Basically, ODT feature is intended for data DQ, data strobes DQS, and data masks DM.
Address and command lines are not affected by the ODT.
The ODT field of DRAM_ADDRxx register relates only to address lines, and
really should not be used. The MMDC PHY ODT control register is applied to
configure data DQ, data strobes DQS, and data masks DM. This register is used really for
ODT configuring.
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
