What I need to add to image to run QT app?
995 次查看
Majid
I build an image using yocto and some package to it to run QT apps.
    qtquickcontrols \
    qtquickcontrols2 \
    qtmultimedia \
    qtvirtualkeyboard \
But when I run the app, I got an error:
QML debugging is enabled. Only use this in a safe environment.
qt.qpa.plugin: Could not find the Qt platform plugin "eglfs" in ""
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, minimal, offscreen, vnc.
Aborted
How can I fix this?
-Regards
标签 (4)
981 次查看
Zhiming_Liu
imx-image-full has all QT5 depends
Zhiming
