WM8524CGEDT
WM8524CGEDT
1,181件の閲覧回数
idom
according to IMX8MMEVKHUG on the Audio DAC schematic.
"Line out levels only for audio
Not for headphone use!"
Can you tell me the reason?
Will all headphones wont work?
1,143件の閲覧回数
weidong_sun
Hi ldo
line out pins should be connected to SPEAKER, NOT Headphone, otherwise due higher power output, Headphone is easily damaged.
 More detailed information, you can check WM8524 datasheet.
Have a nice day!
BR,
Weidong
