Why MX6Q PMIC i2c access failed after entered linux kernel
2,852 次查看
raymondwang
Senior Contributor I
My sabresd based new custom board, kernel report error:
mc_pfuze 1-0008: recv failed!:-5,0
mc_pfuze: probe of 1-0008 failed with error -5
Hardware reset to PMIC, boot loader can probe PMIC properly:
Found PFUZE100! deviceid=10,revid=11
Because our linux system software reset is WDOG based, it won't reset PMIC.
After reset ,boot loader will not report PFUZE100 found. Strange issue, Why?
With oscilloscope support, I found the PFUZE100 i2c access failed with no ACK in 9th i2c clk.
Anyone ever encounter issue like this?
标记 (1)
2,217 次查看
raymondwang
Touch panel and PMIC share the same i2c bus but has different pull up power voltage.
2,218 次查看
raymondwang
