifying : python-textutils-2.7.15-r1.aarch64 885/1174
Verifying : python-threading-2.7.15-r1.aarch64 886/1174
Verifying : python-tkinter-2.7.15-r1.aarch64 887/1174
Verifying : python-unittest-2.7.15-r1.aarch64 888/1174
Verifying : python-unixadmin-2.7.15-r1.aarch64 889/1174
Verifying : python-xml-2.7.15-r1.aarch64 890/1174
Verifying : python-xmlrpc-2.7.15-r1.aarch64 891/1174
Verifying : python-zlib-2.7.15-r1.aarch64 892/1174
Verifying : media-ctl-1.12.3-r0.aarch64_mx8mm 893/1174
Verifying : glibc-localedata-iso14651-t1-common-2.27-r0.aa 894/1174
Verifying : glibc-localedata-translit-circle-2.27-r0.aarch 895/1174
Verifying : glibc-localedata-translit-cjk-compat-2.27-r0.a 896/1174
Verifying : glibc-localedata-translit-compat-2.27-r0.aarch 897/1174
Verifying : glibc-localedata-translit-font-2.27-r0.aarch64 898/1174
Verifying : glibc-localedata-translit-fraction-2.27-r0.aar 899/1174
Verifying : glibc-localedata-translit-narrow-2.27-r0.aarch 900/1174
Verifying : glibc-localedata-translit-small-2.27-r0.aarch6 901/1174
Verifying : glibc-localedata-translit-wide-2.27-r0.aarch64 902/1174
Verifying : imx-parser-4.4.5-r0.aarch64 903/1174
Verifying : libfslvpuwrap3-4.4.5-r0.aarch64_mx8mm 904/1174
Verifying : libgstfsl-1.0-0-4.4.5-r0.aarch64_mx8mm 905/1174
Verifying : librecorder-engine-1.0-0-4.4.5-r0.aarch64_mx8m 906/1174
Verifying : libgcrypt-1.8.2-r0.aarch64 907/1174
Verifying : libavahi-common3-0.7-r0.aarch64 908/1174
Verifying : libavahi-core7-0.7-r0.aarch64 909/1174
Verifying : libdaemon0-0.14-r0.aarch64 910/1174
Verifying : libgdbm-compat4-1.14.1-r0.aarch64 911/1174
Verifying : libcroco-0.6.12-r0.aarch64 912/1174
Verifying : perl-module-file-spec-5.24.1-r0.aarch64 913/1174
Verifying : perl-module-xsloader-5.24.1-r0.aarch64 914/1174
Verifying : perl-module-overload-numbers-5.24.1-r0.aarch64 915/1174
Verifying : perl-module-list-util-5.24.1-r0.aarch64 916/1174
Verifying : libicudata60-60.2-r0.aarch64 917/1174
Verifying : kernel-module-galcore-4.14.98-imx_4.14.98_2.0. 918/1174
Verifying : kernel-image-4.14.98-imx-4.14.98-2.0.0-ga+g5d6 919/1174
Verifying : db-1:5.3.28-r1.aarch64 920/1174
Verifying : libgdbm5-1.14.1-r0.aarch64 921/1174
Verifying : imx-vpu-hantro-1.11.0-r0.aarch64_mx8mm 922/1174
Verifying : libgpg-error0-1.27-r0.aarch64 923/1174
Verifying : perl-module-file-spec-unix-5.24.1-r0.aarch64 924/1174
Verifying : perl-module-dynaloader-5.24.1-r0.aarch64 925/1174
Verifying : kernel-image-image-4.14.98-imx-4.14.98-2.0.0-g 926/1174
Verifying : perl-module-cwd-5.24.1-r0.aarch64 927/1174
Verifying : perf-4.14.98-r9.imx8mmevk 928/1174
Verifying : libbfd-2.30-r0.aarch64 929/1174
Verifying : libunwind-1.2.1-r0.aarch64 930/1174
Verifying : slang-2.3.2-r0.aarch64 931/1174
Verifying : kernel-module-cdc-acm-4.14.98-imx_4.14.98_2.0. 932/1174
Verifying : os-release-1.0-r0.noarch 933/1174
Verifying : liberation-fonts-1:2.00.1-r0.noarch 934/1174
Verifying : fontconfig-utils-2.12.6-r0.aarch64 935/1174
Verifying : pointercal-0.0-r11.imx8mmevk 936/1174
Verifying : xserver-xf86-config-0.1-r33.imx8mmevk 937/1174
Verifying : fbset-modes-0.1.0-r6.imx8mmevk 938/1174
Verifying : kernel-module-g-ether-4.14.98-imx_4.14.98_2.0. 939/1174
Verifying : kernel-module-g-serial-4.14.98-imx_4.14.98_2.0 940/1174
Verifying : kernel-module-usbnet-4.14.98-imx_4.14.98_2.0.0 941/1174
Verifying : kernel-module-qca6174-4.14.98-imx_4.14.98_2.0. 942/1174
Verifying : kernel-module-qca9377-4.14.98-imx_4.14.98_2.0. 943/1174
Verifying : firmware-qca6174-2.0.3-r0.noarch 944/1174
Verifying : firmware-qca9377-2.0.3-r0.noarch 945/1174
Verifying : linux-firmware-ath10k-1:0.0+git0+d114732723_a0 946/1174
Verifying : linux-firmware-ath10k-license-1:0.0+git0+d1147 947/1174
Verifying : linux-firmware-bcm43455-1:0.0+git0+d114732723_ 948/1174
Verifying : linux-firmware-broadcom-license-1:0.0+git0+d11 949/1174
Verifying : linux-firmware-bcm4356-pcie-1:0.0+git0+d114732 950/1174
Verifying : linux-firmware-cypress-license-1:0.0+git0+d114 951/1174
Verifying : linux-firmware-bcm4359-pcie-1:0.0+git0+d114732 952/1174
Verifying : firmware-imx-sdma-1:8.1-r0.noarch 953/1174
Verifying : kernel-modules-4.14.98-r0.imx8mmevk 954/1174
Verifying : kernel-module-8021q-4.14.98-imx_4.14.98_2.0.0_ 955/1174
Verifying : kernel-module-adc-keys-4.14.98-imx_4.14.98_2.0 956/1174
Verifying : kernel-module-aes-neon-blk-4.14.98-imx_4.14.98 957/1174
Verifying : kernel-module-aes-neon-bs-4.14.98-imx_4.14.98_ 958/1174
Verifying : kernel-module-analogix-dp-4.14.98-imx_4.14.98_ 959/1174
Verifying : kernel-module-asix-4.14.98-imx_4.14.98_2.0.0_g 960/1174
Verifying : kernel-module-at25-4.14.98-imx_4.14.98_2.0.0_g 961/1174
Verifying : kernel-module-ax88179-178a-4.14.98-imx_4.14.98 962/1174
Verifying : kernel-module-bcm-crypto-spu-4.14.98-imx_4.14. 963/1174
Verifying : kernel-module-bcm-sba-raid-4.14.98-imx_4.14.98 964/1174
Verifying : kernel-module-bcm2835-dma-4.14.98-imx_4.14.98_ 965/1174
Verifying : kernel-module-br-netfilter-4.14.98-imx_4.14.98 966/1174
Verifying : kernel-module-brcmfmac-4.14.98-imx_4.14.98_2.0 967/1174
Verifying : kernel-module-brcmutil-4.14.98-imx_4.14.98_2.0 968/1174
Verifying : kernel-module-bridge-4.14.98-imx_4.14.98_2.0.0 969/1174
Verifying : kernel-module-btrfs-4.14.98-imx_4.14.98_2.0.0_ 970/1174
Verifying : kernel-module-cdc-ether-4.14.98-imx_4.14.98_2. 971/1174
Verifying : kernel-module-cdc-ncm-4.14.98-imx_4.14.98_2.0. 972/1174
Verifying : kernel-module-cdc-subset-4.14.98-imx_4.14.98_2 973/1174
Verifying : kernel-module-ch7006-4.14.98-imx_4.14.98_2.0.0 974/1174
Verifying : kernel-module-chacha20-neon-4.14.98-imx_4.14.9 975/1174
Verifying : kernel-module-cppc-cpufreq-4.14.98-imx_4.14.98 976/1174
Verifying : kernel-module-crc32-ce-4.14.98-imx_4.14.98_2.0 977/1174
Verifying : kernel-module-crct10dif-ce-4.14.98-imx_4.14.98 978/1174
Verifying : kernel-module-crypto-engine-4.14.98-imx_4.14.9 979/1174
Verifying : kernel-module-cuse-4.14.98-imx_4.14.98_2.0.0_g 980/1174
Verifying : kernel-module-dm9601-4.14.98-imx_4.14.98_2.0.0 981/1174
Verifying : kernel-module-dw-drm-dsi-4.14.98-imx_4.14.98_2 982/1174
Verifying : kernel-module-dwmac-generic-4.14.98-imx_4.14.9 983/1174
Verifying : kernel-module-dwmac-ipq806x-4.14.98-imx_4.14.9 984/1174
Verifying : kernel-module-dwmac-meson-4.14.98-imx_4.14.98_ 985/1174
Verifying : kernel-module-dwmac-meson8b-4.14.98-imx_4.14.9 986/1174
Verifying : kernel-module-dwmac-rk-4.14.98-imx_4.14.98_2.0 987/1174
Verifying : kernel-module-dwmac-sun8i-4.14.98-imx_4.14.98_ 988/1174
Verifying : kernel-module-dwmac-sunxi-4.14.98-imx_4.14.98_ 989/1174
Verifying : kernel-module-exynos-gsc-4.14.98-imx_4.14.98_2 990/1174
Verifying : kernel-module-exynos-lpass-4.14.98-imx_4.14.98 991/1174
Verifying : kernel-module-exynosdrm-4.14.98-imx_4.14.98_2. 992/1174
Verifying : kernel-module-fuse-4.14.98-imx_4.14.98_2.0.0_g 993/1174
Verifying : kernel-module-g-audio-4.14.98-imx_4.14.98_2.0. 994/1174
Verifying : kernel-module-g-cdc-4.14.98-imx_4.14.98_2.0.0_ 995/1174
Verifying : kernel-module-g-mass-storage-4.14.98-imx_4.14. 996/1174
Verifying : kernel-module-g-ncm-4.14.98-imx_4.14.98_2.0.0_ 997/1174
Verifying : kernel-module-g-zero-4.14.98-imx_4.14.98_2.0.0 998/1174
Verifying : kernel-module-garp-4.14.98-imx_4.14.98_2.0.0_g 999/1174
Verifying : kernel-module-generic-bl-4.14.98-imx_4.14.98_2 1000/1174
Verifying : kernel-module-gspca-main-4.14.98-imx_4.14.98_2 1001/1174
Verifying : kernel-module-host1x-4.14.98-imx_4.14.98_2.0.0 1002/1174
Verifying : kernel-module-i2c-bcm2835-4.14.98-imx_4.14.98_ 1003/1174
Verifying : kernel-module-imx-rpmsg-pingpong-4.14.98-imx_4 1004/1174
Verifying : kernel-module-imx-rpmsg-tty-4.14.98-imx_4.14.9 1005/1174
Verifying : kernel-module-ina2xx-4.14.98-imx_4.14.98_2.0.0 1006/1174
Verifying : kernel-module-ip-tables-4.14.98-imx_4.14.98_2. 1007/1174
Verifying : kernel-module-ip-tunnel-4.14.98-imx_4.14.98_2. 1008/1174
Verifying : kernel-module-ip6-tables-4.14.98-imx_4.14.98_2 1009/1174
Verifying : kernel-module-ip6t-masquerade-4.14.98-imx_4.14 1010/1174
Verifying : kernel-module-ip6t-reject-4.14.98-imx_4.14.98_ 1011/1174
Verifying : kernel-module-ip6table-filter-4.14.98-imx_4.14 1012/1174
Verifying : kernel-module-ip6table-mangle-4.14.98-imx_4.14 1013/1174
Verifying : kernel-module-ip6table-nat-4.14.98-imx_4.14.98 1014/1174
Verifying : kernel-module-ipt-masquerade-4.14.98-imx_4.14. 1015/1174
Verifying : kernel-module-ipt-reject-4.14.98-imx_4.14.98_2 1016/1174
Verifying : kernel-module-iptable-filter-4.14.98-imx_4.14. 1017/1174
Verifying : kernel-module-iptable-mangle-4.14.98-imx_4.14. 1018/1174
Verifying : kernel-module-iptable-nat-4.14.98-imx_4.14.98_ 1019/1174
Verifying : kernel-module-kirin-drm-4.14.98-imx_4.14.98_2. 1020/1174
Verifying : kernel-module-lcd-4.14.98-imx_4.14.98_2.0.0_ga 1021/1174
Verifying : kernel-module-libcrc32c-4.14.98-imx_4.14.98_2. 1022/1174
Verifying : kernel-module-lm90-4.14.98-imx_4.14.98_2.0.0_g 1023/1174
Verifying : kernel-module-lp855x-bl-4.14.98-imx_4.14.98_2. 1024/1174
Verifying : kernel-module-macvlan-4.14.98-imx_4.14.98_2.0. 1025/1174
Verifying : kernel-module-macvtap-4.14.98-imx_4.14.98_2.0. 1026/1174
Verifying : kernel-module-marvell-4.14.98-imx_4.14.98_2.0. 1027/1174
Verifying : kernel-module-mcs7830-4.14.98-imx_4.14.98_2.0. 1028/1174
Verifying : kernel-module-mdt-loader-4.14.98-imx_4.14.98_2 1029/1174
Verifying : kernel-module-meson-drm-4.14.98-imx_4.14.98_2. 1030/1174
Verifying : kernel-module-meson-dw-hdmi-4.14.98-imx_4.14.9 1031/1174
Verifying : kernel-module-meson-gxbb-wdt-4.14.98-imx_4.14. 1032/1174
Verifying : kernel-module-meson-gxl-4.14.98-imx_4.14.98_2. 1033/1174
Verifying : kernel-module-meson-wdt-4.14.98-imx_4.14.98_2. 1034/1174
Verifying : kernel-module-mrp-4.14.98-imx_4.14.98_2.0.0_ga 1035/1174
Verifying : kernel-module-msm-4.14.98-imx_4.14.98_2.0.0_ga 1036/1174
Verifying : kernel-module-nbd-4.14.98-imx_4.14.98_2.0.0_ga 1037/1174
Verifying : kernel-module-net1080-4.14.98-imx_4.14.98_2.0. 1038/1174
Verifying : kernel-module-nf-conntrack-4.14.98-imx_4.14.98 1039/1174
Verifying : kernel-module-nf-conntrack-ipv4-4.14.98-imx_4. 1040/1174
Verifying : kernel-module-nf-conntrack-ipv6-4.14.98-imx_4. 1041/1174
Verifying : kernel-module-nf-defrag-ipv4-4.14.98-imx_4.14. 1042/1174
Verifying : kernel-module-nf-defrag-ipv6-4.14.98-imx_4.14. 1043/1174
Verifying : kernel-module-nf-log-common-4.14.98-imx_4.14.9 1044/1174
Verifying : kernel-module-nf-log-ipv4-4.14.98-imx_4.14.98_ 1045/1174
Verifying : kernel-module-nf-log-ipv6-4.14.98-imx_4.14.98_ 1046/1174
Verifying : kernel-module-nf-nat-4.14.98-imx_4.14.98_2.0.0 1047/1174
Verifying : kernel-module-nf-nat-ipv4-4.14.98-imx_4.14.98_ 1048/1174
Verifying : kernel-module-nf-nat-ipv6-4.14.98-imx_4.14.98_ 1049/1174
Verifying : kernel-module-nf-nat-masquerade-ipv4-4.14.98-i 1050/1174
Verifying : kernel-module-nf-nat-masquerade-ipv6-4.14.98-i 1051/1174
Verifying : kernel-module-nf-reject-ipv4-4.14.98-imx_4.14. 1052/1174
Verifying : kernel-module-nf-reject-ipv6-4.14.98-imx_4.14. 1053/1174
Verifying : kernel-module-nfs-layout-flexfiles-4.14.98-imx 1054/1174
Verifying : kernel-module-nouveau-4.14.98-imx_4.14.98_2.0. 1055/1174
Verifying : kernel-module-nvme-4.14.98-imx_4.14.98_2.0.0_g 1056/1174
Verifying : kernel-module-nvme-core-4.14.98-imx_4.14.98_2. 1057/1174
Verifying : kernel-module-overlay-4.14.98-imx_4.14.98_2.0. 1058/1174
Verifying : kernel-module-pcie-rockchip-4.14.98-imx_4.14.9 1059/1174
Verifying : kernel-module-pegasus-4.14.98-imx_4.14.98_2.0. 1060/1174
Verifying : kernel-module-phy-rockchip-pcie-4.14.98-imx_4. 1061/1174
Verifying : kernel-module-plusb-4.14.98-imx_4.14.98_2.0.0_ 1062/1174
Verifying : kernel-module-pwm-bcm2835-4.14.98-imx_4.14.98_ 1063/1174
Verifying : kernel-module-pwm-cros-ec-4.14.98-imx_4.14.98_ 1064/1174
Verifying : kernel-module-pwm-meson-4.14.98-imx_4.14.98_2. 1065/1174
Verifying : kernel-module-pwm-tegra-4.14.98-imx_4.14.98_2. 1066/1174
Verifying : kernel-module-qcom-emac-4.14.98-imx_4.14.98_2. 1067/1174
Verifying : kernel-module-r8152-4.14.98-imx_4.14.98_2.0.0_ 1068/1174
Verifying : kernel-module-raid6-pq-4.14.98-imx_4.14.98_2.0 1069/1174
Verifying : kernel-module-rcar-du-drm-4.14.98-imx_4.14.98_ 1070/1174
Verifying : kernel-module-rcar-fcp-4.14.98-imx_4.14.98_2.0 1071/1174
Verifying : kernel-module-realtek-4.14.98-imx_4.14.98_2.0. 1072/1174
Verifying : kernel-module-renesas-usbhs-4.14.98-imx_4.14.9 1073/1174
Verifying : kernel-module-rockchip-saradc-4.14.98-imx_4.14 1074/1174
Verifying : kernel-module-rockchip-thermal-4.14.98-imx_4.1 1075/1174
Verifying : kernel-module-rockchipdrm-4.14.98-imx_4.14.98_ 1076/1174
Verifying : kernel-module-rtc-rk808-4.14.98-imx_4.14.98_2. 1077/1174
Verifying : kernel-module-rtl8150-4.14.98-imx_4.14.98_2.0. 1078/1174
Verifying : kernel-module-s5p-jpeg-4.14.98-imx_4.14.98_2.0 1079/1174
Verifying : kernel-module-s5p-mfc-4.14.98-imx_4.14.98_2.0. 1080/1174
Verifying : kernel-module-sha512-arm64-4.14.98-imx_4.14.98 1081/1174
Verifying : kernel-module-sil164-4.14.98-imx_4.14.98_2.0.0 1082/1174
Verifying : kernel-module-sit-4.14.98-imx_4.14.98_2.0.0_ga 1083/1174
Verifying : kernel-module-smsc75xx-4.14.98-imx_4.14.98_2.0 1084/1174
Verifying : kernel-module-smsc95xx-4.14.98-imx_4.14.98_2.0 1085/1174
Verifying : kernel-module-snd-hwdep-4.14.98-imx_4.14.98_2. 1086/1174
Verifying : kernel-module-snd-soc-bcm2835-i2s-4.14.98-imx_ 1087/1174
Verifying : kernel-module-snd-usb-audio-4.14.98-imx_4.14.9 1088/1174
Verifying : kernel-module-snd-usbmidi-lib-4.14.98-imx_4.14 1089/1174
Verifying : kernel-module-spi-bcm2835-4.14.98-imx_4.14.98_ 1090/1174
Verifying : kernel-module-spi-bcm2835aux-4.14.98-imx_4.14. 1091/1174
Verifying : kernel-module-spi-meson-spicc-4.14.98-imx_4.14 1092/1174
Verifying : kernel-module-spi-meson-spifc-4.14.98-imx_4.14 1093/1174
Verifying : kernel-module-sr9800-4.14.98-imx_4.14.98_2.0.0 1094/1174
Verifying : kernel-module-stmmac-4.14.98-imx_4.14.98_2.0.0 1095/1174
Verifying : kernel-module-stmmac-platform-4.14.98-imx_4.14 1096/1174
Verifying : kernel-module-stp-4.14.98-imx_4.14.98_2.0.0_ga 1097/1174
Verifying : kernel-module-tap-4.14.98-imx_4.14.98_2.0.0_ga 1098/1174
Verifying : kernel-module-tcrypt-4.14.98-imx_4.14.98_2.0.0 1099/1174
Verifying : kernel-module-tegra-drm-4.14.98-imx_4.14.98_2. 1100/1174
Verifying : kernel-module-ttm-4.14.98-imx_4.14.98_2.0.0_ga 1101/1174
Verifying : kernel-module-tunnel4-4.14.98-imx_4.14.98_2.0. 1102/1174
Verifying : kernel-module-usbtest-4.14.98-imx_4.14.98_2.0. 1103/1174
Verifying : kernel-module-uvcvideo-4.14.98-imx_4.14.98_2.0 1104/1174
Verifying : kernel-module-vc4-4.14.98-imx_4.14.98_2.0.0_ga 1105/1174
Verifying : kernel-module-veth-4.14.98-imx_4.14.98_2.0.0_g 1106/1174
Verifying : kernel-module-virtio-crypto-4.14.98-imx_4.14.9 1107/1174
Verifying : kernel-module-vsp1-4.14.98-imx_4.14.98_2.0.0_g 1108/1174
Verifying : kernel-module-x-tables-4.14.98-imx_4.14.98_2.0 1109/1174
Verifying : kernel-module-xen-netback-4.14.98-imx_4.14.98_ 1110/1174
Verifying : kernel-module-xfrm6-mode-beet-4.14.98-imx_4.14 1111/1174
Verifying : kernel-module-xfrm6-mode-transport-4.14.98-imx 1112/1174
Verifying : kernel-module-xfrm6-mode-tunnel-4.14.98-imx_4. 1113/1174
Verifying : kernel-module-xor-4.14.98-imx_4.14.98_2.0.0_ga 1114/1174
Verifying : kernel-module-xt-addrtype-4.14.98-imx_4.14.98_ 1115/1174
Verifying : kernel-module-xt-checksum-4.14.98-imx_4.14.98_ 1116/1174
Verifying : kernel-module-xt-conntrack-4.14.98-imx_4.14.98 1117/1174
Verifying : kernel-module-xt-log-4.14.98-imx_4.14.98_2.0.0 1118/1174
Verifying : kernel-module-xt-nat-4.14.98-imx_4.14.98_2.0.0 1119/1174
Verifying : kernel-module-xt-tcpudp-4.14.98-imx_4.14.98_2. 1120/1174
Verifying : kernel-module-xxhash-4.14.98-imx_4.14.98_2.0.0 1121/1174
Verifying : kernel-module-zaurus-4.14.98-imx_4.14.98_2.0.0 1122/1174
Verifying : kernel-module-zstd-compress-4.14.98-imx_4.14.9 1123/1174
Verifying : kernel-module-zstd-decompress-4.14.98-imx_4.14 1124/1174
Verifying : adwaita-icon-theme-symbolic-3.26.1-r0.noarch 1125/1174
Verifying : hicolor-icon-theme-0.17-r0.noarch 1126/1174
Verifying : alsa-states-0.2.0-r5.imx8mmevk 1127/1174
Verifying : ca-certificates-20170717-r0.noarch 1128/1174
Verifying : imx-alsa-plugins-1.0.26-r0.aarch64_mx8mm 1129/1174
Verifying : blktrace-1.2.0+git0+cca113f2fe-r0.aarch64 1130/1174
Verifying : trace-cmd-2.7-r0.aarch64 1131/1174
Verifying : systemd-analyze-1:237-r0.aarch64 1132/1174
Verifying : psplash-default-0.1+git0+2015f7073e-r15.aarch6 1133/1174
Verifying : libssp0-7.3.0-r0.aarch64 1134/1174
Verifying : libssp-dev-7.3.0-r0.aarch64 1135/1174
Verifying : gstreamer1.0-rtsp-server-meta-1.14.4-r0.aarch6 1136/1174
Verifying : gstreamer1.0-rtsp-server-rtspclientsink-1.14.4 1137/1174
Verifying : libgstrtspserver-1.0-0-1.14.4-r0.aarch64 1138/1174
Verifying : busybox-udhcpc-1.27.2-r0.aarch64 1139/1174
Verifying : systemd-compat-units-1.0-r29.aarch64 1140/1174
Verifying : e2fsprogs-e2fsck-1.43.8-r0.aarch64 1141/1174
Verifying : udev-hwdb-1:237-r0.aarch64 1142/1174
Verifying : util-linux-fsck-2.32.1-r0.aarch64 1143/1174
Verifying : systemd-extra-utils-1:237-r0.aarch64 1144/1174
Verifying : rgb-1:1.0.6-r0.aarch64 1145/1174
Verifying : xf86-input-libinput-2:0.26.0-r0.aarch64 1146/1174
Verifying : xserver-xorg-2:1.19.6-r0.aarch64_mx8mm 1147/1174
Verifying : libpciaccess0-0.14-r0.aarch64 1148/1174
Verifying : xkbcomp-1.4.0-r8.0.aarch64 1149/1174
Verifying : libxkbfile1-1:1.0.9-r0.aarch64 1150/1174
Verifying : linux-libc-headers-dev-4.14-r0.aarch64 1151/1174
Verifying : qca-tools-2.0.3-r0.aarch64 1152/1174
Verifying : udev-rules-imx-1.0-r0.aarch64 1153/1174
Verifying : mobile-broadband-provider-info-1:20170310-r0.a 1154/1174
Verifying : libgdk-pixbuf-2.0-loader-gif-2.36.11-r0.aarch6 1155/1174
Verifying : libgdk-pixbuf-2.0-loader-jpeg-2.36.11-r0.aarch 1156/1174
Verifying : libgdk-pixbuf-2.0-loader-png-2.36.11-r0.aarch6 1157/1174
Verifying : libgdk-pixbuf-2.0-loader-xpm-2.36.11-r0.aarch6 1158/1174
Verifying : gnome-theme-adwaita-3.22.3-r0.aarch64 1159/1174
Verifying : kbd-consolefonts-2.0.4-r0.aarch64 1160/1174
Verifying : kbd-keymaps-2.0.4-r0.aarch64 1161/1174
Verifying : util-linux-cfdisk-2.32.1-r0.aarch64 1162/1174
Verifying : libfdisk1-2.32.1-r0.aarch64 1163/1174
Verifying : util-linux-fdisk-2.32.1-r0.aarch64 1164/1174
Verifying : util-linux-ionice-2.32.1-r0.aarch64 1165/1174
Verifying : util-linux-mkfs-2.32.1-r0.aarch64 1166/1174
Verifying : util-linux-mountpoint-2.32.1-r0.aarch64 1167/1174
Verifying : util-linux-prlimit-2.32.1-r0.aarch64 1168/1174
Verifying : util-linux-readprofile-2.32.1-r0.aarch64 1169/1174
Verifying : util-linux-sfdisk-2.32.1-r0.aarch64 1170/1174
Verifying : util-linux-switch-root-2.32.1-r0.aarch64 1171/1174
Verifying : glib-networking-2.54.1-r0.aarch64 1172/1174
Verifying : wpa-supplicant-cli-2.6-r0.aarch64 1173/1174
Verifying : wpa-supplicant-passphrase-2.6-r0.aarch64 1174/1174
Installed:
packagegroup-base-extended.imx8mmevk 1.0-r83
packagegroup-core-boot.imx8mmevk 1.0-r17
packagegroup-core-full-cmdline.noarch 1.0-r6
packagegroup-core-nfs-server.noarch 1.0-r2
packagegroup-core-ssh-dropbear.noarch 1.0-r1
packagegroup-core-standalone-sdk-target.noarch 1.0-r8
packagegroup-core-tools-debug.noarch 1.0-r3
packagegroup-core-tools-profile.imx8mmevk 1.0-r3
packagegroup-core-tools-testapps.imx8mmevk 1.0-r2
packagegroup-fsl-gstreamer1.0.imx8mmevk 1.0-r0
packagegroup-fsl-gstreamer1.0-full.noarch 1.0-r0
packagegroup-fsl-optee-imx.noarch 1.0-r0
packagegroup-fsl-tools-audio.noarch 1.0-r0
packagegroup-fsl-tools-benchmark.imx8mmevk 1.0-r0
packagegroup-fsl-tools-gpu.imx8mmevk 1.0-r0
packagegroup-fsl-tools-gpu-external.imx8mmevk 1.0-r0
packagegroup-fsl-tools-testapps.imx8mmevk 1.0-r0
packagegroup-tools-bluetooth.noarch 1.0-r0
psplash.aarch64 0.1+git0+2015f7073e-r15
run-postinsts.noarch 1.0-r10
target-sdk-provides-dummy.sdk_provides_dummy_target 1.0-r0
weston-init.noarch 1.0-r0
weston-xwayland.aarch64_mx8mm 5.0.0.imx-r0
xterm.aarch64 330-r0
adwaita-icon-theme-symbolic.noarch 3.26.1-r0
alsa-states.imx8mmevk 0.2.0-r5
blktrace.aarch64 1.2.0+git0+cca113f2fe-r0
busybox-udhcpc.aarch64 1.27.2-r0
ca-certificates.noarch 20170717-r0
e2fsprogs-e2fsck.aarch64 1.43.8-r0
fbset-modes.imx8mmevk 0.1.0-r6
firmware-imx-sdma.noarch 1:8.1-r0
firmware-qca6174.noarch 2.0.3-r0
firmware-qca9377.noarch 2.0.3-r0
glib-networking.aarch64 2.54.1-r0
gnome-theme-adwaita.aarch64 3.22.3-r0
gstreamer1.0-rtsp-server-meta.aarch64 1.14.4-r0
imx-alsa-plugins.aarch64_mx8mm 1.0.26-r0
kbd-consolefonts.aarch64 2.0.4-r0
kbd-keymaps.aarch64 2.0.4-r0
kernel-module-cdc-acm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-g-ether-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-g-serial-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-qca6174-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 2.1-r0
kernel-module-qca9377-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 2.1-r0
kernel-module-usbnet-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-modules.imx8mmevk 4.14.98-r0
liberation-fonts.noarch 1:2.00.1-r0
libgdk-pixbuf-2.0-loader-gif.aarch64 2.36.11-r0
libgdk-pixbuf-2.0-loader-jpeg.aarch64 2.36.11-r0
libgdk-pixbuf-2.0-loader-png.aarch64 2.36.11-r0
libgdk-pixbuf-2.0-loader-xpm.aarch64 2.36.11-r0
libssp-dev.aarch64 7.3.0-r0
libssp0.aarch64 7.3.0-r0
linux-firmware-ath10k.noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
linux-firmware-bcm43455.noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
linux-firmware-bcm4356-pcie.noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
linux-firmware-bcm4359-pcie.noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
linux-libc-headers-dev.aarch64 4.14-r0
mobile-broadband-provider-info.aarch64 1:20170310-r0
os-release.noarch 1.0-r0
perf.imx8mmevk 4.14.98-r9
pointercal.imx8mmevk 0.0-r11
psplash-default.aarch64 0.1+git0+2015f7073e-r15
qca-tools.aarch64 2.0.3-r0
rgb.aarch64 1:1.0.6-r0
systemd-analyze.aarch64 1:237-r0
systemd-compat-units.aarch64 1.0-r29
systemd-extra-utils.aarch64 1:237-r0
trace-cmd.aarch64 2.7-r0
udev-hwdb.aarch64 1:237-r0
udev-rules-imx.aarch64 1.0-r0
util-linux-cfdisk.aarch64 2.32.1-r0
util-linux-fdisk.aarch64 2.32.1-r0
util-linux-fsck.aarch64 2.32.1-r0
util-linux-ionice.aarch64 2.32.1-r0
util-linux-mkfs.aarch64 2.32.1-r0
util-linux-mountpoint.aarch64 2.32.1-r0
util-linux-prlimit.aarch64 2.32.1-r0
util-linux-readprofile.aarch64 2.32.1-r0
util-linux-sfdisk.aarch64 2.32.1-r0
util-linux-switch-root.aarch64 2.32.1-r0
wpa-supplicant-cli.aarch64 2.6-r0
wpa-supplicant-passphrase.aarch64 2.6-r0
xf86-input-libinput.aarch64 2:0.26.0-r0
xkbcomp.aarch64 1.4.0-r8.0
xserver-xf86-config.imx8mmevk 0.1-r33
acl.aarch64 2.2.52-r0
alsa-conf.aarch64_mx8mm 1.1.5-r0
alsa-plugins-pulseaudio-conf.aarch64 1.1.5-r0
alsa-state.imx8mmevk 0.2.0-r5
alsa-tools.aarch64 1.1.5-r0
alsa-utils.aarch64 1.1.5-r0
alsa-utils-aconnect.aarch64 1.1.5-r0
alsa-utils-alsactl.aarch64 1.1.5-r0
alsa-utils-alsaloop.aarch64 1.1.5-r0
alsa-utils-alsamixer.aarch64 1.1.5-r0
alsa-utils-alsatplg.aarch64 1.1.5-r0
alsa-utils-alsaucm.aarch64 1.1.5-r0
alsa-utils-amixer.aarch64 1.1.5-r0
alsa-utils-aplay.aarch64 1.1.5-r0
alsa-utils-aseqdump.aarch64 1.1.5-r0
alsa-utils-aseqnet.aarch64 1.1.5-r0
alsa-utils-iecset.aarch64 1.1.5-r0
alsa-utils-midi.aarch64 1.1.5-r0
alsa-utils-speakertest.aarch64 1.1.5-r0
arm-compute-library.aarch64 18.11+git0+64441b79b8-r0
at.aarch64 3.1.20-r0
attr.aarch64 2.4.47-r0
avahi-daemon.aarch64 0.7-r0
babeltrace.aarch64 1.5.4-r0
base-files.imx8mmevk 3.0.14-r89
base-passwd.aarch64 3.5.29-r0
bash.aarch64 4.4.12-r0
bc.aarch64 1.06-r3
blktool.aarch64 4+7-r0
bluez5.aarch64 5.49-r0
bluez5-noinst-tools.aarch64 5.49-r0
bluez5-obex.aarch64 5.49-r0
bluez5-testtools.aarch64 5.49-r0
bonnie++.aarch64 1.03e-r0
busybox.aarch64 1.27.2-r0
bzip2.aarch64 1.0.6-r5
can-utils.aarch64 0.0+gitr0+4c8fb05cb4-r0
connman.aarch64 1.35-r0
connman-client.aarch64 1.35-r0
