WEC7, iMX6Q : SDBUS error in MultiBinFS implementation on SD
5,553 次查看
KeshavaGN
Hi all,
I'm trying to implement MultiBinFS OS image on SDMMC.
I have flashed the SD with eboot.nb0 and NK.nb0 using cfimager.exe -raw
It is loading xip.nb0 successfully and loading sdbus.dll, sdmemory.dll and usdhc.dll (which are changed for MultiBinFS as suggested in this link. Difference is that I'm having an updated WEC7 and i'm implementing on iMX6Q).
But then I'm getting data abort exception in SDBus.dll.
I checked the debug build and below is the log.
Any help is greatly appreciated.
DEBUG LOG:
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar 31 2014 at 17:35:09
ProcessorType=0c09  Revision=10 CpuId=0x412fc09a
OEMAddressTable = 80201424
Initializing VFP, FPSID=41033094
NKStartup done, starting up kernel. nCpus = 1
Windows CE KernelInit
Booting Windows CE version 7.00 for (ARM)
Memory Configuring: Total pages: 206549, Filesystem pages = 25818
Booting kernel with clean memory configuration:
Total Memory Sections:4
[0] (static): start: 80927000, extension/attributes: 0003e000, length: 0f6d5000
[1] (dynamic): start: 002d0000, extension/attributes: 00040800, length: 10000000
[2] (dynamic): start: 003d0000, extension/attributes: 00040800, length: 10000000
[3] (dynamic): start: 004d0000, extension/attributes: 0000c800, length: 03000000
Scheduling the first thread.
PID:00400002 TID:00410002 PGPOOL: Reserved 768 pages for Loader pool
PID:00400002 TID:00410002 PGPOOL: Reserved 256 pages for File pool
PID:00400002 TID:00410002 OSAXST0: Platform Name = i.MX6Q SABREAuto
PID:00400002 TID:00410002 OSAXST1: >>> Loading Module 'kd.dll' (0xC0801F30) at address 0xEFFE0000-0xEFFFE000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00410002 KD: Starting kernel debugger software probe (KdStub) - KD API version 27
PID:00400002 TID:00410002 OSAXST1: >>> Loading Module 'NK.EXE' (0x80909AD0) at address 0x80200000-0x80230000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00410002 Message Queue support initialized, g_hMsgQHeap = c48c0010
PID:00400002 TID:00500002 OSAXST1: >>> Loading Module 'filesys.dll' (0xC08027D4) at address 0xEFD10000-0xEFDD7000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00500002 OSAXST1: >>> Loading Module 'fsdmgr.dll' (0xC080290C) at address 0xEFC30000-0xEFC85000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00520002 FileSystem Starting - starting with clean file system
PID:00400002 TID:00520002 OSAXST1: >>> Loading Module 'romfsd.dll' (0xC0803000) at address 0xEFD00000-0xEFD07000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00520002 OSAXST1: >>> Loading Module 'binfs_sdmemory.dll' (0xC0805000) at address 0xEFB40000-0xEFB5B000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00520002 OSAXST1: >>> Loading Module 'binfs_sdbus.dll' (0xC0805138) at address 0xEFB60000-0xEFB9D000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00520002 OSAXST1: >>> Loading Module 'k.ceddk.dll' (0xC0805270) at address 0xEFC00000-0xEFC0E000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00520002 SDBusDriver: PROCESS_ATTACH
PID:00400002 TID:00520002 SDMemory: +SMC_Init
PID:00400002 TID:00520002 SDMemory: LoadDriver binfs_sdbus.dll.
PID:00400002 TID:00520002 SDMemory: Call SDC_Init(), hLoadDriver = 0xc0805138.
PID:00400002 TID:00520002 SDBusDriver: +SDC_Init
PID:00400002 TID:00520002 SDBusDriver: Bus Driver instance created : 0xC4833AD0 ! -SDC_Init
PID:00400002 TID:00520002 SDMemory: LoadDriver binfs_usdhc.dll.
PID:00400002 TID:00520002 OSAXST1: >>> Loading Module 'binfs_usdhc.dll' (0xC0805700) at address 0xEFBA0000-0xEFBC1000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00520002 OSAXST1: >>> Loading Module 'cspddk.dll' (0xC0805838) at address 0xEFBD0000-0xEFBEF000 in Process 'NK.EXE' (0x80909AD0)
PID:00400002 TID:00520002 SDHCDGetHCFunctions: +Init
PID:00400002 TID:00520002 SDHCDGetHCFunctions: -Init
PID:00400002 TID:00520002 SDMemory: Call SHC_Init(), hLoadDriver = 0xc0805700.
