Why doesn't uart2 node include dmas in imx8mm.dtsi?
takeshi100
Hi.
In imx8mm.dtsi, uart2 node don't include the dmas.
But other uart node (1. 2 and 4) include the dmas.
Why? and What is the impact of not including the dmas?
■ imx8mm.dtsi
https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/freescale/imx8mm.dtsi
uart1: serial@30860000 {
compatible = "fsl,imx8mm-uart", "fsl,imx6q-uart";
reg = <0x30860000 0x10000>;
interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk IMX8MM_CLK_UART1_ROOT>,
<&clk IMX8MM_CLK_UART1_ROOT>;
clock-names = "ipg", "per";
dmas = <&sdma1 22 4 0>, <&sdma1 23 4 0>;
dma-names = "rx", "tx";
status = "disabled";
uart3: serial@30880000 {
reg = <0x30880000 0x10000>;
interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk IMX8MM_CLK_UART3_ROOT>,
<&clk IMX8MM_CLK_UART3_ROOT>;
dmas = <&sdma1 26 4 0>, <&sdma1 27 4 0>;
uart2: serial@30890000 {
reg = <0x30890000 0x10000>;
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk IMX8MM_CLK_UART2_ROOT>,
<&clk IMX8MM_CLK_UART2_ROOT>;
Best Regards.
JorgeCas
This is because UART2 is used for debug purposes. If you check the device tree, the debug UART port doesn't use DMA.
Best regards.
JorgeCas
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2022543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWhy%20doesn't%20uart2%20node%20include%20dmas%20in%20imx8mm.dtsi%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2022543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EIn%20imx8mm.dtsi%2C%20uart2%20node%20don't%20include%20the%20dmas.%3C%2FP%3E%3CP%3EBut%20other%20uart%20node%20(1.%202%20and%204)%20include%20the%20dmas.%3C%2FP%3E%3CP%3EWhy%3F%20and%20What%20is%20the%20impact%20of%20not%20including%20the%20dmas%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E2%96%A0%20imx8mm.dtsi%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Ftorvalds%2Flinux%2Fblob%2Fmaster%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm.dtsi%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Ftorvalds%2Flinux%2Fblob%2Fmaster%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm.dtsi%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%3CSPAN%3Euart1%3A%20serial%4030860000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cimx8mm-uart%22%2C%20%22fsl%2Cimx6q-uart%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x30860000%200x10000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einterrupts%20%3D%20%3CGIC_SPI%2026%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%3C%2FGIC_SPI%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eclocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MM_CLK_UART1_ROOT%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Bclk%20IMX8MM_CLK_UART1_ROOT%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eclock-names%20%3D%20%22ipg%22%2C%20%22per%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edmas%20%3D%20%26lt%3B%26amp%3Bsdma1%2022%204%200%26gt%3B%2C%20%26lt%3B%26amp%3Bsdma1%2023%204%200%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edma-names%20%3D%20%22rx%22%2C%20%22tx%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%20%3D%20%22disabled%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euart3%3A%20serial%4030880000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cimx8mm-uart%22%2C%20%22fsl%2Cimx6q-uart%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x30880000%200x10000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einterrupts%20%3D%20%3CGIC_SPI%2028%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%3C%2FGIC_SPI%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eclocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MM_CLK_UART3_ROOT%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Bclk%20IMX8MM_CLK_UART3_ROOT%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eclock-names%20%3D%20%22ipg%22%2C%20%22per%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edmas%20%3D%20%26lt%3B%26amp%3Bsdma1%2026%204%200%26gt%3B%2C%20%26lt%3B%26amp%3Bsdma1%2027%204%200%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edma-names%20%3D%20%22rx%22%2C%20%22tx%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%20%3D%20%22disabled%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euart2%3A%20serial%4030890000%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecompatible%20%3D%20%22fsl%2Cimx8mm-uart%22%2C%20%22fsl%2Cimx6q-uart%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ereg%20%3D%20%26lt%3B0x30890000%200x10000%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einterrupts%20%3D%20%3CGIC_SPI%2027%3D%22%22%20irq_type_level_high%3D%22%22%3E%3B%3C%2FGIC_SPI%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eclocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MM_CLK_UART2_ROOT%26gt%3B%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26lt%3B%26amp%3Bclk%20IMX8MM_CLK_UART2_ROOT%26gt%3B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eclock-names%20%3D%20%22ipg%22%2C%20%22per%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Estatus%20%3D%20%22disabled%22%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3EBest%20Regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2022856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Why%20doesn't%20uart2%20node%20include%20dmas%20in%20imx8mm.dtsi%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2022856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThis%20is%20because%20UART2%20is%20used%20for%20debug%20purposes.%20If%20you%20check%20the%20device%20tree%2C%20the%20debug%20UART%20port%20doesn't%20use%20DMA.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