connman-tests.aarch64 1.35-r0
connman-tools.aarch64 1.35-r0
consolekit.aarch64 0.4.6-r0
coreutils.aarch64 8.29-r0
cpio.aarch64 2.12-r0
cpufrequtils.aarch64 008-r5
cracklib.aarch64 2.9.5-r0
cronie.aarch64 1.5.1-r0
cryptodev-module.imx8mmevk 1.9-r0
cryptodev-tests.aarch64 1.9-r0
curl.aarch64 7.61.0-r0
db.aarch64 1:5.3.28-r1
dbench.aarch64 4.0-r0
dbus-1.aarch64 1.12.2-r0
devil.imx8mmevk 1.8.0-r0
diffutils.aarch64 3.6-r0
dosfstools.aarch64 4.1-r0
dropbear.aarch64 2017.75-r0
e2fsprogs.aarch64 1.43.8-r0
e2fsprogs-badblocks.aarch64 1.43.8-r0
e2fsprogs-mke2fs.aarch64 1.43.8-r0
e2fsprogs-resize2fs.aarch64 1.43.8-r0
ed.aarch64 1.14.2-r0
elfutils.aarch64 0.170-r0
ethtool.aarch64 4.13-r0
evtest.aarch64 1.33+0+ab140a2dab-r0
expect.aarch64 5.45.4-r0
fbset.aarch64 2.1-r4
file.aarch64 5.32-r0
findutils.aarch64 4.6.0-r0
fio.aarch64 2.9-r0
flex-libfl.aarch64 2.6.0-r0
fontconfig-utils.aarch64 2.12.6-r0
fsl-rc-local.aarch64 1.0-r0
fstests.aarch64_mx8mm 0.1+git0+e5939ff608-r0
fuser.aarch64 23.0-r0
gawk.aarch64 4.2.1-r0
gdb.aarch64 8.0.1-r0
gdbserver.aarch64 8.0.1-r0
glibc-gconv.aarch64 2.27-r0
glibc-gconv-cp1252.aarch64 2.27-r0
glibc-gconv-ibm850.aarch64 2.27-r0
glibc-gconv-iso8859-1.aarch64 2.27-r0
glibc-gconv-iso8859-15.aarch64 2.27-r0
glibc-localedata-i18n.aarch64 2.27-r0
glibc-localedata-i18n-ctype.aarch64 2.27-r0
glibc-localedata-iso14651-t1.aarch64 2.27-r0
glibc-localedata-iso14651-t1-common.aarch64 2.27-r0
glibc-localedata-translit-circle.aarch64 2.27-r0
glibc-localedata-translit-cjk-compat.aarch64 2.27-r0
glibc-localedata-translit-compat.aarch64 2.27-r0
glibc-localedata-translit-font.aarch64 2.27-r0
glibc-localedata-translit-fraction.aarch64 2.27-r0
glibc-localedata-translit-narrow.aarch64 2.27-r0
glibc-localedata-translit-neutral.aarch64 2.27-r0
glibc-localedata-translit-small.aarch64 2.27-r0
glibc-localedata-translit-wide.aarch64 2.27-r0
glibc-mtrace.aarch64 2.27-r0
glmark2.aarch64_mx8mm 2017.07+0+ed20c633f1-r0
gobject-introspection.aarch64 1.54.1-r0
gputop.aarch64_mx8mm 6.2.4.p4.0-r0
grep.aarch64 3.1-r0
gst-examples.aarch64 0.0.1+git0+48247c6ab6-r0
gstreamer1.0.aarch64 1.14.4.imx-r0
gstreamer1.0-plugins-bad-accurip.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-adpcmdec.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-adpcmenc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-aiff.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-asfmux.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-audiobuffersplit.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-audiofxbad.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-audiolatency.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-audiomixmatrix.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-audiovisualizers.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-autoconvert.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-bayer.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-bluez.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-bz2.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-camerabin.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-coloreffects.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-compositor.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-curl.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-dashdemux.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-debugutilsbad.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-decklink.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-dtls.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-dvb.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-dvbsuboverlay.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-dvdspu.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-faceoverlay.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-fbdevsink.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-festival.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-fieldanalysis.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-freeverb.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-frei0r.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-gaudieffects.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-gdp.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-geometrictransform.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-hls.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-id3tag.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-inter.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-interlace.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-ipcpipeline.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-ivfparse.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-ivtc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-jp2kdecimator.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-jpegformat.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-kms.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-legacyrawparse.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-meta.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-midi.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-mpegpsdemux.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-mpegpsmux.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-mpegtsdemux.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-mpegtsmux.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-mxf.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-netsim.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-openglmixers.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-pcapparse.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-pnm.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-proxy.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-removesilence.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-rfbsrc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-rsvg.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-rtponvif.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-sbc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-sdpelem.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-segmentclip.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-shm.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-siren.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-smooth.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-smoothstreaming.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-sndfile.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-speed.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-stereo.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-subenc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-timecode.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-ttmlsubs.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-uvch264.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-vcdsrc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-videofiltersbad.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-videoframe-audiolevel.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-videoparsersbad.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-videosignal.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-vmnc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-waylandsink.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-webp.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-y4mdec.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-bad-yadif.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-adder.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-alsa.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-app.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-apps.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-audioconvert.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-audiomixer.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-audiorate.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-audioresample.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-audiotestsrc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-encoding.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-gio.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-meta.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-ogg.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-opengl.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-pango.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-pbtypes.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-playback.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-rawparse.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-subparse.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-tcp.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-theora.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-typefindfunctions.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-videoconvert.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-videorate.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-videoscale.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-videotestsrc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-volume.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-vorbis.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-ximagesink.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-base-xvimagesink.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-alaw.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-alpha.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-alphacolor.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-apetag.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-audiofx.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-audioparsers.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-auparse.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-autodetect.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-avi.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-cairo.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-cutter.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-debug.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-deinterlace.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-dtmf.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-effectv.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-equalizer.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-flac.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-flv.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-flxdec.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-gdkpixbuf.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-goom.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-goom2k1.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-icydemux.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-id3demux.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-imagefreeze.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-interleave.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-isomp4.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-jpeg.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-level.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-matroska.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-meta.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-mulaw.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-multifile.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-multipart.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-navigationtest.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-ossaudio.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-png.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-pulseaudio.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-replaygain.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-rtp.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-rtpmanager.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-rtsp.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-shapewipe.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-smpte.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-soup.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-spectrum.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-speex.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-taglib.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-udp.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-video4linux2.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-videobox.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-videocrop.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-videofilter.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-videomixer.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-wavenc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-wavparse.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-ximagesrc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-plugins-good-y4menc.aarch64_mx8mm 1.14.4.imx-r0
gstreamer1.0-rtsp-server.aarch64 1.14.4-r0
gstreamer1.0-rtsp-server-rtspclientsink.aarch64 1.14.4-r0
gtk+3-demo.aarch64_mx8mm 3.22.28-r0
gtkperf.aarch64 0.40-r0
gzip.aarch64 1.9-r0
hicolor-icon-theme.noarch 0.17-r0
hostapd.aarch64 2.6-r0
i2c-tools.aarch64 4.0-r0
imx-codec-g.711.aarch64_mx8mm 4.4.5-r0
imx-codec-g.723.1.aarch64_mx8mm 4.4.5-r0
imx-codec-g.726.aarch64_mx8mm 4.4.5-r0
imx-codec-g.729ab.aarch64_mx8mm 4.4.5-r0
imx-codec-nb.aarch64_mx8mm 4.4.5-r0
imx-codec-test-bin.aarch64_mx8mm 4.4.5-r0
imx-codec-test-source.aarch64_mx8mm 4.4.5-r0
imx-codec-wb.aarch64_mx8mm 4.4.5-r0
imx-gpu-apitrace.aarch64_mx8mm 7.1.0-r0
imx-gpu-apitrace-bin.aarch64_mx8mm 7.1.0-r0
imx-gpu-sdk.aarch64_mx8mm 5.3.0-r0
imx-gpu-viv.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
imx-gpu-viv-demos.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
imx-gpu-viv-tools.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
imx-gst1.0-plugin.aarch64_mx8mm 4.4.5-r0
imx-gst1.0-plugin-gplay.aarch64_mx8mm 4.4.5-r0
imx-gst1.0-plugin-grecorder.aarch64_mx8mm 4.4.5-r0
imx-kobs.aarch64 5.5+git0+02c01d4a3d-r0
imx-parser.aarch64 4.4.5-r0
imx-test.aarch64_mx8mm 1:7.0+0+d32727a9d7-r0
imx-vpu-hantro.aarch64_mx8mm 1.11.0-r0
initscripts.imx8mmevk 1.0-r155
initscripts-functions.imx8mmevk 1.0-r155
iozone3.aarch64 465-r0
iperf3.aarch64 3.2-r0
iproute2.aarch64 4.14.1-r0
iptables.aarch64 1.6.2-r0
iputils-arping.aarch64 s20161105-r0
iputils-clockdiff.aarch64 s20161105-r0
iputils-ping.aarch64 s20161105-r0
iputils.aarch64 s20161105-r0
iputils-tracepath.aarch64 s20161105-r0
iputils-traceroute6.aarch64 s20161105-r0
iw.aarch64 4.14-r0
kbd.aarch64 2.0.4-r0
kernel-4.14.98-imx-4.14.98-2.0.0-ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-image-4.14.98-imx-4.14.98-2.0.0-ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-image-image-4.14.98-imx-4.14.98-2.0.0-ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-8021q-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-adc-keys-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-aes-neon-blk-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-aes-neon-bs-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-analogix-dp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-asix-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-at25-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ax88179-178a-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-bcm-crypto-spu-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-bcm-sba-raid-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-bcm2835-dma-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-br-netfilter-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-brcmfmac-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-brcmutil-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-bridge-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-btrfs-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-cdc-ether-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-cdc-ncm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-cdc-subset-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ch7006-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-chacha20-neon-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-cppc-cpufreq-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-crc32-ce-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-crct10dif-ce-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-crypto-engine-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-cryptodev-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 1.9-r0
kernel-module-cuse-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-dm9601-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-dw-drm-dsi-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-dwmac-generic-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-dwmac-ipq806x-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-dwmac-meson-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-dwmac-meson8b-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-dwmac-rk-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-dwmac-sun8i-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-dwmac-sunxi-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-exynos-gsc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-exynos-lpass-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-exynosdrm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-fuse-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-g-audio-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-g-cdc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-g-mass-storage-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-g-ncm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-g-zero-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-galcore-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 6.2.4.p4.0-r0
kernel-module-garp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-generic-bl-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-gspca-main-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-host1x-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-i2c-bcm2835-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-imx-gpu-viv.imx8mmevk 6.2.4.p4.0-r0
kernel-module-imx-rpmsg-pingpong-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-imx-rpmsg-tty-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ina2xx-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ip-tables-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ip-tunnel-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ip6-tables-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ip6t-masquerade-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ip6t-reject-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ip6table-filter-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ip6table-mangle-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ip6table-nat-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ipt-masquerade-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ipt-reject-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-iptable-filter-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-iptable-mangle-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-iptable-nat-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-kirin-drm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-lcd-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-libcrc32c-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-lm90-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-lp855x-bl-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-macvlan-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-macvtap-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-marvell-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-mcs7830-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-mdt-loader-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-meson-drm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-meson-dw-hdmi-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-meson-gxbb-wdt-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-meson-gxl-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-meson-wdt-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-mrp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-msm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nbd-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-net1080-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-conntrack-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-conntrack-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-conntrack-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-defrag-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-defrag-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-log-common-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-log-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-log-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-nat-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-nat-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-nat-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-nat-masquerade-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-nat-masquerade-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-reject-ipv4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nf-reject-ipv6-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nfs-layout-flexfiles-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nouveau-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nvme-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-nvme-core-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-overlay-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-pcie-rockchip-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-pegasus-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-phy-rockchip-pcie-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-plusb-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-pwm-bcm2835-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-pwm-cros-ec-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-pwm-meson-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-pwm-tegra-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-qcom-emac-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-r8152-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-raid6-pq-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-rcar-du-drm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-rcar-fcp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-realtek-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-renesas-usbhs-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-rockchip-saradc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-rockchip-thermal-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-rockchipdrm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-rtc-rk808-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-rtl8150-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-s5p-jpeg-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-s5p-mfc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-sha512-arm64-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-sil164-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-sit-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-smsc75xx-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-smsc95xx-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-snd-hwdep-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-snd-soc-bcm2835-i2s-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-snd-usb-audio-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-snd-usbmidi-lib-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-spi-bcm2835-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-spi-bcm2835aux-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-spi-meson-spicc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-spi-meson-spifc-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-sr9800-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-stmmac-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-stmmac-platform-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-stp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-tap-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-tcrypt-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-tegra-drm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-ttm-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-tunnel4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-usbtest-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-uvcvideo-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-vc4-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-veth-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-virtio-crypto-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-vsp1-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-x-tables-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xen-netback-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xfrm6-mode-beet-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xfrm6-mode-transport-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xfrm6-mode-tunnel-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xor-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xt-addrtype-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xt-checksum-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xt-conntrack-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xt-log-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xt-nat-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xt-tcpudp-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-xxhash-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-zaurus-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-zstd-compress-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kernel-module-zstd-decompress-4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c.imx8mmevk 4.14.98-r0