PID:00400002 TID:00520002 SDHC +Init
PID:00400002 TID:00520002 SDHC Active RegPath: Drivers\BlockDevice\USDHC
PID:00400002 TID:00520002 +CUSDHCBase::Init: Active RegPath: Drivers\BlockDevice\USDHC
PID:00400002 TID:00520002 Unknown: DEBUGCHK failed in file e:\wince700\platform\common\src\soc\common_fsl_v3\binfs_sdcard\sdbus\sdworki.cpp at line 101
  KdTrap: JIT debugging requested, waiting for OEM selection
  KdTrap: JIT debugging accepted
PID:00400002 TID:00520002 DEBUG_BREAK @efb92128 Ignored.
PID:00400002 TID:00520002 m_dwVendorVersion=0x0
PID:00400002 TID:00520002 SlotpOptionHandler: Caps = 0x2001013c, HSS = 0x1
PID:00400002 TID:00520002 SDHCInitialize++
PID:00400002 TID:00520002 CUSDHCBase::Start
PID:00400002 TID:00520002 CUSDHCBase::Start: PROCTL set value = 7000021
PID:00400002 TID:00520002 SDHC[3]: Using ADMA2
PID:00400002 TID:00520002 CUSDHCBase32BitADMA2:Create DMA Object for ADMA2
PID:00400002 TID:00520002 BspUSDHCInit==>
PID:00400002 TID:00520002 BspUSDHCInit1
PID:00400002 TID:00520002 sdhc3
PID:00400002 TID:00520002 SetClockRate - Requested Rate: 100000, Setting clock rate to 96679 Hz
PID:00400002 TID:00520002 SYSCTL 0x008E40FF
PID:00400002 TID:009D0002 SDHC[3] status did not change
PID:00400002 TID:00520002 SDHCInitialize--
PID:00400002 TID:00520002 -CUSDHCBase::Init
PID:00400002 TID:00520002 SDHC -Init
PID:00400002 TID:00520002 SDMemory: Load SDBUS driver Done.
PID:00400002 TID:00980002 CUSDHCBase::SetInterface: Setting for 1 bit mode
PID:00400002 TID:00980002 CUSDHCBase::SetInterface: PROCTL value = 0x7800021
PID:00400002 TID:00980002 SetClockRate - Requested Rate: 100000, Setting clock rate to 96679 Hz
PID:00400002 TID:00980002 SYSCTL 0x008E40FF
PID:00400002 TID:00980002 SDSetCardInterfaceForSlot - HC ClockRate differs desired setting: desired: 100000 Hz, Actual : 96679 Hz
PID:00400002 TID:00980002 SendCommand ucCmd = 0x5, Arg = 0x0, respType = 0x5, TransferClass = 0x2
PID:00400002 TID:00980002 HandleCommandErrors - STATUS ERROR BITS=0x00010000
PID:00400002 TID:00980002 DumpCurrentRequest: 0xC4834494
PID:00400002 TID:00980002        Command: 5
PID:00400002 TID:00980002        Argument: 0x00000000
PID:00400002 TID:00980002        ResponseType: 5
PID:00400002 TID:00980002        NumBlocks: 0
PID:00400002 TID:00980002        BlockSize: 0
PID:00400002 TID:00980002        HCParam: 0
PID:00400002 TID:00980002 +DumpUSDHCRegs-------------------------
PID:00400002 TID:00980002 DSADDR 0x00000000
PID:00400002 TID:00980002 BLKATTR 0x00010200
PID:00400002 TID:00980002 CMDARG 0x00000000
PID:00400002 TID:00980002 XFERTYP 0x05020000
PID:00400002 TID:00980002 CMDRSP0 0x00000900
PID:00400002 TID:00980002 CMDRSP1 0x001D8A7F
PID:00400002 TID:00980002 CMDRSP2 0x325B5900
PID:00400002 TID:00980002 CMDRSP3 0x00000B00
PID:00400002 TID:00980002 PRSSTAT 0xFF8D8089
PID:00400002 TID:00980002 PROCTL 0x07800021
PID:00400002 TID:00980002 IRQSTAT 0x00010000
PID:00400002 TID:00980002 AUTOC12ERR 0x00000000
PID:00400002 TID:00980002 HOSTCAPBLT 0x07F30000
PID:00400002 TID:00980002 WML 0x08800880
PID:00400002 TID:00980002 HOSTVER 0x00000003
PID:00400002 TID:00980002 -DumpUSDHCRegs-------------------------
PID:00400002 TID:00980002 HandleCommandErrors - Command line error (0x10000). Resetting CMD line.
