Windows 10 IOT iMX6DL Driver Peripherals Test Applications
1,861件の閲覧回数
Zaid_Noordeen
I am working with iMX6DL Sabresd EVK board with Windows 10 IOT Core BSP. I needs to verify driver peripherals like SPI, I2C, UART are working fine. Is their any test applications available for those testing?
I am using Microsoft provided Sample Applications from following link for testing the peripherals. In that there is an option for listing down all the device peripherals which can be accessed by user space. I am not getting any peripherals list during SPI, I2C, PWM test applications. Is the SPI, I2C, PWM drivers available for access in user space by default?
Test Apps were downloaded from following link: https://github.com/microsoft/Windows-iotcore-samples/tree/develop/BusTools/
ラベル(3)
1,845件の閲覧回数
Bio_TICFSL
Hello Zaid,
Those peripheral are just accessed as user space, windows IOT not let you modify any of the driver.For Usage please go to device-sensor and samples in your SDK.