kexec.aarch64 2.0.16-r1
killall.aarch64 23.0-r0
kmod.aarch64 25+git0+aca4eca103-r0
kmscube.aarch64_mx8mm git-r0
ldd.aarch64 2.27-r0
less.aarch64 529-r0
lib-aac-dec-arm-elinux3.aarch64_mx8mm 4.4.5-r0
lib-bsac-dec-arm-elinux2.aarch64_mx8mm 4.4.5-r0
lib-mp3-dec-arm-elinux2.aarch64_mx8mm 4.4.5-r0
lib-oggvorbis-dec-arm-elinux2.aarch64_mx8mm 4.4.5-r0
libacl1.aarch64 2.2.52-r0
libaio1.aarch64 0.3.110-r0
libasound-module-conf-pulse.aarch64 1.1.5-r0
libasound-module-ctl-pulse.aarch64 1.1.5-r0
libasound-module-pcm-pulse.aarch64 1.1.5-r0
libasound2.aarch64_mx8mm 1.1.5-r0
libassimp4.aarch64 4.1.0-r0
libatk-1.0-0.aarch64 2.26.1-r0
libatomic-dev.aarch64 7.3.0-r0
libatomic1.aarch64 7.3.0-r0
libattr1.aarch64 2.4.47-r0
libavahi-common3.aarch64 0.7-r0
libavahi-core7.aarch64 0.7-r0
libbfd.aarch64 2.30-r0
libblkid1.aarch64 2.32.1-r0
libbz2-1.aarch64 1.0.6-r5
libc6.aarch64 2.27-r0
libc6-dbg.aarch64 2.27-r0
libc6-dev.aarch64 2.27-r0
libc6-extra-nss.aarch64 2.27-r0
libc6-thread-db.aarch64 2.27-r0
libc6-utils.aarch64 2.27-r0
libcairo-gobject2.aarch64_mx8mm 1.14.12-r0
libcairo2.aarch64_mx8mm 1.14.12-r0
libcap2.aarch64 2.25-r0
libcidn1.aarch64 2.27-r0
libclc-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libclutter-1.0-0.aarch64_mx8mm 1.26.2-r0
libclutter-1.0-examples.aarch64_mx8mm 1.26.2-r0
libcogl-pango20.aarch64_mx8mm 1.22.2-r0
libcogl-path20.aarch64_mx8mm 1.22.2-r0
libcogl20.aarch64_mx8mm 1.22.2-r0
libcom-err2.aarch64 1.43.8-r0
libcroco.aarch64 0.6.12-r0
libcrypto1.0.2.aarch64 1.0.2p-r0
libcurl4.aarch64 7.61.0-r0
libdaemon0.aarch64 0.14-r0
libdbus-1-3.aarch64 1.12.2-r0
libdbus-glib-1-2.aarch64 0.108-r0
libdrm-etnaviv1.aarch64_mx8mm 2.4.91.imx-r0
libdrm-freedreno1.aarch64_mx8mm 2.4.91.imx-r0
libdrm-tests.aarch64_mx8mm 2.4.91.imx-r0
libdrm2.aarch64_mx8mm 2.4.91.imx-r0
libdw1.aarch64 0.170-r0
libe2p2.aarch64 1.43.8-r0
libegl-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libelf1.aarch64 0.170-r0
libepoxy0.aarch64_mx8mm 1.5.0-r0
libevdev.aarch64 1.5.8-r0
libevent.aarch64 2.1.8-r0
libexpat1.aarch64 2.2.5-r0
libext2fs2.aarch64 1.43.8-r0
libfdisk1.aarch64 2.32.1-r0
libffi6.aarch64 3.2.1-r0
libflac8.aarch64 1.3.2-r0
libfontconfig1.aarch64 2.12.6-r0
libfontenc1.aarch64 1:1.1.3-r0
libformw5.aarch64 6.0+20171125-r0
libfreetype6.aarch64 2.9-r0
libfslvpuwrap3.aarch64_mx8mm 4.4.5-r0
libg2d1.1.aarch64_mx8mm 6.2.4.p4.0-r0
libgal-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libgbm-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libgcc-s-dev.aarch64 7.3.0-r0
libgcc1.aarch64 7.3.0-r0
libgcrypt.aarch64 1.8.2-r0
libgdbm-compat4.aarch64 1.14.1-r0
libgdbm5.aarch64 1.14.1-r0
libgdk-pixbuf-2.0-0.aarch64 2.36.11-r0
libgl-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libglapi0.aarch64_mx8mm 2:17.3.8-r0
libgles-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libgles2-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libglew2.1.aarch64_mx8mm 2.1.0-r0
libglib-2.0-0.aarch64 1:2.54.3-r0
libglib-2.0-utils.aarch64 1:2.54.3-r0
libglslc-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libglu1.aarch64_mx8mm 2:9.0.0-0
libglut3.aarch64_mx8mm 3.0.0-r0
libgmp10.aarch64 6.1.2-r0
libgnutls30.aarch64 3.6.1-r0
libgpg-error0.aarch64 1.27-r0
libgpuperfcnt1.4.0.aarch64_mx8mm 6.2.4.p4.0-r0
libgstadaptivedemux-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstallocators-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstapp-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstaudio-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstbadaudio-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstbadvideo-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstbasecamerabinsrc-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstcodecparsers-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstfft-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstfsl-1.0-0.aarch64_mx8mm 4.4.5-r0
libgstgl-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstinsertbin-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstisoff-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstmpegts-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstpbutils-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstphotography-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstplayer-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstriff-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstrtp-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstrtsp-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstrtspserver-1.0-0.aarch64 1.14.4-r0
libgstsdp-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgsttag-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgsturidownloader-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstvideo-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstwayland-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgstwebrtc-1.0-0.aarch64_mx8mm 1.14.4.imx-r0
libgtk-2.0.aarch64_mx8mm 2.24.32-r0
libgtk-3.0.aarch64_mx8mm 3.22.28-r0
libgudev-1.0-0.aarch64 232-r0
libharfbuzz0.aarch64_mx8mm 1.7.5-r0
libical.aarch64 2.0.0-r0
libice6.aarch64 1:1.0.9-r0
libicudata60.aarch64 60.2-r0
libicui18n60.aarch64 60.2-r0
libicuuc60.aarch64 60.2-r0
libinput10.aarch64 1.9.4-r0
libjpeg62.aarch64 1:1.5.3-r0
libjson-c3.aarch64 0.13-r0
libjson-glib-1.0-0.aarch64 1.4.2-r0
libkmod2.aarch64 25+git0+aca4eca103-r0
libkms1.aarch64_mx8mm 2.4.91.imx-r0
libltdl7.aarch64 2.4.6-r0
liblzma5.aarch64 5.2.3-r0
liblzo2-2.aarch64 2.10-r0
libmenuw5.aarch64 6.0+20171125-r0
libmnl0.aarch64 1.0.4-r0
libmount1.aarch64 2.32.1-r0
libncurses5.aarch64 6.0+20171125-r0
libncursesw5.aarch64 6.0+20171125-r0
libnfsidmap0.aarch64 0.25-r0
libnl-3-200.aarch64 1:3.4.0-r0
libnl-genl-3-200.aarch64 1:3.4.0-r0
libnss-mdns.aarch64 0.10-r7
libogg0.aarch64 1.3.3-r0
libopencl-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libopenvg-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
liborc-0.4-0.aarch64 0.4.28-r0
libpam.aarch64 1.3.0-r5
libpam-runtime.aarch64 1.3.0-r5
libpanel5.aarch64 6.0+20171125-r0
libpanelw5.aarch64 6.0+20171125-r0
libpcap1.aarch64 1.8.1-r0
libpci3.aarch64 3.5.6-r0
libpciaccess0.aarch64 0.14-r0
libpcre1.aarch64 8.41-r0
libperl5.aarch64 5.24.1-r0
libpixman-1-0.aarch64 1:0.34.0-r0
libpng16-16.aarch64 1.6.34-r0
libpopt0.aarch64 1.16-r3
libpulse0.aarch64_mx8mm 11.1-r0
libpulsecommon.aarch64_mx8mm 11.1-r0
libpulsecore.aarch64_mx8mm 11.1-r0
libpython2.7-1.0.aarch64 2.7.15-r1
libpython3.5m1.0.aarch64 3.5.5-r1.0
libreadline7.aarch64 7.0-r0
librecorder-engine-1.0-0.aarch64_mx8mm 4.4.5-r0
librsvg-2-2.aarch64_mx8mm 2.40.20-r0
libsamplerate0.aarch64 0.1.9-r1
libsbc1.aarch64 1.3-r0
libsegfault.aarch64 2.27-r0
libsm6.aarch64 1:1.2.2-r0
libsmartcols1.aarch64 2.32.1-r0
libsndfile1.aarch64 1.0.28-r0
libsoup-2.4.aarch64 2.60.3-r0
libspeex1.aarch64 1.2.0-r0
libspeexdsp1.aarch64 1.2rc3-r0
libsqlite3-0.aarch64 3:3.22.0-r0
libss2.aarch64 1.43.8-r0
libssl1.0.2.aarch64 1.0.2p-r0
libstdc++-dev.aarch64 7.3.0-r0
libstdc++6.aarch64 7.3.0-r0
libsystemd0.aarch64 1:237-r0
libtag1.aarch64 1.11.1-r0
libtcl8.6-0.aarch64 8.6.8-r0
libtheora.aarch64 1.1.1-r1
libtiff5.aarch64 4.0.9-r0
libtinfo5.aarch64 6.0+20171125-r0
libtirpc3.aarch64 1.0.2-r0
libts0.aarch64 1.15-r0
libudev1.aarch64 1:237-r0
libunistring2.aarch64 0.9.9-r0
libunwind.aarch64 1.2.1-r0
liburcu.aarch64 0.10.1-r0
libusb-1.0-0.aarch64 1.0.21-r0
libuser.aarch64 0.62-r0
libuuid1.aarch64 2.32.1-r0
libv4l.aarch64_mx8mm 1.12.3-r0
libvdk-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libvorbis.aarch64 1.3.5-r1
libvsc-imx.aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
libwebp.aarch64 0.6.1-r0
libweston-5.aarch64_mx8mm 5.0.0.imx-r0
libwrap0.aarch64 7.6-r10
libx11-6.aarch64 1:1.6.5-r0
libx11-xcb1.aarch64 1:1.6.5-r0
libxau6.aarch64 1:1.0.8-r0
libxaw7-7.aarch64 1:1.0.13-r2
libxcb-composite0.aarch64 1.12-r0
libxcb-render0.aarch64 1.12-r0
libxcb-shape0.aarch64 1.12-r0
libxcb-shm0.aarch64 1.12-r0
libxcb-xfixes0.aarch64 1.12-r0
libxcb-xkb1.aarch64 1.12-r0
libxcb1.aarch64 1.12-r0
libxcomposite1.aarch64 1:0.4.4-r0
libxcursor1.aarch64 1:1.1.15-r0
libxdamage1.aarch64 1:1.1.4-r0
libxdmcp6.aarch64 1:1.1.2-r0
libxext6.aarch64 1:1.3.3-r0
libxfixes3.aarch64 1:5.0.3-r0
libxfont2-2.aarch64 2.0.3-r0
libxft2.aarch64 1:2.3.2-r0
libxi6.aarch64 1:1.7.9-r0
libxinerama1.aarch64 1:1.1.3-r0
libxkbcommon.aarch64 0.8.0-r0
libxkbfile1.aarch64 1:1.0.9-r0
libxml2.aarch64 2.9.7-r0
libxmu6.aarch64 1:1.1.2-r0
libxmuu1.aarch64 1:1.1.2-r0
libxpm4.aarch64 1:3.5.12-r0
libxrandr2.aarch64 1:1.5.1-r0
libxrender1.aarch64 1:0.9.10-r0
libxres1.aarch64 1:1.2.0-r0
libxshmfence1.aarch64 1.2-r0
libxt6.aarch64 1:1.1.5-r0
libxtst6.aarch64 1:1.2.3-r0
libxv1.aarch64 1.0.11-r0
libxxf86vm1.aarch64 1:1.1.4-r0
libz1.aarch64 1.2.11-r0
linux-firmware-ath10k-license.noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
linux-firmware-broadcom-license.noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
linux-firmware-cypress-license.noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
linuxptp.aarch64 1.8-r0
lmbench.aarch64 3.0+a9-r2
logrotate.aarch64 3.13.0-r0
lrzsz.aarch64 0.12.20-r6
ltp.aarch64 20180118-r0
lttng-modules.imx8mmevk 2.10.6-r0
lttng-tools.aarch64 2.9.5-r0
lttng-ust.aarch64 2:2.10.1-r0
m4.aarch64 1.4.18-r0
make.aarch64 4.2.1-r0
makedevs.aarch64 1.0.1-r0
mc.aarch64 4.8.20-r0
mc-fish.aarch64 4.8.20-r0
mc-helpers.aarch64 4.8.20-r0
mc-helpers-perl.aarch64 4.8.20-r0
media-ctl.aarch64_mx8mm 1.12.3-r0
memtester.aarch64 4.3.0-r0
mesa-demos.aarch64_mx8mm 8.3.0-r0
minicom.aarch64 2.7.1-r0
mktemp.aarch64 1.7-r3
mmc-utils.aarch64 0.1-r0
mtd-utils.aarch64 2.0.1+0+9c6173559f-r0
mtd-utils-ubifs.aarch64 2.0.1+0+9c6173559f-r0
mtdev.aarch64 1.1.5-r0
nano.aarch64 2.9.3-r0
nbench-byte.aarch64 2.2.3-r0
ncurses.aarch64 6.0+20171125-r0
ncurses-terminfo.aarch64 6.0+20171125-r0
ncurses-terminfo-base.aarch64 6.0+20171125-r0
neard.aarch64 0.16-r0
net-tools.aarch64 1.60+26-r0
netbase.aarch64 1:5.4-r0
nettle.aarch64 3.4-r0
nfs-utils.aarch64 2.1.1-r0
nfs-utils-client.aarch64 2.1.1-r0
nfs-utils-mount.aarch64 2.1.1-r0
ntpdate.aarch64 4.2.8p11-r0
numactl.aarch64 2.0.11+git0+ea3a70681c-r0
ofono.aarch64 1.22-r0
ofono-tests.aarch64 1.22-r0
openssl.aarch64 1.0.2p-r0
openssl-conf.aarch64 1.0.2p-r0
optee-client-imx.aarch64 git-r0
optee-os-imx.imx8mmevk git-r0
optee-test-imx.aarch64 git-r0
packagegroup-base.imx8mmevk 1.0-r83
packagegroup-base-3g.imx8mmevk 1.0-r83
packagegroup-base-alsa.imx8mmevk 1.0-r83
packagegroup-base-bluetooth.imx8mmevk 1.0-r83
packagegroup-base-ipv6.imx8mmevk 1.0-r83
packagegroup-base-nfc.imx8mmevk 1.0-r83
packagegroup-base-nfs.imx8mmevk 1.0-r83
packagegroup-base-pci.imx8mmevk 1.0-r83
packagegroup-base-usbgadget.imx8mmevk 1.0-r83
packagegroup-base-usbhost.imx8mmevk 1.0-r83
packagegroup-base-wifi.imx8mmevk 1.0-r83
packagegroup-base-zeroconf.imx8mmevk 1.0-r83
packagegroup-core-full-cmdline-dev-utils.noarch 1.0-r6
packagegroup-core-full-cmdline-extended.noarch 1.0-r6
packagegroup-core-full-cmdline-initscripts.noarch 1.0-r6
packagegroup-core-full-cmdline-libs.noarch 1.0-r6
packagegroup-core-full-cmdline-multiuser.noarch 1.0-r6
packagegroup-core-full-cmdline-sys-services.noarch 1.0-r6
packagegroup-core-full-cmdline-utils.noarch 1.0-r6
packagegroup-distro-base.imx8mmevk 1.0-r83
packagegroup-fsl-gstreamer1.0-audio.imx8mmevk 1.0-r0
packagegroup-fsl-gstreamer1.0-base.imx8mmevk 1.0-r0
packagegroup-fsl-gstreamer1.0-debug.imx8mmevk 1.0-r0
packagegroup-fsl-gstreamer1.0-network-base.imx8mmevk 1.0-r0
packagegroup-fsl-gstreamer1.0-video.imx8mmevk 1.0-r0
packagegroup-fsl-tools-testapps-fslcodec-testapps.imx8mmevk 1.0-r0
packagegroup-machine-base.imx8mmevk 1.0-r83
pam-plugin-access.aarch64 1.3.0-r5
pam-plugin-deny.aarch64 1.3.0-r5
pam-plugin-env.aarch64 1.3.0-r5
pam-plugin-faildelay.aarch64 1.3.0-r5
pam-plugin-group.aarch64 1.3.0-r5
pam-plugin-keyinit.aarch64 1.3.0-r5
pam-plugin-lastlog.aarch64 1.3.0-r5
pam-plugin-limits.aarch64 1.3.0-r5
pam-plugin-loginuid.aarch64 1.3.0-r5
pam-plugin-mail.aarch64 1.3.0-r5
pam-plugin-motd.aarch64 1.3.0-r5
pam-plugin-nologin.aarch64 1.3.0-r5
pam-plugin-permit.aarch64 1.3.0-r5
pam-plugin-rootok.aarch64 1.3.0-r5
pam-plugin-securetty.aarch64 1.3.0-r5
pam-plugin-shells.aarch64 1.3.0-r5
pam-plugin-unix.aarch64 1.3.0-r5
pam-plugin-warn.aarch64 1.3.0-r5
pango.aarch64_mx8mm 1.40.14-r0
patch.aarch64 2.7.6-r0
pciutils.aarch64 3.5.6-r0
pciutils-ids.aarch64 3.5.6-r0
perl.aarch64 5.24.1-r0
perl-module-carp.aarch64 5.24.1-r0
perl-module-constant.aarch64 5.24.1-r0
perl-module-cwd.aarch64 5.24.1-r0
perl-module-dynaloader.aarch64 5.24.1-r0
perl-module-exporter.aarch64 5.24.1-r0
perl-module-exporter-heavy.aarch64 5.24.1-r0
perl-module-file-spec.aarch64 5.24.1-r0
perl-module-file-spec-unix.aarch64 5.24.1-r0
perl-module-getopt-long.aarch64 5.24.1-r0
perl-module-list-util.aarch64 5.24.1-r0
perl-module-mro.aarch64 5.24.1-r0
perl-module-overload.aarch64 5.24.1-r0
perl-module-overload-numbers.aarch64 5.24.1-r0
perl-module-overloading.aarch64 5.24.1-r0
perl-module-pod-usage.aarch64 5.24.1-r0
perl-module-scalar-util.aarch64 5.24.1-r0
perl-module-text-parsewords.aarch64 5.24.1-r0
perl-module-xsloader.aarch64 5.24.1-r0
powertop.aarch64 2.9-r0
procps.aarch64 3.3.12-r0
psmisc.aarch64 23.0-r0
pstree.aarch64 23.0-r0
ptpd.aarch64 2.3.1-r0
pulseaudio-lib-alsa-util.aarch64_mx8mm 11.1-r0
pulseaudio-lib-bluez5-util.aarch64_mx8mm 11.1-r0
pulseaudio-lib-cli.aarch64_mx8mm 11.1-r0
pulseaudio-lib-protocol-cli.aarch64_mx8mm 11.1-r0
pulseaudio-lib-protocol-native.aarch64_mx8mm 11.1-r0
pulseaudio-misc.aarch64_mx8mm 11.1-r0
pulseaudio-module-alsa-card.aarch64_mx8mm 11.1-r0
pulseaudio-module-alsa-sink.aarch64_mx8mm 11.1-r0
pulseaudio-module-alsa-source.aarch64_mx8mm 11.1-r0
pulseaudio-module-always-sink.aarch64_mx8mm 11.1-r0
pulseaudio-module-augment-properties.aarch64_mx8mm 11.1-r0
pulseaudio-module-bluetooth-discover.aarch64_mx8mm 11.1-r0
pulseaudio-module-bluetooth-policy.aarch64_mx8mm 11.1-r0
pulseaudio-module-bluez5-device.aarch64_mx8mm 11.1-r0
pulseaudio-module-bluez5-discover.aarch64_mx8mm 11.1-r0
pulseaudio-module-card-restore.aarch64_mx8mm 11.1-r0
pulseaudio-module-cli.aarch64_mx8mm 11.1-r0
pulseaudio-module-cli-protocol-unix.aarch64_mx8mm 11.1-r0
pulseaudio-module-console-kit.aarch64_mx8mm 11.1-r0
pulseaudio-module-default-device-restore.aarch64_mx8mm 11.1-r0
pulseaudio-module-detect.aarch64_mx8mm 11.1-r0
pulseaudio-module-device-manager.aarch64_mx8mm 11.1-r0
pulseaudio-module-device-restore.aarch64_mx8mm 11.1-r0
pulseaudio-module-filter-apply.aarch64_mx8mm 11.1-r0
pulseaudio-module-filter-heuristics.aarch64_mx8mm 11.1-r0
pulseaudio-module-intended-roles.aarch64_mx8mm 11.1-r0
pulseaudio-module-loopback.aarch64_mx8mm 11.1-r0
pulseaudio-module-native-protocol-unix.aarch64_mx8mm 11.1-r0
pulseaudio-module-null-sink.aarch64_mx8mm 11.1-r0
pulseaudio-module-position-event-sounds.aarch64_mx8mm 11.1-r0
pulseaudio-module-rescue-streams.aarch64_mx8mm 11.1-r0
pulseaudio-module-role-cork.aarch64_mx8mm 11.1-r0
pulseaudio-module-stream-restore.aarch64_mx8mm 11.1-r0
pulseaudio-module-suspend-on-idle.aarch64_mx8mm 11.1-r0
pulseaudio-module-switch-on-connect.aarch64_mx8mm 11.1-r0
pulseaudio-module-switch-on-port-available.aarch64_mx8mm 11.1-r0
pulseaudio-module-udev-detect.aarch64_mx8mm 11.1-r0
pulseaudio-module-x11-bell.aarch64_mx8mm 11.1-r0
pulseaudio-module-x11-cork-request.aarch64_mx8mm 11.1-r0
pulseaudio-module-x11-publish.aarch64_mx8mm 11.1-r0
pulseaudio-module-x11-xsmp.aarch64_mx8mm 11.1-r0
pulseaudio-server.aarch64_mx8mm 11.1-r0
python-2to3.aarch64 2.7.15-r1
python-argparse.aarch64 2.7.15-r1
python-audio.aarch64 2.7.15-r1
python-bsddb.aarch64 2.7.15-r1
python-codecs.aarch64 2.7.15-r1
python-compile.aarch64 2.7.15-r1
python-compiler.aarch64 2.7.15-r1
python-compression.aarch64 2.7.15-r1
python-contextlib.aarch64 2.7.15-r1
python-core.aarch64 2.7.15-r1
python-crypt.aarch64 2.7.15-r1
python-ctypes.aarch64 2.7.15-r1
python-curses.aarch64 2.7.15-r1
python-datetime.aarch64 2.7.15-r1
python-db.aarch64 2.7.15-r1
python-debugger.aarch64 2.7.15-r1
python-difflib.aarch64 2.7.15-r1
python-distutils.aarch64 2.7.15-r1
python-doctest.aarch64 2.7.15-r1
python-email.aarch64 2.7.15-r1
python-fcntl.aarch64 2.7.15-r1
python-gdbm.aarch64 2.7.15-r1
python-hotshot.aarch64 2.7.15-r1
python-html.aarch64 2.7.15-r1
python-idle.aarch64 2.7.15-r1
python-image.aarch64 2.7.15-r1
python-io.aarch64 2.7.15-r1
python-json.aarch64 2.7.15-r1
python-lang.aarch64 2.7.15-r1
python-logging.aarch64 2.7.15-r1
python-mailbox.aarch64 2.7.15-r1
python-math.aarch64 2.7.15-r1
python-mime.aarch64 2.7.15-r1
python-misc.aarch64 2.7.15-r1
python-mmap.aarch64 2.7.15-r1
python-modules.aarch64 2.7.15-r1
python-multiprocessing.aarch64 2.7.15-r1
python-netclient.aarch64 2.7.15-r1
python-netserver.aarch64 2.7.15-r1
python-numbers.aarch64 2.7.15-r1
python-pickle.aarch64 2.7.15-r1
python-pip.aarch64 9.0.3-r0
python-pkgutil.aarch64 2.7.15-r1
python-plistlib.aarch64 2.7.15-r1
python-pprint.aarch64 2.7.15-r1
python-profile.aarch64 2.7.15-r1
python-pydoc.aarch64 2.7.15-r1
python-re.aarch64 2.7.15-r1
python-resource.aarch64 2.7.15-r1
python-robotparser.aarch64 2.7.15-r1
python-runpy.aarch64 2.7.15-r1
python-setuptools.aarch64 39.0.0-r0
python-shell.aarch64 2.7.15-r1
python-smtpd.aarch64 2.7.15-r1
python-sqlite3.aarch64 2.7.15-r1
python-stringold.aarch64 2.7.15-r1
python-subprocess.aarch64 2.7.15-r1
python-syslog.aarch64 2.7.15-r1
python-terminal.aarch64 2.7.15-r1
python-textutils.aarch64 2.7.15-r1
python-threading.aarch64 2.7.15-r1
python-tkinter.aarch64 2.7.15-r1
python-unittest.aarch64 2.7.15-r1
python-unixadmin.aarch64 2.7.15-r1
python-xml.aarch64 2.7.15-r1
python-xmlrpc.aarch64 2.7.15-r1
python-zlib.aarch64 2.7.15-r1
python3-2to3.aarch64 3.5.5-r1.0
python3-asyncio.aarch64 3.5.5-r1.0
python3-audio.aarch64 3.5.5-r1.0
python3-codecs.aarch64 3.5.5-r1.0
python3-compile.aarch64 3.5.5-r1.0
python3-compression.aarch64 3.5.5-r1.0
python3-core.aarch64 3.5.5-r1.0
python3-crypt.aarch64 3.5.5-r1.0
python3-ctypes.aarch64 3.5.5-r1.0
python3-curses.aarch64 3.5.5-r1.0
python3-datetime.aarch64 3.5.5-r1.0
python3-db.aarch64 3.5.5-r1.0
python3-dbus.aarch64 1.2.6-r0
python3-debugger.aarch64 3.5.5-r1.0
python3-difflib.aarch64 3.5.5-r1.0
python3-distutils.aarch64 3.5.5-r1.0
python3-doctest.aarch64 3.5.5-r1.0
python3-email.aarch64 3.5.5-r1.0
python3-fcntl.aarch64 3.5.5-r1.0
python3-html.aarch64 3.5.5-r1.0
python3-idle.aarch64 3.5.5-r1.0
python3-image.aarch64 3.5.5-r1.0
python3-io.aarch64 3.5.5-r1.0
python3-json.aarch64 3.5.5-r1.0
python3-logging.aarch64 3.5.5-r1.0
python3-mailbox.aarch64 3.5.5-r1.0
python3-math.aarch64 3.5.5-r1.0
python3-mime.aarch64 3.5.5-r1.0
python3-mmap.aarch64 3.5.5-r1.0
python3-modules.aarch64 3.5.5-r1.0
python3-multiprocessing.aarch64 3.5.5-r1.0
python3-netclient.aarch64 3.5.5-r1.0
python3-netserver.aarch64 3.5.5-r1.0
python3-numbers.aarch64 3.5.5-r1.0
python3-pickle.aarch64 3.5.5-r1.0
python3-pkgutil.aarch64 3.5.5-r1.0
python3-plistlib.aarch64 3.5.5-r1.0
python3-pprint.aarch64 3.5.5-r1.0
python3-profile.aarch64 3.5.5-r1.0
python3-pycairo.aarch64_mx8mm 1.15.6-r0
python3-pydoc.aarch64 3.5.5-r1.0
python3-pygobject.aarch64_mx8mm 3.28.1-r0
python3-resource.aarch64 3.5.5-r1.0
python3-runpy.aarch64 3.5.5-r1.0
python3-setuptools.aarch64 39.0.0-r0
python3-shell.aarch64 3.5.5-r1.0
python3-smtpd.aarch64 3.5.5-r1.0
python3-sqlite3.aarch64 3.5.5-r1.0
python3-stringold.aarch64 3.5.5-r1.0
python3-syslog.aarch64 3.5.5-r1.0
python3-terminal.aarch64 3.5.5-r1.0
python3-threading.aarch64 3.5.5-r1.0
python3-tkinter.aarch64 3.5.5-r1.0
python3-typing.aarch64 3.5.5-r1.0
python3-unittest.aarch64 3.5.5-r1.0
python3-unixadmin.aarch64 3.5.5-r1.0
python3-xml.aarch64 3.5.5-r1.0
python3-xmlrpc.aarch64 3.5.5-r1.0
rpcbind.aarch64 0.2.4-r0
sed.aarch64 4.2.2-r0
shadow.aarch64 4.2.1-r0
shadow-base.aarch64 4.2.1-r0
shadow-securetty.imx8mmevk 4.2.1-r3
shared-mime-info.aarch64 1.9-r0
sigma-dut.aarch64 git-r0
slang.aarch64 2.3.2-r0
strace.aarch64 4.20-r0
sudo.aarch64 1.8.22-r0
sysklogd.aarch64 1.5.1-r0
systemd.aarch64 1:237-r0
systemd-container.aarch64 1:237-r0
systemd-gpuconfig.aarch64 1.0-r0
systemd-serialgetty.imx8mmevk 1.0-r5
systemd-vconsole-setup.aarch64 1:237-r0
systemtap.aarch64 3.2-r0
tar.aarch64 1.30-r0
tcl.aarch64 8.6.8-r0
tcp-wrappers.aarch64 7.6-r10
time.aarch64 1.8-r0
tinycompress.aarch64 1.1.6-r0
tiobench.aarch64 0.3.3-r1
tk.aarch64 8.6.8-r0
tk-lib.aarch64 8.6.8-r0
tslib-conf.aarch64 1.15-r0
tzdata.noarch 2018f-r0
udev.aarch64 1:237-r0
udev-extraconf.aarch64 1.1-r0
unzip.aarch64 1:6.0-r5
update-alternatives-opkg.aarch64 0.3.6-r0
update-rc.d.noarch 0.7-r5
usbutils.aarch64 009-r0
util-linux.aarch64 2.32.1-r0
util-linux-agetty.aarch64 2.32.1-r0
util-linux-losetup.aarch64 2.32.1-r0
util-linux-lsblk.aarch64 2.32.1-r0
util-linux-mount.aarch64 2.32.1-r0
util-linux-runuser.aarch64 2.32.1-r0
util-linux-su.aarch64 2.32.1-r0
util-linux-sulogin.aarch64 2.32.1-r0
util-linux-swaponoff.aarch64 2.32.1-r0
util-linux-umount.aarch64 2.32.1-r0
v4l-utils.aarch64_mx8mm 1.12.3-r0
valgrind.aarch64 3.13.0-r0
vlan.aarch64 1.9-r0
volatile-binds.noarch 1.0-r0
wayland.aarch64 1.16.0-r0
weston.aarch64_mx8mm 5.0.0.imx-r0
weston-examples.aarch64_mx8mm 5.0.0.imx-r0
which.aarch64 2.21-r3
wireless-tools.aarch64 1:30.pre9-r0
wpa-supplicant.aarch64 2.6-r0
x11perf.aarch64 1:1.6.0-r0
xkeyboard-config.aarch64 2.22-r0
xprop.aarch64 1:1.2.2-r0
xrestop.aarch64 0.4-r3
xserver-xorg.aarch64_mx8mm 2:1.19.6-r0
xserver-xorg-xwayland.aarch64_mx8mm 2:1.19.6-r0
xvideo-tests.aarch64 0.1+git0+7d38b881e9-r0
xwininfo.aarch64 1.1.3-r0
Complete!
