Yocto bsp setup
2,974件の閲覧回数
jiangdongli
I get a error:  "fatal: bad config file line 1 in .git/config"  when i run command: "repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga" in fsl-arm-yocto-bsp directory. But i can't find the file .git/config in current directory.
Did anyone encounter a similar problem? i need help.
thanks!
ラベル(3)
タグ(1)
2,873件の閲覧回数
jiangdongli
I have solved this problem myself, it caused by our EIS
2,874件の閲覧回数
jiangdongli
2,873件の閲覧回数
gusarambula
Hello Jiangdong Li,
I'm glad you solved the problem. Thank you for letting us know!