PID:00400002 TID:00980002 SDSynchronousBusRequest_I: queue request failed(0xc0000014),TransferClass(2), CommandCode(5),CommandArgument(0)
PID:00400002 TID:00980002 SendCommand ucCmd = 0x0, Arg = 0x0, respType = 0x0, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x1, Arg = 0x400e0000, respType = 0x4, TransferClass = 0x2
PID:00400002 TID:00980002        Command: 1
PID:00400002 TID:00980002        Argument: 0x400e0000
PID:00400002 TID:00980002        ResponseType: 4
PID:00400002 TID:00980002 CMDARG 0x400E0000
PID:00400002 TID:00980002 XFERTYP 0x01020000
PID:00400002 TID:00980002 SDSynchronousBusRequest_I: queue request failed(0xc0000014),TransferClass(2), CommandCode(1),CommandArgument(400e0000)
PID:00400002 TID:00980002 SendCommand ucCmd = 0x8, Arg = 0x15a, respType = 0x8, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x37, Arg = 0x0, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x29, Arg = 0x400e0000, respType = 0x4, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x29, Arg = 0x40040000, respType = 0x4, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x2, Arg = 0x0, respType = 0x3, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x3, Arg = 0x0, respType = 0x7, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x9, Arg = 0xe6240000, respType = 0x3, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0xd, Arg = 0xe6240000, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x7, Arg = 0xe6240000, respType = 0x2, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x37, Arg = 0xe6240000, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00980002 SendCommand ucCmd = 0x33, Arg = 0x0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00980002 SendCommand ucCmd = 0x2a, Arg = 0x0, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00980002  GetCustomRegPath
PID:00400002 TID:00980002  get the parsed CID registers
PID:00400002 TID:00980002  SD_API_SUCCESS(status)
PID:00400002 TID:00980002 SDBusDriver: built custom MMC/SD path: \Drivers\SDCARD\ClientDrivers\Custom\CID-03-DS-G40US
PID:00400002 TID:00980002 SDBusDriver: The SDIO card does not support block mode.  Use Soft-Block instead.
PID:00400002 TID:00980002 SendCommand ucCmd = 0x6, Arg = 0x2, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00980002 CUSDHCBase::SetInterface: Setting for 4 bit mode
PID:00400002 TID:00980002 CUSDHCBase::SetInterface: PROCTL value = 0x7800023
PID:00400002 TID:00980002 SetClockRate - Requested Rate: 25000000, Setting clock rate to 24750000 Hz
PID:00400002 TID:00980002 SYSCTL 0x008E007F
PID:00400002 TID:00980002 SDSetCardInterfaceForSlot - HC ClockRate differs desired setting: desired: 25000000 Hz, Actual : 24750000 Hz
PID:00400002 TID:00980002 The clock rate is set to 24750000PID:00400002 TID:00980002 SendCommand ucCmd = 0x6, Arg = 0x1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00980002 SendCommand ucCmd = 0x6, Arg = 0x80000001, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00980002 SetClockRate - Requested Rate: 24750000, Setting clock rate to 24750000 Hz
PID:00400002 TID:00980002 SYSCTL 0x008E040F
PID:00400002 TID:00980002 SendCommand ucCmd = 0x7, Arg = 0x0, respType = 0x0, TransferClass = 0x2
PID:00400002 TID:00980002 SetClockRate - Requested Rate: 50000000, Setting clock rate to 49500000 Hz
PID:00400002 TID:00980002 SYSCTL 0x008E003F
PID:00400002 TID:00980002 The clock rate is set to 50000000PID:00400002 TID:00980002 LoadDevice: type = 2, slot 0PID:00400002 TID:00980002 SDLoadDevice
PID:00400002 TID:00980002 SDLoadDevice no CUSTOM driver path was found so set the default path
PID:00400002 TID:00980002 SDLoadDevice Device_SD_Memory == m_DeviceType || Device_SD_Combo == m_DeviceType
PID:00400002 TID:00980002 SDLoadDevice SDLoadDevice Device_SD_Memory == m_DeviceType || Device_SD_Combo == m_DeviceType BSP_SUPPORT_MULTIBIN
PID:00400002 TID:00980002 SDLoadDevice SUCCEEDED(hr)
PID:00400002 TID:00980002 SDLoadDevice ASSERT(deviceFound);
PID:00400002 TID:00980002 SDLoadDevice GetHostContainer
PID:00400002 TID:00980002 SDLoadDevice status = SD_API_STATUS_UNSUCCESSFUL;
PID:00400002 TID:00980002 SDLoadDevice new DeviceFolder
PID:00400002 TID:00980002 DeviceFolder::DeviceFolder
PID:00400002 TID:00980002 SDLoadDevice m_pDriverFolder->Init
PID:00400002 TID:00980002 DeviceFolder::AddInitReg
PID:00400002 TID:00980002 SDLoadDevice m_pDriverFolder->AddRef
PID:00400002 TID:00980002 SDLoadDevice Ready
PID:00400002 TID:00980002 DeviceFolder::LoadDevice
PID:00400002 TID:00980002 Exception 'Data Abort' (0x4): Thread-Id=00980002(pth=c0806700), Proc-Id=00400002(pprc=80909ad0) 'NK.EXE', VM-active=00400002(pprc=80909ad0) 'NK.EXE'
PID:00400002 TID:00980002 PC=efe4d908(k.coredll.dll+0x0004d908) RA=00000030(???+0x00000030) SP=ccb1f778, BVA=00000030
PID:00400002 TID:00980002 RtlDispatchException: returning failure. Flags=0
Unhandled exception c0000005:
PID:00400002 TID:00980002 Secondary thread in proc 00400002 faulted, Exception code = c0000005, Exception Address = efe4d908!