NOTE: Running /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/dnf -y -c /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/dnf/dnf.conf --setopt=reposdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/yum.repos.d --repofrompath=oe-repo,/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/oe-sdk-repo --installroot=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --setopt=logdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/temp repoquery --installed --queryformat Package: %{name} %{arch} %{version} %{name}-%{version}-%{release}.%{arch}.rpm
Dependencies:
%{requires}
Recommendations:
%{recommends}
DependenciesEndHere:
NOTE: Installing complementary packages ...
NOTE: Running ['oe-pkgdata-util', '-p', '/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/pkgdata/imx8mmevk', 'glob', '/tmp/installed-pkgsoiz7zi58', '*-dbg *-dev']
NOTE: Running /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/dnf -y -c /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/dnf/dnf.conf --setopt=reposdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/yum.repos.d --repofrompath=oe-repo,/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/oe-sdk-repo --installroot=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --setopt=logdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/temp --skip-broken --nogpgcheck install libxmu-dbg packagegroup-fsl-tools-gpu-external-dev libxcomposite-dev busybox-dbg bc-dev procps-dev glib-networking-dbg libical-dev diffutils-dev kbd-dbg libxml2-dbg libtirpc-dev libgles-imx-dev mtdev-dbg packagegroup-base-ipv6-dev ptpd-dev nbench-byte-dbg libaio-dbg pulseaudio-dev packagegroup-fsl-tools-benchmark-dbg trace-cmd-dbg libwebp-dev blktool-dev libglib-2.0-dev libnss-mdns-dev gstreamer1.0-plugins-good-dbg gtk+3-dev e2fsprogs-dbg mtdev-dev iw-dbg ed-dev libgmp-dev libpam-dbg packagegroup-base-usbhost-dbg systemtap-dev packagegroup-core-full-cmdline-dev imx-gpu-apitrace-dbg xkbcomp-dev flex-dev libxcb-dbg libxmu-dev powertop-dbg lmbench-dbg libinput-dev libxrandr-dbg perf-dev nettle-dev optee-test-imx-dbg kmscube-dev arm-compute-library-dev imx-vpu-hantro-dev packagegroup-fsl-gstreamer1.0-audio-dbg packagegroup-core-full-cmdline-utils-dbg gtk+-dbg packagegroup-base-usbgadget-dbg fbset-modes-dev base-files-dev packagegroup-fsl-gstreamer1.0-video-dev target-sdk-provides-dummy-dev libical-dbg packagegroup-base-ipv6-dbg libsm-dev glib-networking-dev gst-examples-dev libgpuperfcnt-dev packagegroup-base-dev weston-init-dev alsa-plugins-dev at-dbg libtool-dbg libv4l-dev procps-dbg packagegroup-core-full-cmdline-initscripts-dev mesa-dbg vlan-dbg mesa-demos-dev imx-test-dbg packagegroup-distro-base-dev db-dev libnl-3-dbg alsa-state-dev systemd-dev gtk+-dev python-setuptools-dev libclutter-1.0-dbg lrzsz-dev firmware-imx-dev iproute2-dbg consolekit-dev libcroco-dbg iproute2-dev alsa-utils-dbg alsa-plugins-dbg ed-dbg libogg-dev hicolor-icon-theme-dev ethtool-dev python3-dbus-dev libpixman-1-dev cpio-dbg xkeyboard-config-dev dbus-dbg libdbus-glib-1-dbg packagegroup-fsl-optee-imx-dbg libexpat-dev libglew-dbg cogl-1.0-dbg weston-init-dbg libgdbm-dbg cracklib-dev imx-codec-dev python3-dev libxdmcp-dbg packagegroup-fsl-tools-testapps-dbg libevdev-dbg python-pip-dev ca-certificates-dbg libtheora-dbg packagegroup-fsl-gstreamer1.0-base-dbg xwininfo-dbg bzip2-dbg kmod-dev libxext-dev libclc-imx-dev packagegroup-fsl-tools-gpu-dev tar-dbg linux-firmware-dbg gnome-themes-standard-dbg bzip2-dev curl-dbg ofono-dev cryptodev-module-dev packagegroup-core-full-cmdline-multiuser-dbg glmark2-dev libg2d-dev libgdbm-dev sigma-dut-dbg lmbench-dev libts-dbg gstreamer1.0-dev libpixman-1-dbg libpcre-dbg ptpd-dbg libassimp-dev packagegroup-core-full-cmdline-sys-services-dbg ltp-dbg cracklib-dbg tiobench-dbg packagegroup-base-alsa-dev less-dbg libgpg-error-dev packagegroup-fsl-gstreamer1.0-network-base-dev memtester-dev packagegroup-core-tools-testapps-dev psplash-dev fbset-dbg valgrind-dbg trace-cmd-dev packagegroup-fsl-tools-gpu-external-dbg kbd-dev packagegroup-base-wifi-dbg libxfont2-dbg libjson-c-dbg libxcursor-dbg nbench-byte-dev psmisc-dbg libxdamage-dev imx-gpu-apitrace-dev libcroco-dev libnfsidmap-dbg dbench-dev lttng-tools-dbg imx-gpu-viv-dev packagegroup-base-extended-dbg dropbear-dev libglu-dbg packagegroup-core-ssh-dropbear-dbg packagegroup-fsl-gstreamer1.0-audio-dev libg2d-dbg librsvg-2-dev libmnl-dev libexpat-dbg liblzo2-dbg libsqlite3-dev packagegroup-core-standalone-sdk-target-dbg packagegroup-base-nfc-dbg packagegroup-core-tools-profile-dev python-dbg time-dev tk-dev m4-dev packagegroup-core-full-cmdline-libs-dbg packagegroup-fsl-tools-testapps-fslcodec-testapps-dbg libice-dbg diffutils-dbg packagegroup-fsl-tools-audio-dbg wpa-supplicant-dev less-dev arm-compute-library-dbg initscripts-dbg libffi-dbg libglut-dev libxpm-dev cryptodev-tests-dbg libtag-dev gstreamer1.0-plugins-good-dev usbutils-dbg pointercal-dbg libunwind-dev bash-dbg libxv-dbg libjpeg-dev python3-pygobject-dev libsamplerate0-dbg mobile-broadband-provider-info-dev packagegroup-core-full-cmdline-extended-dbg tk-dbg packagegroup-base-zeroconf-dbg evtest-dbg libpcap-dev libmnl-dbg wpa-supplicant-dbg icu-dbg libnfsidmap-dev xkeyboard-config-dbg libglew-dev imx-alsa-plugins-dbg wayland-dev libtirpc-dbg sudo-dev expect-dev gtk+3-dbg linuxptp-dbg libepoxy-dev xf86-input-libinput-dev tinycompress-dev lttng-ust-dbg weston-dev pointercal-dev base-files-dbg mc-dbg flac-dbg optee-os-imx-dbg pulseaudio-dbg libegl-imx-dev libpciaccess-dbg elfutils-dbg imx-codec-dbg sed-dev cpufrequtils-dbg gawk-dbg hostapd-dbg gstreamer1.0-rtsp-server-dbg libxv-dev m4-dbg vlan-dev fbset-dev packagegroup-fsl-gstreamer1.0-video-dbg gstreamer1.0-plugins-bad-dbg libxft-dbg fsl-rc-local-dbg libxfixes-dbg psmisc-dev gobject-introspection-dev packagegroup-fsl-gstreamer1.0-full-dbg shared-mime-info-dev python-setuptools-dbg libatk-1.0-dev libxinerama-dbg packagegroup-base-alsa-dbg xserver-xorg-dbg busybox-dev libnss-mdns-dbg strace-dev wayland-dbg packagegroup-fsl-gstreamer1.0-debug-dbg libusb-1.0-dev libuser-dbg gstreamer1.0-plugins-base-dbg binutils-dev libevdev-dev liburcu-dev netbase-dev i2c-tools-dev fio-dev fsl-rc-local-dev base-passwd-dev packagegroup-core-full-cmdline-utils-dev util-linux-dev xrestop-dev libglib-2.0-dbg gstreamer1.0-plugins-bad-dev libxcb-dev patch-dev libxres-dbg numactl-dbg packagegroup-fsl-tools-gpu-dbg dosfstools-dev systemd-dbg connman-dev e2fsprogs-dev ncurses-dbg run-postinsts-dev time-dbg flac-dev packagegroup-base-nfc-dev lttng-modules-dbg mmc-utils-dev libsm-dbg net-tools-dev python3-setuptools-dbg pciutils-dev gcc-runtime-dbg libspeex-dbg shadow-securetty-dev iozone3-dbg patch-dbg imx-vpu-hantro-dbg iptables-dbg binutils-dbg kexec-tools-dbg bonnie++-dbg firmware-imx-dbg logrotate-dbg nano-dbg attr-dbg libpng16-dbg shadow-securetty-dbg unzip-dev xterm-dev strace-dbg libxkbfile-dev flex-dbg packagegroup-fsl-optee-imx-dev libasound-dbg libgl-imx-dev volatile-binds-dev kexec-tools-dev libassimp-dbg libevent-dbg cryptodev-tests-dev libxfixes-dev gzip-dbg fio-dbg minicom-dbg packagegroup-core-standalone-sdk-target-dev liburcu-dbg which-dev libepoxy-dbg dropbear-dbg libgdk-pixbuf-2.0-dev packagegroup-base-nfs-dbg shadow-dbg consolekit-dbg linuxptp-dev xz-dev python-dev gst-examples-dbg neard-dbg ethtool-dbg dbench-dbg libglapi-dev libxaw-dev sysklogd-dbg libevent-dev libxxf86vm-dev packagegroup-core-tools-profile-dbg systemd-gpuconfig-dbg libxrandr-dev cpio-dev base-passwd-dbg alsa-tools-dev tar-dev hostapd-dev packagegroup-tools-bluetooth-dev gobject-introspection-dbg xvideo-tests-dbg libclutter-1.0-dev cpufrequtils-dev libice-dev optee-client-imx-dev run-postinsts-dbg findutils-dbg bluez5-dev libpopt-dbg libspeexdsp-dbg optee-test-imx-dev libgnutls-dbg packagegroup-base-dbg xkbcomp-dbg sqlite3-dbg make-dbg tcl-dbg firmware-qca9377-dbg libx11-dev slang-dbg libx11-dbg packagegroup-base-bluetooth-dev packagegroup-base-zeroconf-dev sed-dbg iw-dev imx-alsa-plugins-dev gstreamer1.0-rtsp-server-dev mktemp-dbg iperf3-dbg libxtst-dev packagegroup-fsl-gstreamer1.0-dbg rgb-dbg acl-dbg bonnie++-dev imx-gpu-sdk-dev libxtst-dbg gstreamer1.0-plugins-base-dev libpcap-dbg packagegroup-core-nfs-server-dev imx-parser-dbg packagegroup-distro-base-dbg libatk-1.0-dbg python3-setuptools-dev xf86-input-libinput-dbg libaio-dev libfreetype-dbg tcp-wrappers-dbg nettle-dbg libgles2-imx-dev openssl-dev packagegroup-core-full-cmdline-initscripts-dbg imx-test-dev cogl-1.0-dev libxdamage-dbg libharfbuzz-dev libxi-dbg libcap-dev libwebp-dbg shared-mime-info-dbg libdaemon-dev net-tools-dbg libxaw-dbg libts-dev libsbc-dbg mesa-demos-dbg file-dev librsvg-2-dbg packagegroup-tools-bluetooth-dbg file-dbg icu-dev libreadline-dev packagegroup-fsl-gstreamer1.0-debug-dev initscripts-dev libgpuperfcnt-dbg libpng16-dev libz-dbg libglu-dev evtest-dev lttng-tools-dev udev-extraconf-dev x11perf-dbg libgcrypt-dev libfontconfig-dev x11perf-dev neard-dev libpciaccess-dev mmc-utils-dbg libcairo-dbg coreutils-dev libfslvpuwrap-dbg lttng-ust-dev slang-dev gdb-dbg libinput-dbg packagegroup-base-pci-dbg memtester-dbg optee-os-imx-dev libgcc-s-dbg imx-gpu-sdk-dbg libgdk-pixbuf-2.0-dbg packagegroup-fsl-gstreamer1.0-dev cronie-dev libtool-dev libjson-c-dev packagegroup-core-full-cmdline-multiuser-dev libfontenc-dev perf-dbg python3-pygobject-dbg opkg-utils-dbg packagegroup-core-full-cmdline-libs-dev libgudev-1.0-dbg python-pip-dbg libgnutls-dev gstreamer1.0-dbg os-release-dev udev-rules-imx-dbg mktemp-dev libsamplerate0-dev xwininfo-dev systemtap-dbg cryptodev-module-dbg packagegroup-core-tools-debug-dev sigma-dut-dev libxft-dev libpam-dev gzip-dev libxkbfile-dbg xterm-dbg iputils-dev libpopt-dev packagegroup-core-nfs-server-dbg target-sdk-provides-dummy-dbg packagegroup-core-tools-debug-dbg pango-dbg rpcbind-dbg packagegroup-base-3g-dbg hicolor-icon-theme-dbg v4l-utils-dev gdb-dev perl-dev libfontenc-dbg nfs-utils-dev xprop-dbg libxt-dev v4l-utils-dbg libharfbuzz-dbg bluez5-dbg connman-dbg psplash-dbg sudo-dbg qca-tools-dbg libjson-glib-1.0-dbg qca-tools-dev bc-dbg db-dbg perl-dbg systemd-compat-units-dev elfutils-dev packagegroup-base-nfs-dev systemd-compat-units-dbg libsoup-2.4-dev alsa-state-dbg libsndfile-dev mtd-utils-dbg packagegroup-fsl-tools-benchmark-dev at-dev imx-gst1.0-plugin-dev liblzo2-dev tiobench-dev fstests-dbg libxt-dbg blktrace-dbg logrotate-dev libunistring-dev fbset-modes-dbg libxxf86vm-dbg grep-dev attr-dev avahi-dbg glmark2-dbg orc-dbg libvdk-imx-dev packagegroup-machine-base-dbg packagegroup-core-ssh-dropbear-dev openssl-dbg libxcomposite-dbg netbase-dbg i2c-tools-dbg libvorbis-dbg kmscube-dbg os-release-dbg pciutils-dbg packagegroup-base-wifi-dev libgbm-imx-dev libgpg-error-dbg glibc-mtrace-dbg libwrap-dev kmod-dbg firmware-qca9377-dev libunwind-dbg packagegroup-fsl-gstreamer1.0-network-base-dbg libxshmfence-dbg libxinerama-dev findutils-dev packagegroup-base-usbhost-dev packagegroup-core-boot-dev libvorbis-dev python3-dbus-dbg libasound-dev gtkperf-dbg packagegroup-core-boot-dbg libjson-glib-1.0-dev cronie-dbg ofono-dbg update-rc.d-dbg firmware-qca6174-dev libxml2-dev libgal-imx-dev libgmp-dbg packagegroup-core-tools-testapps-dbg packagegroup-fsl-tools-testapps-dev which-dbg packagegroup-base-bluetooth-dbg udev-rules-imx-dev dbus-dev packagegroup-machine-base-dev util-linux-dbg grep-dbg libogg-dbg makedevs-dev libcairo-dev libpcre-dev libz-dev mtd-utils-dev dosfstools-dbg packagegroup-fsl-tools-testapps-fslcodec-testapps-dev tinycompress-dbg packagegroup-core-full-cmdline-dbg gawk-dev lttng-modules-dev packagegroup-fsl-gstreamer1.0-base-dev libgcrypt-dbg libxrender-dev libxkbcommon-dev libxi-dev ncurses-dev imx-kobs-dev libcap-dbg libdbus-glib-1-dev systemd-serialgetty-dev alsa-utils-dev xserver-xorg-dev packagegroup-base-usbgadget-dev imx-gpu-viv-dbg packagegroup-fsl-gstreamer1.0-full-dev xrestop-dbg xserver-xf86-config-dev packagegroup-core-full-cmdline-extended-dev libunistring-dbg shadow-dev iputils-dbg make-dev libspeexdsp-dev babeltrace-dev libffi-dev can-utils-dbg blktool-dbg libglut-dbg libxfont2-dev glibc-locale-dbg avahi-dev libtag-dbg linux-firmware-dev nano-dev libreadline-dbg gtkperf-dev packagegroup-core-full-cmdline-dev-utils-dbg valgrind-dev libdrm-dev glibc-mtrace-dev packagegroup-core-full-cmdline-sys-services-dev libtiff-dbg rpcbind-dev tcl-dev libuser-dev xz-dbg libdaemon-dbg imx-parser-dev ntp-dbg numactl-dev libopenvg-imx-dev optee-client-imx-dbg libxcursor-dev gnome-themes-standard-dev ltp-dev packagegroup-base-3g-dev libfreetype-dev libusb-1.0-dbg python3-pycairo-dev python3-dbg libxau-dev sysklogd-dev orc-dev libjpeg-dbg libxpm-dbg unzip-dbg devil-dbg packagegroup-base-extended-dev ca-certificates-dev ntp-dev alsa-tools-dbg curl-dev imx-gst1.0-plugin-dbg nfs-utils-dbg xvideo-tests-dev libsbc-dev can-utils-dev libxshmfence-dev makedevs-dbg packagegroup-core-full-cmdline-dev-utils-dev expect-dbg iperf3-dev mobile-broadband-provider-info-dbg imx-kobs-dbg babeltrace-dbg libxau-dbg lrzsz-dbg systemd-gpuconfig-dev wireless-tools-dbg mc-dev iozone3-dev libxrender-dbg blktrace-dev devil-dev udev-extraconf-dbg libfslvpuwrap-dev libtiff-dev bash-dev libgudev-1.0-dev libxkbcommon-dbg minicom-dev firmware-qca6174-dbg systemd-serialgetty-dbg update-rc.d-dev libtheora-dev xprop-dev libxext-dbg acl-dev libfontconfig-dbg libspeex-dev libdrm-dbg pango-dev python3-pycairo-dbg volatile-binds-dbg weston-dbg powertop-dev xserver-xf86-config-dbg iptables-dev libnl-3-dev libxdmcp-dev libxres-dev rgb-dev libsndfile-dbg fstests-dev coreutils-dbg packagegroup-fsl-tools-audio-dev packagegroup-base-pci-dev libsoup-2.4-dbg usbutils-dev
ERROR: Could not invoke dnf. Command '/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/recipe-sysroot-native/usr/bin/dnf -y -c /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/dnf/dnf.conf --setopt=reposdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux/etc/yum.repos.d --repofrompath=oe-repo,/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/oe-sdk-repo --installroot=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/sdk/image/opt/fsl-imx-xwayland/4.14-sumo/sysroots/aarch64-poky-linux --setopt=logdir=/data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/temp --skip-broken --nogpgcheck install libxmu-dbg packagegroup-fsl-tools-gpu-external-dev libxcomposite-dev busybox-dbg bc-dev procps-dev glib-networking-dbg libical-dev diffutils-dev kbd-dbg libxml2-dbg libtirpc-dev libgles-imx-dev mtdev-dbg packagegroup-base-ipv6-dev ptpd-dev nbench-byte-dbg libaio-dbg pulseaudio-dev packagegroup-fsl-tools-benchmark-dbg trace-cmd-dbg libwebp-dev blktool-dev libglib-2.0-dev libnss-mdns-dev gstreamer1.0-plugins-good-dbg gtk+3-dev e2fsprogs-dbg mtdev-dev iw-dbg ed-dev libgmp-dev libpam-dbg packagegroup-base-usbhost-dbg systemtap-dev packagegroup-core-full-cmdline-dev imx-gpu-apitrace-dbg xkbcomp-dev flex-dev libxcb-dbg libxmu-dev powertop-dbg lmbench-dbg libinput-dev libxrandr-dbg perf-dev nettle-dev optee-test-imx-dbg kmscube-dev arm-compute-library-dev imx-vpu-hantro-dev packagegroup-fsl-gstreamer1.0-audio-dbg packagegroup-core-full-cmdline-utils-dbg gtk+-dbg packagegroup-base-usbgadget-dbg fbset-modes-dev base-files-dev packagegroup-fsl-gstreamer1.0-video-dev target-sdk-provides-dummy-dev libical-dbg packagegroup-base-ipv6-dbg libsm-dev glib-networking-dev gst-examples-dev libgpuperfcnt-dev packagegroup-base-dev weston-init-dev alsa-plugins-dev at-dbg libtool-dbg libv4l-dev procps-dbg packagegroup-core-full-cmdline-initscripts-dev mesa-dbg vlan-dbg mesa-demos-dev imx-test-dbg packagegroup-distro-base-dev db-dev libnl-3-dbg alsa-state-dev systemd-dev gtk+-dev python-setuptools-dev libclutter-1.0-dbg lrzsz-dev firmware-imx-dev iproute2-dbg consolekit-dev libcroco-dbg iproute2-dev alsa-utils-dbg alsa-plugins-dbg ed-dbg libogg-dev hicolor-icon-theme-dev ethtool-dev python3-dbus-dev libpixman-1-dev cpio-dbg xkeyboard-config-dev dbus-dbg libdbus-glib-1-dbg packagegroup-fsl-optee-imx-dbg libexpat-dev libglew-dbg cogl-1.0-dbg weston-init-dbg libgdbm-dbg cracklib-dev imx-codec-dev python3-dev libxdmcp-dbg packagegroup-fsl-tools-testapps-dbg libevdev-dbg python-pip-dev ca-certificates-dbg libtheora-dbg packagegroup-fsl-gstreamer1.0-base-dbg xwininfo-dbg bzip2-dbg kmod-dev libxext-dev libclc-imx-dev packagegroup-fsl-tools-gpu-dev tar-dbg linux-firmware-dbg gnome-themes-standard-dbg bzip2-dev curl-dbg ofono-dev cryptodev-module-dev packagegroup-core-full-cmdline-multiuser-dbg glmark2-dev libg2d-dev libgdbm-dev sigma-dut-dbg lmbench-dev libts-dbg gstreamer1.0-dev libpixman-1-dbg libpcre-dbg ptpd-dbg libassimp-dev packagegroup-core-full-cmdline-sys-services-dbg ltp-dbg cracklib-dbg tiobench-dbg packagegroup-base-alsa-dev less-dbg libgpg-error-dev packagegroup-fsl-gstreamer1.0-network-base-dev memtester-dev packagegroup-core-tools-testapps-dev psplash-dev fbset-dbg valgrind-dbg trace-cmd-dev packagegroup-fsl-tools-gpu-external-dbg kbd-dev packagegroup-base-wifi-dbg libxfont2-dbg libjson-c-dbg libxcursor-dbg nbench-byte-dev psmisc-dbg libxdamage-dev imx-gpu-apitrace-dev libcroco-dev libnfsidmap-dbg dbench-dev lttng-tools-dbg imx-gpu-viv-dev packagegroup-base-extended-dbg dropbear-dev