Why environment variable from u-boot and console are different?
3,311件の閲覧回数
emb-bharpay
Hello Team,
When I run "printenv" from u-boot, its output is different from fw_printenv from the console.
Actually, with fw_printenv it is taking the default u-boot environment variable instead of the currently set environment variable.
Also, I am not able to change or set the environment variable from console.
Please guide me to resolve this issue.
FYI: Using iMX8QM-MEK board.
Thanks in advance.
3,279件の閲覧回数
Rita_Wang
You can see the 4.7 Running Linux OS on the target of the use guide.
