[YOCTO] How to Change Python3.5 to Python3.6 over
5,385 次查看
peanutstars_job
Hello, All
I'm using YOCTO for imx6dl board, set up as follow from NXP document:
Command Line
 $ mkdir imx-yocto-bsp
 $ cd imx-yocto-bsp
 $ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.0.0_ga.xml
 $ repo sync
It had the python3_3.5.5 recipe.  I want to change it to python3_3.6 over.
I tried to add a  custom layer and recipes, finally it worked. But I don't know how to change/update to python3.6 over.
Please show me the advice.
HyunSuk Lee.
标签 (2)
标记 (2)
5,168 次查看
gusarambula
Hello HyunSuk Lee,
Usually some of the recipe versions are tied to a specific branch, so you would need to look for a newer phyton recipe from a newer branch. It’s not a trivial task as you would need to fix all dependencies.
There may be some python3_3.6.0.bb recipes on other branches you may use.