Thanks.
Keshava
15 回复数
4,791 次查看
qiang_li-mpu_se
By the way, I found your code "BOOL CSDWorkItem::Init(DWORD  dwCeThreadPriority)" is wrong, that error "ASSERT(FALSE);" will always happen, even though bRet=TRUE;
Then the "Unlock();" will never be called.
My original code is based on "wince700\public\COMMON\oak\drivers\sdcard\sdbus", but I found your code is not from there.
For MultiBIN system, NK.nb0 was not used, the final image is xip.nb0.
4,791 次查看
KeshavaGN
The new log :
It's unloading filesys.dll and after that showing exception in fsdmgr.dll . Please help:
Microsoft Windows CE Ethernet Bootloader 1.0 for MX6Q SABREAuto (Aug 12 2014 17:29:10)
INFO: Loading boot configuration from SDHC
INFO: Successfully loaded boot configuration from SDHC
3 seconds.
Freescale iMX SOC Menu Item
[0] IP Address : 192.168.2.5
[1] Set IP Mask : 255.255.255.0
[2] Boot Delay : 3
[3] DHCP : Disabled
[4] Reset to Factory Default Configuration
[5] Select Boot Device : NK from SD/MMC
[6] Set MAC Address : ff-ff-ff-ff-ff-ff
[7] Format OS NAND Region
[8] Format All NAND Regions
[9] Bootloader Shell
[I] KITL Work Mode : Interrupt
[K] KITL Enable Mode : Enable
[P] KITL Passive Mode : Disable
[S] Save Settings
[D] Download Image Now
[L] Launch Existing Flash Resident Image Now
[E] Select Ether Device : ENET
[M] MMC and SD Utilities : SDHC[3] is activated
[A] ATA Utilities
Selection: k
Freescale iMX SOC Menu Item   (UNSAVED CHANGES)
[2] Boot Delay : 3
[3] DHCP : Disabled
[K] KITL Enable Mode : Disable
[S] Save Settings
[A] ATA Utilities
Selection: s
INFO: Storing boot configuration to SDHC
INFO: Successfully stored boot configuration to SDHC
[2] Boot Delay : 3
[3] DHCP : Disabled
[S] Save Settings
[A] ATA Utilities
Selection: l
INFO: Reading NK image to SDHC (please wait)...
INFO: Copying NK image to RAM address 0xa0200000
INFO: Copying NK image size 0x700000 BYTEs.
