VPU video encoding can fast forward in Windows software
1,803 次查看
画梁佳
I use Freescale official Vpu code, and then with Windows software play, play normally, but can not fast forward and rewind, may I ask, are there any good solution?
1,749 次查看
joanxie
could you share more detailed information with me? what bsp version do you use? and did you try to use gstreamer to test this?
1,749 次查看
画梁佳
hello! I use the BSP version is L3.0.35_4.1.0_130816_source , GStreamer that I not use too, do not know what to do, I am now using L3.0.35_4.1.0_130816_source compiled mxc_vpu_test.outt to coding, and windows software video playback, no fast forward
