Hi All,
I'm using 4.14.98 Sumo i.MX8M Mini board with qt 5.10.1, X-Wayland Server.
When I'm trying to run qt application with combo-box, submenu. Application is terminating with
following errors when I click on it.
Using Wayland-EGL Using the 'xdg-shell-v6' shell integration zxdg_shell_v6@17: error 2: xdg_popup was not created on the topmost popup The Wayland connection experienced a fatal error (Protocol error).
How this error can be solved. Please do the needful.
Thanks in advance,
Deeksha
 Zhiming_Liu
			Zhiming_Liu
		I tested xdg-shell-v6 on L5.10.XX and there is no issue when run qt demo.You can try newest BSP
