Wayland dual display setting
1,991 次查看
haeyoungkwon
Hello, I just newly installed wayland on i.MX6q.
It works fine with one single display, but my goal is to run the dual display using wayland to see the graphic acceleration with the extended mode.
Can anyone help with that?
I was not able to run dual screen, only one screen works. (LVDS1 + HDMI)
Thanks.
标签 (3)
1,528 次查看
Bio_TICFSL
FSL have not enabled dual display on Wayland, but from our point of view, to Wayland display, it had supported multi frame buffer devices, the dual display feature should be Wayland's task.
Maybe you need check with Wayland for dual display support.
