Using MFG tool to write JFFS2 type rootfs
1,465件の閲覧回数
nagesha71
Hi all,
We are using i.MX53 SABRE SMD tablet.
We have used Freescale provided MFG tool to programme the Linux images, like u-boot, uImage, and rootfs.tar.bz2 to the eMMC4.4 card which is of size 4GB.
The MFG tool internally uses a script file in which it is basically creating a partitions using "dd" command and untar'ing the rootfs.tar.bz2 image in that partition.
But our requirement is to go for JFFS2 type rootfs.
I am not able to understand how it can be worked with MFG tool to flash JFFS2 type rootfs image.
Can anybody give suggestions over this ?
Is it possible to flash JFFS2 rootfs images in i.MX53 SMD tablet board ?
thanks in advance,
-Nagesh A
0 返答(返信)
