When the video decoding, I found the video overlay a vertical green stripes frame, why?
5,203 次查看
taowang
When the video decoding, I found the video overlay a vertical green stripes  frame, normal frame and green striped frame has been alternately flashing. I used imx51, please help me why? how to deal with it ? thank you very much.
标记 (1)
5,010 次查看
LeonardoSandova
Specialist I
Do you observer the same when using gstreamer? try playing (decoding + displaying) the file using
gst-launch playbin2 uri=file://<full path including the media file name>
If it looks bad with the above command, so there may be an issue with the HW decoder.
5 回复数
5,010 次查看
taowang
i used vpu lib to decode the h.264 raw data, then use v4l2 to display decoded frame. how can i get the reason to the problem?
5,011 次查看
LeonardoSandova
Specialist I
5,010 次查看
LeonardoSandova
Specialist I
POst the pipeline you used (add -v to check the caps and also share this log)
5,010 次查看
hardlywhen
I met the same problem, could you sent the detail how to get the log?
is -v a command line parameter? which command should i do?
Do we konw  the problem is V4L2 or vpu error for sure?
5,010 次查看
LeonardoSandova
Specialist I
-v is a gst-launch parameter, and indicates to show caps for all sinks and sources.