INFO: Read is 100% complete
INFO: Copy of NK completed successfully
Either card is not eSD2.1, or boot partition is not created yet
PID:00400002 TID:00960002 SYSCTL 0x008E40FF
PID:00400002 TID:00960002 SendCommand ucCmd = 0x5, Arg = 0x0, respType = 0x5, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x0, Arg = 0x0, respType = 0x0, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x1, Arg = 0x400e0000, respType = 0x4, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x8, Arg = 0x15a, respType = 0x8, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x37, Arg = 0x0, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x29, Arg = 0x400e0000, respType = 0x4, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x29, Arg = 0x40040000, respType = 0x4, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x2, Arg = 0x0, respType = 0x3, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x3, Arg = 0x0, respType = 0x7, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x9, Arg = 0xe6240000, respType = 0x3, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0xd, Arg = 0xe6240000, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x7, Arg = 0xe6240000, respType = 0x2, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x37, Arg = 0xe6240000, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00960002 SendCommand ucCmd = 0x33, Arg = 0x0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00960002 SendCommand ucCmd = 0x2a, Arg = 0x0, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00960002  GetCustomRegPath
PID:00400002 TID:00960002  get the parsed CID registers
PID:00400002 TID:00960002  SD_API_SUCCESS(status)
PID:00400002 TID:00960002 SDBusDriver: built custom MMC/SD path: \Drivers\SDCARD\ClientDrivers\Custom\CID-03-DS-G40US
PID:00400002 TID:00960002 SendCommand ucCmd = 0x6, Arg = 0x2, respType = 0x1, TransferClass = 0x2
PID:00400002 TID:00960002 SYSCTL 0x008E007F
PID:00400002 TID:00960002 SendCommand ucCmd = 0x6, Arg = 0x1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00960002 SendCommand ucCmd = 0x6, Arg = 0x80000001, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00960002 SYSCTL 0x008E040F
PID:00400002 TID:00960002 SendCommand ucCmd = 0x7, Arg = 0x0, respType = 0x0, TransferClass = 0x2
PID:00400002 TID:00960002 SYSCTL 0x008E003F
PID:00400002 TID:00960002 SDLoadDevice
                                      PID:00400002 TID:00960002 SDLoadDevice no CUSTOM driver path was found so set the default path
PID:00400002 TID:00960002 SDLoadDevice Device_SD_Memory == m_DeviceType || Device_SD_Combo == m_DeviceType
PID:00400002 TID:00960002 SDLoadDevice SDLoadDevice Device_SD_Memory == m_DeviceType || Device_SD_Combo == m_DeviceType BSP_SUPPORT_MULTIBIN
PID:00400002 TID:00960002 SDLoadDevice SUCCEEDED(hr)
PID:00400002 TID:00960002 SDLoadDevice ASSERT(deviceFound);
PID:00400002 TID:00960002 SDLoadDevice GetHostContainer
PID:00400002 TID:00960002 SDLoadDevice status = SD_API_STATUS_UNSUCCESSFUL;
PID:00400002 TID:00960002 SDLoadDevice new DeviceFolder
PID:00400002 TID:00960002 DeviceFolder::DeviceFolder
PID:00400002 TID:00960002 SDLoadDevice m_pDriverFolder->Init
PID:00400002 TID:00960002 DeviceFolder::AddInitReg
PID:00400002 TID:00960002 SDLoadDevice m_pDriverFolder->AddRef
PID:00400002 TID:00960002 SDLoadDevice Ready
PID:00400002 TID:00960002 DeviceFolder::LoadDevice
PID:00400002 TID:00960002 SDLoadDevice LoadDevice
PID:00400002 TID:00960002 SDLoadDevice RegOpenKeyEx
PID:00400002 TID:00520002 SDMemory: +-SMC_Open
                                              PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x21902, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x902, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2902, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7bb3, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x7bb4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:009B0002 SendCommand ucCmd = 0xc, Arg = 0x0, respType = 0x2, TransferClass = 0x2
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7bbc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2c91, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2c92, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2999, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29b1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2989, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x298a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6eb5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29a9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29aa, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6eb6, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2991, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2992, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6eb7, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2949, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x294a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2959, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29c1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29c2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2939, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x293a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2929, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6eb8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2f41, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29d9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6eb9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2969, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x296a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2941, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2942, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6eba, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2951, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2952, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ebb, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x299a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ebc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29a1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29a2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ebd, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2981, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2982, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ebe, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29b2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ebf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29b9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29ba, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2931, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2932, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2961, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2962, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec3, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2f29, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2f2a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29da, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7baf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec6, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec7, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ec9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6eca, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7bb0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ecb, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ecc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ecd, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ece, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ecf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed3, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed6, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed7, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7bb1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ed9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6eda, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6edb, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6edc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6edd, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ede, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6edf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee3, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee6, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee7, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7bb2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ee9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6eea, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x7bbd, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0xc, Arg = 0x0, respType = 0x2, TransferClass = 0x2
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7bbf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3566, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3567, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3568, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3569, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x356b, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x356c, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3570, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3571, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3575, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3576, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x357a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x357b, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x357e, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x357f, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3583, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3584, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3587, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3588, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x358b, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x358c, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3590, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3591, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3594, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3595, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3599, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x359a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x359d, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x359e, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35a2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35a3, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35a6, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35a7, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35ab, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35ac, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35af, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35b0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35b4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35b5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35b9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35ba, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35bc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35bd, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35bf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2938, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2943, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2945, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35c0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35c4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35c5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35c8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x21f18, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x21f58, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x21f98, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x21fd8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22018, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22058, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22098, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x220d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22118, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22158, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22198, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x221d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22218, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22258, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22298, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x222d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22318, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22358, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22398, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x223d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22418, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22458, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22498, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x224d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22518, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22558, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22598, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x225d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22618, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22658, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22698, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x226d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22718, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22758, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22798, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