What happened to the imxotp command in uboot?
3,442 次查看
EdSutter
Senior Contributor II
I'm working with a mainline version of uboot from u-boot-2013.10.
I need to burn my fuses (iMX6D custom hardware), but I see that the imxotp command is not part of this source tree.
Has it been replaced (since u-boot-2009.08) or was it just never merged into mainline uboot?
Tx
Ed
1,485 次查看
EricNelson
Hi Ed,
Thanks for the easy one.
I think you'll find the answer here:
     http://boundarydevices.com/fuse-command/
Benoît Thébaudeau implemented with the more general "fuse" command.
1,486 次查看
EricNelson
Hi Ed,
1,485 次查看
EdSutter
Eric,
I'm glad I could help!  LOL!
I removed all the hacks I started pulling in to get imxotp, and pulled in "fuse".
For anyone else reading, you have to add
#define CONFIG_MXC_OCOTP
#define CONFIG_CMD_FUSE
to your configuration.
Ed
