Where can I find GPU tools (gpuinfo and gputop)
sandeepgandiga
Where can I find GPU tools (gpuinfo and gputop) as mentioned in https://www.nxp.com/docs/en/user-guide/IMX_GRAPHICS_USERS_GUIDE.pdf
And, do they work on i.MX8 running Android?
Tags (2)
Rita_Wang
gpuinfo
/unit_tests/GPU/gpuinfo.sh
gputop
/usr/bin/gputop
For android BSP the gputop maybe not default support you need to build and deploy it
  • Build gputop
    git clone ssh://git@bitbucket.sw.nxp.com/gtec/gputop.git
    cd gputop
    git apply 0001-gputop-fix-compilation.patch
    export PATH=/path/to/android-ndk-rxxx:$PATH
    export NDK_PROJECT_PATH=.
    export TARGET_PLATFORM=arm64-v8a
    export GPUPERFCNT_INCLUDE_PATH=/path/to/libgpuperfcnt/include
    export GPUPERFCNT_LIB_PATH=/path/to/libgpuperfcnt/obj/local/arm64-v8a
    ndk-build NDK_APPLICATION_MK=./tools/Application.mk
    output: /path/to/gputop/libs/arm64-v8a/gpu-top
  • Deploy gputop
    adb root
    adb push /path/to/libs/arm64-v8a/gpu-top /data/local
  • Run gputop
    /data/local/gpu-top
Before running the command, you would need to enable vProfiler option as described in  "12.6.3.1 Enable vProfiler option in kernel" from "i.MX Graphics User's Guide" in order to get proper occupancy values.
