Hi Qiang_FSL
The cfg80211.ko module have built in the same ltib.
we write the file system to sd card using this command
./mk_mx28_sd /dev/sdb
Then use the insmod cfg80211.ko command to install the module.
This is the message log which I get
root@freescale /home/user$ insmod cfg80211.ko
cfg80211: disagrees about version of symbol skb_copy_bits
cfg80211: Unknown symbol skb_copy_bits (err -22)
cfg80211: disagrees about version of symbol rfkill_unregister
cfg80211: Unknown symbol rfkill_unregister (err -22)
cfg80211: disagrees about version of symbol skb_put
cfg80211: Unknown symbol skb_put (err -22)
cfg80211: disagrees about version of symbol consume_skb
cfg80211: Unknown symbol consume_skb (err -22)
cfg80211: disagrees about version of symbol rfkill_blocked
cfg80211: Unknown symbol rfkill_blocked (err -22)
cfg80211: disagrees about version of symbol rfkill_destroy
cfg80211: Unknown symbol rfkill_destroy (err -22)
cfg80211: disagrees about version of symbol genlmsg_multicast_allns
cfg80211: Unknown symbol genlmsg_multicast_allns (err -22)
cfg80211: disagrees about version of symbol pskb_expand_head
cfg80211: Unknown symbol pskb_expand_head (err -22)
cfg80211: disagrees about version of symbol kfree_skb
cfg80211: Unknown symbol kfree_skb (err -22)
cfg80211: disagrees about version of symbol netlink_broadcast
cfg80211: Unknown symbol netlink_broadcast (err -22)
cfg80211: disagrees about version of symbol __alloc_skb
cfg80211: Unknown symbol __alloc_skb (err -22)
cfg80211: disagrees about version of symbol rfkill_resume_polling
cfg80211: Unknown symbol rfkill_resume_polling (err -22)
cfg80211: disagrees about version of symbol kobject_uevent_env
cfg80211: Unknown symbol kobject_uevent_env (err -22)
cfg80211: disagrees about version of symbol __dev_get_by_index
cfg80211: Unknown symbol __dev_get_by_index (err -22)
cfg80211: disagrees about version of symbol skb_pull
cfg80211: Unknown symbol skb_pull (err -22)
cfg80211: disagrees about version of symbol genl_register_family_with_ops
cfg80211: Unknown symbol genl_register_family_with_ops (err -22)
cfg80211: disagrees about version of symbol rfkill_pause_polling
cfg80211: Unknown symbol rfkill_pause_polling (err -22)
cfg80211: disagrees about version of symbol netlink_unicast
cfg80211: Unknown symbol netlink_unicast (err -22)
cfg80211: disagrees about version of symbol dev_get_by_index
cfg80211: Unknown symbol dev_get_by_index (err -22)
cfg80211: disagrees about version of symbol dev_close
cfg80211: Unknown symbol dev_close (err -22)
cfg80211: disagrees about version of symbol skb_push
cfg80211: Unknown symbol skb_push (err -22)
cfg80211: disagrees about version of symbol wireless_send_event
cfg80211: Unknown symbol wireless_send_event (err -22)
cfg80211: disagrees about version of symbol nla_put
cfg80211: Unknown symbol nla_put (err -22)
cfg80211: disagrees about version of symbol rfkill_set_hw_state
cfg80211: Unknown symbol rfkill_set_hw_state (err -22)
cfg80211: disagrees about version of symbol ethtool_op_get_link
cfg80211: Unknown symbol ethtool_op_get_link (err -22)
cfg80211: disagrees about version of symbol rfkill_alloc
cfg80211: Unknown symbol rfkill_alloc (err -22)
cfg80211: disagrees about version of symbol dev_alloc_skb
cfg80211: Unknown symbol dev_alloc_skb (err -22)
cfg80211: disagrees about version of symbol __pskb_pull_tail
cfg80211: Unknown symbol __pskb_pull_tail (err -22)
cfg80211: disagrees about version of symbol skb_trim
cfg80211: Unknown symbol skb_trim (err -22)
cfg80211: disagrees about version of symbol rfkill_register
cfg80211: Unknown symbol rfkill_register (err -22)
cfg80211: disagrees about version of symbol dev_change_net_namespace
cfg80211: Unknown symbol dev_change_net_namespace (err -22)
cfg80211: disagrees about version of symbol rfkill_set_sw_state
cfg80211: Unknown symbol rfkill_set_sw_state (err -22)
insmod: can't insert 'cfg80211.ko': Invalid argument
