Working with third party libraries
1,197 次查看
chandraevolute
Yuri​
Hi ,
I am using third part source files, cross compiling them and generating the shared library.
I am using imx6ulevk, poky version 1.8. I am able to generate the shared libraries.
And i wrote a sample application using the shared library and crosscompiled and generated the executable.
When I am trying to run the executable say
./Example it is giving a error like libMso.so cannot be opened . File is missing.
I copied the libraries to /usr/lib/ still the error comes.
Do i need to build the RFS again by copying these libraries ??
1,135 次查看
Yuri
  Please try the following :
$ file ./Example
and
$ ldd ./Example
and let me look at the log.
Yuri