x227d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22818, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22858, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22898, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x228d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22918, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22958, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22998, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x229d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22a18, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22a58, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22a98, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22ad8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22b18, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22b58, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22b98, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22bd8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22c18, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22c58, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22c98, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22cd8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22d18, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22d58, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22d98, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22dd8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22e18, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22e58, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22e98, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22ed8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22f18, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22f58, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22f98, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x22fd8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23018, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23058, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23098, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x230d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23118, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23158, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23198, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x231d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23218, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23258, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23298, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x232d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23318, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23358, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23398, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x233d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23418, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23458, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23498, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x234d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23518, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23558, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23598, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x235d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23618, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23658, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23698, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x236d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23718, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23758, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23798, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x237d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23818, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23858, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23898, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x238d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23918, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23958, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23998, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x239d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23a18, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23a58, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23a98, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23ad8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23b18, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23b58, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23b98, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x23bd8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x25902, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35c9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35cc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35cd, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35d0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35d1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35d4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35d5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35d8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35d9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35dc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35dd, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35e0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35e1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35e5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x35e6, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x35e9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2946, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2947, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2948, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2590a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ef0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x6ef1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x6ef3, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fab, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fac, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fae, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2faf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fb3, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fb4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fb7, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fb8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fbb, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fbc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fbe, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fbf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fc3, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fc4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fc7, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fc8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fcb, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fcc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fcf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fd0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fd3, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fd4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fd7, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fd8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fdb, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fdc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fe0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fe1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fe5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fe6, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fe9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fea, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fed, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2fee, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ff1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2ff2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ff4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2b59, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2f1e, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x2f1f, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2f21, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ff5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ff6, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ff7, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ff8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ff9, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ffa, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ffb, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ffc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ffd, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2ffe, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2fff, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3000, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3001, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3002, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3003, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3004, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3005, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3006, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3007, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3008, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3009, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x300a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x300b, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x300d, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x300e, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x300f, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3010, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3011, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3012, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3013, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3014, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3015, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7abb, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x7abc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7abf, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7ac0, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7ac1, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x7ac2, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7ac4, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7ac5, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7ac6, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7acc, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7acd, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x7ace, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3066, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3067, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x306a, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x306b, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x306f, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3070, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3073, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3074, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3078, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3079, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x307c, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29a8, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3652, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3653, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3654, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3655, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3658, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3659, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x365c, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x365d, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3660, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3661, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3663, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3664, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x3667, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x12, Arg = 0x3668, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x366b, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x366c, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x2958, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29ca, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 SendCommand ucCmd = 0x11, Arg = 0x29cb, respType = 0x1, TransferClass = 0x0
PID:00400002 TID:00520002 Exception 'Data Abort' (0x4): Thread-Id=00520002(pth=c0802c1c), Proc-Id=00400002(pprc=8065f5e0) 'NK.EXE', VM-active=00400002(pprc=8065f5e0) 'NK.EXE'
PID:00400002 TID:00520002 PC=eff124f8(k.coredll.dll+0x000224f8) RA=efde3e4c(fsdmgr.dll+0x00003e4c) SP=c48ff26c, BVA=efe717dc
!KITLRegisterDfltClient called before KitlInit. KITLGlobalState=00000080
PID:00400002 TID:00520002 PC=80273668(kernel.dll+0x00038668) RA=80273618(kernel.dll+0x00038618) SP=c48fee3c, BVA=efe71798
PID:00400002 TID:01790006 Exception 'Data Abort' (0x4): Thread-Id=01790006(pth=c0809b10), Proc-Id=00400002(pprc=8065f5e0) 'NK.EXE', VM-active=00400002(pprc=8065f5e0) 'NK.EXE'
PID:00400002 TID:01790006 PC=eff126f0(k.coredll.dll+0x000226f0) RA=efe71798(???+0xefe71798) SP=cecff9ec, BVA=efe717f4
4,791 次查看
qiang_li-mpu_se
Hi Kesava, your log is OK, the binfs_sdmemory.dll had been successfully loaded "PID:00400002 TID:00520002 SDMemory: -SMC_Init". For the file system issue, did you create BINFS MBR on your SD card?.
