Weston sources?
Weston sources?
stephenminutill
I am working with the new 4.0.0 Linux BSP on i.MX6Q, with Qt and Wayland/Weston.  I need to make some customizations to Weston, but I can't find the sources.  The sources I'm looking for are those for the prebuilt Weston binaries in the package weston-imx-bin-3.0.35-4.0.0.tar.gz.  Can these sources be made available?
Labels (2)
lily_zhang
lily_zhang
aurelienbouin
When fallowing the tuto you do not get the files needed : fb-backend.so and gal2d-backend.so
XiaoPong
AbhijitPotnis
Fresh Out Contributor
I guess what stephenminutillo meant by sources is that he needed the sources for GAL2d and framebuffer backend implementation for weston. The files that generate fb-backend.so and gal2d-backend.so.