libglu-dbg packagegroup-core-ssh-dropbear-dbg packagegroup-fsl-gstreamer1.0-audio-dev libg2d-dbg librsvg-2-dev libmnl-dev libexpat-dbg liblzo2-dbg libsqlite3-dev packagegroup-core-standalone-sdk-target-dbg packagegroup-base-nfc-dbg packagegroup-core-tools-profile-dev python-dbg time-dev tk-dev m4-dev packagegroup-core-full-cmdline-libs-dbg packagegroup-fsl-tools-testapps-fslcodec-testapps-dbg libice-dbg diffutils-dbg packagegroup-fsl-tools-audio-dbg wpa-supplicant-dev less-dev arm-compute-library-dbg initscripts-dbg libffi-dbg libglut-dev libxpm-dev cryptodev-tests-dbg libtag-dev gstreamer1.0-plugins-good-dev usbutils-dbg pointercal-dbg libunwind-dev bash-dbg libxv-dbg libjpeg-dev python3-pygobject-dev libsamplerate0-dbg mobile-broadband-provider-info-dev packagegroup-core-full-cmdline-extended-dbg tk-dbg packagegroup-base-zeroconf-dbg evtest-dbg libpcap-dev libmnl-dbg wpa-supplicant-dbg icu-dbg libnfsidmap-dev xkeyboard-config-dbg libglew-dev imx-alsa-plugins-dbg wayland-dev libtirpc-dbg sudo-dev expect-dev gtk+3-dbg linuxptp-dbg libepoxy-dev xf86-input-libinput-dev tinycompress-dev lttng-ust-dbg weston-dev pointercal-dev base-files-dbg mc-dbg flac-dbg optee-os-imx-dbg pulseaudio-dbg libegl-imx-dev libpciaccess-dbg elfutils-dbg imx-codec-dbg sed-dev cpufrequtils-dbg gawk-dbg hostapd-dbg gstreamer1.0-rtsp-server-dbg libxv-dev m4-dbg vlan-dev fbset-dev packagegroup-fsl-gstreamer1.0-video-dbg gstreamer1.0-plugins-bad-dbg libxft-dbg fsl-rc-local-dbg libxfixes-dbg psmisc-dev gobject-introspection-dev packagegroup-fsl-gstreamer1.0-full-dbg shared-mime-info-dev python-setuptools-dbg libatk-1.0-dev libxinerama-dbg packagegroup-base-alsa-dbg xserver-xorg-dbg busybox-dev libnss-mdns-dbg strace-dev wayland-dbg packagegroup-fsl-gstreamer1.0-debug-dbg libusb-1.0-dev libuser-dbg gstreamer1.0-plugins-base-dbg binutils-dev libevdev-dev liburcu-dev netbase-dev i2c-tools-dev fio-dev fsl-rc-local-dev base-passwd-dev packagegroup-core-full-cmdline-utils-dev util-linux-dev xrestop-dev libglib-2.0-dbg gstreamer1.0-plugins-bad-dev libxcb-dev patch-dev libxres-dbg numactl-dbg packagegroup-fsl-tools-gpu-dbg dosfstools-dev systemd-dbg connman-dev e2fsprogs-dev ncurses-dbg run-postinsts-dev time-dbg flac-dev packagegroup-base-nfc-dev lttng-modules-dbg mmc-utils-dev libsm-dbg net-tools-dev python3-setuptools-dbg pciutils-dev gcc-runtime-dbg libspeex-dbg shadow-securetty-dev iozone3-dbg patch-dbg imx-vpu-hantro-dbg iptables-dbg binutils-dbg kexec-tools-dbg bonnie++-dbg firmware-imx-dbg logrotate-dbg nano-dbg attr-dbg libpng16-dbg shadow-securetty-dbg unzip-dev xterm-dev strace-dbg libxkbfile-dev flex-dbg packagegroup-fsl-optee-imx-dev libasound-dbg libgl-imx-dev volatile-binds-dev kexec-tools-dev libassimp-dbg libevent-dbg cryptodev-tests-dev libxfixes-dev gzip-dbg fio-dbg minicom-dbg packagegroup-core-standalone-sdk-target-dev liburcu-dbg which-dev libepoxy-dbg dropbear-dbg libgdk-pixbuf-2.0-dev packagegroup-base-nfs-dbg shadow-dbg consolekit-dbg linuxptp-dev xz-dev python-dev gst-examples-dbg neard-dbg ethtool-dbg dbench-dbg libglapi-dev libxaw-dev sysklogd-dbg libevent-dev libxxf86vm-dev packagegroup-core-tools-profile-dbg systemd-gpuconfig-dbg libxrandr-dev cpio-dev base-passwd-dbg alsa-tools-dev tar-dev hostapd-dev packagegroup-tools-bluetooth-dev gobject-introspection-dbg xvideo-tests-dbg libclutter-1.0-dev cpufrequtils-dev libice-dev optee-client-imx-dev run-postinsts-dbg findutils-dbg bluez5-dev libpopt-dbg libspeexdsp-dbg optee-test-imx-dev libgnutls-dbg packagegroup-base-dbg xkbcomp-dbg sqlite3-dbg make-dbg tcl-dbg firmware-qca9377-dbg libx11-dev slang-dbg libx11-dbg packagegroup-base-bluetooth-dev packagegroup-base-zeroconf-dev sed-dbg iw-dev imx-alsa-plugins-dev gstreamer1.0-rtsp-server-dev mktemp-dbg iperf3-dbg libxtst-dev packagegroup-fsl-gstreamer1.0-dbg rgb-dbg acl-dbg bonnie++-dev imx-gpu-sdk-dev libxtst-dbg gstreamer1.0-plugins-base-dev libpcap-dbg packagegroup-core-nfs-server-dev imx-parser-dbg packagegroup-distro-base-dbg libatk-1.0-dbg python3-setuptools-dev xf86-input-libinput-dbg libaio-dev libfreetype-dbg tcp-wrappers-dbg nettle-dbg libgles2-imx-dev openssl-dev packagegroup-core-full-cmdline-initscripts-dbg imx-test-dev cogl-1.0-dev libxdamage-dbg libharfbuzz-dev libxi-dbg libcap-dev libwebp-dbg shared-mime-info-dbg libdaemon-dev net-tools-dbg libxaw-dbg libts-dev libsbc-dbg mesa-demos-dbg file-dev librsvg-2-dbg packagegroup-tools-bluetooth-dbg file-dbg icu-dev libreadline-dev packagegroup-fsl-gstreamer1.0-debug-dev initscripts-dev libgpuperfcnt-dbg libpng16-dev libz-dbg libglu-dev evtest-dev lttng-tools-dev udev-extraconf-dev x11perf-dbg libgcrypt-dev libfontconfig-dev x11perf-dev neard-dev libpciaccess-dev mmc-utils-dbg libcairo-dbg coreutils-dev libfslvpuwrap-dbg lttng-ust-dev slang-dev gdb-dbg libinput-dbg packagegroup-base-pci-dbg memtester-dbg optee-os-imx-dev libgcc-s-dbg imx-gpu-sdk-dbg libgdk-pixbuf-2.0-dbg packagegroup-fsl-gstreamer1.0-dev cronie-dev libtool-dev libjson-c-dev packagegroup-core-full-cmdline-multiuser-dev libfontenc-dev perf-dbg python3-pygobject-dbg opkg-utils-dbg packagegroup-core-full-cmdline-libs-dev libgudev-1.0-dbg python-pip-dbg libgnutls-dev gstreamer1.0-dbg os-release-dev udev-rules-imx-dbg mktemp-dev libsamplerate0-dev xwininfo-dev systemtap-dbg cryptodev-module-dbg packagegroup-core-tools-debug-dev sigma-dut-dev libxft-dev libpam-dev gzip-dev libxkbfile-dbg xterm-dbg iputils-dev libpopt-dev packagegroup-core-nfs-server-dbg target-sdk-provides-dummy-dbg packagegroup-core-tools-debug-dbg pango-dbg rpcbind-dbg packagegroup-base-3g-dbg hicolor-icon-theme-dbg v4l-utils-dev gdb-dev perl-dev libfontenc-dbg nfs-utils-dev xprop-dbg libxt-dev v4l-utils-dbg libharfbuzz-dbg bluez5-dbg connman-dbg psplash-dbg sudo-dbg qca-tools-dbg libjson-glib-1.0-dbg qca-tools-dev bc-dbg db-dbg perl-dbg systemd-compat-units-dev elfutils-dev packagegroup-base-nfs-dev systemd-compat-units-dbg libsoup-2.4-dev alsa-state-dbg libsndfile-dev mtd-utils-dbg packagegroup-fsl-tools-benchmark-dev at-dev imx-gst1.0-plugin-dev liblzo2-dev tiobench-dev fstests-dbg libxt-dbg blktrace-dbg logrotate-dev libunistring-dev fbset-modes-dbg libxxf86vm-dbg grep-dev attr-dev avahi-dbg glmark2-dbg orc-dbg libvdk-imx-dev packagegroup-machine-base-dbg packagegroup-core-ssh-dropbear-dev openssl-dbg libxcomposite-dbg netbase-dbg i2c-tools-dbg libvorbis-dbg kmscube-dbg os-release-dbg pciutils-dbg packagegroup-base-wifi-dev libgbm-imx-dev libgpg-error-dbg glibc-mtrace-dbg libwrap-dev kmod-dbg firmware-qca9377-dev libunwind-dbg packagegroup-fsl-gstreamer1.0-network-base-dbg libxshmfence-dbg libxinerama-dev findutils-dev packagegroup-base-usbhost-dev packagegroup-core-boot-dev libvorbis-dev python3-dbus-dbg libasound-dev gtkperf-dbg packagegroup-core-boot-dbg libjson-glib-1.0-dev cronie-dbg ofono-dbg update-rc.d-dbg firmware-qca6174-dev libxml2-dev libgal-imx-dev libgmp-dbg packagegroup-core-tools-testapps-dbg packagegroup-fsl-tools-testapps-dev which-dbg packagegroup-base-bluetooth-dbg udev-rules-imx-dev dbus-dev packagegroup-machine-base-dev util-linux-dbg grep-dbg libogg-dbg makedevs-dev libcairo-dev libpcre-dev libz-dev mtd-utils-dev dosfstools-dbg packagegroup-fsl-tools-testapps-fslcodec-testapps-dev tinycompress-dbg packagegroup-core-full-cmdline-dbg gawk-dev lttng-modules-dev packagegroup-fsl-gstreamer1.0-base-dev libgcrypt-dbg libxrender-dev libxkbcommon-dev libxi-dev ncurses-dev imx-kobs-dev libcap-dbg libdbus-glib-1-dev systemd-serialgetty-dev alsa-utils-dev xserver-xorg-dev packagegroup-base-usbgadget-dev imx-gpu-viv-dbg packagegroup-fsl-gstreamer1.0-full-dev xrestop-dbg xserver-xf86-config-dev packagegroup-core-full-cmdline-extended-dev libunistring-dbg shadow-dev iputils-dbg make-dev libspeexdsp-dev babeltrace-dev libffi-dev can-utils-dbg blktool-dbg libglut-dbg libxfont2-dev glibc-locale-dbg avahi-dev libtag-dbg linux-firmware-dev nano-dev libreadline-dbg gtkperf-dev packagegroup-core-full-cmdline-dev-utils-dbg valgrind-dev libdrm-dev glibc-mtrace-dev packagegroup-core-full-cmdline-sys-services-dev libtiff-dbg rpcbind-dev tcl-dev libuser-dev xz-dbg libdaemon-dbg imx-parser-dev ntp-dbg numactl-dev libopenvg-imx-dev optee-client-imx-dbg libxcursor-dev gnome-themes-standard-dev ltp-dev packagegroup-base-3g-dev libfreetype-dev libusb-1.0-dbg python3-pycairo-dev python3-dbg libxau-dev sysklogd-dev orc-dev libjpeg-dbg libxpm-dbg unzip-dbg devil-dbg packagegroup-base-extended-dev ca-certificates-dev ntp-dev alsa-tools-dbg curl-dev imx-gst1.0-plugin-dbg nfs-utils-dbg xvideo-tests-dev libsbc-dev can-utils-dev libxshmfence-dev makedevs-dbg packagegroup-core-full-cmdline-dev-utils-dev expect-dbg iperf3-dev mobile-broadband-provider-info-dbg imx-kobs-dbg babeltrace-dbg libxau-dbg lrzsz-dbg systemd-gpuconfig-dev wireless-tools-dbg mc-dev iozone3-dev libxrender-dbg blktrace-dev devil-dev udev-extraconf-dbg libfslvpuwrap-dev libtiff-dev bash-dev libgudev-1.0-dev libxkbcommon-dbg minicom-dev firmware-qca6174-dbg systemd-serialgetty-dbg update-rc.d-dev libtheora-dev xprop-dev libxext-dbg acl-dev libfontconfig-dbg libspeex-dev libdrm-dbg pango-dev python3-pycairo-dbg volatile-binds-dbg weston-dbg powertop-dev xserver-xf86-config-dbg iptables-dev libnl-3-dev libxdmcp-dev libxres-dev rgb-dev libsndfile-dbg fstests-dev coreutils-dbg packagegroup-fsl-tools-audio-dev packagegroup-base-pci-dev libsoup-2.4-dbg usbutils-dev' returned 1:
Added oe-repo repo from /data/blackbox/imx-yocto-bsp/build-evk-xwayland/tmp/work/imx8mmevk-poky-linux/fsl-image-gui/1.0-r0/oe-sdk-repo
Last metadata expiration check: 0:01:31 ago on Thu 23 Jan 2020 12:02:11 PM UTC.
Dependencies resolved.
Problem: package libgl-imx-dev-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8mm requires libgl-mesa-dev, but none of the providers can be installed
- package libgl-mesa-dev-2:17.3.8-r0.aarch64_mx8mm conflicts with libgl-dev provided by libgl-imx-dev-1:6.2.4.p4.0+aarch64-r0.aarch64_mx8mm
- conflicting requests
Package Arch Version Repository
Size
Installing:
acl-dbg aarch64 2.2.52-r0 oe-repo 116 k
acl-dev aarch64 2.2.52-r0 oe-repo 9.3 k
alsa-plugins-dbg aarch64 1.1.5-r0 oe-repo 135 k
alsa-plugins-dev aarch64 1.1.5-r0 oe-repo 6.3 k
alsa-state-dbg imx8mmevk 0.2.0-r5 oe-repo 5.8 k
alsa-state-dev imx8mmevk 0.2.0-r5 oe-repo 5.9 k
alsa-tools-dbg aarch64 1.1.5-r0 oe-repo 358 k
alsa-tools-dev aarch64 1.1.5-r0 oe-repo 6.0 k
alsa-utils-dbg aarch64 1.1.5-r0 oe-repo 426 k
alsa-utils-dev aarch64 1.1.5-r0 oe-repo 6.4 k
arm-compute-library-dbg aarch64 18.11+git0+64441b79b8-r0
oe-repo 418 k
arm-compute-library-dev aarch64 18.11+git0+64441b79b8-r0
oe-repo 549 k
at-dbg aarch64 3.1.20-r0 oe-repo 98 k
at-dev aarch64 3.1.20-r0 oe-repo 6.0 k
attr-dbg aarch64 2.4.47-r0 oe-repo 66 k
attr-dev aarch64 2.4.47-r0 oe-repo 11 k
avahi-dbg aarch64 0.7-r0 oe-repo 666 k
avahi-dev aarch64 0.7-r0 oe-repo 43 k
babeltrace-dbg aarch64 1.5.4-r0 oe-repo 619 k
babeltrace-dev aarch64 1.5.4-r0 oe-repo 26 k
base-files-dbg imx8mmevk 3.0.14-r89 oe-repo 5.7 k
base-files-dev imx8mmevk 3.0.14-r89 oe-repo 5.8 k
base-passwd-dbg aarch64 3.5.29-r0 oe-repo 31 k
base-passwd-dev aarch64 3.5.29-r0 oe-repo 5.9 k
bash-dbg aarch64 4.4.12-r0 oe-repo 1.5 M
bash-dev aarch64 4.4.12-r0 oe-repo 66 k
bc-dbg aarch64 1.06-r3 oe-repo 137 k
bc-dev aarch64 1.06-r3 oe-repo 5.9 k
binutils-dbg aarch64 2.30-r0 oe-repo 34 M
binutils-dev aarch64 2.30-r0 oe-repo 94 k
blktool-dbg aarch64 4+7-r0 oe-repo 40 k
blktool-dev aarch64 4+7-r0 oe-repo 6.0 k
blktrace-dbg aarch64 1.2.0+git0+cca113f2fe-r0
oe-repo 362 k
blktrace-dev aarch64 1.2.0+git0+cca113f2fe-r0
oe-repo 5.9 k
bluez5-dbg aarch64 5.49-r0 oe-repo 4.7 M
bluez5-dev aarch64 5.49-r0 oe-repo 33 k
bonnie++-dbg aarch64 1.03e-r0 oe-repo 15 k
bonnie++-dev aarch64 1.03e-r0 oe-repo 5.9 k
busybox-dbg aarch64 1.27.2-r0 oe-repo 1.7 M
busybox-dev aarch64 1.27.2-r0 oe-repo 6.4 k
bzip2-dbg aarch64 1.0.6-r5 oe-repo 110 k
bzip2-dev aarch64 1.0.6-r5 oe-repo 8.6 k
ca-certificates-dbg noarch 20170717-r0 oe-repo 5.9 k
ca-certificates-dev noarch 20170717-r0 oe-repo 6.0 k
can-utils-dbg aarch64 0.0+gitr0+4c8fb05cb4-r0
oe-repo 202 k
can-utils-dev aarch64 0.0+gitr0+4c8fb05cb4-r0
oe-repo 5.9 k
cogl-1.0-dbg aarch64_mx8mm 1.22.2-r0 oe-repo 1.6 M
cogl-1.0-dev aarch64_mx8mm 1.22.2-r0 oe-repo 209 k
connman-dbg aarch64 1.35-r0 oe-repo 1.4 M
connman-dev aarch64 1.35-r0 oe-repo 16 k
consolekit-dbg aarch64 0.4.6-r0 oe-repo 287 k
consolekit-dev aarch64 0.4.6-r0 oe-repo 8.6 k
coreutils-dbg aarch64 8.29-r0 oe-repo 3.6 M
coreutils-dev aarch64 8.29-r0 oe-repo 6.1 k
cpio-dbg aarch64 2.12-r0 oe-repo 365 k
cpio-dev aarch64 2.12-r0 oe-repo 6.0 k
cpufrequtils-dbg aarch64 008-r5 oe-repo 50 k
cpufrequtils-dev aarch64 008-r5 oe-repo 8.5 k
cracklib-dbg aarch64 2.9.5-r0 oe-repo 44 k
cracklib-dev aarch64 2.9.5-r0 oe-repo 8.2 k
cronie-dbg aarch64 1.5.1-r0 oe-repo 114 k
cronie-dev aarch64 1.5.1-r0 oe-repo 6.2 k
cryptodev-module-dbg imx8mmevk 1.9-r0 oe-repo 5.7 k
cryptodev-module-dev imx8mmevk 1.9-r0 oe-repo 6.7 k
cryptodev-tests-dbg aarch64 1.9-r0 oe-repo 74 k
cryptodev-tests-dev aarch64 1.9-r0 oe-repo 5.9 k
curl-dbg aarch64 7.61.0-r0 oe-repo 27 k
curl-dev aarch64 7.61.0-r0 oe-repo 49 k
db-dbg aarch64 1:5.3.28-r1 oe-repo 3.3 M
db-dev aarch64 1:5.3.28-r1 oe-repo 42 k
dbench-dbg aarch64 4.0-r0 oe-repo 84 k
dbench-dev aarch64 4.0-r0 oe-repo 5.8 k
dbus-dbg aarch64 1.12.2-r0 oe-repo 1.0 M
dbus-dev aarch64 1.12.2-r0 oe-repo 37 k
devil-dbg imx8mmevk 1.8.0-r0 oe-repo 575 k
devil-dev imx8mmevk 1.8.0-r0 oe-repo 16 k
diffutils-dbg aarch64 3.6-r0 oe-repo 573 k
diffutils-dev aarch64 3.6-r0 oe-repo 6.0 k
dosfstools-dbg aarch64 4.1-r0 oe-repo 126 k
dosfstools-dev aarch64 4.1-r0 oe-repo 5.8 k
dropbear-dbg aarch64 2017.75-r0 oe-repo 593 k
dropbear-dev aarch64 2017.75-r0 oe-repo 6.0 k
e2fsprogs-dbg aarch64 1.43.8-r0 oe-repo 1.6 M
e2fsprogs-dev aarch64 1.43.8-r0 oe-repo 50 k
ed-dbg aarch64 1.14.2-r0 oe-repo 70 k
ed-dev aarch64 1.14.2-r0 oe-repo 5.8 k
elfutils-dbg aarch64 0.170-r0 oe-repo 1.7 M
elfutils-dev aarch64 0.170-r0 oe-repo 49 k
ethtool-dbg aarch64 4.13-r0 oe-repo 314 k
ethtool-dev aarch64 4.13-r0 oe-repo 5.9 k
evtest-dbg aarch64 1.33+0+ab140a2dab-r0
oe-repo 29 k
evtest-dev aarch64 1.33+0+ab140a2dab-r0
oe-repo 5.9 k
expect-dbg aarch64 5.45.4-r0 oe-repo 417 k
expect-dev aarch64 5.45.4-r0 oe-repo 13 k
fbset-dbg aarch64 2.1-r4 oe-repo 13 k
fbset-dev aarch64 2.1-r4 oe-repo 5.8 k
fbset-modes-dbg imx8mmevk 0.1.0-r6 oe-repo 5.7 k
fbset-modes-dev imx8mmevk 0.1.0-r6 oe-repo 5.8 k
file-dbg aarch64 5.32-r0 oe-repo 216 k
file-dev aarch64 5.32-r0 oe-repo 8.7 k
findutils-dbg aarch64 4.6.0-r0 oe-repo 781 k
findutils-dev aarch64 4.6.0-r0 oe-repo 6.1 k
fio-dbg aarch64 2.9-r0 oe-repo 1.1 M
fio-dev aarch64 2.9-r0 oe-repo 6.2 k
firmware-imx-dbg noarch 1:8.1-r0 oe-repo 5.7 k
firmware-imx-dev noarch 1:8.1-r0 oe-repo 5.7 k
firmware-qca6174-dbg noarch 2.0.3-r0 oe-repo 5.7 k
firmware-qca6174-dev noarch 2.0.3-r0 oe-repo 5.7 k
firmware-qca9377-dbg noarch 2.0.3-r0 oe-repo 5.7 k
firmware-qca9377-dev noarch 2.0.3-r0 oe-repo 5.7 k
flac-dbg aarch64 1.3.2-r0 oe-repo 794 k
flac-dev aarch64 1.3.2-r0 oe-repo 63 k
flex-dbg aarch64 2.6.0-r0 oe-repo 905 k
flex-dev aarch64 2.6.0-r0 oe-repo 9.3 k
fsl-rc-local-dbg aarch64 1.0-r0 oe-repo 5.7 k
fsl-rc-local-dev aarch64 1.0-r0 oe-repo 5.7 k
fstests-dbg aarch64_mx8mm 0.1+git0+e5939ff608-r0
oe-repo 93 k
fstests-dev aarch64_mx8mm 0.1+git0+e5939ff608-r0
oe-repo 6.0 k
gawk-dbg aarch64 4.2.1-r0 oe-repo 915 k
gawk-dev aarch64 4.2.1-r0 oe-repo 17 k
gcc-runtime-dbg aarch64 7.3.0-r0 oe-repo 2.3 M
gdb-dbg aarch64 8.0.1-r0 oe-repo 14 M
gdb-dev aarch64 8.0.1-r0 oe-repo 6.0 k
glib-networking-dbg aarch64 2.54.1-r0 oe-repo 114 k
glib-networking-dev aarch64 2.54.1-r0 oe-repo 6.0 k
glibc-locale-dbg aarch64 2.27-r0 oe-repo 837 k
glibc-mtrace-dbg aarch64 2.27-r0 oe-repo 5.7 k
glibc-mtrace-dev aarch64 2.27-r0 oe-repo 5.8 k
glmark2-dbg aarch64_mx8mm 2017.07+0+ed20c633f1-r0
oe-repo 2.7 M
glmark2-dev aarch64_mx8mm 2017.07+0+ed20c633f1-r0
oe-repo 6.1 k
gnome-themes-standard-dbg aarch64 3.22.3-r0 oe-repo 26 k
gnome-themes-standard-dev aarch64 3.22.3-r0 oe-repo 6.1 k
gobject-introspection-dbg aarch64 1.54.1-r0 oe-repo 533 k
gobject-introspection-dev aarch64 1.54.1-r0 oe-repo 637 k
grep-dbg aarch64 3.1-r0 oe-repo 541 k
grep-dev aarch64 3.1-r0 oe-repo 5.8 k
gst-examples-dbg aarch64 0.0.1+git0+48247c6ab6-r0
oe-repo 114 k
gst-examples-dev aarch64 0.0.1+git0+48247c6ab6-r0
oe-repo 6.1 k
gstreamer1.0-dbg aarch64 1.14.4.imx-r0
oe-repo 2.8 M
gstreamer1.0-dev aarch64 1.14.4.imx-r0
oe-repo 398 k
oe-repo 5.4 M
oe-repo 90 k
oe-repo 5.0 M
oe-repo 336 k
oe-repo 5.2 M
oe-repo 9.2 k
aarch64 1.14.4-r0 oe-repo 516 k
aarch64 1.14.4-r0 oe-repo 26 k
gtk+-dbg aarch64_mx8mm 2.24.32-r0 oe-repo 7.5 M
gtk+-dev aarch64_mx8mm 2.24.32-r0 oe-repo 681 k
gtk+3-dbg aarch64_mx8mm 3.22.28-r0 oe-repo 11 M
gtk+3-dev aarch64_mx8mm 3.22.28-r0 oe-repo 911 k
gtkperf-dbg aarch64 0.40-r0 oe-repo 13 k
gtkperf-dev aarch64 0.40-r0 oe-repo 5.8 k
gzip-dbg aarch64 1.9-r0 oe-repo 200 k
gzip-dev aarch64 1.9-r0 oe-repo 5.9 k
hicolor-icon-theme-dbg noarch 0.17-r0 oe-repo 5.8 k
hicolor-icon-theme-dev noarch 0.17-r0 oe-repo 5.8 k
hostapd-dbg aarch64 2.6-r0 oe-repo 1.6 M
hostapd-dev aarch64 2.6-r0 oe-repo 5.9 k
i2c-tools-dbg aarch64 4.0-r0 oe-repo 69 k
i2c-tools-dev aarch64 4.0-r0 oe-repo 7.8 k