4,791 次查看
KeshavaGN
I'm sorry, the actual log when creating BINFS MBR is:
Card Capacity 3872256 (Kbytes)
Successfully created 3 partitions
Boot Partition size = 1152 Kbytes, startSect = 0x2, totSect = 0x900.
BINFS Partition size = 67584 Kbytes, startSect = 0x902, totSect = 0x21000
File System Partition size = 3803519 Kbytes, startSect = 0x21902, totSect = 0x7412fe
MultiBIN MBR was created.
4,791 次查看
KeshavaGN
And still the exception is not solved.
4,791 次查看
qiang_li-mpu_se
I have no more idea for your issues.
4,791 次查看
KeshavaGN
Thanks.
Can you please clarify:
1. Whether my understanding is correct about creating binfs mbr? that is using eboot menu... Is there any other tool for this?
2. If I insert the card to Win7 PC (after creating binfs mbr in eboot), I'm getting this prompt to format the card, and if I format it, the binaries will be erased. Is it OK?
4,791 次查看
qiang_li-mpu_se
For Q1, yes, no other tool for BINFS MBR.
For Q2, you should not format the card on PC again.
4,791 次查看
KeshavaGN
Reg. Q2.
I asked this because, according to eboot MBR utility, it will create 3rd partition as FATFS. But it's not opening on host PC.
4,791 次查看
KeshavaGN
And if I insert the card to Win7 PC, I'm getting this prompt to format the card, and if I format it, the binaries will be erased. Is it OK?
4,791 次查看
KeshavaGN
Hi Qiang_FSL ,
Thanks for reply.
I have tried creating the BINFS MBR using eboot menu utility.
I got following prints. Is it ok?
Please help.
Thanks & regards,
Keshava
4,791 次查看
KeshavaGN
Hi Qiang_FSL ,
I have edited the code little more so that I can get a code similar to your's ,
and I am not getting exception in SDBus/SDMemory.
So, now SDMemory initialization is completed.
I'm getting the following prints:
PID:00400002 TID:00980002 SDHCGetLocalAdaptiveControl_I: type = 2, slot 0PID:00400002 TID:00980002 SDHCUpcallSetAdaptiveControl_I: type = 2, slot 0PID:00400002 TID:00520002 SDGetDeviceHandle: ActivePath: Drivers\BlockDevice\SDMMC
        PID:00400002 TID:00520002 SDGetClientFunctions: +Init
                                           PID:00400002 TID:00520002 SDGetClientFunctions: -Init
                PID:00400002 TID:00520002 SDMemCardConfig: Card is high capacity (2.0+)
PID:00400002 TID:00520002 SDMemCalcDataAccessClocks: Tpd:f ns, Asynch: f ns, AsyncClocks:0 , SyncClocks: 1077149696, ReadTotal: 0, Write Factor: 1093567616 WriteTotal: 50000
              PID:00400002 TID:00520002 SDMemory: Initialize: Using block transfer size of 64 blocks
PID:00400002 TID:00520002 SDMemory: Idle Timeout: 2000 Idle Power State: 2
PID:00400002 TID:00520002 SDCard: Warning: Please call SDInitializeCardLib to avoid race conditions
                   PID:00400002 TID:00520002 SDMemory: Power Management Setup complete
But theoretically what should happen once the sdmemory initialization is completed? Can you please guide on this? Because I'm getting exceptions in coredll.
Keshava
4,791 次查看
qiang_li-mpu_se
Hi Keshava, I think you can use my original "WINCE700\PLATFORM\COMMON\SRC\SOC\COMMON_FSL_V3\BINFS_SDCARD\" to try. Those codes are not hardware related.
4,791 次查看
KeshavaGN
Hi Qiang_FSL,
As i already mentioned, initially I tried it..
But I was getting build errors (may be because of updates?)
BUILD: [02:0000000112:ERRORE] Error(s) in directory "E:\WINCE700\platform\common\src\soc\COMMON_FSL_V3\BINFS_SDCARD\SDBUS\".
