Using Segger J-Link with the IMX8MPLUS EVK
dylanrd
I currently have the IMX8M Plus EVK, along with the J-Link Plus Compact. I am trying to connect to the EVK using JTAG. I am trying to connect to either the M7 core or the A53 core. However, I keep getting the same type of errors. Either 'Supply Voltage too low', or 'TDO is constantly high'. I have tried selecting different devices to connect to the EVK using J-Link Commander. The devices I have used are 'MIMX8ML8_M7' or 'MIMX8ML8_A53_*' and then any of the available cores. The DIP switches are set to Serial Download. I am wondering if there is something specific we need to change, or do as a prerequisite to get the connection to work properly. We have found different guides, but they all seem to assume that the connection is already established.
Manuel_Salas
Hello @dylanrd
I hope you are doing very well.
Have you tried with the AN14120?
There is explained the connection and integration with VSCode.
Also, you can take a look to this community post about the connection.
Salas.
dylanrd
Hi @Manuel_Salas , I have followed that tutorial but it still does not seem to connect properly and I get the errors as I have mentioned beforw. Do you know of any parts that people often get stuck with that I might have overlooked?
Thanks in advance!
%3CLINGO-SUB%20id%3D%22lingo-sub-2162317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUsing%20Segger%20J-Link%20with%20the%20IMX8MPLUS%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20currently%20have%20the%20IMX8M%20Plus%20EVK%2C%20along%20with%20the%20J-Link%20Plus%20Compact.%20I%20am%20trying%20to%20connect%20to%20the%20EVK%20using%20JTAG.%20I%20am%20trying%20to%20connect%20to%20either%20the%20M7%20core%20or%20the%20A53%20core.%20However%2C%20I%20keep%20getting%20the%20same%20type%20of%20errors.%20Either%20'Supply%20Voltage%20too%20low'%2C%20or%20'TDO%20is%20constantly%20high'.%20I%20have%20tried%20selecting%20different%20devices%20to%20connect%20to%20the%20EVK%20using%20J-Link%20Commander.%20The%20devices%20I%20have%20used%20are%20'MIMX8ML8_M7'%20or%20'MIMX8ML8_A53_*'%20and%20then%20any%20of%20the%20available%20cores.%20The%20DIP%20switches%20are%20set%20to%20Serial%20Download.%20I%20am%20wondering%20if%20there%20is%20something%20specific%20we%20need%20to%20change%2C%20or%20do%20as%20a%20prerequisite%20to%20get%20the%20connection%20to%20work%20properly.%20We%20have%20found%20different%20guides%2C%20but%20they%20all%20seem%20to%20assume%20that%20the%20connection%20is%20already%20established.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2162317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Segger%20J-Link%20with%20the%20IMX8MPLUS%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203368%22%20target%3D%22_blank%22%3E%40Manuel_Salas%3C%2FA%3E%26nbsp%3B%2C%20I%20have%20followed%20that%20tutorial%20but%20it%20still%20does%20not%20seem%20to%20connect%20properly%20and%20I%20get%20the%20errors%20as%20I%20have%20mentioned%20beforw.%20Do%20you%20know%20of%20any%20parts%20that%20people%20often%20get%20stuck%20with%20that%20I%20might%20have%20overlooked%3F%3C%2FP%3E%3CP%3EThanks%20in%20advance!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20Segger%20J-Link%20with%20the%20IMX8MPLUS%20EVK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253616%22%20target%3D%22_blank%22%3E%40dylanrd%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20hope%20you%20are%20doing%20very%20well.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20you%20tried%20with%20the%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14120.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN14120%3C%2FA%3E%3F%3C%2FP%3E%0A%3CP%3EThere%20is%20explained%20the%20connection%20and%20integration%20with%20VSCode.%3C%2FP%3E%0A%3CP%3EAlso%2C%20you%20can%20take%20a%20look%20to%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHow-to-Use-Segger-J-Link-Plus-with-i-MX-8M-Processors-EVKs-to%2Fta-p%2F1742362%22%20target%3D%22_self%22%3Ethis%20community%3C%2FA%3E%20post%20about%20the%20connection.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E