icu-dbg aarch64 60.2-r0 oe-repo 8.0 M
icu-dev aarch64 60.2-r0 oe-repo 605 k
imx-alsa-plugins-dbg aarch64_mx8mm 1.0.26-r0 oe-repo 18 k
imx-alsa-plugins-dev aarch64_mx8mm 1.0.26-r0 oe-repo 5.8 k
imx-codec-dbg aarch64_mx8mm 4.4.5-r0 oe-repo 6.1 k
imx-codec-dev aarch64_mx8mm 4.4.5-r0 oe-repo 36 k
imx-gpu-apitrace-dbg aarch64_mx8mm 7.1.0-r0 oe-repo 8.0 M
imx-gpu-apitrace-dev aarch64_mx8mm 7.1.0-r0 oe-repo 5.9 k
imx-gpu-sdk-dbg aarch64_mx8mm 5.3.0-r0 oe-repo 5.9 k
imx-gpu-sdk-dev aarch64_mx8mm 5.3.0-r0 oe-repo 6.1 k
imx-gpu-viv-dbg aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 6.2 k
imx-gpu-viv-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 5.9 k
imx-gst1.0-plugin-dbg aarch64_mx8mm 4.4.5-r0 oe-repo 572 k
imx-gst1.0-plugin-dev aarch64_mx8mm 4.4.5-r0 oe-repo 11 k
imx-kobs-dbg aarch64 5.5+git0+02c01d4a3d-r0
oe-repo 181 k
imx-kobs-dev aarch64 5.5+git0+02c01d4a3d-r0
oe-repo 5.8 k
imx-parser-dbg aarch64 4.4.5-r0 oe-repo 5.7 k
imx-parser-dev aarch64 4.4.5-r0 oe-repo 19 k
imx-test-dbg aarch64_mx8mm 1:7.0+0+d32727a9d7-r0
oe-repo 5.8 k
imx-test-dev aarch64_mx8mm 1:7.0+0+d32727a9d7-r0
oe-repo 5.9 k
imx-vpu-hantro-dbg aarch64_mx8mm 1.11.0-r0 oe-repo 1.1 M
imx-vpu-hantro-dev aarch64_mx8mm 1.11.0-r0 oe-repo 140 k
initscripts-dbg imx8mmevk 1.0-r155 oe-repo 6.0 k
initscripts-dev imx8mmevk 1.0-r155 oe-repo 6.1 k
iozone3-dbg aarch64 465-r0 oe-repo 19 k
iozone3-dev aarch64 465-r0 oe-repo 5.8 k
iperf3-dbg aarch64 3.2-r0 oe-repo 173 k
iperf3-dev aarch64 3.2-r0 oe-repo 11 k
iproute2-dbg aarch64 4.14.1-r0 oe-repo 1.3 M
iproute2-dev aarch64 4.14.1-r0 oe-repo 151 k
iptables-dbg aarch64 1.6.2-r0 oe-repo 762 k
iptables-dev aarch64 1.6.2-r0 oe-repo 16 k
iputils-dbg aarch64 s20161105-r0
oe-repo 141 k
iputils-dev aarch64 s20161105-r0
oe-repo 6.1 k
iw-dbg aarch64 4.14-r0 oe-repo 245 k
iw-dev aarch64 4.14-r0 oe-repo 6.0 k
kbd-dbg aarch64 2.0.4-r0 oe-repo 349 k
kbd-dev aarch64 2.0.4-r0 oe-repo 5.9 k
kexec-tools-dbg aarch64 2.0.16-r1 oe-repo 237 k
kexec-tools-dev aarch64 2.0.16-r1 oe-repo 5.9 k
kmod-dbg aarch64 25+git0+aca4eca103-r0
oe-repo 269 k
kmod-dev aarch64 25+git0+aca4eca103-r0
oe-repo 9.7 k
kmscube-dbg aarch64_mx8mm git-r0 oe-repo 143 k
kmscube-dev aarch64_mx8mm git-r0 oe-repo 6.0 k
less-dbg aarch64 529-r0 oe-repo 268 k
less-dev aarch64 529-r0 oe-repo 6.0 k
libaio-dbg aarch64 0.3.110-r0 oe-repo 17 k
libaio-dev aarch64 0.3.110-r0 oe-repo 8.9 k
libasound-dbg aarch64_mx8mm 1.1.5-r0 oe-repo 1.2 M
libasound-dev aarch64_mx8mm 1.1.5-r0 oe-repo 74 k
libassimp-dbg aarch64 4.1.0-r0 oe-repo 20 M
libassimp-dev aarch64 4.1.0-r0 oe-repo 101 k
libatk-1.0-dbg aarch64 2.26.1-r0 oe-repo 208 k
libatk-1.0-dev aarch64 2.26.1-r0 oe-repo 87 k
libcairo-dbg aarch64_mx8mm 1.14.12-r0 oe-repo 2.2 M
libcairo-dev aarch64_mx8mm 1.14.12-r0 oe-repo 40 k
libcap-dbg aarch64 2.25-r0 oe-repo 70 k
libcap-dev aarch64 2.25-r0 oe-repo 8.3 k
libclc-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 61 k
libclutter-1.0-dbg aarch64_mx8mm 1.26.2-r0 oe-repo 2.1 M
libclutter-1.0-dev aarch64_mx8mm 1.26.2-r0 oe-repo 327 k
libcroco-dbg aarch64 0.6.12-r0 oe-repo 309 k
libcroco-dev aarch64 0.6.12-r0 oe-repo 28 k
libdaemon-dbg aarch64 0.14-r0 oe-repo 38 k
libdaemon-dev aarch64 0.14-r0 oe-repo 12 k
libdbus-glib-1-dbg aarch64 0.108-r0 oe-repo 300 k
libdbus-glib-1-dev aarch64 0.108-r0 oe-repo 37 k
libdrm-dbg aarch64_mx8mm 2.4.91.imx-r0
oe-repo 508 k
libdrm-dev aarch64_mx8mm 2.4.91.imx-r0
oe-repo 114 k
libegl-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 24 k
libepoxy-dbg aarch64_mx8mm 1.5.0-r0 oe-repo 942 k
libepoxy-dev aarch64_mx8mm 1.5.0-r0 oe-repo 123 k
libevdev-dbg aarch64 1.5.8-r0 oe-repo 111 k
libevdev-dev aarch64 1.5.8-r0 oe-repo 25 k
libevent-dbg aarch64 2.1.8-r0 oe-repo 1.0 M
libevent-dev aarch64 2.1.8-r0 oe-repo 79 k
libexpat-dbg aarch64 2.2.5-r0 oe-repo 198 k
libexpat-dev aarch64 2.2.5-r0 oe-repo 20 k
libffi-dbg aarch64 3.2.1-r0 oe-repo 106 k
libffi-dev aarch64 3.2.1-r0 oe-repo 12 k
libfontconfig-dbg aarch64 2.12.6-r0 oe-repo 393 k
libfontconfig-dev aarch64 2.12.6-r0 oe-repo 15 k
libfontenc-dbg aarch64 1:1.1.3-r0 oe-repo 35 k
libfontenc-dev aarch64 1:1.1.3-r0 oe-repo 9.4 k
libfreetype-dbg aarch64 2.9-r0 oe-repo 1.4 M
libfreetype-dev aarch64 2.9-r0 oe-repo 154 k
libfslvpuwrap-dbg aarch64_mx8mm 4.4.5-r0 oe-repo 73 k
libfslvpuwrap-dev aarch64_mx8mm 4.4.5-r0 oe-repo 15 k
libg2d-dbg aarch64_mx8mm 6.2.4.p4.0-r0
oe-repo 76 k
libg2d-dev aarch64_mx8mm 6.2.4.p4.0-r0
oe-repo 9.4 k
libgal-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 83 k
libgbm-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 10 k
libgcc-s-dbg aarch64 7.3.0-r0 oe-repo 115 k
libgcrypt-dbg aarch64 1.8.2-r0 oe-repo 1.0 M
libgcrypt-dev aarch64 1.8.2-r0 oe-repo 30 k
libgdbm-dbg aarch64 1.14.1-r0 oe-repo 247 k
libgdbm-dev aarch64 1.14.1-r0 oe-repo 11 k
libgdk-pixbuf-2.0-dbg aarch64 2.36.11-r0 oe-repo 609 k
libgdk-pixbuf-2.0-dev aarch64 2.36.11-r0 oe-repo 49 k
libglapi-dev aarch64_mx8mm 2:17.3.8-r0 oe-repo 6.9 k
libgles-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 23 k
libgles2-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 38 k
libglew-dbg aarch64_mx8mm 2.1.0-r0 oe-repo 568 k
libglew-dev aarch64_mx8mm 2.1.0-r0 oe-repo 136 k
libglib-2.0-dbg aarch64 1:2.54.3-r0 oe-repo 7.2 M
libglib-2.0-dev aarch64 1:2.54.3-r0 oe-repo 299 k
libglu-dbg aarch64_mx8mm 2:9.0.0-0 oe-repo 710 k
libglu-dev aarch64_mx8mm 2:9.0.0-0 oe-repo 11 k
libglut-dbg aarch64_mx8mm 3.0.0-r0 oe-repo 275 k
libglut-dev aarch64_mx8mm 3.0.0-r0 oe-repo 15 k
libgmp-dbg aarch64 6.1.2-r0 oe-repo 860 k
libgmp-dev aarch64 6.1.2-r0 oe-repo 33 k
libgnutls-dbg aarch64 3.6.1-r0 oe-repo 2.7 M
libgnutls-dev aarch64 3.6.1-r0 oe-repo 107 k
libgpg-error-dbg aarch64 1.27-r0 oe-repo 164 k
libgpg-error-dev aarch64 1.27-r0 oe-repo 27 k
libgpuperfcnt-dbg aarch64_mx8mm 6.2.4.p4.0-r0
oe-repo 55 k
libgpuperfcnt-dev aarch64_mx8mm 6.2.4.p4.0-r0
oe-repo 13 k
libgudev-1.0-dbg aarch64 232-r0 oe-repo 49 k
libgudev-1.0-dev aarch64 232-r0 oe-repo 16 k
libharfbuzz-dbg aarch64_mx8mm 1.7.5-r0 oe-repo 1.4 M
libharfbuzz-dev aarch64_mx8mm 1.7.5-r0 oe-repo 27 k
libical-dbg aarch64 2.0.0-r0 oe-repo 668 k
libical-dev aarch64 2.0.0-r0 oe-repo 61 k
libice-dbg aarch64 1:1.0.9-r0 oe-repo 116 k
libice-dev aarch64 1:1.0.9-r0 oe-repo 14 k
libinput-dbg aarch64 1.9.4-r0 oe-repo 433 k
libinput-dev aarch64 1.9.4-r0 oe-repo 32 k
libjpeg-dbg aarch64 1:1.5.3-r0 oe-repo 635 k
libjpeg-dev aarch64 1:1.5.3-r0 oe-repo 38 k
libjson-c-dbg aarch64 0.13-r0 oe-repo 94 k
libjson-c-dev aarch64 0.13-r0 oe-repo 28 k
libjson-glib-1.0-dbg aarch64 1.4.2-r0 oe-repo 219 k
libjson-glib-1.0-dev aarch64 1.4.2-r0 oe-repo 35 k
liblzo2-dbg aarch64 2.10-r0 oe-repo 225 k
liblzo2-dev aarch64 2.10-r0 oe-repo 28 k
libmnl-dbg aarch64 1.0.4-r0 oe-repo 36 k
libmnl-dev aarch64 1.0.4-r0 oe-repo 9.0 k
libnfsidmap-dbg aarch64 0.25-r0 oe-repo 50 k
libnfsidmap-dev aarch64 0.25-r0 oe-repo 8.3 k
libnl-3-dbg aarch64 1:3.4.0-r0 oe-repo 1.1 M
libnl-3-dev aarch64 1:3.4.0-r0 oe-repo 61 k
libnss-mdns-dbg aarch64 0.10-r7 oe-repo 37 k
libnss-mdns-dev aarch64 0.10-r7 oe-repo 6.0 k
libogg-dbg aarch64 1.3.3-r0 oe-repo 40 k
libogg-dev aarch64 1.3.3-r0 oe-repo 12 k
libopenvg-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 17 k
libpam-dbg aarch64 1.3.0-r5 oe-repo 562 k
libpam-dev aarch64 1.3.0-r5 oe-repo 19 k
libpcap-dbg aarch64 1.8.1-r0 oe-repo 403 k
libpcap-dev aarch64 1.8.1-r0 oe-repo 34 k
libpciaccess-dbg aarch64 0.14-r0 oe-repo 61 k
libpciaccess-dev aarch64 0.14-r0 oe-repo 11 k
libpcre-dbg aarch64 8.41-r0 oe-repo 577 k
libpcre-dev aarch64 8.41-r0 oe-repo 26 k
libpixman-1-dbg aarch64 1:0.34.0-r0 oe-repo 502 k
libpixman-1-dev aarch64 1:0.34.0-r0 oe-repo 16 k
libpng16-dbg aarch64 1.6.34-r0 oe-repo 447 k
libpng16-dev aarch64 1.6.34-r0 oe-repo 49 k
libpopt-dbg aarch64 1.16-r3 oe-repo 81 k
libpopt-dev aarch64 1.16-r3 oe-repo 12 k
libreadline-dbg aarch64 7.0-r0 oe-repo 356 k
libreadline-dev aarch64 7.0-r0 oe-repo 23 k
librsvg-2-dbg aarch64_mx8mm 2.40.20-r0 oe-repo 375 k
librsvg-2-dev aarch64_mx8mm 2.40.20-r0 oe-repo 15 k
libsamplerate0-dbg aarch64 0.1.9-r1 oe-repo 2.9 M
libsamplerate0-dev aarch64 0.1.9-r1 oe-repo 8.9 k
libsbc-dbg aarch64 1.3-r0 oe-repo 86 k
libsbc-dev aarch64 1.3-r0 oe-repo 8.3 k
libsm-dbg aarch64 1:1.2.2-r0 oe-repo 51 k
libsm-dev aarch64 1:1.2.2-r0 oe-repo 11 k
libsndfile-dbg aarch64 1.0.28-r0 oe-repo 687 k
libsndfile-dev aarch64 1.0.28-r0 oe-repo 18 k
libsoup-2.4-dbg aarch64 2.60.3-r0 oe-repo 749 k
libsoup-2.4-dev aarch64 2.60.3-r0 oe-repo 115 k
libspeex-dbg aarch64 1.2.0-r0 oe-repo 150 k
libspeex-dev aarch64 1.2.0-r0 oe-repo 17 k
libspeexdsp-dbg aarch64 1.2rc3-r0 oe-repo 109 k
libspeexdsp-dev aarch64 1.2rc3-r0 oe-repo 16 k
libsqlite3-dev aarch64 3:3.22.0-r0 oe-repo 118 k
libtag-dbg aarch64 1.11.1-r0 oe-repo 1.6 M
libtag-dev aarch64 1.11.1-r0 oe-repo 87 k
libtheora-dbg aarch64 1.1.1-r1 oe-repo 382 k
libtheora-dev aarch64 1.1.1-r1 oe-repo 30 k
libtiff-dbg aarch64 4.0.9-r0 oe-repo 826 k
libtiff-dev aarch64 4.0.9-r0 oe-repo 25 k
libtirpc-dbg aarch64 1.0.2-r0 oe-repo 323 k
libtirpc-dev aarch64 1.0.2-r0 oe-repo 40 k
libtool-dbg aarch64 2.4.6-r0 oe-repo 65 k
libtool-dev aarch64 2.4.6-r0 oe-repo 12 k
libts-dbg aarch64 1.15-r0 oe-repo 169 k
libts-dev aarch64 1.15-r0 oe-repo 9.1 k
libunistring-dbg aarch64 0.9.9-r0 oe-repo 846 k
libunistring-dev aarch64 0.9.9-r0 oe-repo 31 k
libunwind-dbg aarch64 1.2.1-r0 oe-repo 283 k
libunwind-dev aarch64 1.2.1-r0 oe-repo 18 k
liburcu-dbg aarch64 0.10.1-r0 oe-repo 225 k
liburcu-dev aarch64 0.10.1-r0 oe-repo 47 k
libusb-1.0-dbg aarch64 1.0.21-r0 oe-repo 182 k
libusb-1.0-dev aarch64 1.0.21-r0 oe-repo 22 k
libuser-dbg aarch64 0.62-r0 oe-repo 316 k
libuser-dev aarch64 0.62-r0 oe-repo 16 k
libv4l-dev aarch64_mx8mm 1.12.3-r0 oe-repo 72 k
libvdk-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 10 k
libvorbis-dbg aarch64 1.3.5-r1 oe-repo 388 k
libvorbis-dev aarch64 1.3.5-r1 oe-repo 17 k
libwebp-dbg aarch64 0.6.1-r0 oe-repo 1.0 M
libwebp-dev aarch64 0.6.1-r0 oe-repo 30 k
libwrap-dev aarch64 7.6-r10 oe-repo 9.6 k
libx11-dbg aarch64 1:1.6.5-r0 oe-repo 1.7 M
libx11-dev aarch64 1:1.6.5-r0 oe-repo 48 k
libxau-dbg aarch64 1:1.0.8-r0 oe-repo 27 k
libxau-dev aarch64 1:1.0.8-r0 oe-repo 8.8 k
libxaw-dbg aarch64 1:1.0.13-r2 oe-repo 770 k
libxaw-dev aarch64 1:1.0.13-r2 oe-repo 49 k
libxcb-dbg aarch64 1.12-r0 oe-repo 219 k
libxcb-dev aarch64 1.12-r0 oe-repo 151 k
libxcomposite-dbg aarch64 1:0.4.4-r0 oe-repo 27 k
libxcomposite-dev aarch64 1:0.4.4-r0 oe-repo 9.4 k
libxcursor-dbg aarch64 1:1.1.15-r0 oe-repo 74 k
libxcursor-dev aarch64 1:1.1.15-r0 oe-repo 11 k
libxdamage-dbg aarch64 1:1.1.4-r0 oe-repo 28 k
libxdamage-dev aarch64 1:1.1.4-r0 oe-repo 9.0 k
libxdmcp-dbg aarch64 1:1.1.2-r0 oe-repo 30 k
libxdmcp-dev aarch64 1:1.1.2-r0 oe-repo 9.4 k
libxext-dbg aarch64 1:1.3.3-r0 oe-repo 146 k
libxext-dev aarch64 1:1.3.3-r0 oe-repo 19 k
libxfixes-dbg aarch64 1:5.0.3-r0 oe-repo 44 k
libxfixes-dev aarch64 1:5.0.3-r0 oe-repo 9.9 k
libxfont2-dbg aarch64 2.0.3-r0 oe-repo 349 k
libxfont2-dev aarch64 2.0.3-r0 oe-repo 9.4 k
libxft-dbg aarch64 1:2.3.2-r0 oe-repo 156 k
libxft-dev aarch64 1:2.3.2-r0 oe-repo 12 k
libxi-dbg aarch64 1:1.7.9-r0 oe-repo 179 k
libxi-dev aarch64 1:1.7.9-r0 oe-repo 16 k
libxinerama-dbg aarch64 1:1.1.3-r0 oe-repo 26 k
libxinerama-dev aarch64 1:1.1.3-r0 oe-repo 9.3 k
libxkbcommon-dbg aarch64 0.8.0-r0 oe-repo 366 k
libxkbcommon-dev aarch64 0.8.0-r0 oe-repo 52 k
libxkbfile-dbg aarch64 1:1.0.9-r0 oe-repo 165 k
libxkbfile-dev aarch64 1:1.0.9-r0 oe-repo 14 k
libxml2-dbg aarch64 2.9.7-r0 oe-repo 3.9 M
libxml2-dev aarch64 2.9.7-r0 oe-repo 80 k
libxmu-dbg aarch64 1:1.1.2-r0 oe-repo 199 k
libxmu-dev aarch64 1:1.1.2-r0 oe-repo 21 k
libxpm-dbg aarch64 1:3.5.12-r0 oe-repo 151 k
libxpm-dev aarch64 1:3.5.12-r0 oe-repo 11 k
libxrandr-dbg aarch64 1:1.5.1-r0 oe-repo 71 k
libxrandr-dev aarch64 1:1.5.1-r0 oe-repo 11 k
libxrender-dbg aarch64 1:0.9.10-r0 oe-repo 79 k
libxrender-dev aarch64 1:0.9.10-r0 oe-repo 11 k
libxres-dbg aarch64 1:1.2.0-r0 oe-repo 27 k
libxres-dev aarch64 1:1.2.0-r0 oe-repo 8.3 k
libxshmfence-dbg aarch64 1.2-r0 oe-repo 14 k
libxshmfence-dev aarch64 1.2-r0 oe-repo 8.1 k
libxt-dbg aarch64 1:1.1.5-r0 oe-repo 570 k
libxt-dev aarch64 1:1.1.5-r0 oe-repo 44 k
libxtst-dbg aarch64 1:1.2.3-r0 oe-repo 49 k
libxtst-dev aarch64 1:1.2.3-r0 oe-repo 9.7 k
libxv-dbg aarch64 1.0.11-r0 oe-repo 39 k
libxv-dev aarch64 1.0.11-r0 oe-repo 9.8 k
libxxf86vm-dbg aarch64 1:1.1.4-r0 oe-repo 36 k
libxxf86vm-dev aarch64 1:1.1.4-r0 oe-repo 9.6 k
libz-dbg aarch64 1.2.11-r0 oe-repo 213 k
libz-dev aarch64 1.2.11-r0 oe-repo 33 k
linux-firmware-dbg noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 7.2 k
linux-firmware-dev noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 12 k
linuxptp-dbg aarch64 1.8-r0 oe-repo 293 k
linuxptp-dev aarch64 1.8-r0 oe-repo 5.8 k
lmbench-dbg aarch64 3.0+a9-r2 oe-repo 616 k
lmbench-dev aarch64 3.0+a9-r2 oe-repo 11 k
logrotate-dbg aarch64 3.13.0-r0 oe-repo 79 k
logrotate-dev aarch64 3.13.0-r0 oe-repo 5.9 k
lrzsz-dbg aarch64 0.12.20-r6 oe-repo 130 k
lrzsz-dev aarch64 0.12.20-r6 oe-repo 6.2 k
ltp-dbg aarch64 20180118-r0 oe-repo 35 M
ltp-dev aarch64 20180118-r0 oe-repo 6.5 k
lttng-modules-dbg imx8mmevk 2.10.6-r0 oe-repo 5.7 k
lttng-modules-dev imx8mmevk 2.10.6-r0 oe-repo 6.5 k
lttng-tools-dbg aarch64 2.9.5-r0 oe-repo 2.1 M
lttng-tools-dev aarch64 2.9.5-r0 oe-repo 21 k
lttng-ust-dbg aarch64 2:2.10.1-r0 oe-repo 830 k
lttng-ust-dev aarch64 2:2.10.1-r0 oe-repo 41 k
m4-dbg aarch64 1.4.18-r0 oe-repo 481 k
m4-dev aarch64 1.4.18-r0 oe-repo 6.1 k
make-dbg aarch64 4.2.1-r0 oe-repo 359 k
make-dev aarch64 4.2.1-r0 oe-repo 8.1 k
makedevs-dbg aarch64 1.0.1-r0 oe-repo 24 k
makedevs-dev aarch64 1.0.1-r0 oe-repo 5.8 k
mc-dbg aarch64 4.8.20-r0 oe-repo 1.6 M
mc-dev aarch64 4.8.20-r0 oe-repo 6.0 k
memtester-dbg aarch64 4.3.0-r0 oe-repo 29 k
memtester-dev aarch64 4.3.0-r0 oe-repo 5.9 k
mesa-dbg aarch64_mx8mm 2:17.3.8-r0 oe-repo 6.5 M
mesa-demos-dbg aarch64_mx8mm 8.3.0-r0 oe-repo 3.3 M
mesa-demos-dev aarch64_mx8mm 8.3.0-r0 oe-repo 6.1 k
minicom-dbg aarch64 2.7.1-r0 oe-repo 245 k
minicom-dev aarch64 2.7.1-r0 oe-repo 6.0 k
mktemp-dbg aarch64 1.7-r3 oe-repo 20 k
mktemp-dev aarch64 1.7-r3 oe-repo 5.9 k
mmc-utils-dbg aarch64 0.1-r0 oe-repo 103 k
mmc-utils-dev aarch64 0.1-r0 oe-repo 5.8 k
aarch64 1:20170310-r0
oe-repo 5.9 k
oe-repo 6.9 k
mtd-utils-dbg aarch64 2.0.1+0+9c6173559f-r0
oe-repo 1.0 M
mtd-utils-dev aarch64 2.0.1+0+9c6173559f-r0
oe-repo 6.1 k
mtdev-dbg aarch64 1.1.5-r0 oe-repo 45 k
mtdev-dev aarch64 1.1.5-r0 oe-repo 11 k
nano-dbg aarch64 2.9.3-r0 oe-repo 527 k
nano-dev aarch64 2.9.3-r0 oe-repo 6.0 k
nbench-byte-dbg aarch64 2.2.3-r0 oe-repo 102 k
nbench-byte-dev aarch64 2.2.3-r0 oe-repo 5.9 k
ncurses-dbg aarch64 6.0+20171125-r0
oe-repo 1.0 M
ncurses-dev aarch64 6.0+20171125-r0
oe-repo 67 k
neard-dbg aarch64 0.16-r0 oe-repo 433 k
neard-dev aarch64 0.16-r0 oe-repo 16 k
net-tools-dbg aarch64 1.60+26-r0 oe-repo 267 k
net-tools-dev aarch64 1.60+26-r0 oe-repo 5.9 k
netbase-dbg aarch64 1:5.4-r0 oe-repo 5.8 k
netbase-dev aarch64 1:5.4-r0 oe-repo 5.8 k
nettle-dbg aarch64 3.4-r0 oe-repo 2.2 M
nettle-dev aarch64 3.4-r0 oe-repo 48 k
nfs-utils-dbg aarch64 2.1.1-r0 oe-repo 553 k
nfs-utils-dev aarch64 2.1.1-r0 oe-repo 6.3 k
ntp-dbg aarch64 4.2.8p11-r0 oe-repo 2.3 M
ntp-dev aarch64 4.2.8p11-r0 oe-repo 6.2 k
numactl-dbg aarch64 2.0.11+git0+ea3a70681c-r0
oe-repo 168 k
numactl-dev aarch64 2.0.11+git0+ea3a70681c-r0
oe-repo 11 k
ofono-dbg aarch64 1.22-r0 oe-repo 2.1 M
ofono-dev aarch64 1.22-r0 oe-repo 28 k
openssl-dbg aarch64 1.0.2p-r0 oe-repo 3.9 M
openssl-dev aarch64 1.0.2p-r0 oe-repo 230 k
opkg-utils-dbg aarch64 0.3.6-r0 oe-repo 5.8 k
optee-client-imx-dbg aarch64 git-r0 oe-repo 16 k
optee-client-imx-dev aarch64 git-r0 oe-repo 14 k
optee-os-imx-dbg imx8mmevk git-r0 oe-repo 12 k
optee-os-imx-dev imx8mmevk git-r0 oe-repo 936 k
optee-test-imx-dbg aarch64 git-r0 oe-repo 1.1 M
optee-test-imx-dev aarch64 git-r0 oe-repo 5.9 k
orc-dbg aarch64 0.4.28-r0 oe-repo 430 k
orc-dev aarch64 0.4.28-r0 oe-repo 32 k
os-release-dbg noarch 1.0-r0 oe-repo 5.7 k
os-release-dev noarch 1.0-r0 oe-repo 5.7 k
packagegroup-base-3g-dbg imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-3g-dev imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-alsa-dbg imx8mmevk 1.0-r83 oe-repo 5.8 k
packagegroup-base-alsa-dev imx8mmevk 1.0-r83 oe-repo 5.8 k
packagegroup-base-dbg imx8mmevk 1.0-r83 oe-repo 6.2 k
packagegroup-base-dev imx8mmevk 1.0-r83 oe-repo 6.2 k
packagegroup-base-ipv6-dbg imx8mmevk 1.0-r83 oe-repo 5.6 k
packagegroup-base-ipv6-dev imx8mmevk 1.0-r83 oe-repo 5.6 k
packagegroup-base-nfc-dbg imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-nfc-dev imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-nfs-dbg imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-nfs-dev imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-pci-dbg imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-pci-dev imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-wifi-dbg imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-base-wifi-dev imx8mmevk 1.0-r83 oe-repo 5.7 k
packagegroup-core-boot-dbg imx8mmevk 1.0-r17 oe-repo 5.9 k
packagegroup-core-boot-dev imx8mmevk 1.0-r17 oe-repo 5.9 k
noarch 1.0-r6 oe-repo 6.4 k
noarch 1.0-r6 oe-repo 6.5 k
noarch 1.0-r6 oe-repo 6.1 k
noarch 1.0-r6 oe-repo 6.0 k
