Using MFG TOOLS with i.MX6SXSD,something wrong with it
3,442 次查看
bowenzhang
log:
Allocating group tables: done
Writing inode tables: done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: done
UTP: sending Success to kernel for command $ mkfs.ext4 /dev/mmcblk3p6.
utp_poll: pass returned.
UTP: received command '$ mkfs.ext4 /dev/mmcblk3p7'
UTP: executing "mkfs.ext4 /dev/mmcblk3p7"
mke2fs 1.42.9 (28-Dec-2013)
Filesystem label=
OS type: Linux
Block size=1024 (log=0)
Fragment size=1024 (log=0)
Stride=0 blocks, Stripe width=0 blocks
2048 inodes, 8192 blocks
409 blocks (4.99%) reserved for the super user
First data block=1
Maximum filesystem blocks=8388608
1 block group
8192 blocks per group, 8192 fragments per group
2048 inodes per group
Creating journal (1024 blocks): done
UTP: sending Success to kernel for command $ mkfs.ext4 /dev/mmcblk3p7.
UTP: received command '$ mount -o remount,size=600M rootfs /'
UTP: executing "mount -o remount,size=600M rootfs /"
UTP: sending Success to kernel for command $ mount -o remount,size=600M rootfs /.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ simg2img $FILE /dev/mmcblk3p5'
UTP: executing "simg2img $FILE /dev/mmcblk3p5"
Failed to read sparse file
UTP: sending Non-success to kernel for command $ simg2img $FILE /dev/mmcblk3p5.
utp_poll: exit with status 65280
6 回复数
3,223 次查看
bowenzhang
I used demo image.Now,I have make it.because  mfg's version is wrong.thx
3,223 次查看
brunochen
I have the same problem.
How do you know you use the wrong mfg version?
BTW, could you share how to find the correct mfg tool?
Bruno
3,223 次查看
bowenzhang
3,223 次查看
brunochen
Got it. Many thanks!!!
3,223 次查看
bowenzhang
I have changed serval sd card,but nothing changed.
3,223 次查看
joanxie
could you tell me the steps? let's reproduce this, did you  use demo image or cusomized image? pls share your test steps.
