Dear support,
We came across a dragging issue which we could not solve for weeks. Currently we built core-image-base and qt4-embedded based on Yocto 3.14.26 for Sabresd board with necessary components listed as the following.
local.conf
MACHINE ??= 'imx6solosabresd'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks"
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
ABORT,${TMPDIR},100M,1K \
ABORT,${DL_DIR},100M,1K \
ABORT,${SSTATE_DIR},100M,1K"
PACKAGECONFIG_append_pn-qemu-native = " sdl"
PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
ASSUME_PROVIDED += "libsdl-native"
CONF_VERSION = "1"
IMAGE_INSTALL_append = " \
freetype jpeg libpng zlib dbus openssl glib-2.0 gstreamer gst-plugins-base sqlite3 tiff icu \
pulseaudio \
qt4-embedded \
libqt-embedded3support4 \
libqt-embeddedclucene4 \
libqt-embeddedcore4 \
libqt-embeddeddbus4 \
libqt-embeddedgui4 \
libqt-embeddedhelp4 \
libqt-embeddedmultimedia4 \
libqt-embeddednetwork4 \
libqt-embeddedscript4 \
libqt-embeddedscripttools4 \
libqt-embeddedsql4 \
libqt-embeddedsvg4 \
libqt-embeddedtest4 \
libqt-embeddedxml4 \
qt4-embedded-fonts-ttf-dejavu \
qt4-embedded-fonts-ttf-vera \
qt4-embedded-plugin-iconengine-svgicon \
qt4-embedded-plugin-imageformat-gif \
qt4-embedded-plugin-imageformat-ico \
qt4-embedded-plugin-imageformat-jpeg \
qt4-embedded-plugin-imageformat-mng \
qt4-embedded-plugin-imageformat-svg \
qt4-embedded-plugin-imageformat-tiff \
qt4-embedded-plugin-phonon-backend-gstreamer \
qt4-embedded-plugin-script-dbus \
qt4-embedded-plugin-sqldriver-sqlite \
gst-plugins-good \
gst-plugins-bad \
gst-fsl-plugin \
gst-meta-base \
libxml2 libcheck liboil libpng \
BB_NUMBER_THREADS = '4'
PARALLEL_MAKE = '-j 4'
DL_DIR ?= "${BSPDIR}/downloads/"
ACCEPT_FSL_EULA = ""
PREFERRED_PROVIDER_virtual/mesa = ""
DISTRO_FEATURES_remove = " wayland directfb "
Unfortunately we found we could not show any video based on the gstreamer0.1 inside qt4-embedded. However, gstreamer0.1 could work independently. Interestingly the audio playback is find inside qt4-embedded. The error we got when decoding video is missing gstreamer0.1-plugins-good but gst-plugins-good has been installed in the image. The display is a standard LCD display. Could anyone share his/her experience to tell us how to configure qt4-embedded to make it support mp4 video playback?
Vincent