noarch 1.0-r6 oe-repo 6.2 k
noarch 1.0-r2 oe-repo 5.6 k
noarch 1.0-r1 oe-repo 5.7 k
noarch 1.0-r1 oe-repo 5.8 k
noarch 1.0-r8 oe-repo 6.0 k
noarch 1.0-r8 oe-repo 6.1 k
noarch 1.0-r3 oe-repo 5.8 k
imx8mmevk 1.0-r3 oe-repo 5.8 k
imx8mmevk 1.0-r3 oe-repo 5.9 k
imx8mmevk 1.0-r2 oe-repo 6.1 k
imx8mmevk 1.0-r2 oe-repo 6.2 k
imx8mmevk 1.0-r0 oe-repo 6.1 k
imx8mmevk 1.0-r0 oe-repo 6.4 k
imx8mmevk 1.0-r0 oe-repo 6.0 k
imx8mmevk 1.0-r0 oe-repo 6.2 k
noarch 1.0-r0 oe-repo 6.1 k
noarch 1.0-r0 oe-repo 6.2 k
imx8mmevk 1.0-r0 oe-repo 5.9 k
noarch 1.0-r0 oe-repo 5.8 k
noarch 1.0-r0 oe-repo 5.9 k
imx8mmevk 1.0-r0 oe-repo 6.7 k
imx8mmevk 1.0-r0 oe-repo 6.8 k
imx8mmevk 1.0-r0 oe-repo 5.8 k
pango-dbg aarch64_mx8mm 1.40.14-r0 oe-repo 776 k
pango-dev aarch64_mx8mm 1.40.14-r0 oe-repo 111 k
patch-dbg aarch64 2.7.6-r0 oe-repo 364 k
patch-dev aarch64 2.7.6-r0 oe-repo 6.0 k
pciutils-dbg aarch64 3.5.6-r0 oe-repo 157 k
pciutils-dev aarch64 3.5.6-r0 oe-repo 26 k
perf-dbg imx8mmevk 4.14.98-r9 oe-repo 6.1 k
perf-dev imx8mmevk 4.14.98-r9 oe-repo 6.3 k
perl-dbg aarch64 5.24.1-r0 oe-repo 8.9 M
perl-dev aarch64 5.24.1-r0 oe-repo 388 k
pointercal-dbg imx8mmevk 0.0-r11 oe-repo 5.6 k
pointercal-dev imx8mmevk 0.0-r11 oe-repo 5.7 k
powertop-dbg aarch64 2.9-r0 oe-repo 1.5 M
powertop-dev aarch64 2.9-r0 oe-repo 6.0 k
procps-dbg aarch64 3.3.12-r0 oe-repo 508 k
procps-dev aarch64 3.3.12-r0 oe-repo 18 k
psmisc-dbg aarch64 23.0-r0 oe-repo 112 k
psmisc-dev aarch64 23.0-r0 oe-repo 6.3 k
psplash-dbg aarch64 0.1+git0+2015f7073e-r15
oe-repo 40 k
psplash-dev aarch64 0.1+git0+2015f7073e-r15
oe-repo 6.3 k
ptpd-dbg aarch64 2.3.1-r0 oe-repo 416 k
ptpd-dev aarch64 2.3.1-r0 oe-repo 6.1 k
pulseaudio-dbg aarch64_mx8mm 11.1-r0 oe-repo 3.4 M
pulseaudio-dev aarch64_mx8mm 11.1-r0 oe-repo 77 k
python-dbg aarch64 2.7.15-r1 oe-repo 4.4 M
python-dev aarch64 2.7.15-r1 oe-repo 113 k
python-pip-dbg aarch64 9.0.3-r0 oe-repo 5.8 k
python-pip-dev aarch64 9.0.3-r0 oe-repo 5.9 k
python-setuptools-dbg aarch64 39.0.0-r0 oe-repo 5.8 k
python-setuptools-dev aarch64 39.0.0-r0 oe-repo 6.3 k
python3-dbg aarch64 3.5.5-r1.0 oe-repo 5.1 M
python3-dbus-dbg aarch64 1.2.6-r0 oe-repo 167 k
python3-dbus-dev aarch64 1.2.6-r0 oe-repo 9.0 k
python3-dev aarch64 3.5.5-r1.0 oe-repo 147 k
python3-pycairo-dbg aarch64_mx8mm 1.15.6-r0 oe-repo 135 k
python3-pycairo-dev aarch64_mx8mm 1.15.6-r0 oe-repo 9.3 k
python3-pygobject-dbg aarch64_mx8mm 3.28.1-r0 oe-repo 427 k
python3-pygobject-dev aarch64_mx8mm 3.28.1-r0 oe-repo 13 k
python3-setuptools-dbg aarch64 39.0.0-r0 oe-repo 5.8 k
python3-setuptools-dev aarch64 39.0.0-r0 oe-repo 6.3 k
qca-tools-dbg aarch64 2.0.3-r0 oe-repo 108 k
qca-tools-dev aarch64 2.0.3-r0 oe-repo 5.9 k
rgb-dbg aarch64 1:1.0.6-r0 oe-repo 15 k
rgb-dev aarch64 1:1.0.6-r0 oe-repo 6.0 k
rpcbind-dbg aarch64 0.2.4-r0 oe-repo 117 k
rpcbind-dev aarch64 0.2.4-r0 oe-repo 6.1 k
run-postinsts-dbg noarch 1.0-r10 oe-repo 5.7 k
run-postinsts-dev noarch 1.0-r10 oe-repo 5.7 k
sed-dbg aarch64 4.2.2-r0 oe-repo 542 k
sed-dev aarch64 4.2.2-r0 oe-repo 5.9 k
shadow-dbg aarch64 4.2.1-r0 oe-repo 709 k
shadow-dev aarch64 4.2.1-r0 oe-repo 6.4 k
shadow-securetty-dbg imx8mmevk 4.2.1-r3 oe-repo 5.7 k
shadow-securetty-dev imx8mmevk 4.2.1-r3 oe-repo 5.7 k
shared-mime-info-dbg aarch64 1.9-r0 oe-repo 71 k
shared-mime-info-dev aarch64 1.9-r0 oe-repo 6.8 k
sigma-dut-dbg aarch64 git-r0 oe-repo 368 k
sigma-dut-dev aarch64 git-r0 oe-repo 5.8 k
slang-dbg aarch64 2.3.2-r0 oe-repo 1.5 M
slang-dev aarch64 2.3.2-r0 oe-repo 29 k
sqlite3-dbg aarch64 3:3.22.0-r0 oe-repo 2.3 M
strace-dbg aarch64 4.20-r0 oe-repo 2.1 M
strace-dev aarch64 4.20-r0 oe-repo 5.9 k
sudo-dbg aarch64 1.8.22-r0 oe-repo 757 k
sudo-dev aarch64 1.8.22-r0 oe-repo 9.4 k
sysklogd-dbg aarch64 1.5.1-r0 oe-repo 91 k
sysklogd-dev aarch64 1.5.1-r0 oe-repo 5.9 k
systemd-compat-units-dbg aarch64 1.0-r29 oe-repo 5.8 k
systemd-compat-units-dev aarch64 1.0-r29 oe-repo 5.9 k
systemd-dbg aarch64 1:237-r0 oe-repo 11 M
systemd-dev aarch64 1:237-r0 oe-repo 28 k
systemd-gpuconfig-dbg aarch64 1.0-r0 oe-repo 5.7 k
systemd-gpuconfig-dev aarch64 1.0-r0 oe-repo 5.9 k
systemd-serialgetty-dbg imx8mmevk 1.0-r5 oe-repo 5.7 k
systemd-serialgetty-dev imx8mmevk 1.0-r5 oe-repo 5.8 k
systemtap-dbg aarch64 3.2-r0 oe-repo 8.1 M
systemtap-dev aarch64 3.2-r0 oe-repo 12 k
tar-dbg aarch64 1.30-r0 oe-repo 929 k
tar-dev aarch64 1.30-r0 oe-repo 5.9 k
sdk_provides_dummy_target 1.0-r0 oe-repo 5.8 k
sdk_provides_dummy_target 1.0-r0 oe-repo 5.9 k
tcl-dbg aarch64 8.6.8-r0 oe-repo 2.7 M
tcl-dev aarch64 8.6.8-r0 oe-repo 152 k
tcp-wrappers-dbg aarch64 7.6-r10 oe-repo 110 k
time-dbg aarch64 1.8-r0 oe-repo 58 k
time-dev aarch64 1.8-r0 oe-repo 5.9 k
tinycompress-dbg aarch64 1.1.6-r0 oe-repo 53 k
tinycompress-dev aarch64 1.1.6-r0 oe-repo 9.7 k
tiobench-dbg aarch64 0.3.3-r1 oe-repo 12 k
tiobench-dev aarch64 0.3.3-r1 oe-repo 5.9 k
tk-dbg aarch64 8.6.8-r0 oe-repo 2.2 M
tk-dev aarch64 8.6.8-r0 oe-repo 32 k
trace-cmd-dbg aarch64 2.7-r0 oe-repo 496 k
trace-cmd-dev aarch64 2.7-r0 oe-repo 5.8 k
udev-extraconf-dbg aarch64 1.1-r0 oe-repo 5.8 k
udev-extraconf-dev aarch64 1.1-r0 oe-repo 5.9 k
udev-rules-imx-dbg aarch64 1.0-r0 oe-repo 5.7 k
udev-rules-imx-dev aarch64 1.0-r0 oe-repo 5.7 k
unzip-dbg aarch64 1:6.0-r5 oe-repo 387 k
unzip-dev aarch64 1:6.0-r5 oe-repo 5.9 k
update-rc.d-dbg noarch 0.7-r5 oe-repo 5.8 k
update-rc.d-dev noarch 0.7-r5 oe-repo 5.8 k
usbutils-dbg aarch64 009-r0 oe-repo 130 k
usbutils-dev aarch64 009-r0 oe-repo 6.8 k
util-linux-dbg aarch64 2.32.1-r0 oe-repo 6.0 M
util-linux-dev aarch64 2.32.1-r0 oe-repo 26 k
v4l-utils-dbg aarch64_mx8mm 1.12.3-r0 oe-repo 2.2 M
v4l-utils-dev aarch64_mx8mm 1.12.3-r0 oe-repo 6.6 k
valgrind-dbg aarch64 3.13.0-r0 oe-repo 17 M
valgrind-dev aarch64 3.13.0-r0 oe-repo 272 k
vlan-dbg aarch64 1.9-r0 oe-repo 16 k
vlan-dev aarch64 1.9-r0 oe-repo 5.8 k
volatile-binds-dbg noarch 1.0-r0 oe-repo 5.7 k
volatile-binds-dev noarch 1.0-r0 oe-repo 5.7 k
wayland-dbg aarch64 1.16.0-r0 oe-repo 230 k
wayland-dev aarch64 1.16.0-r0 oe-repo 82 k
weston-dbg aarch64_mx8mm 5.0.0.imx-r0
oe-repo 2.4 M
weston-dev aarch64_mx8mm 5.0.0.imx-r0
oe-repo 33 k
weston-init-dbg noarch 1.0-r0 oe-repo 5.7 k
weston-init-dev noarch 1.0-r0 oe-repo 5.8 k
which-dbg aarch64 2.21-r3 oe-repo 42 k
which-dev aarch64 2.21-r3 oe-repo 6.0 k
wireless-tools-dbg aarch64 1:30.pre9-r0
oe-repo 193 k
wpa-supplicant-dbg aarch64 2.6-r0 oe-repo 2.5 M
wpa-supplicant-dev aarch64 2.6-r0 oe-repo 5.9 k
x11perf-dbg aarch64 1:1.6.0-r0 oe-repo 111 k
x11perf-dev aarch64 1:1.6.0-r0 oe-repo 6.0 k
xf86-input-libinput-dbg aarch64 2:0.26.0-r0 oe-repo 109 k
xf86-input-libinput-dev aarch64 2:0.26.0-r0 oe-repo 9.4 k
xkbcomp-dbg aarch64 1.4.0-r8.0 oe-repo 227 k
xkbcomp-dev aarch64 1.4.0-r8.0 oe-repo 7.0 k
xkeyboard-config-dbg aarch64 2.22-r0 oe-repo 6.0 k
xkeyboard-config-dev aarch64 2.22-r0 oe-repo 7.0 k
xprop-dbg aarch64 1:1.2.2-r0 oe-repo 60 k
xprop-dev aarch64 1:1.2.2-r0 oe-repo 6.1 k
xrestop-dbg aarch64 0.4-r3 oe-repo 25 k
xrestop-dev aarch64 0.4-r3 oe-repo 6.0 k
xserver-xf86-config-dbg imx8mmevk 0.1-r33 oe-repo 5.7 k
xserver-xf86-config-dev imx8mmevk 0.1-r33 oe-repo 5.8 k
xserver-xorg-dbg aarch64_mx8mm 2:1.19.6-r0 oe-repo 10 M
xserver-xorg-dev aarch64_mx8mm 2:1.19.6-r0 oe-repo 202 k
xterm-dbg aarch64 330-r0 oe-repo 779 k
xterm-dev aarch64 330-r0 oe-repo 6.1 k
xvideo-tests-dbg aarch64 0.1+git0+7d38b881e9-r0
oe-repo 29 k
xvideo-tests-dev aarch64 0.1+git0+7d38b881e9-r0
oe-repo 5.9 k
xwininfo-dbg aarch64 1.1.3-r0 oe-repo 62 k
xwininfo-dev aarch64 1.1.3-r0 oe-repo 6.0 k
xz-dbg aarch64 5.2.3-r0 oe-repo 424 k
xz-dev aarch64 5.2.3-r0 oe-repo 42 k
Installing dependencies:
alsa-plugins aarch64 1.1.5-r0 oe-repo 6.0 k
bash-completion aarch64 2.7-r0 oe-repo 27 k
binutils aarch64 2.30-r0 oe-repo 2.0 M
bison aarch64 3.0.4-r0 oe-repo 225 k
boost aarch64 1.66.0-r0 oe-repo 6.2 k
boost-log aarch64 1.66.0-r0 oe-repo 341 k
boost-math aarch64 1.66.0-r0 oe-repo 329 k
boost-serialization aarch64 1.66.0-r0 oe-repo 93 k
boost-test aarch64 1.66.0-r0 oe-repo 205 k
btrfs-tools aarch64 4.13.3-r0 oe-repo 466 k
cantarell-fonts noarch 0.0.24-r0 oe-repo 144 k
cryptodev-linux aarch64 1.9-r0 oe-repo 5.6 k
encodings noarch 1:1.0.4-r2.1
oe-repo 568 k
firmware-imx noarch 1:8.1-r0 oe-repo 5.6 k
flac aarch64 1.3.2-r0 oe-repo 121 k
flex aarch64 2.6.0-r0 oe-repo 95 k
fmt aarch64 5.3.0-r0 oe-repo 5.7 k
fmt-staticdev aarch64 5.3.0-r0 oe-repo 415 k
font-util aarch64 1.3.1-r0 oe-repo 27 k
gconf aarch64 3.2.6-r0 oe-repo 143 k
gnome-desktop-testing aarch64 2014.1-r1 oe-repo 25 k
gstreamer1.0-plugins-bad aarch64_mx8mm 1.14.4.imx-r0
oe-repo 5.8 k
gstreamer1.0-plugins-base aarch64_mx8mm 1.14.4.imx-r0
oe-repo 83 k
gstreamer1.0-plugins-good aarch64_mx8mm 1.14.4.imx-r0
oe-repo 5.8 k
gtest aarch64 1.8.1-r0 oe-repo 5.6 k
gtest-staticdev aarch64 1.8.1-r0 oe-repo 1.0 M
half aarch64 1.12.0-r0 oe-repo 5.7 k
icu aarch64 60.2-r0 oe-repo 170 k
imx-codec aarch64_mx8mm 4.4.5-r0 oe-repo 5.7 k
iso-codes noarch 3.77-r0 oe-repo 254 k
kexec-tools aarch64 2.0.16-r1 oe-repo 5.8 k
leptonica aarch64 1.74.4-r0 oe-repo 747 k
lib-flac-dec-arm-elinux2 aarch64_mx8mm 4.4.5-r0 oe-repo 82 k
libasm1 aarch64 0.170-r0 oe-repo 16 k
libasound-module-ctl-arcam-av
aarch64 1.1.5-r0 oe-repo 14 k
libasound-module-ctl-oss aarch64 1.1.5-r0 oe-repo 11 k
libasound-module-pcm-oss aarch64 1.1.5-r0 oe-repo 10 k
libasound-module-pcm-speex aarch64 1.1.5-r0 oe-repo 10 k
libasound-module-pcm-upmix aarch64 1.1.5-r0 oe-repo 10 k
libasound-module-pcm-usb-stream
libasound-module-pcm-vdownmix
aarch64 1.1.5-r0 oe-repo 9.9 k
libasound-module-rate-samplerate
aarch64 1.1.5-r0 oe-repo 9.6 k
libasound-module-rate-speexrate
aarch64 1.1.5-r0 oe-repo 9.0 k
libatomic-ops aarch64 7.6.2+git0+5ae4b4aeea-r0
oe-repo 5.7 k
libavahi-client3 aarch64 0.7-r0 oe-repo 25 k
libavahi-glib1 aarch64 0.7-r0 oe-repo 11 k
libavahi-gobject0 aarch64 0.7-r0 oe-repo 21 k
libboost-atomic1.66.0 aarch64 1.66.0-r0 oe-repo 8.1 k
libboost-chrono1.66.0 aarch64 1.66.0-r0 oe-repo 16 k
libboost-container1.66.0 aarch64 1.66.0-r0 oe-repo 42 k
libboost-date-time1.66.0 aarch64 1.66.0-r0 oe-repo 21 k
libboost-filesystem1.66.0 aarch64 1.66.0-r0 oe-repo 40 k
libboost-graph1.66.0 aarch64 1.66.0-r0 oe-repo 86 k
libboost-iostreams1.66.0 aarch64 1.66.0-r0 oe-repo 31 k
libboost-locale1.66.0 aarch64 1.66.0-r0 oe-repo 208 k
libboost-program-options1.66.0
aarch64 1.66.0-r0 oe-repo 121 k
libboost-python3-1.66.0 aarch64 1.66.0-r0 oe-repo 70 k
libboost-random1.66.0 aarch64 1.66.0-r0 oe-repo 15 k
libboost-regex1.66.0 aarch64 1.66.0-r0 oe-repo 205 k
libboost-signals1.66.0 aarch64 1.66.0-r0 oe-repo 31 k
libboost-system1.66.0 aarch64 1.66.0-r0 oe-repo 12 k
libboost-thread1.66.0 aarch64 1.66.0-r0 oe-repo 42 k
libboost-timer1.66.0 aarch64 1.66.0-r0 oe-repo 15 k
libboost-wave1.66.0 aarch64 1.66.0-r0 oe-repo 152 k
libcairo-perf-utils aarch64_mx8mm 1.14.12-r0 oe-repo 36 k
libcairo-script-interpreter2
aarch64_mx8mm 1.14.12-r0 oe-repo 42 k
libcgroup aarch64 0.41-r0 oe-repo 66 k
libcheck aarch64 0.12.0-r0 oe-repo 22 k
libcogl-gles2-20 aarch64_mx8mm 1.22.2-r0 oe-repo 12 k
libdrm-amdgpu1 aarch64_mx8mm 2.4.91.imx-r0
oe-repo 19 k
libdrm-nouveau2 aarch64_mx8mm 2.4.91.imx-r0
oe-repo 18 k
libdrm-omap1 aarch64_mx8mm 2.4.91.imx-r0
oe-repo 10 k
libdrm-radeon1 aarch64_mx8mm 2.4.91.imx-r0
oe-repo 22 k
libdrm-vivante1 aarch64_mx8mm 2.4.91.imx-r0
oe-repo 10 k
libexif12 aarch64 0.6.21-r0 oe-repo 62 k
libflac++6 aarch64 1.3.2-r0 oe-repo 27 k
libform5 aarch64 6.0+20171125-r0
oe-repo 25 k
libgif7 aarch64 5.1.4-r0 oe-repo 19 k
libgles3-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 23 k
libgmpxx4 aarch64 6.1.2-r0 oe-repo 14 k
libgnutls-openssl27 aarch64 3.6.1-r0 oe-repo 35 k
libgnutlsxx28 aarch64 3.6.1-r0 oe-repo 19 k
libgomp1 aarch64 7.3.0-r0 oe-repo 63 k
libgphoto2-6 aarch64 2.5.16-r0 oe-repo 109 k
libgphoto2-port12 aarch64 2.5.16-r0 oe-repo 19 k
libicuio60 aarch64 60.2-r0 oe-repo 27 k
libicutu60 aarch64 60.2-r0 oe-repo 76 k
libidn11 aarch64 1.33-r0 oe-repo 44 k
libmenu5 aarch64 6.0+20171125-r0
oe-repo 17 k
libnewt0.52 aarch64 0.52.20-r0 oe-repo 34 k
libnl-3-cli aarch64 1:3.4.0-r0 oe-repo 79 k
libnl-idiag-3-200 aarch64 1:3.4.0-r0 oe-repo 15 k
libnl-nf-3-200 aarch64 1:3.4.0-r0 oe-repo 28 k
libnl-route-3-200 aarch64 1:3.4.0-r0 oe-repo 116 k
libnl-xfrm-3-200 aarch64 1:3.4.0-r0 oe-repo 27 k
libopencv-aruco4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 213 k
libopencv-bgsegm4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 48 k
libopencv-bioinspired4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 56 k
libopencv-calib3d4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 455 k
libopencv-ccalib4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 113 k
libopencv-core4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 695 k
libopencv-datasets4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 120 k
libopencv-dnn-objdetect4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 20 k
libopencv-dnn4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 716 k
libopencv-dpm4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 42 k
libopencv-face4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 168 k
libopencv-features2d4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 198 k
libopencv-flann4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 91 k
libopencv-fuzzy4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 33 k
libopencv-gapi4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 374 k
libopencv-hfs4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 33 k
libopencv-highgui4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 20 k
libopencv-img-hash4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 32 k
libopencv-imgcodecs4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 217 k
libopencv-imgproc4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 749 k
libopencv-line-descriptor4.0
oe-repo 60 k
libopencv-ml4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 202 k
libopencv-objdetect4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 126 k
libopencv-optflow4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 83 k
libopencv-phase-unwrapping4.0
oe-repo 18 k
libopencv-photo4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 170 k
libopencv-plot4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 19 k
libopencv-reg4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 41 k
libopencv-rgbd4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 173 k
libopencv-saliency4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 57 k
libopencv-shape4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 55 k
libopencv-stereo4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 44 k
libopencv-stitching4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 161 k
libopencv-structured-light4.0
oe-repo 34 k
libopencv-superres4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 38 k
libopencv-surface-matching4.0
oe-repo 105 k
libopencv-text4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 127 k
libopencv-tracking4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 1.1 M
libopencv-video4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 92 k
libopencv-videoio4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 101 k
libopencv-videostab4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 92 k
libopencv-xfeatures2d4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 1.0 M
libopencv-ximgproc4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 317 k
libopencv-xobjdetect4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 37 k
libopencv-xphoto4.0 aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 76 k
liborc-test-0.4-0 aarch64 0.4.28-r0 oe-repo 16 k
libpcrecpp0 aarch64 8.41-r0 oe-repo 19 k
libpcreposix0 aarch64 8.41-r0 oe-repo 9.7 k
libprotobuf-compiler aarch64 3.5.1+git0+106ffc04be-r0
oe-repo 595 k
libprotobuf-lite15 aarch64 3.5.1+git0+106ffc04be-r0
oe-repo 106 k
libprotobuf15 aarch64 3.5.1+git0+106ffc04be-r0
oe-repo 635 k
libpulse-mainloop-glib0 aarch64_mx8mm 11.1-r0 oe-repo 13 k
libpulse-simple0 aarch64_mx8mm 11.1-r0 oe-repo 12 k
libsocketcan2 aarch64 0.0.10-r0 oe-repo 11 k
libtag-c0 aarch64 1.11.1-r0 oe-repo 12 k
libtic5 aarch64 6.0+20171125-r0
oe-repo 28 k
libticw5 aarch64 6.0+20171125-r0
oe-repo 28 k
libtiffxx5 aarch64 4.0.9-r0 oe-repo 10 k
libtool aarch64 2.4.6-r0 oe-repo 287 k
libturbojpeg0 aarch64 1:1.5.3-r0 oe-repo 101 k
libxaw6-6 aarch64 1:1.0.13-r2 oe-repo 97 k
libxcb-damage0 aarch64 1.12-r0 oe-repo 9.0 k
libxcb-dpms0 aarch64 1.12-r0 oe-repo 9.0 k
libxcb-dri2-0 aarch64 1.12-r0 oe-repo 10 k
libxcb-dri3-0 aarch64 1.12-r0 oe-repo 9.2 k
libxcb-glx0 aarch64 1.12-r0 oe-repo 20 k
libxcb-present0 aarch64 1.12-r0 oe-repo 9.4 k
libxcb-randr0 aarch64 1.12-r0 oe-repo 16 k
libxcb-record0 aarch64 1.12-r0 oe-repo 10 k
libxcb-res0 aarch64 1.12-r0 oe-repo 9.9 k
libxcb-screensaver0 aarch64 1.12-r0 oe-repo 9.9 k
libxcb-sync1 aarch64 1.12-r0 oe-repo 12 k
libxcb-xf86dri0 aarch64 1.12-r0 oe-repo 10 k
libxcb-xinerama0 aarch64 1.12-r0 oe-repo 9.2 k
libxcb-xtest0 aarch64 1.12-r0 oe-repo 8.9 k
libxcb-xv0 aarch64 1.12-r0 oe-repo 12 k
libxcb-xvmc0 aarch64 1.12-r0 oe-repo 9.8 k
linux-firmware noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 47 M
linux-firmware-adsp-sst noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 705 k
linux-firmware-adsp-sst-license
