WM8960 driver porting in 3.14 kernel
3,919 次查看
bandarulavanya
Hi all,
I am trying to use wm8960 in my kernel i can able to play what ever i recorded(arecord) using aplay But i am getting noise.
My MCLK is 24MHZ, SYSCLK-11.2896 and sample rate is 44.1. I am using LINPUT1 to Left out from Speaker i am using.
Kindly any one give the configurations for sample rates 16000, 8000, and 44100.
Thanks & Regards,
Lavanya
标签 (2)
标记 (3)
3,496 次查看
Hi Lavanya
please check patches on
https://community.nxp.com/docs/DOC-106295
https://community.nxp.com/thread/439583
3,497 次查看
bandarulavanya
Hi igorpadykov,
I tried those register settings but no use.
i am not able to get any thing. Is there any other settings, we are getting MCLK as 24MHz we probed with DSO.
Lavanya
3,496 次查看
Hi Lavanya
typical bring-up procedure is to check codec clocks with oscilloscope,
use driver sources described in attached Linux Manual Table 28-1
Stereo Codec SoC Driver Files for debugging.
