When disable CAAM can not wakeup
1,238 次查看
xu_ji1
In i.MX6Q when disable CAAM can not wakeup from sleep,and find in caam crtl.c this function is key point:  init_clocks(ctrlpriv);
Why about this issue?How to fixed it when disable CAAM also can wakeup
1,233 次查看
Hi xu_ji1
what bsp used in the case, may be recommended to test on i.MX6Q Sabre SD with
latest linux
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_5.4.70_2.3.0
Documentation
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
1,228 次查看
xu_ji1
we used BSP 4.14.98_2.3.0,our project based on it, and our project can not boot on latest Linux,so we can not test on latest Linux
1,225 次查看
BSP 4.14.98_2.3.0 does not supported i.MX6Q as described on below link, column "Supported Platforms" :