oe-repo 13 k
linux-firmware-ar3k noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 219 k
linux-firmware-ar3k-license
oe-repo 7.8 k
linux-firmware-ar9170 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 51 k
linux-firmware-ath6k noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 522 k
linux-firmware-ath9k noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 106 k
linux-firmware-atheros-license
oe-repo 7.5 k
linux-firmware-bcm-0bb4-0306
oe-repo 41 k
linux-firmware-bcm43143 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 265 k
linux-firmware-bcm43236b noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 193 k
linux-firmware-bcm43241b0 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 254 k
linux-firmware-bcm43241b4 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 220 k
linux-firmware-bcm43241b5 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 226 k
linux-firmware-bcm43242a noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 259 k
linux-firmware-bcm4329 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 157 k
linux-firmware-bcm4329-fullmac
oe-repo 159 k
linux-firmware-bcm4330 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 126 k
linux-firmware-bcm4334 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 275 k
linux-firmware-bcm43340 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 231 k
linux-firmware-bcm4335 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 312 k
linux-firmware-bcm43362 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 115 k
linux-firmware-bcm4339 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 306 k
linux-firmware-bcm43430 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 242 k
linux-firmware-bcm43430a0 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 226 k
linux-firmware-bcm4350 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 329 k
linux-firmware-bcm4350c2 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 329 k
linux-firmware-bcm4354 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 332 k
linux-firmware-bcm4356 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 281 k
linux-firmware-bcm43569 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 299 k
linux-firmware-bcm43570 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 298 k
linux-firmware-bcm4358 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 346 k
linux-firmware-bcm43602 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 424 k
linux-firmware-bcm4366b noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 447 k
linux-firmware-bcm4371 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 335 k
linux-firmware-bcm4373 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 286 k
linux-firmware-bcm43xx noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 29 k
linux-firmware-bcm43xx-hdr noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 6.6 k
linux-firmware-bnx2-mips noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 51 k
linux-firmware-carl9170 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 15 k
linux-firmware-gplv2-license
oe-repo 13 k
linux-firmware-i915 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 293 k
linux-firmware-i915-license
oe-repo 7.5 k
linux-firmware-ibt-11-5 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 366 k
linux-firmware-ibt-12-16 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 366 k
linux-firmware-ibt-17 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 567 k
linux-firmware-ibt noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 7.3 k
linux-firmware-ibt-hw-37-7 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 34 k
linux-firmware-ibt-hw-37-8 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 65 k
linux-firmware-ibt-license noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 7.5 k
linux-firmware-ibt-misc noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 5.7 k
linux-firmware-iwlwifi-135-6
oe-repo 207 k
linux-firmware-iwlwifi noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 6.5 k
linux-firmware-iwlwifi-3160-10
oe-repo 193 k
linux-firmware-iwlwifi-3160-12
oe-repo 196 k
linux-firmware-iwlwifi-3160-13
oe-repo 196 k
linux-firmware-iwlwifi-3160-16
oe-repo 220 k
linux-firmware-iwlwifi-3160-17
oe-repo 219 k
linux-firmware-iwlwifi-3160-7
oe-repo 197 k
linux-firmware-iwlwifi-3160-8
oe-repo 189 k
linux-firmware-iwlwifi-3160-9
oe-repo 193 k
linux-firmware-iwlwifi-6000-4
oe-repo 135 k
linux-firmware-iwlwifi-6000g2a-5
oe-repo 137 k
linux-firmware-iwlwifi-6000g2a-6
oe-repo 185 k
linux-firmware-iwlwifi-6000g2b-5
oe-repo 142 k
linux-firmware-iwlwifi-6000g2b-6
oe-repo 186 k
linux-firmware-iwlwifi-6050-4
oe-repo 138 k
linux-firmware-iwlwifi-6050-5
oe-repo 142 k
linux-firmware-iwlwifi-7260
oe-repo 1.0 M
linux-firmware-iwlwifi-7265
oe-repo 905 k
linux-firmware-iwlwifi-7265d
oe-repo 1.1 M
linux-firmware-iwlwifi-8000c
oe-repo 1.4 M
linux-firmware-iwlwifi-8265
oe-repo 1.1 M
linux-firmware-iwlwifi-9000
oe-repo 760 k
linux-firmware-iwlwifi-license
oe-repo 7.5 k
linux-firmware-iwlwifi-misc
oe-repo 2.0 M
linux-firmware-license noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 33 k
linux-firmware-marvell-license
oe-repo 7.5 k
linux-firmware-mt7601u noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 29 k
linux-firmware-mt7601u-license
oe-repo 7.6 k
linux-firmware-netronome noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 7.5 k
linux-firmware-netronome-license
oe-repo 9.6 k
linux-firmware-pcie8897 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 509 k
linux-firmware-pcie8997 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 592 k
linux-firmware-qat noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 137 k
linux-firmware-qat-license noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 7.5 k
linux-firmware-qca noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 107 k
linux-firmware-qcom-adreno-a3xx
oe-repo 11 k
linux-firmware-qcom-adreno-a530
oe-repo 27 k
linux-firmware-qcom-license
oe-repo 17 k
linux-firmware-qcom-venus-1.8
oe-repo 375 k
linux-firmware-qcom-venus-4.2
oe-repo 356 k
linux-firmware-radeon noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 847 k
linux-firmware-radeon-license
oe-repo 7.8 k
linux-firmware-ralink noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 18 k
linux-firmware-ralink-license
oe-repo 7.6 k
linux-firmware-rtl-license noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 7.5 k
linux-firmware-rtl8168 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 17 k
linux-firmware-rtl8188 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 17 k
linux-firmware-rtl8192ce noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 23 k
linux-firmware-rtl8192cu noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 20 k
linux-firmware-rtl8192su noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 56 k
linux-firmware-rtl8723 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 119 k
linux-firmware-rtl8821 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 41 k
linux-firmware-sd8686 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 85 k
linux-firmware-sd8688 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 170 k
linux-firmware-sd8787 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 291 k
linux-firmware-sd8797 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 314 k
linux-firmware-sd8801 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 169 k
linux-firmware-sd8887 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 422 k
linux-firmware-sd8897 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 494 k
linux-firmware-ti-connectivity-license
oe-repo 7.8 k
linux-firmware-vt6656 noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 11 k
linux-firmware-vt6656-license
oe-repo 7.1 k
linux-firmware-whence-license
oe-repo 25 k
linux-firmware-wl12xx noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 1.6 M
linux-firmware-wl18xx noarch 1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0
oe-repo 6.8 k
linux-imx-headers aarch64_mx8mm 4.14.98-r0 oe-repo 5.6 k
mkfontdir aarch64 1:1.0.7-r8.0
oe-repo 6.6 k
mkfontscale aarch64 1.1.2-r0 oe-repo 18 k
ntp aarch64 4.2.8p11-r0 oe-repo 318 k
ntp-tickadj aarch64 4.2.8p11-r0 oe-repo 8.4 k
opencv aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 15 k
opencv-apps aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 70 k
opencv-samples aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 22 M
orc aarch64 0.4.28-r0 oe-repo 21 k
ppp aarch64 2.4.7-r0 oe-repo 129 k
pps-tools aarch64 0.0.0+git0+0deb9c7e13-r0
oe-repo 13 k
pulseaudio aarch64_mx8mm 11.1-r0 oe-repo 5.6 k
python3-misc aarch64 3.5.5-r1.0 oe-repo 2.2 M
python3-nose aarch64 1.3.7-r0 oe-repo 214 k
python3-numpy aarch64 1.14.2-r0 oe-repo 2.7 M
python3-opencv aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 1.0 M
quota aarch64 4.04-r0 oe-repo 119 k
stb aarch64 2.19.0-r0 oe-repo 5.6 k
tbb aarch64 20170412+0+a2cfdfe946-r0
oe-repo 88 k
tclap aarch64 1.2.1-r0 oe-repo 5.6 k
tesseract aarch64 3.05.01+git0+215866151e-r0
oe-repo 996 k
wayland-protocols noarch 1.16.imx-r0 oe-repo 65 k
xz aarch64 5.2.3-r0 oe-repo 40 k
Installing weak dependencies:
bash-completion-dev aarch64 2.7-r0 oe-repo 7.5 k
bigreqsproto-dev aarch64 1:1.1.2-r0 oe-repo 8.4 k
bison-dev aarch64 3.0.4-r0 oe-repo 7.9 k
boost-dev aarch64 1.66.0-r0 oe-repo 8.8 M
btrfs-tools-dev aarch64 4.13.3-r0 oe-repo 42 k
cantarell-fonts-dev noarch 0.0.24-r0 oe-repo 6.0 k
compositeproto-dev aarch64 1:0.4.2-r1 oe-repo 9.2 k
cryptodev-linux-dev aarch64 1.9-r0 oe-repo 9.3 k
damageproto-dev aarch64 1:1.2.1-r1 oe-repo 8.9 k
dri2proto-dev aarch64 2.8-r0 oe-repo 9.4 k
dri3proto-dev aarch64 1.0-r0 oe-repo 8.5 k
encodings-dev noarch 1:1.0.4-r2.1
oe-repo 5.8 k
fixesproto-dev aarch64 1:5.0-r1 oe-repo 11 k
fmt-dev aarch64 5.3.0-r0 oe-repo 66 k
font-util-dev aarch64 1.3.1-r0 oe-repo 11 k
fontsproto-dev aarch64 1:2.1.3-r0 oe-repo 16 k
gconf-dbg aarch64 3.2.6-r0 oe-repo 543 k
gconf-dev aarch64 3.2.6-r0 oe-repo 29 k
gli-dev aarch64 0.8.2.0-r0 oe-repo 66 k
glm-dev aarch64 0.9.8.5-r0 oe-repo 170 k
glproto-dev aarch64 1:1.4.17-r0 oe-repo 22 k
gnome-desktop-testing-dev aarch64 2014.1-r1 oe-repo 5.9 k
gtest-dev aarch64 1.8.1-r0 oe-repo 200 k
half-dev aarch64 1.12.0-r0 oe-repo 25 k
inputproto-dev aarch64 1:2.3.2-r0 oe-repo 21 k
iso-codes-dev noarch 3.77-r0 oe-repo 6.7 k
kbproto-dev aarch64 1:1.0.7-r0 oe-repo 29 k
kdump aarch64 2.0.16-r1 oe-repo 12 k
kernel-module-imx-gpu-viv-dev
imx8mmevk 6.2.4.p4.0-r0
oe-repo 6.9 k
leptonica-dev aarch64 1.74.4-r0 oe-repo 107 k
libatomic-ops-dev aarch64 7.6.2+git0+5ae4b4aeea-r0
oe-repo 68 k
libcgroup-dev aarch64 0.41-r0 oe-repo 21 k
libcheck-dbg aarch64 0.12.0-r0 oe-repo 74 k
libcheck-dev aarch64 0.12.0-r0 oe-repo 19 k
libexif-dev aarch64 0.6.21-r0 oe-repo 19 k
libgif-dev aarch64 5.1.4-r0 oe-repo 9.9 k
libgl-mesa-dev aarch64_mx8mm 2:17.3.8-r0 oe-repo 75 k
libgomp-dev aarch64 7.3.0-r0 oe-repo 9.7 k
libgphoto2-camlibs aarch64 2.5.16-r0 oe-repo 559 k
libgphoto2-dev aarch64 2.5.16-r0 oe-repo 29 k
libidn-dev aarch64 1.33-r0 oe-repo 14 k
libnewt-dev aarch64 0.52.20-r0 oe-repo 11 k
libopencv-aruco-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-bgsegm-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-bioinspired-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-calib3d-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-ccalib-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.1 k
libopencv-core-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-datasets-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-dnn-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-dnn-objdetect-dev
oe-repo 7.0 k
libopencv-dpm-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-face-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-features2d-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-flann-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-fuzzy-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-gapi-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-hfs-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-highgui-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-img-hash-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-imgcodecs-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-imgproc-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-line-descriptor-dev
oe-repo 7.0 k
libopencv-ml-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-objdetect-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-optflow-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.1 k
libopencv-phase-unwrapping-dev
oe-repo 7.0 k
libopencv-photo-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-plot-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-reg-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 6.9 k
libopencv-rgbd-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-saliency-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-shape-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-stereo-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-stitching-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.1 k
libopencv-structured-light-dev
oe-repo 7.1 k
libopencv-superres-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.1 k
libopencv-surface-matching-dev
oe-repo 7.0 k
libopencv-text-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-tracking-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-video-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-videoio-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.1 k
libopencv-videostab-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.1 k
libopencv-xfeatures2d-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-ximgproc-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libopencv-xobjdetect-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.1 k
libopencv-xphoto-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 7.0 k
libprotobuf-dev aarch64 3.5.1+git0+106ffc04be-r0
oe-repo 304 k
libpthread-stubs-dev aarch64 0.4-r0 oe-repo 6.8 k
libsocketcan-dev aarch64 0.0.10-r0 oe-repo 9.1 k
linux-imx-headers-dev aarch64_mx8mm 4.14.98-r0 oe-repo 39 k
mesa-dev aarch64_mx8mm 2:17.3.8-r0 oe-repo 7.4 k
mkfontdir-dev aarch64 1:1.0.7-r8.0
oe-repo 6.1 k
mkfontscale-dev aarch64 1.1.2-r0 oe-repo 6.2 k
opencv-dev aarch64_mx8mm 4.0.1.imx+git0+737f8fad13_2522124473_32e315a5b1_34e4206aef_fccf7cd6a4_d29d003e00-r0
oe-repo 855 k
ppp-dev aarch64 2.4.7-r0 oe-repo 34 k
pps-tools-dev aarch64 0.0.0+git0+0deb9c7e13-r0
oe-repo 8.4 k
presentproto-dev aarch64 1.1+git0+bfdc7e0523-r0
oe-repo 9.5 k
python3-nose-dev aarch64 1.3.7-r0 oe-repo 6.0 k
python3-numpy-dev aarch64 1.14.2-r0 oe-repo 6.4 k
quota-dev aarch64 4.04-r0 oe-repo 8.6 k
randrproto-dev aarch64 1:1.5.0-r0 oe-repo 12 k
rapidjson-dev aarch64 1.1.0+git0+e5635fb27f-r0
oe-repo 97 k
recordproto-dev aarch64 1:1.14.2-r1 oe-repo 9.8 k
renderproto-dev aarch64 1:0.11.1-r1 oe-repo 11 k
resourceproto-dev aarch64 1:1.2.0-r1 oe-repo 8.3 k
scrnsaverproto-dev aarch64 1:1.2.2-r0 oe-repo 9.2 k
stb-dev aarch64 2.19.0-r0 oe-repo 95 k
tbb-dev aarch64 20170412+0+a2cfdfe946-r0
oe-repo 241 k
tclap-dev aarch64 1.2.1-r0 oe-repo 31 k
tesseract-dev aarch64 3.05.01+git0+215866151e-r0
oe-repo 76 k
tesseract-lang-eng noarch 3.04.00+git0+3cf1e2df1f-r0
oe-repo 8.5 M
util-macros-dev aarch64 1:1.19.1-r0 oe-repo 22 k
videoproto-dev aarch64 1:2.3.3-r0 oe-repo 14 k
vmcore-dmesg aarch64 2.0.16-r1 oe-repo 12 k
xcb-proto-dev aarch64 1.12-r0 oe-repo 80 k
xcmiscproto-dev aarch64 1:1.2.2-r0 oe-repo 8.5 k
xextproto-dev aarch64 1:7.3.0-r0 oe-repo 31 k
xf86dgaproto-dev aarch64 1:2.1-r2 oe-repo 11 k
xf86driproto-dev aarch64 1:2.1.1-r0 oe-repo 9.9 k
xf86miscproto-dev aarch64 1:0.9.3-r1 oe-repo 9.4 k
xf86vidmodeproto-dev aarch64 1:2.3.1-r1 oe-repo 10 k
xineramaproto-dev aarch64 1:1.2.1-r0 oe-repo 8.8 k
xproto-dev aarch64 1:7.0.31-r0 oe-repo 67 k
xtrans-dev aarch64 1:1.3.5-r0 oe-repo 42 k
Skipping packages with conflicts:
(add '--best --allowerasing' to command line to force their upgrade):
libgl-imx-dev aarch64_mx8mm 1:6.2.4.p4.0+aarch64-r0
oe-repo 98 k
Transaction Summary
Install 1182 Packages
Skip 2 Packages
Total size: 559 M
Installed size: 3.4 G
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Error: Transaction check error:
file /etc/bluetooth/firmware.conf from install of linux-firmware-qca-1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0.noarch conflicts with file from package firmware-qca9377-2.0.3-r0.noarch
file /etc/bluetooth/firmware.conf from install of linux-firmware-qca-1:0.0+git0+d114732723_a0026b646c+f6d0859f94-r0.noarch conflicts with file from package firmware-qca6174-2.0.3-r0.noarch
Error Summary
DEBUG: Python function do_populate_sdk finished
ERROR: Function failed: do_populate_sdk
8,682 次查看
shriyanayak1992
hi @Yann Morvan ,
I am facing same issues.May i know how did u resolve it?
Sriraksha
8,682 次查看
gusarambula
Hello y yq,
Are you still encountering this issue? Have you tried using the recipe meta-toolchain ? It should start the same task chain as populate_sdk but it’s worth a try.
Sometimes performing a clean may also help. The log doesn’t show much detail. Would you please copy the log stored to see if there is more hints of what could be the problem?
