Hi Igor,
Thanks for the replay. But this question is not related to PCIe and imx6.
I am observing that if i enable PCI bus support in the kernel, then i am not able to use x11 gpu hardware acceleration(glxgears and es2gears give segmentation faults).
But if i disable PCI support , i could use x11 gpu hardware acceleration with above mentioned versions of xserver.
What role is PCI drivers playing in x11 hardware acceleration? How to get x11 acceleration working with PCI bus support enabled.
Prathamesh
