Yocto-SDK: populate_sdk failed on imx8qxpc0mek
2,473 次查看
wasim_nazir
Hi All,
Failing to run this command "DISTRO=fsl-imx-wayland MACHINE=imx8qxpc0mek bitbake imx-image-full -c populate_sdk" for imx-yocto-L4.14.78_1.0.0_ga:
I tried the following but still, it didn't work:
    2) Comment out the line: PACKAGE_CLASSES = "package_deb" conf/local.conf
Any lead will be appreciated.
Thanks In Advance
Wasim
2,459 次查看
Zhiming_Liu
Can you attach the error log?
2,433 次查看
balaji1
I tried the same using the command: bitbake imx-image-full -c populate_sdk
