What is the pad GPANAIO?
3,647件の閲覧回数
KlausGuertler
the pad name GPANAIO is mentioned in the data sheet (pad C8 at the 21x21mm package) but there are no further descriptions in the data sheet and in the reference manual.
Does anyone know what is used for?
BR Klaus
3,325件の閲覧回数
david_babin
It's in the rev C data sheet. See Table 4.
5 返答(返信)
3,325件の閲覧回数
KlausGuertler
Thanks for the hint to revision C. I have still revision B via
NDA from my FAE. So I am not automatically updated.
3,326件の閲覧回数
david_babin
3,325件の閲覧回数
KlausGuertler
thanks to all, hopefully it apears in the next data sheet revision.
BR Klaus
3,325件の閲覧回数
david_babin
For the MX6 series, GPANAIO must be a no connect. This output is reserved for Freescale manufacturing use.
3,325件の閲覧回数
DirkBehme
It's not i.MX6, but
http://cache.freescale.com/files/dsp/doc/data_sheet/IMX51CEC.pdf
mentions:
GPANAIO: This signal is reserved for Freescale manufacturing use only. Users should float this output.