BUILD: [02:0000000113:ERRORE] e:\wince700\public\common\ddk\inc\cesdbus.h(202) : error C2146: syntax error : missing ';' before identifier 'pAdaptiveControl'
BUILD: [02:0000000114:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2059: syntax error : '<L_TYPE_raw>'
BUILD: [02:0000000115:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2238: unexpected token(s) preceding ';'
BUILD: [02:0000000116:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(448) : error C2061: syntax error : identifier 'PSD_CARD_STATUS'
BUILD: [02:0000000121:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2059: syntax error : '<L_TYPE_raw>'
BUILD: [02:0000000122:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2238: unexpected token(s) preceding ';'
BUILD: [02:0000000123:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(448) : error C2061: syntax error : identifier 'PSD_CARD_STATUS'
BUILD: [02:0000000124:ERRORE] e:\wince700\public\common\ddk\inc\cesdbus.h(202) : error C2146: syntax error : missing ';' before identifier 'pAdaptiveControl'
BUILD: [02:0000000128:ERRORE] e:\wince700\public\common\ddk\inc\cesdbus.h(202) : error C2146: syntax error : missing ';' before identifier 'pAdaptiveControl'
BUILD: [02:0000000129:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2059: syntax error : '<L_TYPE_raw>'
BUILD: [02:0000000130:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2238: unexpected token(s) preceding ';'
BUILD: [02:0000000131:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(448) : error C2061: syntax error : identifier 'PSD_CARD_STATUS'
BUILD: [02:0000000134:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2059: syntax error : '<L_TYPE_raw>'
BUILD: [02:0000000135:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2238: unexpected token(s) preceding ';'
BUILD: [02:0000000136:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(448) : error C2061: syntax error : identifier 'PSD_CARD_STATUS'
BUILD: [01:0000000137:ERRORE] Error(s) in directory "E:\WINCE700\platform\common\src\soc\COMMON_FSL_V3\BINFS_SDCARD\SDCARDLIB\".
BUILD: [01:0000000138:ERRORE] e:\wince700\platform\common\src\soc\common_fsl_v3\binfs_sdcard\sdcardlib\busacc.cpp(41) : error C2440: '=' : cannot convert from 'void (__cdecl *)(HBUS_REQUEST)' to 'PSD_FREE_BUS_REQUEST'
BUILD: [01:0000000140:ERRORE] e:\wince700\platform\common\src\soc\common_fsl_v3\binfs_sdcard\sdcardlib\busacc.cpp(47) : error C2440: '=' : cannot convert from 'void (__cdecl *)(SD_DEVICE_HANDLE)' to 'PSD_IO_DISCONNECT_INTERRUPT'
BUILD: [02:0000000144:ERRORE] e:\wince700\public\common\ddk\inc\cesdbus.h(202) : error C2146: syntax error : missing ';' before identifier 'pAdaptiveControl'
BUILD: [02:0000000145:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2059: syntax error : '<L_TYPE_raw>'
BUILD: [02:0000000146:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2238: unexpected token(s) preceding ';'
BUILD: [02:0000000147:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(448) : error C2061: syntax error : identifier 'PSD_CARD_STATUS'
BUILD: [01:0000000150:ERRORE] NMAKE : fatal error U1077: 'E:\WINCE700\sdk\bin\i386\ARM\cl.EXE' : return code '0x2'
BUILD: [01:0000000152:ERRORE]  clean TargetCompilePass  -nologo BUILDMSG=Stop.  BUILDROOT=E:\WINCE700\platform\common CLEANBUILD=1 NOLINK=1 NOPASS0=1 failed - rc = 2.
BUILD: [02:0000000153:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2059: syntax error : '<L_TYPE_raw>'
BUILD: [02:0000000154:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2238: unexpected token(s) preceding ';'
BUILD: [02:0000000155:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(448) : error C2061: syntax error : identifier 'PSD_CARD_STATUS'
BUILD: [02:0000000157:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2059: syntax error : '<L_TYPE_raw>'
BUILD: [02:0000000158:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2238: unexpected token(s) preceding ';'
BUILD: [02:0000000159:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(448) : error C2061: syntax error : identifier 'PSD_CARD_STATUS'
BUILD: [02:0000000161:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2059: syntax error : '<L_TYPE_raw>'
BUILD: [02:0000000162:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(241) : error C2238: unexpected token(s) preceding ';'
BUILD: [02:0000000163:ERRORE] e:\wince700\public\common\oak\inc\sdhcd.h(448) : error C2061: syntax error : identifier 'PSD_CARD_STATUS'
BUILD: [02:0000000165:ERRORE] e:\wince700\public\common\ddk\inc\cesdbus.h(202) : error C2146: syntax error : missing ';' before identifier 'pAdaptiveControl'
BUILD: [02:0000000168:ERRORE] NMAKE : fatal error U1077: 'E:\WINCE700\sdk\bin\i386\ARM\cl.EXE' : return code '0x2'
Hence I cloned my own SDBus, SDMemory etc.
Can you please try the code on updated WEC7 system and let me know the result?
Thanks & regards,
Keshava
4,791 次查看
KeshavaGN
Hi Qiang_FSL , Deactivated user , sunajiang , huzizhen , henrylee , holyyuan can you help on this?
